Does anyone know how to type theta with a double dot on top of it as a second time derivative in maple 10?
I'm trying to numerically evaluate an integral using the evalf function, but I keep ending up with just the value "Float(Undefined)". After manipulating the expression in different ways I also get other error messages stating that something or value is too large. Can someone please help with this ? thanks, (worksheet attached in this message) Dan. Download 285_casimirEENG501HW5.mws
View file details
Ich searched a lot but solve return me an error or just don't solve it. An the linsolve package is the wrong for that use How can I solve something like this with maple: A := Matrix(2, 2, {(1, 1) = a, (1, 2) = b, (2, 1) = c, (2, 2) = d}) E := Matrix(2, 2, {(1, 1) = 1, (1, 2) = 0, (2, 1) = 0, (2, 2) = 1}) solve((VectorCalculus[DotProduct])(A, A) = E) brings an error A korrekt solution would be for A for Example Matrix(2, 2, {(1, 1) = 0, (1, 2) = 1, (2, 1) = 1, (2, 2) = 0}) us rene
Hi, I would like to project the 3D surface generated from the following equation to the xy plane (2D): Itouch50 := -0.4058074876e13*sqrt(1.+h)/(sqrt(ts)*(-500000000.0*ln((625.+125.*h+25.*h^2+5.*h^3)/h)*sqrt(1.+h)+587311661.7)) where x=Itouch50 y= ts and z= h Moreover, if possible, I would like to calculate the equation of the projection or the equations giving the upper and lower side of the projection. Finally, if I had multiple equations as the initial one, would it be possible to create their accumulated projections on the same plane. I know that Im asking for too much, but any help would be extremely appreciated.
Currently I am using worksheets. Please help me how to Create and read .mpl files in Maple. Can I use worksheet for this? On using read command in worksheet to access a " .mpl" file it shows "Error, on line 1, syntax error, character `?` unexpected:" Please help me on this.
so i have the following functions in my college calc class for our maple homework assignment: f(x)=x^4 and g(x)=6^x i have to plot them and then find their point of intersection using maple. i have no problem plotting it but i cant seem to figure out how to find the intersection point. all the ways i have tried just give me a list of answers with natural log and something with the word LambertW in it. if some one could help me out i would greatly appreciate it.
I have a second-order differential equation dEq := diff(theta(t), t, t) = sin(theta(t)) i would like to find the solution of it, so soln := dsolve({dEq, theta(0) = 0, (D(theta))(0) = 0}, theta(t)) and then plot the solution, that is plot 'theta' vs. 't' but the solution contains weird charecters and I tried many examples on the net but never worked out for me. Can you guys help? thank you in advance.
Why there is no way (except I am stupidly missing something) to let
Maple convert exp(phi*I) to argument with piecewise discussing the
input (as it is explained quite nice in ?argument)?
Even assume(-Pi < phi, phi <= Pi) does not help and results in some
arctan(sin(phi),cos(phi)) and convert(%, piecewise, phi) does not
give the desired presentation.
I recently posted a worksheet to my blog. I used the feature in the MAPLE file manager which turns a worksheet into code so it can be displayed more or less the same way it looks in MAPLE. I copied this code and pasted it into the text of my post. When I did a preview I saw what I would refer to as the "blue equations" but for the equations I actually typed into the worksheet at the MAPLE prompt, I only got boxes which said "Maple equation". When I click on these boxes nothing happens. So someone would really have to open my worksheet to get any sense of what I was talking about, which was not what I intended. I don't recall running into this problem before. Maybe I am doing something different than before and just don't know it. I would appreciate any suggestions.
Hi Our university (Univ. Sao Paulo - Brazil) has license for maple 9 (not sure which release).. It can be also that the version they have is Maple 6 since there is a xmaple6 in the files (see bellow) I use in my machine Ubuntu linux, the newest version. Althoug it says it has linux support for maple, nobody was able to install it from the instructions provided from above to us, users. I will describe the situation: we get from the university a tar file containing the files root@edf:/etc/Maple/bin.IBM_INTEL_LINUX_REDHAT# ls -1 hostpatch ld-linux.so.2 libc.so.6 libdl.so.2 libICE.so.6
Hi I got an equation that I would like to find out its turning points.As you know you first have to differentiate it and then..... Here is my command on maple: y:=x->6x^2-7x-3*exp(-1/5*x); df:=diff(y(x),x); solve(%,x); and then I get 5 LambertW(-1/100 (e)^(((-7)/60)))+7/12 5 LambertW(-1,-1/100 (e)^(((-7)/60)))+7/12 as answers, I don't know if they are correct, but I do know that there must be a simpler answer than this! I was therefore wondering if you guys know how I can approach this problem differently! Thanks Chris
I am currently running a Maple T.A. Homework Assignment for approximately 300 students. For the fitst time, I have included some "sketch" questions, but they are giving many many problems. I instructed students how to download, install and enable Java if necessary, but the problem is persistent, so much that I suspect it is not the students fault. Of some of them at least I know their settings seem fine. Is there a known problem with Java 1.5.0_09, which is what they get from download? Any help is appreciated, also info about what questions I should ask them to find out where the problem is: I
I wish to know if there is way to plot the following functions: x1=X1+X2*gamma(t) x2=X2 and x1=alpha*cons(theta)*X1-beta*sin(theta)*X2+gamma x2=alpha*sin(theta)*X1-beta*cos(theta)*X2+gamma where in the second one alpha, beta. and gamma are constants. many thanks, A.
Hi, At my university i saw a presentation of maple. It was running under linux (kde), and obviously it had a (Trolltech) Qt GUI. I really would like to work under a Qt-GUI, too, but I have no idea how to do that. The only GUI I get to work is the normal Swing-GUI of the Java Version. Thanks a lot, David
First 2368 2369 2370 2371 2372 2373 2374 Last Page 2370 of 2430
