hello
i have a Table in my worksheet;
it countains 3 coulmns, and each coulmns cointains a loop that requires about a day to evaluate.
is there a way to excute the 3 coulmns in parallel, there is no interaction between them and i cant seprete them into different worksheets.
thanks in advance.
Anyone experience a delay in typing as the screen fills with text/math etc.?
I'm using Maple 2021 and as the space is filled typing slows. I can finish typing and watch the last 4 keys enter on the screen.
Since approximately a week ago, probably after some Ubuntu update, the xmaple 2021.2 interface started to crash after some simple commands, without any error message or log. I tried to run with java (open-jdk) 11 and 8, and I had the same problem. I still have an old 2017.3 version, and it works perfectly. The problem only affects the new Maple release.
Is there some bug report? What can I do?
Hi !
Looks like there is a bug in the inert "Diff" command.
I have Maple 2018 on Windows 10 ,64 bits.
Does Maple consider Diff(f(x),x) to be equal to Diff(f(x),[x]) ?
It should be the same.
Maple displays  that it is equal but keeps in memory something else.
In the attached file, I give a very simple example.
I don't like to say this but my old version of Maple V Release V (1997) is more consistent i.e.
this version shows it's different and  keeps in memory that difference.
diff-problem.mw
I wonder if newer versions have this problem ?
Best regards !
When using the built-in fsolve function to find the roots of a polynomial, how does exponentiation occur? For example, x3 is found​​​​​​first, and then to find x4, will he start again from the beginning, that is, x*x*x*x, or will he take the value of x3​​​​​​ and multiply by x? The teacher is interested in finding out this, but I don't know how to find out myself.
Hello guys,
I try at the moment to solve this terms:
The function is: f(x,y)=2x2-3xy-(y+2)3+5
1. diff(2*x^2 - 3*xy - (y + 2)^3 + 5, x) = 4x output but this is wrong. The correct output is 4x -3y
2.diff(2*x^2 - 3*xy - (y + 2)^3 + 5, y) = -3*(y + 2)^2 that also wrong. The correct output is -3(x+(y+2)2 )
THX a lot
I have been performing symbolic solutions on netlists using Syrup, and then performing worst-case analysis on the result using the ranges of all the variables.
I would like to add ifelse and/or piecewise linear expressions to my Syrup models. Using symbolic analysis, I can get multiple sets of results from Syrup based on the conditional statements. I'm thinking that if I could put Syrup solve inside my worst case analysis procedure and submit numeric values to Syrup, that the conditional expressions could be solved for.
I think there is something similar that can be done with Dynamic Systems.
Does this request make sense? Is it possible?
The expression
f := arctan(y, x)+arctan(-y, x)
simplifies to zero in the real range if y=0 is excluded.
x < 0, y::real, y <> 0; `assuming`([simplify(f), is(f = 0)], [%])
0, true
x >= 0, y::real, y <> 0; `assuming`([simplify(f), is(f = 0)], [%])
0, true
Combining the above assumptions as attempted bellow does not simplify to zero
x::real, y::real, y <> 0; `assuming`([simplify(f), is(f = 0)], [%])
arctan(y, x)+arctan(-y, x), FAIL
`or`(x < 0, x >= 0), y::real, y <> 0; `assuming`([simplify(f), is(f = 0)], [%])
Or(x < 0, x >= 0), y::real, y <> 0; `assuming`([simplify(f), is(f = 0)], [%])
`and`(-infinity <= x, x <= infinity), y::real, y <> 0; `assuming`([simplify(f), is(f = 0)], [%])
interface(version)
`Standard Worksheet Interface, Maple 2022.0, Windows 10, March 8 2022 Build ID 1599809`
Download assuming_and_differently_combined_inequalities.mw
I'm a newbie to maple, I want to get a group that meeting the criteria with this code:
with(GroupTheory);
G := SymmetricGroup(6);
do
H := Subgroup({RandomElement(G),RandomElement(G)}, G);
C := Core(H, G);
until is(GroupOrder(C) <> 1) and is(GroupOrder(C) <> GroupOrder(H));
H;
C;
But it's seem I cannot construct subgroup. so I adjust it into:
with(GroupTheory);
do
H := Subgroup({[[rand(1 .. 6)]], [[rand(1 .. 6), rand(1 .. 6)], [rand(1 .. 6), rand(1 .. 6)]]}, G);
C := Core(H, G);
H;
C;
However, it is clear that random numbers do not always satisfy the rules of permutation. So how can I use the loop to generate a random subgroup that satisfies the condition?
I am wondering how maple did this calculation:
Show_Solution_Complex_Numbers.mw
How can I ask maple to show its work in this calculation?
how we can solve it
restart; int(log(sqrt(2*t))*e^(-t), t = 0 .. infinity);
How to adapt this program C to Maple ? Thank you.
Sub Les_Vendredi_13()
Dim Annee As Integer
Dim Mois As Byte
Dim Cellule As String
Dim Compteur As Byte
Cellule = "B2"
Compteur = 1
Columns("B:B")
.ClearContents For Annee = 1949 To 2009
For Mois = 1 To 12 If Weekday(Mois & "/13/" & Annee) = 6
Then Range(Cellule).Offset(Compteur, 0) = "13-" & Format(Mois, "00") & "-" & Annee Compteur = Compteur + 1 End
If Next Mois Next Annee Range(Cellule).Offset(Compteur, 0) = "Nbre = " & Compteur - 1
End Sub
Can anyone tell me what this means? (workfile maple.file.mw)
I expected Maple Flow 2022 to return return 2 pi Radians as the answer to the below ... but instead it returned 360 arcdeg.
360 arcdeg * (pi rad/180 arcdeg) =
Question: Why don't the "arcdeg" units cancel out and Maple Flow 2022 return the answer 2 pi rad ?
I expected Maple Flow to handle the units by cancelling out the "arcdeg" units and return 2 pi rad as the answer.
(Note: in this post I placed a space between the numbers and the units for clarity ...
understanding that in Flow you actually enter the number, then press Ctl+Space+U then enter the unit.)
Thanks for any help.
maybe some of you can help me with this.
In the equations are variables F_[i][j] and GG_[i][j] (for i=1,2,3 and j=1,2,3). There are 5 Equations that equal 0 and 1 Equation that equals Q(given).
Is there a better way to try and solve this equations?
First 315 316 317 318 319 320 321 Last Page 317 of 2431
