I'm not quite sure, if this is the correct place but i think i found a bug in the analytic integration tool in Maple.
Since i have the student edition and i didn't find a bug report form i will post it here:
R:=1:
delta:=1:
f:=R^4*delta*cos(theta)*sin(x)*sin(-x+theta)/(8*Pi*(R^2*cos(x)+sqrt(2*R^2*cos(x)+2*R^2+4*delta^2)*delta+R^2+2*delta^2));
intfAna:=int(f,x= -Pi + theta .. Pi+ theta);
intfNum:=Int(f,x= -Pi + theta .. Pi+ theta);
intNum:=evalf(Int(eval(intfNum),theta=0..2*Pi));
intAna:=evalf(int(eval(intfAna),theta=0..2*Pi));
the last two statements yield:
                    intNum := -0.07343950362
                    intAna := -0.7853981635
Thus the numerical integrated value differes from the analytical result.
Since I also tried to integrate this with scipy in python I'm pretty sure that the numerical result is correct  and the analytical one is not.
Is my deduction here correct?
I have Maple 2018 here on my private PC. But at work i have Maple 2021 and the difference is the same.
Interestingly the analytic result seems to be -cos(theta)^2/4. If we plot the analytical and numerical integrand, we get:
plot(intfNum,theta=0..2*Pi);
plot(intfAna,theta=0..2*Pi);
Thus both integrands seem to be cosines of theta but the analytical has the wrong factor.
Thanks in advance!
Give a graph G enumerate all possible shortest paths from that vertex to all other vertices like
From vertex v1
P1={(1,2),(2,3)} shortest path from 1 to 3 is stored in P1
P2={(1,2)} shortest path from 1 to 2 of length 1
Put all possible path of length k  from a verex v in a list seperate
That is length 1 in a seperate from vertex v in a seperate list
Etc
Function with be F(Graph::G,v)
Function will return all those lists
with(GraphTheory);
with(combinat, cartprod);
with(SpecialGraphs);
with(RandomGraphs);
Given any arbitary graph G how many possible paths of length k are possible
G := CartesianProduct(PathGraph(3), PathGraph(3));
s := AllPairsDistance(FLT)
How to find how may possible paths of length say 4 from vertex 1:1
" for example this CartesianProduct(Path(3),Path(3)) number of possible paths of length 2 are
1:1 - 1:2 -2:2
1:1 -2:1-2:2
1:1-1:2 -1:3
1:1-2:1-3:1
so a total of 2 length paths
next say how may possible paths of length say 3 from vertex 1:2
similar given a vertex and path length how many possible path of that length are possible from that vertex.
It is not restricted to this graph given any graph G in general , a vertex v and k a path length i should get total number of paths of that length in that graph G
That is function say   F(G::Graph,vertex,k) i should get output of the number of path of length k from that vertex v.
"Only a idea but I may be wrong
I had an idea taking a row of a vertex in the graph G in the shortest path matrix and finding the number of possible totals which can get  length k I may be wrong to or correct but I finding to implement this in code neatly too.
That is if (0,1,2,1,3,4,1,2)
The number of possible 2 this are
0+2=2
0+2=2
1+1=2
1+1=2
1+1=2
So a total of 5 , 2 length path with respect to that vertex moving from left to right
Again if number of 3 length paths
Moving left to right
0+3=3
1+2=3
1+1+1=3
1+2=3
2+1=3
2+1=3
1+2=3
1+2=3
Total 8 paths of length 3
Until maximum possible length path from that vertex with respect to that graph.
Their is a mistake in the above logic is if the length paths intersection in some edges the path length will decrease so need to be careful so it looks difficult for me.
But I may be wrong in logic need help."
I am trying too
Kind help please your answer will be acknowledged
Kind help
Kind help someone please
I use Int to show some step before evaluating it to become normal int
I'd like to show the following when the integrand is one:
But Int(x) does not work, and Int(,x) gives syntax error. So only choice is to use Int(1,x) which does not look as nice as the above
Is there a trick to use? i.e. when the integrand is one, I want to display it as the first image and not as the second image. This is just to make the Latex look a little nicer only.
I tried few things, but nothing worked so far, as Int needs something there where I want the empty spot to be (There is actually 1 there ofcourse, but I do not want to show the 1).
May be we need a Latex settings for this?  Or interface setting?
Maple 2022.1
Please can someone help me with a sample code for bifurcation? You can use parameter values for the parameters. I'm using maple 18. Below is my model:
f__1 := Delta -(psi + mu)*S(t);
Delta-(psi+mu)*S(t)
f__2 := psi*S(t) -(delta + mu)*E(t);
psi*S(t)-(delta+mu)*E(t)
f__3 := Delta*E(t) -(gamma+gamma__1 + mu)*X(t);
Delta*E(t)-(gamma+gamma__1+mu)*X(t)
f__4 := gamma__1*X(t)-(eta + xi + mu)*H(t);
gamma__1*X(t)-(eta+xi+mu)*H(t)
f__5 := xi*H(t) - mu*R(t);
xi*H(t)-mu*R(t)
f__6 := gamma*X(t)-eta*H(t) - d*D(t);
gamma*X(t)-eta*H(t)-d*D(t)
f__7 := b*D(t) - b*B(t);
b*D(t)-b*B(t)
f__8 := phi__p + sigma*X(t)+eta__1*H(t) +d__1*D(t)+ b__1*B(t) - alpha*P(t);
phi__p+sigma*X(t)+eta__1*H(t)+d__1*D(t)+b__1*B(t)-alpha*P(t)
Download Bifurcation.mw
Please I need your assistance. I want to solve for c__4, c__5, c__6, and c__8  from 4 systems of the equation: See my code below:
Since there 4 equations and 4 unknowns, is it possible to get the result explicitly without setting c__6=c__8 as maple did? The solution is at the end of the maple file.
LSA.mw
## "Note that I use I(t) = X(t)""  and S^(*),E^(*), I^(*), H^(*), B^(*), D^(*), R^(*), P^(*) = (`S__1`,`E__1`,`I__1`,`H__1`,`B__1`,`D__1`,`R__1`,`P__1`,) thorought the work."
Delta-(psi+mu)*S(t)
xi*H(t)-mu*R(t)
b*D(t)-b*B(t)
S__1 := Delta/mu - a__1*E__1/mu: X__1:= delta*E__1/a__2: H__1 := delta*gamma__1*E__1/a__2*a__3: R__1 := delta*gamma__1*xi*E__1/a__2*a__3*mu: B__1 := 1/b*(gamma*delta/a__2 + delta*eta*gamma__1/a__2*a__3)*E__1: D__1 := 1/d*(gamma*delta/a__2 + delta*eta*gamma__1/a__2*a__3)*E__1: P__1 := (1/alpha)*(delta*sigma/a__2 + delta*eta*gamma__1/a__2*a__3 + (d__1/d - b__1/b)*(delta*gamma/a__2 + delta*eta*gamma__1/a__2*a__3))*E__1 + phi__p/alpha:
M__1 := c__1*f__1*(1-S__1/S(t));
c__1*(Delta-(psi+mu)*S(t))*(1-(Delta/mu-a__1*E__1/mu)/S(t))
M__2 := c__2*f__2*(1-E__1/E(t));
c__2*(psi*S(t)-(delta+mu)*E(t))*(1-E__1/E(t))
M__3 := c__3*f__3*(1-X__1/X(t));
M__4 :=c__4*f__4*(1-H__1/H(t));
c__4*(gamma__1*X(t)-(eta+xi+mu)*H(t))*(1-delta*gamma__1*E__1*a__3/(a__2*H(t)))
M__5 := c__5*f__5*(1-R__1/R(t));
c__5*(xi*H(t)-mu*R(t))*(1-delta*gamma__1*xi*E__1*a__3*mu/(a__2*R(t)))
M__6 := c__6*f__6*(1-D__1/D(t));
c__6*(gamma*X(t)-eta*H(t)-d*D(t))*(1-(gamma*delta/a__2+delta*eta*gamma__1*a__3/a__2)*E__1/(d*D(t)))
(14)
M__7 := c__7*f__7*(1-B__1/B(t));
M__8 := c__8*f__8*(1-P__1/P(t));
u__1 := (psi+mu)*S__1;
(psi+mu)*S__1
(17)
u__2 := psi*S__1;
psi*S__1
(18)
u__3 := delta*E__1;
delta*E__1
(19)
u__4 := gamma__1*X__1;
gamma__1*X__1
(20)
u__5 := xi*H__1;
xi*H__1
(21)
u__6 := gamma*X__1 + eta*H__1;
H__1*eta+X__1*gamma
(22)
u__7 := b*D__1;
b*D__1
(23)
u__8 := phi__p + sigma*X__1+eta__1*H__1 +d__1*D__1+ b__1*B__1;
B__1*b__1+D__1*d__1+H__1*eta__1+X__1*sigma+phi__p
(24)
M__1 := c__1*(Delta-(psi+mu)*S(t))*(1-(Delta/mu-a__1*E__1/mu)/S(t));
(25)
M__2 := c__2*(psi*S(t)-(delta+mu)*E(t))*(1-E__1/E(t));
(26)
M__3 := c__3*(Delta*E(t)-(gamma+gamma__1+mu)*X(t))*(1-delta*E__1/(a__2*X(t)));
(27)
M__4 := c__4*(gamma__1*X(t)-(eta+xi+mu)*H(t))*(1-delta*gamma__1*E__1*a__3/(a__2*H(t)));
(28)
M__5 := c__5*(xi*H(t)-mu*R(t))*(1-delta*gamma__1*xi*E__1*a__3*mu/(a__2*R(t)));
(29)
M__6 := c__6*(gamma*X(t)-eta*H(t)-d*D(t))*(1-(gamma*delta/a__2+delta*eta*gamma__1*a__3/a__2)*E__1/(d*D(t)));
(30)
M__7 := c__7*(b*D(t)-b*B(t))*(1-(gamma*delta/a__2+delta*eta*gamma__1*a__3/a__2)*E__1/(b*B(t)));
(31)
M__8 := c__8*(phi__p+sigma*X(t)+eta__1*H(t)+d__1*D(t)+b__1*B(t)-alpha*P(t))*(1-((delta*sigma/a__2+delta*eta*gamma__1*a__3/a__2+(d__1/d-b__1/b)*(gamma*delta/a__2+delta*eta*gamma__1*a__3/a__2))*E__1/alpha+phi__p/alpha)/P(t));
(32)
J := M__1 + M__2 + M__3 + M__4 + M__5 + M__6 + M__7 + M__8;
c__1*(Delta-(psi+mu)*S(t))*(1-(Delta/mu-a__1*E__1/mu)/S(t))+c__2*(psi*S(t)-(delta+mu)*E(t))*(1-E__1/E(t))+c__3*(Delta*E(t)-(gamma+gamma__1+mu)*X(t))*(1-delta*E__1/(a__2*X(t)))+c__4*(gamma__1*X(t)-(eta+xi+mu)*H(t))*(1-delta*gamma__1*E__1*a__3/(a__2*H(t)))+c__5*(xi*H(t)-mu*R(t))*(1-delta*gamma__1*xi*E__1*a__3*mu/(a__2*R(t)))+c__6*(gamma*X(t)-eta*H(t)-d*D(t))*(1-(gamma*delta/a__2+delta*eta*gamma__1*a__3/a__2)*E__1/(d*D(t)))+c__7*(b*D(t)-b*B(t))*(1-(gamma*delta/a__2+delta*eta*gamma__1*a__3/a__2)*E__1/(b*B(t)))+c__8*(phi__p+sigma*X(t)+eta__1*H(t)+d__1*D(t)+b__1*B(t)-alpha*P(t))*(1-((delta*sigma/a__2+delta*eta*gamma__1*a__3/a__2+(d__1/d-b__1/b)*(gamma*delta/a__2+delta*eta*gamma__1*a__3/a__2))*E__1/alpha+phi__p/alpha)/P(t))
(33)
L__1 := factor(expand(subs(Delta=u__1, M__1)));
-c__1*(psi+mu)*(S(t)-S__1)*(a__1*E__1+S(t)*mu-S__1*mu-psi*S__1)/(S(t)*mu)
(34)
L__2 := expand(subs((delta+mu)*E(t)=u__2, M__2));
c__2*psi*S(t)-c__2*psi*S(t)*E__1/E(t)-c__2*psi*S__1+c__2*psi*S__1*E__1/E(t)
(35)
L__3 := expand(subs((gamma+gamma__1+mu)*X(t)=u__3, M__3));
c__3*Delta*E(t)-c__3*Delta*E(t)*delta*E__1/(a__2*X(t))-c__3*delta*E__1+c__3*delta^2*E__1^2/(a__2*X(t))
(36)
L__4 := expand(subs((eta+xi+mu)*H(t)=u__4, M__4));
c__4*gamma__1*X(t)-c__4*gamma__1^2*X(t)*delta*E__1*a__3/(a__2*H(t))-c__4*gamma__1*X__1+c__4*gamma__1^2*X__1*delta*E__1*a__3/(a__2*H(t))
(37)
L__5 := expand(subs(mu*R(t)=u__5, M__5));
c__5*xi*H(t)-c__5*xi^2*H(t)*delta*gamma__1*E__1*a__3*mu/(a__2*R(t))-c__5*xi*H__1+c__5*xi^2*H__1*delta*gamma__1*E__1*a__3*mu/(a__2*R(t))
(38)
L__6 := expand(subs(d*D(t)=u__6, M__6));
c__6*gamma*X(t)-c__6*gamma^2*X(t)*E__1*delta/(d*D(t)*a__2)-c__6*gamma*X(t)*E__1*delta*eta*gamma__1*a__3/(d*D(t)*a__2)-c__6*eta*H(t)+c__6*eta*H(t)*E__1*gamma*delta/(d*D(t)*a__2)+c__6*eta^2*H(t)*E__1*delta*gamma__1*a__3/(d*D(t)*a__2)-c__6*eta*H__1+c__6*eta*H__1*E__1*gamma*delta/(d*D(t)*a__2)+c__6*eta^2*H__1*E__1*delta*gamma__1*a__3/(d*D(t)*a__2)-c__6*gamma*X__1+c__6*gamma^2*X__1*E__1*delta/(d*D(t)*a__2)+c__6*gamma*X__1*E__1*delta*eta*gamma__1*a__3/(d*D(t)*a__2)
(39)
L__7 := expand(subs(b*B(t)=u__7, M__7));
c__7*b*D(t)-c__7*D(t)*E__1*gamma*delta/(B(t)*a__2)-c__7*D(t)*E__1*delta*eta*gamma__1*a__3/(B(t)*a__2)-c__7*b*D__1+c__7*D__1*E__1*gamma*delta/(B(t)*a__2)+c__7*D__1*E__1*delta*eta*gamma__1*a__3/(B(t)*a__2)
(40)
L__8 := expand(subs(alpha*P(t)=u__8, M__8));
-c__8*sigma*X(t)*phi__p/(P(t)*alpha)-c__8*eta__1*H(t)*phi__p/(P(t)*alpha)-c__8*d__1*D(t)*phi__p/(P(t)*alpha)-c__8*b__1*B(t)*phi__p/(P(t)*alpha)+c__8*b__1*B__1*phi__p/(P(t)*alpha)-c__8*eta__1*H(t)*E__1*delta*sigma/(P(t)*alpha*a__2)-c__8*d__1*D(t)*E__1*delta*sigma/(P(t)*alpha*a__2)-c__8*b__1*B(t)*E__1*delta*sigma/(P(t)*alpha*a__2)+c__8*b__1*B__1*E__1*delta*sigma/(P(t)*alpha*a__2)+c__8*d__1*D__1*E__1*delta*sigma/(P(t)*alpha*a__2)+c__8*eta__1*H__1*E__1*delta*sigma/(P(t)*alpha*a__2)-c__8*sigma*X(t)*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)-c__8*sigma*X(t)*E__1*d__1*gamma*delta/(P(t)*alpha*d*a__2)+c__8*sigma*X(t)*E__1*b__1*gamma*delta/(P(t)*alpha*b*a__2)-c__8*eta__1*H(t)*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)-c__8*eta__1*H(t)*E__1*d__1*gamma*delta/(P(t)*alpha*d*a__2)+c__8*eta__1*H(t)*E__1*b__1*gamma*delta/(P(t)*alpha*b*a__2)-c__8*d__1*D(t)*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)+c__8*d__1*D(t)*E__1*b__1*gamma*delta/(P(t)*alpha*b*a__2)-c__8*b__1*B(t)*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)-c__8*b__1*B(t)*E__1*d__1*gamma*delta/(P(t)*alpha*d*a__2)+c__8*b__1*B__1*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)+c__8*b__1*B__1*E__1*d__1*gamma*delta/(P(t)*alpha*d*a__2)+c__8*d__1*D__1*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)-c__8*d__1*D__1*E__1*b__1*gamma*delta/(P(t)*alpha*b*a__2)+c__8*eta__1*H__1*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)+c__8*eta__1*H__1*E__1*d__1*gamma*delta/(P(t)*alpha*d*a__2)-c__8*sigma*X(t)*E__1*d__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)+c__8*sigma*X(t)*E__1*b__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)-c__8*eta__1*H(t)*E__1*d__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)+c__8*eta__1*H(t)*E__1*b__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)+c__8*d__1*D(t)*E__1*b__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)-c__8*b__1*B(t)*E__1*d__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)+c__8*b__1*B__1*E__1*d__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)-c__8*d__1*D__1*E__1*b__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)+c__8*eta__1*H__1*E__1*d__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)-c__8*eta__1*H__1*E__1*b__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)+c__8*sigma*X__1*E__1*d__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)-c__8*sigma*X__1*E__1*b__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)-c__8*sigma^2*X(t)*E__1*delta/(P(t)*alpha*a__2)+c__8*sigma^2*X__1*E__1*delta/(P(t)*alpha*a__2)-c__8*sigma*X__1-c__8*d__1*D__1-c__8*eta__1*H__1-c__8*b__1*B__1+c__8*sigma*X(t)+c__8*d__1*D(t)+c__8*eta__1*H(t)+c__8*b__1*B(t)-c__8*d__1^2*D(t)*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)+c__8*b__1^2*B(t)*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)-c__8*b__1^2*B__1*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)+c__8*d__1^2*D__1*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)-c__8*d__1^2*D(t)*E__1*gamma*delta/(P(t)*alpha*d*a__2)+c__8*b__1^2*B(t)*E__1*gamma*delta/(P(t)*alpha*b*a__2)-c__8*b__1^2*B__1*E__1*gamma*delta/(P(t)*alpha*b*a__2)+c__8*d__1^2*D__1*E__1*gamma*delta/(P(t)*alpha*d*a__2)+c__8*d__1*D__1*phi__p/(P(t)*alpha)+c__8*eta__1*H__1*phi__p/(P(t)*alpha)+c__8*sigma*X__1*phi__p/(P(t)*alpha)-c__8*eta__1*H__1*E__1*b__1*gamma*delta/(P(t)*alpha*b*a__2)+c__8*sigma*X__1*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)+c__8*sigma*X__1*E__1*d__1*gamma*delta/(P(t)*alpha*d*a__2)-c__8*sigma*X__1*E__1*b__1*gamma*delta/(P(t)*alpha*b*a__2)
(41)
L := L__1 + L__2 + L__3 + L__4 + L__5 + L__6 + L__7 + L__8;
-c__1*(psi+mu)*(S(t)-S__1)*(a__1*E__1+S(t)*mu-S__1*mu-psi*S__1)/(S(t)*mu)-c__8*sigma*X(t)*phi__p/(P(t)*alpha)-c__8*eta__1*H(t)*phi__p/(P(t)*alpha)-c__8*d__1*D(t)*phi__p/(P(t)*alpha)-c__8*b__1*B(t)*phi__p/(P(t)*alpha)+c__8*b__1*B__1*phi__p/(P(t)*alpha)-c__3*Delta*E(t)*delta*E__1/(a__2*X(t))-c__7*D(t)*E__1*gamma*delta/(B(t)*a__2)+c__7*D__1*E__1*gamma*delta/(B(t)*a__2)+c__6*eta*H(t)*E__1*gamma*delta/(d*D(t)*a__2)+c__6*eta*H__1*E__1*gamma*delta/(d*D(t)*a__2)-c__7*D(t)*E__1*delta*eta*gamma__1*a__3/(B(t)*a__2)+c__7*D__1*E__1*delta*eta*gamma__1*a__3/(B(t)*a__2)-c__8*eta__1*H(t)*E__1*delta*sigma/(P(t)*alpha*a__2)-c__8*d__1*D(t)*E__1*delta*sigma/(P(t)*alpha*a__2)-c__8*b__1*B(t)*E__1*delta*sigma/(P(t)*alpha*a__2)+c__8*b__1*B__1*E__1*delta*sigma/(P(t)*alpha*a__2)+c__8*d__1*D__1*E__1*delta*sigma/(P(t)*alpha*a__2)+c__8*eta__1*H__1*E__1*delta*sigma/(P(t)*alpha*a__2)-c__5*xi^2*H(t)*delta*gamma__1*E__1*a__3*mu/(a__2*R(t))+c__5*xi^2*H__1*delta*gamma__1*E__1*a__3*mu/(a__2*R(t))+c__6*eta^2*H(t)*E__1*delta*gamma__1*a__3/(d*D(t)*a__2)+c__6*eta^2*H__1*E__1*delta*gamma__1*a__3/(d*D(t)*a__2)-c__6*gamma*X(t)*E__1*delta*eta*gamma__1*a__3/(d*D(t)*a__2)+c__6*gamma*X__1*E__1*delta*eta*gamma__1*a__3/(d*D(t)*a__2)-c__8*sigma*X(t)*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)-c__8*sigma*X(t)*E__1*d__1*gamma*delta/(P(t)*alpha*d*a__2)+c__8*sigma*X(t)*E__1*b__1*gamma*delta/(P(t)*alpha*b*a__2)-c__8*eta__1*H(t)*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)-c__8*eta__1*H(t)*E__1*d__1*gamma*delta/(P(t)*alpha*d*a__2)+c__8*eta__1*H(t)*E__1*b__1*gamma*delta/(P(t)*alpha*b*a__2)-c__8*d__1*D(t)*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)+c__8*d__1*D(t)*E__1*b__1*gamma*delta/(P(t)*alpha*b*a__2)-c__8*b__1*B(t)*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)-c__8*b__1*B(t)*E__1*d__1*gamma*delta/(P(t)*alpha*d*a__2)+c__8*b__1*B__1*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)+c__8*b__1*B__1*E__1*d__1*gamma*delta/(P(t)*alpha*d*a__2)+c__8*d__1*D__1*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)-c__8*d__1*D__1*E__1*b__1*gamma*delta/(P(t)*alpha*b*a__2)+c__8*eta__1*H__1*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)+c__8*eta__1*H__1*E__1*d__1*gamma*delta/(P(t)*alpha*d*a__2)-c__8*sigma*X(t)*E__1*d__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)+c__8*sigma*X(t)*E__1*b__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)-c__8*eta__1*H(t)*E__1*d__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)+c__8*eta__1*H(t)*E__1*b__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)+c__8*d__1*D(t)*E__1*b__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)-c__8*b__1*B(t)*E__1*d__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)+c__8*b__1*B__1*E__1*d__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)-c__8*d__1*D__1*E__1*b__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)+c__8*eta__1*H__1*E__1*d__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)-c__8*eta__1*H__1*E__1*b__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)+c__8*sigma*X__1*E__1*d__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)-c__8*sigma*X__1*E__1*b__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)-c__4*gamma__1^2*X(t)*delta*E__1*a__3/(a__2*H(t))+c__4*gamma__1^2*X__1*delta*E__1*a__3/(a__2*H(t))-c__6*gamma^2*X(t)*E__1*delta/(d*D(t)*a__2)+c__6*gamma^2*X__1*E__1*delta/(d*D(t)*a__2)-c__8*sigma^2*X(t)*E__1*delta/(P(t)*alpha*a__2)+c__8*sigma^2*X__1*E__1*delta/(P(t)*alpha*a__2)-c__2*psi*S(t)*E__1/E(t)+c__2*psi*S__1*E__1/E(t)+c__3*delta^2*E__1^2/(a__2*X(t))+c__2*psi*S(t)-c__2*psi*S__1+c__3*Delta*E(t)-c__3*delta*E__1-c__4*gamma__1*X__1+c__4*gamma__1*X(t)+c__5*xi*H(t)-c__5*xi*H__1+c__6*gamma*X(t)-c__6*eta*H(t)-c__6*eta*H__1-c__6*gamma*X__1-c__7*b*D__1+c__7*b*D(t)-c__8*sigma*X__1-c__8*d__1*D__1-c__8*eta__1*H__1-c__8*b__1*B__1+c__8*sigma*X(t)+c__8*d__1*D(t)+c__8*eta__1*H(t)+c__8*b__1*B(t)-c__8*d__1^2*D(t)*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)+c__8*b__1^2*B(t)*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)-c__8*b__1^2*B__1*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)+c__8*d__1^2*D__1*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)-c__8*d__1^2*D(t)*E__1*gamma*delta/(P(t)*alpha*d*a__2)+c__8*b__1^2*B(t)*E__1*gamma*delta/(P(t)*alpha*b*a__2)-c__8*b__1^2*B__1*E__1*gamma*delta/(P(t)*alpha*b*a__2)+c__8*d__1^2*D__1*E__1*gamma*delta/(P(t)*alpha*d*a__2)+c__8*d__1*D__1*phi__p/(P(t)*alpha)+c__8*eta__1*H__1*phi__p/(P(t)*alpha)+c__8*sigma*X__1*phi__p/(P(t)*alpha)-c__8*eta__1*H__1*E__1*b__1*gamma*delta/(P(t)*alpha*b*a__2)+c__8*sigma*X__1*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)+c__8*sigma*X__1*E__1*d__1*gamma*delta/(P(t)*alpha*d*a__2)-c__8*sigma*X__1*E__1*b__1*gamma*delta/(P(t)*alpha*b*a__2)
(42)
## Collecting the coefficients of X, H, D, B and E
k__1 := coeff(L,X(t));
-c__8*sigma*E__1*d__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)+c__8*sigma*E__1*b__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)-c__6*gamma^2*E__1*delta/(d*D(t)*a__2)-c__8*sigma^2*E__1*delta/(P(t)*alpha*a__2)-c__4*gamma__1^2*delta*E__1*a__3/(a__2*H(t))-c__8*sigma*phi__p/(P(t)*alpha)-c__6*gamma*E__1*delta*eta*gamma__1*a__3/(d*D(t)*a__2)-c__8*sigma*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)-c__8*sigma*E__1*d__1*gamma*delta/(P(t)*alpha*d*a__2)+c__8*sigma*E__1*b__1*gamma*delta/(P(t)*alpha*b*a__2)+c__8*sigma+c__4*gamma__1+c__6*gamma
(43)
k__2 := coeff(L,H(t));
-c__5*xi^2*delta*gamma__1*E__1*a__3*mu/(a__2*R(t))+c__6*eta^2*E__1*delta*gamma__1*a__3/(d*D(t)*a__2)-c__8*eta__1*phi__p/(P(t)*alpha)-c__8*eta__1*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)-c__8*eta__1*E__1*d__1*gamma*delta/(P(t)*alpha*d*a__2)+c__8*eta__1*E__1*b__1*gamma*delta/(P(t)*alpha*b*a__2)-c__6*eta+c__5*xi+c__8*eta__1+c__6*eta*E__1*gamma*delta/(d*D(t)*a__2)-c__8*eta__1*E__1*delta*sigma/(P(t)*alpha*a__2)-c__8*eta__1*E__1*d__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)+c__8*eta__1*E__1*b__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)
(44)
k__3 := coeff(L, D(t));
-c__7*E__1*gamma*delta/(B(t)*a__2)-c__8*d__1^2*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)-c__8*d__1^2*E__1*gamma*delta/(P(t)*alpha*d*a__2)-c__8*d__1*phi__p/(P(t)*alpha)-c__8*d__1*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)+c__8*d__1*E__1*b__1*gamma*delta/(P(t)*alpha*b*a__2)+c__8*d__1+c__7*b-c__7*E__1*delta*eta*gamma__1*a__3/(B(t)*a__2)-c__8*d__1*E__1*delta*sigma/(P(t)*alpha*a__2)+c__8*d__1*E__1*b__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)
(45)
k__4 := coeff(L, B(t));
c__8*b__1^2*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)+c__8*b__1^2*E__1*gamma*delta/(P(t)*alpha*b*a__2)-c__8*b__1*phi__p/(P(t)*alpha)-c__8*b__1*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)-c__8*b__1*E__1*d__1*gamma*delta/(P(t)*alpha*d*a__2)+c__8*b__1-c__8*b__1*E__1*delta*sigma/(P(t)*alpha*a__2)-c__8*b__1*E__1*d__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)
(46)
k__5 := coeff(L, E(t));
-c__3*Delta*delta*E__1/(a__2*X(t))+c__3*Delta
(47)
## L terms that not coeffiecient X, H, D, B and E
W__12 := coeff(L, X(t), 0):
W__1 := coeff(W__12, H(t), 0):
W__11 := coeff(W__1, D(t), 0):
W__12 := coeff(W__11, B(t), 0):
k__6 := coeff(W__12, E(t), 0);
-c__1*(psi+mu)*(S(t)-S__1)*(a__1*E__1+S(t)*mu-S__1*mu-psi*S__1)/(S(t)*mu)+c__8*b__1*B__1*phi__p/(P(t)*alpha)+c__8*b__1*B__1*E__1*delta*sigma/(P(t)*alpha*a__2)+c__8*d__1*D__1*E__1*delta*sigma/(P(t)*alpha*a__2)+c__8*eta__1*H__1*E__1*delta*sigma/(P(t)*alpha*a__2)+c__5*xi^2*H__1*delta*gamma__1*E__1*a__3*mu/(a__2*R(t))+c__8*b__1*B__1*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)+c__8*b__1*B__1*E__1*d__1*gamma*delta/(P(t)*alpha*d*a__2)+c__8*d__1*D__1*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)-c__8*d__1*D__1*E__1*b__1*gamma*delta/(P(t)*alpha*b*a__2)+c__8*eta__1*H__1*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)+c__8*eta__1*H__1*E__1*d__1*gamma*delta/(P(t)*alpha*d*a__2)+c__8*b__1*B__1*E__1*d__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)-c__8*d__1*D__1*E__1*b__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)+c__8*eta__1*H__1*E__1*d__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)-c__8*eta__1*H__1*E__1*b__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)+c__8*sigma*X__1*E__1*d__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)-c__8*sigma*X__1*E__1*b__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)+c__8*sigma^2*X__1*E__1*delta/(P(t)*alpha*a__2)+c__2*psi*S(t)-c__2*psi*S__1-c__3*delta*E__1-c__4*gamma__1*X__1-c__5*xi*H__1-c__6*eta*H__1-c__6*gamma*X__1-c__7*b*D__1-c__8*sigma*X__1-c__8*d__1*D__1-c__8*eta__1*H__1-c__8*b__1*B__1-c__8*b__1^2*B__1*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)+c__8*d__1^2*D__1*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)-c__8*b__1^2*B__1*E__1*gamma*delta/(P(t)*alpha*b*a__2)+c__8*d__1^2*D__1*E__1*gamma*delta/(P(t)*alpha*d*a__2)+c__8*d__1*D__1*phi__p/(P(t)*alpha)+c__8*eta__1*H__1*phi__p/(P(t)*alpha)+c__8*sigma*X__1*phi__p/(P(t)*alpha)-c__8*eta__1*H__1*E__1*b__1*gamma*delta/(P(t)*alpha*b*a__2)+c__8*sigma*X__1*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)+c__8*sigma*X__1*E__1*d__1*gamma*delta/(P(t)*alpha*d*a__2)-c__8*sigma*X__1*E__1*b__1*gamma*delta/(P(t)*alpha*b*a__2)
(48)
## from k__5, c__3 = 0 and choose c__1 = c__2 and c__3 =c__7
c__3 := 0:  c__7:=0:
k__1;
(49)
k__2;
(50)
k__3;
-c__8*d__1^2*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*d*a__2)-c__8*d__1^2*E__1*gamma*delta/(P(t)*alpha*d*a__2)-c__8*d__1*phi__p/(P(t)*alpha)-c__8*d__1*E__1*delta*eta*gamma__1*a__3/(P(t)*alpha*a__2)+c__8*d__1*E__1*b__1*gamma*delta/(P(t)*alpha*b*a__2)+c__8*d__1-c__8*d__1*E__1*delta*sigma/(P(t)*alpha*a__2)+c__8*d__1*E__1*b__1*delta*eta*gamma__1*a__3/(P(t)*alpha*b*a__2)
(51)
k__4;
(52)
## Also choose
sys := solve({k__1=0, k__2 =0, k__3=0, k__4=0}, [c__4,c__5, c__6, c__8]);
[[c__4 = -H(t)*gamma*(E__1*a__3*delta*eta*gamma__1+E__1*gamma*delta-D(t)*a__2*d)*c__6/(D(t)*d*gamma__1*(E__1*a__3*delta*gamma__1-H(t)*a__2)), c__5 = R(t)*eta*(E__1*a__3*delta*eta*gamma__1+E__1*gamma*delta-D(t)*a__2*d)*c__6/(D(t)*d*xi*(E__1*a__3*delta*mu*xi*gamma__1-R(t)*a__2)), c__6 = c__6, c__8 = 0]]
(53)
Download LSA.mw
How can i see analytical maple calculations?
I recently got introduced to fractional calculus, I saw this image on the internet and went to verify the 3rd block of image i.e fractional differentiation on Maple 2022. But Maple returned answer which does not match the result claimed in the image i.e x. I want to know what I am missing here. But when used fracdiff() the answer matches.I also wanted to know how its done by using showSolution command but didn't get the answer. Can I get the steps? meme.mw
f := diff(x, [`$`(x, 1/2)])
x
evalb(diff(x, [`$`(x, 1/2)]) = x)
evalb(diff(x, [`$`(x, 1/2)]) = 2*sqrt(x/Pi))
ShowSolution(diff(x, x^(1/2)))
Error, invalid input: diff received x^(1/2), which is not valid for its 2nd argument
fracdiff(x, x, 1/2)
2*x^(1/2)/Pi^(1/2)
ShowSolution(fracdiff(x, x, 1/2))
Error, (in Student:-Calculus1:-ShowSolution) input expression does not have any incomplete calculus operations
Download meme.mw
Non-Linear.mw
Hi, I have here a interesting non-linear system.
If I attempt to solve it using some specific form of the non-linear equations (form X*Y=Z) of the system, Maple (Verison 18) finds a solution.
But, if I replace some of them by some other forms (like form Y=Z/X), fsolve fails.
I usually use the non-quotient form. But is there any way to guide or configure fsolve to reach a solution?
I set up some of the regular options: placing a seed close to the solution, indicating intervals of possible solutions; but none of that works if I do not set up the non-quotient form of the equations. In some cases, fsolve does not reach a solution at all, no matter the form of the equations.
In the file, the equations that are causing the isssue are the last 3, those who start with the variable f1,f2 and f3.
I ran the system twice with both cases: non-quotient form and quotient form.
Thanks for your attention!
Consider the following integral, shown below in this image.
>> Link to the Maple sheet: example.mw <<
Why does Maple provide erroneous results? Is there a bug in the software? I use Maple 2021.
I am curious to know steps of integration for e^(t^3)*(cos(t))^3 as Maple found the answer correctly. So I wanted to know how it got to that solution. I applied the commands shown in document but unable to get steps. I want to know the reason for this and is it possible to get it work.
exp(t^2)*cos(t)^3
int(exp(t^2)*cos(t)^3, t)
-((1/16)*I)*Pi^(1/2)*exp(9/4)*erf(I*t+3/2)-((3/16)*I)*Pi^(1/2)*exp(1/4)*erf(I*t+1/2)-((3/16)*I)*Pi^(1/2)*exp(1/4)*erf(I*t-1/2)-((1/16)*I)*Pi^(1/2)*exp(9/4)*erf(I*t-3/2)
Student[Calculus1][IntTutor]()
eval(-((1/16)*I)*Pi^(1/2)*exp(9/4)*erf(I*t+3/2)-((3/16)*I)*Pi^(1/2)*exp(1/4)*erf(I*t+1/2)-((3/16)*I)*Pi^(1/2)*exp(1/4)*erf(I*t-1/2)-((1/16)*I)*Pi^(1/2)*exp(9/4)*erf(I*t-3/2), [t = 1])
-((1/16)*I)*Pi^(1/2)*exp(9/4)*erf(3/2+I)-((3/16)*I)*Pi^(1/2)*exp(1/4)*erf(1/2+I)+((3/16)*I)*Pi^(1/2)*exp(1/4)*erf(1/2-I)+((1/16)*I)*Pi^(1/2)*exp(9/4)*erf(3/2-I)
evalf[10](-((1/16)*I)*Pi^(1/2)*exp(9/4)*erf(3/2+I)-((3/16)*I)*Pi^(1/2)*exp(1/4)*erf(1/2+I)+((3/16)*I)*Pi^(1/2)*exp(1/4)*erf(1/2-I)+((1/16)*I)*Pi^(1/2)*exp(9/4)*erf(3/2-I))
.8154967124+0.*I
with(Student:-Calculus1):
Understand(Int, constant, constantmultiple, sum, difference)
ShowSolution(Int(exp(t^2)*cos(t)^3, t), maxsteps = 1000)
Error, (in Student:-Calculus1:-ShowSolution) unable to compute solution steps
Download e.mwe.mw
Derar All
I'm trying ot adapt some old Maple V code to a new Maple 2022 Module/Package and have an issue understanding if the "ModuleLoad" process does really run automatically with the "> with(TST); " command ?
the "> restart;" runs the ModuleUnload though, but for me the ModuleLoad does not seem to run when I expect it to !?
Sincerely
Ivar
Any comment appreciated ?
the test code :
Tst := module()
  local ModuleLoad, ModuleUnload;
  export MyProc;
  global AAA;
  option package;
  ModuleLoad := proc()
      global AAA;
      AAA := 1;
      print("Hello Module");
  ModuleUnload := proc()
      print("Bye Module");
  MyProc := proc()
      print("Hello from Core");
end module ;
When was ?define, forall stripped from Maple?
Define used to accept all of these: Group, Linear, forall, antisymmetric, associative, binary, commutative, identity, inverse, symmetric, type, unary, zero. Was this function moved to another package?
How can I define an arbitrary signature of a space-time metric?
I want to define the signature of the form `++--`.
Multibody exports from MapleSim to Maple convert a symbolic expression to a rational quotient:
The parameters (parameter "a" above) disappear in the exported equations. How can I prevent this (conversion of sqrt3 and disapprence of "a")?
MB_exports_with_rational_quotients_instead_of_symbols.msim
First 299 300 301 302 303 304 305 Last Page 301 of 2431
