I have an equation obtained from partial derivable of some functions, I would like to compute the limit when my variable named Pe goes to infinity.
I hope to get a more appreciate presentation of my code to obtain the limit (  Pe -> + infty)
limit_infinity.mw
All derivative are well compute, but How can I add the limit as Pe goes to infinity
Hey everyone,
I've been experiencing some issues with Mapleprimes on my laptop. Whenever I try to access the website, it takes an unusually long time to load, and sometimes it doesn't even load at all. This is quite frustrating as I need to use Mapleprimes for my research work. I've tried accessing the website on other devices, and it works fine, so I'm confident that the issue is with my laptop. Has anyone else experienced this problem? Any suggestions on how to fix it?
Why doesn't Maple simplify sin(x) / cos (y) as tan
with(plottools)
with(plots)
with(CurveFitting)
Digits := 10
with(GaussInt)
w := GInearest(0+I)
I
"f(t):=7.0*(e)^((-(t-13180)^(2))/(2000000))+4.7*(e)^((-(t-16000)^(2))/(3200000)):"
p1 := plot(f(t), t = 0 .. 20000, color = green); plots[display]({p1})
D1 := 15
epsilon := 200000
L := 6500
v := .7
.7
t := 10000
10000
i = sqrt(-1)
i = I
"k(n) := evalf((2 *Pi*n)/(L))"
proc (n) options operator, arrow, function_assign; evalf(2*Pi*n/L) end proc
f(n) = (int(f(t)*exp(-w*k(n)*x), x = 0 .. L))/L
"C(x, t) :=  (∑) exp(-v* t*k(n)- D1 *t*(k(n)^())^(2)- epsilon *t*(k(n))^(4)) *f(n)* exp(w*k(n)* x)"
proc (x, t) options operator, arrow, function_assign; sum(exp(-v*t*k(n)-D1*t*k(n)^2-varepsilon*t*k(n)^4)*f(n)*exp(w*k(n)*x), n = 1 .. 10) end proc
uu10000 := [seq(evalf(C(L-j, t)), j = 0 .. 6500, 100)]
[0.8582270020e-37+0.7071768085e-46*I, 0.8542115620e-37-0.8289193755e-38*I, 0.8422030662e-37-0.1650065052e-37*I, 0.8223146210e-37-0.2455737186e-37*I, 0.7947335229e-37-0.3238382907e-37*I, 0.7597194496e-37-0.3990668010e-37*I, 0.7176019535e-37-0.4705546418e-37*I, 0.6687772885e-37-0.5376326775e-37*I, 0.6137045955e-37-0.5996735584e-37*I, 0.5529014934e-37-0.6560976155e-37*I, 0.4869391210e-37-0.7063782859e-37*I, 0.4164366719e-37-0.7500470239e-37*I, 0.3420554942e-37-0.7866976371e-37*I, 0.2644927960e-37-0.8159900244e-37*I, 0.1844750367e-37-0.8376532722e-37*I, 0.1027510610e-37-0.8514880864e-37*I, 0.2008503850e-38-0.8573685436e-37*I, -0.6275071112e-38-0.8552431450e-37*I, -0.1449829443e-37-0.8451351706e-37*I, -0.2258447115e-37-0.8271423331e-37*I, -0.3045824843e-37-0.8014357420e-37*I, -0.3804631338e-37-0.7682581907e-37*I, -0.4527807059e-37-0.7279217843e-37*I, -0.5208629116e-37-0.6808049422e-37*I, -0.5840773014e-37-0.6273487939e-37*I, -0.6418370476e-37-0.5680530177e-37*I, -0.6936062957e-37-0.5034711554e-37*I, -0.7389050434e-37-0.4342054446e-37*I, -0.7773134955e-37-0.3609012248e-37*I, -0.8084758661e-37-0.2842409660e-37*I, -0.8321035975e-37-0.2049379645e-37*I, -0.8479779638e-37-0.1237297776e-37*I, -0.8559520434e-37-0.4137144557e-38*I, -0.8559520435e-37+0.4137144402e-38*I, -0.8479779639e-37+0.1237297769e-37*I, -0.8321035979e-37+0.2049379630e-37*I, -0.8084758664e-37+0.2842409653e-37*I, -0.7773134957e-37+0.3609012242e-37*I, -0.7389050442e-37+0.4342054433e-37*I, -0.6936062961e-37+0.5034711548e-37*I, -0.6418370481e-37+0.5680530171e-37*I, -0.5840773026e-37+0.6273487928e-37*I, -0.5208629121e-37+0.6808049418e-37*I, -0.4527807065e-37+0.7279217840e-37*I, -0.3804631352e-37+0.7682581900e-37*I, -0.3045824850e-37+0.8014357418e-37*I, -0.2258447130e-37+0.8271423327e-37*I, -0.1449829450e-37+0.8451351705e-37*I, -0.6275071183e-38+0.8552431450e-37*I, 0.2008503694e-38+0.8573685437e-37*I, 0.1027510603e-37+0.8514880865e-37*I, 0.1844750360e-37+0.8376532724e-37*I, 0.2644927944e-37+0.8159900249e-37*I, 0.3420554936e-37+0.7866976374e-37*I, 0.4164366713e-37+0.7500470242e-37*I, 0.4869391201e-37+0.7063782866e-37*I, 0.5529014927e-37+0.6560976160e-37*I, 0.6137045944e-37+0.5996735595e-37*I, 0.6687772877e-37+0.5376326784e-37*I, 0.7176019529e-37+0.4705546426e-37*I, 0.7597194490e-37+0.3990668022e-37*I, 0.7947335225e-37+0.3238382916e-37*I, 0.8223146207e-37+0.2455737195e-37*I, 0.8422030659e-37+0.1650065065e-37*I, 0.8542115619e-37+0.8289193856e-38*I, 0.8582270020e-37]
Download 0_one.mw
Could someone explain to me why the Maple online help pages (see here) are still apparently matching the Maple 2021 release for the past few years? Does this mean that all the information on the Maple online help pages is out of date, or just this one specific page is terribly out of date?
I am trying to discretize high order derivatives (typicaly of order 3-4) and I would like to use maple to avoid errors. Using this thread of discussion I got the following minimum example that illustrates the problem I am facing:
# central discretisation u_xx, i=1,..,n-1
dxc:=add([1,-2,1] *~ [u[i+k,j] $k=-1..1])/(h^2);
(u[i-1, j]-2*u[i, j]+u[i+1, j])/h^2
# we need to compute gradient(laplacian) on faces i+1/2,j and i-1/2,j.
#First diff(u_xx,x)|i+1/2,j
d1:=add([1,-1] *~ [dxc[i+p,j] $p=0..1])/(h);
#which should give
d1:=add([1,3,-3,1] *~ [u[i+k,j] $k=-1..2])/(h^3);
(((u[i-1, j]-2*u[i, j]+u[i+1, j])/h^2)[i, j]-((u[i-1, j]-2*u[i, j]+u[i+1, j])/h^2)[i+1, j])/h
(u[i-1, j]+3*u[i, j]-3*u[i+1, j]+u[i+2, j])/h^3
I would like maple to evaluate the first expression for d1 and give the second expression that I wrote manually.
Is there a way to do this ? (using simplify() does't produce anything)
Cheers,
Download high_order_derivatives.mw
I have posted a question in the last couple of days:
https://www.mapleprimes.com/questions/235958-How-Do-I-Get-Of-HIGHLIGHT-And-MARK-Annotations?sq=235958
which was taken down by this member:
https://www.mapleprimes.com/users/acer/reputation
where (s)he posted in a previous question of mine, that the new question is a duplicate.
https://www.mapleprimes.com/questions/235909-Latex-In-ShowSolution
You cannot find his/her reply where (s(he states that the question is a duplicate.
I have replied to his/her reply and explained that my new question is not a duplicate.
(S)he deleted his initial reply together with my reply, and substituted it with what you can see on the page now:
Please stop posting completely separate new Question threads on this issue.
This person wrongly declared that my question is a duplicate, and did not even bother to take into account my reply. (S)he can delete whatever (s)he wants, and just barks orders.
Now, is this really normal support behaviour? Why is this person shutting my questions down? Is this the kind of support a person gets for paying for an expensive software?
Where do I escalate this issue?
Kind help to implement the attached flowchart
Finding_Detour_using_alorigthm.pdf
Just experienced a strange response from Maple when I changed the Font anti-aliasing to enabled.
With Font anti-aliasing disabled I ran evalf(Pi,100) and Maple returned 100 digits - no problem.  I then did some other errands in other programs leaving Maple idle, when I came back I thought I would change anti-aliasing to enabled and see if maybe that's the reason why some users are experiencing icons disappearing etc..
Well I re entered and evalueated evalf(Pi,100) and Maple only output 10 digits.  Huh??? What!? Why?  changed font anti-aliasing back but no joy.  So I closed Maple and I got a pop up
Maybe it was hiding behind Maple I don't know but I don't think it was there until I closed Maple.  It seems this OpenJDK platform I believe is causing a lot of Maple issues.
Whoa!  That's really odd.  My restart was with Maple Font anti-aliasing enabled I performed a evalf(Pi,100) and no problem.  I changed to Font anti-aliasing disabled and evalf(Pi,100) presented me with 10 digits!
What the heck is going on.  This font anti-aliasing enabled caused my Maple to slow down as the screen filled up (as I recorded in a earlier post months ago) and now toggling anti-aliasing causes the outputs to not work as expected.  It's gotta be an open JDK issue. (FYI closing Maple did not produce the same pop-up as earlier - I expect idling maple for a while might)
In the following example, the information in which range fsolve should search for a solution and the range in which a function is defined is somehow redundant. (This example has been adopted from here where fsolve without assumptions does not throw an error but evaluates forever.)
Why can’t fsolve not always assume that the range equals the domain of interest? This would make life easier and provide more solutions to inexperienced users who have not yet learned the need for assumptions.
If there are good reasons (and there probably are) that such an implicit assumption (i.e. range equals domain) would be too restrictive: can’t fsolve give a hint or provide an new option to use ranges as assumptions?
Example with incomplete elliptic integral of the first kind
f := proc (x__0) options operator, arrow; int(1/(sqrt(x__0-x)*sqrt(-x^2+1)), x = 0 .. x__0) end proc
Range := 0 .. 1; plot(f(x__0), x__0 = Range, labels = [x__0, 'f(x__0)'])
f(.5) = 1.524886838NULL
Defining the inverse of f
g := proc (y) options operator, arrow; fsolve(`assuming`([f(x__0) = y, x__0 = Range], [lhs(Range) <= x__0 and x__0 <= rhs(Range)])) end proc
x__0 = g(f(.5)) → x__0 = .5000000000NULL
Now without assumptions
h := proc (y) options operator, arrow; fsolve(f(x__0) = y, x__0 = Range) end proc
h(f(.5))
Error, (in fsolve) cannot determine if this expression is true or false: abs(Re(x))+abs(Im(x)) <= 0.
Download ranges_as_assumptions.mw
I am trying to obtain the solution of the differential equation f'''+ff''-f'^2-Mf'=0, with f(0)=0, f'(0)=1, and f'(5)=0 with M=0.5 using finite element method
But got this error. I attached the file also.
M := .5;
.5
a := 0;
b := 5;
5
N := 50;
50
h := (b-a)/N;
1/10
nodes := [seq(h*i+a, i = 0 .. N)];
[0, 1/10, 1/5, 3/10, 2/5, 1/2, 3/5, 7/10, 4/5, 9/10, 1, 11/10, 6/5, 13/10, 7/5, 3/2, 8/5, 17/10, 9/5, 19/10, 2, 21/10, 11/5, 23/10, 12/5, 5/2, 13/5, 27/10, 14/5, 29/10, 3, 31/10, 16/5, 33/10, 17/5, 7/2, 18/5, 37/10, 19/5, 39/10, 4, 41/10, 21/5, 43/10, 22/5, 9/2, 23/5, 47/10, 24/5, 49/10, 5]
elements := [seq([i, i+1], i = 0 .. N-1)];
[[0, 1], [1, 2], [2, 3], [3, 4], [4, 5], [5, 6], [6, 7], [7, 8], [8, 9], [9, 10], [10, 11], [11, 12], [12, 13], [13, 14], [14, 15], [15, 16], [16, 17], [17, 18], [18, 19], [19, 20], [20, 21], [21, 22], [22, 23], [23, 24], [24, 25], [25, 26], [26, 27], [27, 28], [28, 29], [29, 30], [30, 31], [31, 32], [32, 33], [33, 34], [34, 35], [35, 36], [36, 37], [37, 38], [38, 39], [39, 40], [40, 41], [41, 42], [42, 43], [43, 44], [44, 45], [45, 46], [46, 47], [47, 48], [48, 49], [49, 50]]
bilinear := proc (u, v, w) options operator, arrow; int(diff(u(x), `$`(x, 3))+u(x)*(diff(u(x), `$`(x, 2)))-(diff(u(x), x))^2-M*u(x)*(diff(u(x), x)), x = w[1] .. w[2])+int((diff(u(x), x))*(diff(v(x), x)), x = w[1] .. w[2]) end proc;
Llinear := proc (v, w) options operator, arrow; v(a)*(diff(w(x), x)) end proc, x = a;
proc (v, w) options operator, arrow; v(a)*(diff(w(x), x)) end proc, x = 0
K := CreateMatrix(N+1, N+1, 0);
CreateMatrix(51, 51, 0)
F := CreateVector(N+1, 0);
CreateVector(51, 0)
for e in elements do x1 := nodes[e[1]]; x2 := nodes[e[2]]; h := x2-x1; Ke := bilinear(proc (x) options operator, arrow; piecewise(x < x1+(1/2)*h, 1-(x-x1)/h, (x2-x)/h) end proc, proc (x) options operator, arrow; piecewise(x < x1+(1/2)*h, (x-x1)/h, (x2-x)/h) end proc, [x1, x2]); Fe := Llinear(proc (v) options operator, arrow; v(x)*piecewise(x = x1, 1, x <> x1) end proc, [x1, x2]); for i in [e[1], e[2]] do for j in [e[1], e[2]] do K[i, j] := K[i, j]+Ke[i-e[1]+1, j-e[1]+1] end do; F[i] := F[i]+Fe[i-e[1]+1] end do end do
K[1, 1] := 1;
K[N+1, N+1] := 1;
u := LinearSolve(K, F)
Error, (in LinearAlgebra:-LinearSolve) invalid input: LinearAlgebra:-LinearSolve expects its 1st argument, A, to be of type {Matrix, list({Matrix, Vector})} but received K
f := unapply(u(x), x);
proc (x) options operator, arrow; u(x) end proc
Download FEM.mw
Given a graph G and a vertex v find the shortest self returning walk from that visits all vertices starts at v and comes back to v.
In the below graph the shortest self returning walk which visits all vertices and comes back to first to started vertex
A function which takes a graph G  and  vertex v as input and returns the length of the  shortest self returning walk of that vertex in the below example 10
I am sorry for the error i just saw the change after reading more in deep
For the vertex 7 the shortest self returning walk from that visits all vertices starts at 7 and comes back to 7 It is a walk so edges can repeat
The closed walk which passes through all vertices minimum from vertex 7 is so length 10. is what it means
so it returns 10.
A function which takes a matrix as input and k the number of places to round to Given a matrix
Matrix(17, 17, [[0, 1.67136411, 3.04642520, 3.03792037, 4.46305818, 4.48953189, 11.44947182, 11.44363094, 5.99694026, 10.05030814, 10.04436470, 12.86806872, 12.86675621, 8.65792026, 11.48220112, 11.47942388, 10.13243670], [1.67136411, 0, 1.37506109, 1.36655626, 2.79169407, 2.81816777, 9.77810770, 9.77226682, 4.32557615, 8.37894403, 8.37300059, 11.19670460, 11.19539209, 6.98655615, 9.81083701, 9.80805976, 8.46107258], [3.04642520, 1.37506109, 0, 2.74161735, 1.41663298, 4.19322886, 8.40304661, 8.39720573, 5.70063724, 7.00388294, 6.99793950, 12.57176570, 12.57045318, 5.61149506, 11.18589810, 11.18312085, 9.83613367], [3.03792037, 1.36655626, 2.74161735, 0, 4.15825033, 1.45161152, 11.14466396, 11.13882308, 2.95901989, 9.74550028, 9.73955684, 9.83014835, 9.82883584, 8.35311240, 8.44428075, 8.44150350, 7.09451633], [4.46305818, 2.79169407, 1.41663298, 4.15825033, 0, 5.60986184, 6.98641363, 6.98057275, 7.11727022, 5.58724996, 5.58130652, 13.98839867, 13.98708616, 4.19486208, 12.60253107, 12.59975383, 11.25276665], [4.48953189, 2.81816777, 4.19322886, 1.45161152, 5.60986184, 0, 12.59627548, 12.59043460, 1.50740837, 11.19711180, 11.19116836, 8.37853683, 8.37722432, 9.80472392, 6.99266923, 6.98989199, 5.64290481], [11.44947182, 9.77810770, 8.40304661, 11.14466396, 6.98641363, 12.59627548, 0, 5.58361857, 14.10368385, 6.98420414, 4.19901549, 20.97481231, 20.97349980, 5.59181627, 19.58894471, 19.58616747, 18.23918029], [11.44363094, 9.77226682, 8.39720573, 11.13882308, 6.98057275, 12.59043460, 5.58361857, 0, 14.09784297, 4.19891293, 6.98410159, 20.96897143, 20.96765892, 5.59130081, 19.58310383, 19.58032659, 18.23333941], [5.99694026, 4.32557615, 5.70063724, 2.95901989, 7.11727022, 1.50740837, 14.10368385, 14.09784298, 0, 12.70452017, 12.69857674, 6.87112846, 6.86981595, 11.31213229, 5.48526086, 5.48248361, 4.13549644], [10.05030814, 8.37894403, 7.00388294, 9.74550028, 5.58724996, 11.19711180, 6.98420414, 4.19891293, 12.70452017, 0, 5.59817917, 19.57564863, 19.57433612, 6.99097994, 18.18978103, 18.18700379, 16.84001661], [10.04436470, 8.37300059, 6.99793950, 9.73955684, 5.58130652, 11.19116836, 4.19901549, 6.98410159, 12.69857673, 5.59817917, 0, 19.56970519, 19.56839268, 6.99056705, 18.18383759, 18.18106035, 16.83407317], [12.86806871, 11.19670460, 12.57176569, 9.83014835, 13.98839867, 8.37853683, 20.97481232, 20.96897144, 6.87112846, 19.57564864, 19.56970520, 0, 5.47162962, 18.18326076, 6.88344719, 4.18501750, 5.53368276], [12.86675620, 11.19539209, 12.57045318, 9.82883584, 13.98708616, 8.37722432, 20.97349980, 20.96765892, 6.86981595, 19.57433612, 19.56839268, 5.47162962, 0, 18.18194824, 4.18355276, 6.88198245, 5.53331719], [8.65792026, 6.98655615, 5.61149506, 8.35311240, 4.19486208, 9.80472392, 5.59181627, 5.59130081, 11.31213229, 6.99097994, 6.99056705, 18.18326075, 18.18194824, 0, 16.79739315, 16.79461591, 15.44762873], [11.48220112, 9.81083701, 11.18589810, 8.44428075, 12.60253108, 6.99266923, 19.58894472, 19.58310384, 5.48526086, 18.18978104, 18.18383760, 6.88344719, 4.18355276, 16.79739316, 0, 5.57088509, 6.91955036], [11.47942387, 9.80805976, 11.18312085, 8.44150350, 12.59975383, 6.98989199, 19.58616748, 19.58032660, 5.48248361, 18.18700380, 18.18106036, 4.18501750, 6.88198245, 16.79461592, 5.57088509, 0, 6.92064952], [10.13243670, 8.46107258, 9.83613367, 7.09451633, 11.25276665, 5.64290481, 18.23918030, 18.23333942, 4.13549644, 16.84001662, 16.83407318, 5.53368276, 5.53331719, 15.44762874, 6.91955036, 6.92064952, 0]])
Convert all the digits in the matrix to k decimal places where k I can specify After converting to decimal places it should not show zero's at the end of the decimal places. Kind help
[sqrt(-3)^1, sqrt(-3)^7];
map(indets, %, radnumext),
map(indets, %, radext),
map(indets, %, radical);
Is this going to be fixed/removed?
Please check the following examples, first without using Units, and the second using it:
No Units:
With Units:
Why does the with(Units) doesn't compute the value? How can I make it work?
First 223 224 225 226 227 228 229 Last Page 225 of 2431
