Let
                              "a"
                              "b"
 be real numbers and
"A = Matrix(3, 3, [[a, a - 1, -b], [a - 1, a, -b], [b, b, 2*a -
   1]])"
                              "B="
 "Matrix(5, 5, [[0, a, 3, 0, a], [3, 0, 0, b, 0], [0, 1, b, 0,
    1], [b, 0, 0, 1, 0], [0, a, 1, 0, b]])"
(a) Show that if
                            "0 <= a"
                            "a <= 1"
                      "b^2 = 2*a*(1 - a)"
, then A is an orthogonal matrix with determinant equal to one.
(b) For what values of a and b is the matrix B singular? Determine the inverse of B (for those values of a and b for which B is invertible).
Find all rational function solutions to the Kadomtsev-Petviashvili equation
(&PartialD;)/(&PartialD;x);
diff(u, t) + 6*u*diff(u, x) + diff(u, x, x, x) - diff(u, y, y) = 0;
by u = 2
diff(ln, x, x)*f;
=(2 (((&PartialD;)^2)/(&PartialD;x^2) f) f-2 ((&PartialD;)/(&PartialD;x) f)^2)/(f^2);
 with
f;
(a[1 ]x+a[2] y+a[3] t+a[4])^2+(a[5] x+ a[6] y+a[7] t+a[8])^2+a[9], ;
where
a[i], i=1..9, ;
are real constants.
How to find the values of X(1),X(2),..&Y(1),Y(2)...Plese help .
for k from 0 to 5 do
X(k+1):=solve(2*(k+1)*X(k+1)+(k+1)*Y(k+1)-X(k)-Y(k)+(1)/k!,X(k+1));
Y(k+1):=solve((k+1)*X(k+1)+(k+1)*Y(k+1)+2*X(k)+Y(k)+(1)/k!,Y(k+1)); od;
Error, (in solve) a constant is invalid as a variable, -(1/2)*Y(1)+1
Download DE_Using_DTM-Ex-3(1).mw
The serie is :Sum(-5*3^(-k - 1)*(x - 2)^k, k = 0 .. infinity)
How to simplify (with collect ? with convert ?...) this expression to get this more "traditionnal" writing :
-5/3*sum(((x - 2)/3^k)^k, k = 0 .. infinity)
Thank you for your help.
To Maple support:
I see 2 problems here. Maple solves the ode using series method.
First problem: Using odetest shows the syntax according to help does not work. Which is
           odetest(sol, ODE, series, point = 0);
The above gives internal error.
When changing to the following syntax
         odetest(sol,ODE,type='series',point=0);
No internal error.
So help page should be corrected.
The second problem is that Maple odetest does not return 0 on its own solution. I verified manually that the solution is correct actually. So I do not know why maple does not return zero here. Simplfication does not help.
`Standard Worksheet Interface, Maple 2022.0, Windows 10, March 8 2022 Build ID 1599809`
Order:=6;
ode:=x^2*diff(diff(y(x),x),x)+x^2*diff(y(x),x)+y(x) = 0;
maple_sol:=dsolve(ode,y(x),type='series',x=0):
odetest(maple_sol,ode,series,point=0);
odetest(maple_sol,ode,'series',point=0);
6
x^2*(diff(diff(y(x), x), x))+x^2*(diff(y(x), x))+y(x) = 0
Error, (in odetest/series) complex argument to max/min: 13/2-1/2*I*3^(1/2)
odetest(maple_sol,ode,type='series',point=0); #This should return zero, but it does not.
-I*3^(1/2)*x^(3/2-((1/2)*I)*3^(1/2))*(series(-1/2-(I*3^(1/2)/((I*3^(1/2)-1)*(I*3^(1/2)-2)))*x-((1/4)*((5*I)*3^(1/2)+3)/((I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^2-((1/6)*((8*I)*3^(1/2)+9)/((I*3^(1/2)-4)*(I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^3-((7/16)*((3*I)*3^(1/2)+5)/((I*3^(1/2)-5)*(I*3^(1/2)-4)*(I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^4+O(x^5),x,5))*_C1+((1/2)*I)*3^(1/2)*x^(3/2+((1/2)*I)*3^(1/2))*(series(1-(1/2)*x+(((1/2)*I)*3^(1/2)/((1+I*3^(1/2))*(I*3^(1/2)+2)))*x^2-((1/12)*((5*I)*3^(1/2)-3)/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)))*x^3+((1/24)*(-9+(8*I)*3^(1/2))/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)*(I*3^(1/2)+4)))*x^4-((7/80)*((3*I)*3^(1/2)-5)/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)*(I*3^(1/2)+4)*(I*3^(1/2)+5)))*x^5+O(x^6),x,6))*_C2+_C1*x^(5/2-((1/2)*I)*3^(1/2))*(series(-I*3^(1/2)/((I*3^(1/2)-1)*(I*3^(1/2)-2))-((1/2)*((5*I)*3^(1/2)+3)/((I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x-((1/2)*((8*I)*3^(1/2)+9)/((I*3^(1/2)-4)*(I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^2-((7/4)*((3*I)*3^(1/2)+5)/((I*3^(1/2)-5)*(I*3^(1/2)-4)*(I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^3+O(x^4),x,4))+_C2*x^(5/2+((1/2)*I)*3^(1/2))*(series(I*3^(1/2)/((1+I*3^(1/2))*(I*3^(1/2)+2))-((1/2)*((5*I)*3^(1/2)-3)/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)))*x+((1/2)*(-9+(8*I)*3^(1/2))/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)*(I*3^(1/2)+4)))*x^2-((7/4)*((3*I)*3^(1/2)-5)/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)*(I*3^(1/2)+4)*(I*3^(1/2)+5)))*x^3+O(x^4),x,4))+_C1*x^(3/2-((1/2)*I)*3^(1/2))*(series(-1/2-(I*3^(1/2)/((I*3^(1/2)-1)*(I*3^(1/2)-2)))*x-((1/4)*((5*I)*3^(1/2)+3)/((I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^2-((1/6)*((8*I)*3^(1/2)+9)/((I*3^(1/2)-4)*(I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^3-((7/16)*((3*I)*3^(1/2)+5)/((I*3^(1/2)-5)*(I*3^(1/2)-4)*(I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^4+O(x^5),x,5))+_C2*x^(3/2+((1/2)*I)*3^(1/2))*(series(-1/2+(I*3^(1/2)/((1+I*3^(1/2))*(I*3^(1/2)+2)))*x-((1/4)*((5*I)*3^(1/2)-3)/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)))*x^2+((1/6)*(-9+(8*I)*3^(1/2))/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)*(I*3^(1/2)+4)))*x^3-((7/16)*((3*I)*3^(1/2)-5)/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)*(I*3^(1/2)+4)*(I*3^(1/2)+5)))*x^4+O(x^5),x,5))-((1/2)*I)*3^(1/2)*x^(3/2-((1/2)*I)*3^(1/2))*(series(1-(1/2)*x-(((1/2)*I)*3^(1/2)/((I*3^(1/2)-1)*(I*3^(1/2)-2)))*x^2-((1/12)*((5*I)*3^(1/2)+3)/((I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^3-((1/24)*((8*I)*3^(1/2)+9)/((I*3^(1/2)-4)*(I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^4-((7/80)*((3*I)*3^(1/2)+5)/((I*3^(1/2)-5)*(I*3^(1/2)-4)*(I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^5+O(x^6),x,6))*_C1+I*3^(1/2)*x^(3/2+((1/2)*I)*3^(1/2))*(series(-1/2+(I*3^(1/2)/((1+I*3^(1/2))*(I*3^(1/2)+2)))*x-((1/4)*((5*I)*3^(1/2)-3)/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)))*x^2+((1/6)*(-9+(8*I)*3^(1/2))/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)*(I*3^(1/2)+4)))*x^3-((7/16)*((3*I)*3^(1/2)-5)/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)*(I*3^(1/2)+4)*(I*3^(1/2)+5)))*x^4+O(x^5),x,5))*_C2+x^(5/2-((1/2)*I)*3^(1/2))*(series(-1/2-(I*3^(1/2)/((I*3^(1/2)-1)*(I*3^(1/2)-2)))*x-((1/4)*((5*I)*3^(1/2)+3)/((I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^2-((1/6)*((8*I)*3^(1/2)+9)/((I*3^(1/2)-4)*(I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^3-((7/16)*((3*I)*3^(1/2)+5)/((I*3^(1/2)-5)*(I*3^(1/2)-4)*(I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^4+O(x^5),x,5))*_C1+x^(5/2+((1/2)*I)*3^(1/2))*(series(-1/2+(I*3^(1/2)/((1+I*3^(1/2))*(I*3^(1/2)+2)))*x-((1/4)*((5*I)*3^(1/2)-3)/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)))*x^2+((1/6)*(-9+(8*I)*3^(1/2))/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)*(I*3^(1/2)+4)))*x^3-((7/16)*((3*I)*3^(1/2)-5)/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)*(I*3^(1/2)+4)*(I*3^(1/2)+5)))*x^4+O(x^5),x,5))*_C2+(1/2)*x^(3/2-((1/2)*I)*3^(1/2))*(series(1-(1/2)*x-(((1/2)*I)*3^(1/2)/((I*3^(1/2)-1)*(I*3^(1/2)-2)))*x^2-((1/12)*((5*I)*3^(1/2)+3)/((I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^3-((1/24)*((8*I)*3^(1/2)+9)/((I*3^(1/2)-4)*(I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^4-((7/80)*((3*I)*3^(1/2)+5)/((I*3^(1/2)-5)*(I*3^(1/2)-4)*(I*3^(1/2)-3)*(I*3^(1/2)-2)*(I*3^(1/2)-1)))*x^5+O(x^6),x,6))*_C1+(1/2)*x^(3/2+((1/2)*I)*3^(1/2))*(series(1-(1/2)*x+(((1/2)*I)*3^(1/2)/((1+I*3^(1/2))*(I*3^(1/2)+2)))*x^2-((1/12)*((5*I)*3^(1/2)-3)/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)))*x^3+((1/24)*(-9+(8*I)*3^(1/2))/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)*(I*3^(1/2)+4)))*x^4-((7/80)*((3*I)*3^(1/2)-5)/((1+I*3^(1/2))*(I*3^(1/2)+2)*(I*3^(1/2)+3)*(I*3^(1/2)+4)*(I*3^(1/2)+5)))*x^5+O(x^6),x,6))*_C2
Download problems_with_series_solution.mw
I want to use this L3 list as the index of another list. I am trying to create a model for short time electricity load forecasting in Maple. I am fairly new to maple coding structures. Can anybody suggest an easier way for doing this kind of thing in Maple? Can I use matrix generation? Please give me suggestions.
Note: Currently working in a Doc File.
The code is pasted below:
L1 := [seq([seq(seq1[i], i = 1 .. 7)], i = 1 .. 24)];
L2 := [seq(i, i = 1 .. 24)];
local(i, j, L3);
L3 = [];
for i to 24 do
    for j to 7 do if i = 1 then L3[i][j] := L1[i][j]; else L3[i][j] := L1[i][j] + L2[i] - 1; end if; end do;
print(L3);
How can I found the area of the region bounded by
y=e^xcos(x), y=o, x=−π/2, x= π/2 ?
I have an example where I try to calculate an infinite sum (G&R1.641.1)  in Maple 2022 (or 2021).  I get a different numerical result when I evaluate the sum if I express the coefficients c(m) in the sum using Maple's doublefactorial function for m!! (c1(m)) or the equivalent expression involving the factorial function (c2(m)).  Only the latter gives the correct value for the sum.  This happens even though Maple gives the same numerical value for the coefficients c1(m) and c2(m).  What's going on?? Please see the attached spreadsheet.
Download doublefactorial_test.mw
I solved a linear system using Jacobi method , then I plot the solution, someting is wrong, I can't plot the solution
jacobi.mw
I have the following expression (result of a calculation):
(1/1296)*cBooP0-(1/1296)*cSRP0-(1/1296)*tStartRamp*f__SR/N
Rather obviously the common factor 1/1296 can be factored out, except I cannot get Maple to factor the 1/1296 without also factoring out N, which I do not want. My desired end result is this:
(1/1296)*(cBooP0-cSRP0-tStartRamp*f__SR/N)
I don't seem to be able to coerce Maple to do this. I can freeze the tStartRamp*f__SR/N term (leaving the 1/1296 unfrozen), but in that case I don't get Maple to pull the 1/1296 factor out at all.
Any hint would be appreciated. I am doing this on Maple 2015. It is really a bit cosmetic, but sometimes I use Maple to write "smart" documentation & then I'd like to end up with a somewhat polished result.
Mac Dude
As the LPsolve package returns the solution points in a list format, how we can analyze the list if we're having a large instance problem? By large instance, I mean that there are around 1500+ variables in the linear programming model.
Also, I have attached the screenshot of the output in this thread. To perform further analysis, I want to fetch the value of the DQV, QF, and UQT variables. But since the list contains the values as an expression, for example DQV[0, 0, 0, 0] = 0. In such cases, I cannot perform mathematical operations for the solution points results.
Also, if I can delete the DQV[0,0,0,0] from the expression mentioned above, I'll end with the numeric values list, which can then be converted into an array and make things easier for me. But currently, I'm struggling to delete the DQV part of the expression in one go (manually deletion for each expression, it's very time consuming to delete for 1500 variables).
Please suggest to me some approach to deal with this issue.
I am thanking you.
I am having a problem in evaluating a fluid flow problem at a boundary that includes infinity using a semi-analytic method Adomian Decomposition Method.
Find the attached code. Thanks in advance.
I recently upgraded to Maple 2022 just to use the new latex command. It seems I still can't export DataFrame types, I'm very disappointed. What am I doing wrong?
test:= DataFrame( [[1]], columns = [1] );
latex(test);
returns:
Error, (in DataFrame:-type) invalid input: subtype expects its 2nd argument, _t, to be of type type, but received And(symbol,satisfies(u -> substring(u,1 .. 9) = ('`\\mapleref`')))
Using File > Export As > LaTeX also doesn't work.
Printing the function call using printlevel := 100000: returns the following:
I've attached the worksheet for reference. Demo.mw
Does anyone know a workaround?
-Thanks for the Help
dear all
I try to create a table with four columns but someting wrong, the code contains few lines,
table_columns.mw
dear all
I have a system of 4 equations with 4 unkowns, but maple says that there 7 unknowns, and fsolve does return any solution
problem_solve_system.mw
First 320 321 322 323 324 325 326 Last Page 322 of 2431
