i used:
Y := ssystem("dir C:"); print(Y)
result is
[0,"\" El volumen de la unidad C es OS\n El n£mero de serie del volumen es: 54A9-09DA\n\n Directorio de C:\\Program Files\\Maple 2016"
Windows operating system English version but Maple shows Spanish result
I want result is English. Please help me
Y := ssystem("dir C:"):
[0, " El volumen de la unidad C es OS
 Directorio de C:\Program Files\Maple 2016
21/02/2025  07:53 AM    <DIR>          .
22/02/2025  08:34 AM    <DIR>          ..
21/02/2025  07:50 AM    <DIR>          afm
21/02/2025  07:55 AM    <DIR>          bin.X86_64_WINDOWS
21/02/2025  07:52 AM    <DIR>          data
13/02/2025  07:46 AM    <DIR>          eBookTools
21/02/2025  07:50 AM    <DIR>          etc
02/02/2016  05:05 AM            73,861 EULA.html
21/02/2025  07:52 AM    <DIR>          examples
21/02/2025  07:52 AM    <DIR>          examplesclassic
21/02/2025  07:52 AM    <DIR>          Excel
21/02/2025  07:50 AM    <DIR>          extern
21/02/2025  07:52 AM    <DIR>          Fonts
13/01/2016  06:39 AM           223,499 Install.html
21/02/2025  07:52 AM    <DIR>          java
21/02/2025  07:52 AM    <DIR>          jre
21/02/2025  07:52 AM    <DIR>          lib
21/02/2025  07:55 AM    <DIR>          license
27/01/2011  11:13 PM             6,296 Maple Cloud Terms of Service.html
17/02/2016  02:54 PM         5,490,560 MapleToolbox2016.0WindowsX64Installer.exe
13/02/2025  07:48 AM           317,257 Maple_2016_Install_2025_02_13_08_46_07.log
21/02/2025  07:52 AM           317,834 Maple_2016_Install_2025_02_21_08_47_47.log
21/02/2025  07:50 AM    <DIR>          profiles
21/02/2025  07:52 AM             5,396 readme.txt
21/02/2025  07:52 AM    <DIR>          redist
21/02/2025  07:52 AM    <DIR>          samples
21/02/2025  07:52 AM    <DIR>          uninstall
21/02/2025  07:52 AM    <DIR>          update
13/02/2025  07:46 AM    <DIR>          Users
               7 archivos      6,434,703 bytes
              22 dirs  148,583,636,992 bytes libres"]
Download language_maple.mw
non-expert Maple user here.  Any help would be appreciated, I am trying to perform the following process:
1) Represent State Space matrices calculated by hand (ex: A, B, C, D) as a Maple object.
2) Find a solution to the State Space system of equations based on given initial conditions, or represent the same in any other form such as a plot or table.  I am right now trying without much success to use the ResponsePlot and Simulate functions for this.
I have completed (1) using the DynamicSystems > StateSpace object of the form
sys:= StateSpace(A,B,C,D)    // where A, B, C, D are the numeric matrices of the typical S-S set.
using a simple constant '1' as an algebraic input test, I use the ResponsePlot as follows:
ResponsePlot(sys, 1)
Maple gives me the error:
Error, (in DynamicSystems:-Simulate) for a continuous system, the second argument (input) must be an algebraic expression or a list of algebraic expressions; received Vector(7, [0,1,2,3,4,5,6])
NULL;
I am sure I'm missing something simple.  Can someone please assist in showing me what I'm doing wrong?  I tried using a vector [0,1,2,3,4] instead of an algebraic function, but it still returned an error.  I am open to other ways too, but the next best way seems to be to convert from StateSpace into individual differential equations and then solve them all manually with dsolve.  It seems like there has got to be a simpler way than that.  Does anyone know of a simple way to implement this process?
i did try but i don't know the result is not come out? also i am not sure to put equation in eq1 in pde or linear part?
with(PDEtools)
with(LinearAlgebra)
with(SolveTools)
undeclare(prime)
declare(u(x, y, t))
u(x, y, t)*`will now be displayed as`*u
declare(f(x, y, t))
f(x, y, t)*`will now be displayed as`*f
pde := diff(u(x, y, t), t, y)+diff(u(x, y, t), `$`(x, 3), y)-3*(diff(u(x, y, t), x))*(diff(u(x, y, t), x, y))-3*(diff(u(x, y, t), `$`(x, 2)))*(diff(u(x, y, t), y))+alpha*(diff(u(x, y, t), x, y))+beta*(diff(u(x, y, t), `$`(x, 2)))
diff(diff(u(x, y, t), t), y)+diff(diff(diff(diff(u(x, y, t), x), x), x), y)-3*(diff(u(x, y, t), x))*(diff(diff(u(x, y, t), x), y))-3*(diff(diff(u(x, y, t), x), x))*(diff(u(x, y, t), y))+alpha*(diff(diff(u(x, y, t), x), y))+beta*(diff(diff(u(x, y, t), x), x))
pde_nonlinear, pde_linear := selectremove(proc (term) options operator, arrow; has((eval(term, u(x, y, t) = a*u(x, y, t)))/a, a) end proc, pde)
-3*(diff(u(x, y, t), x))*(diff(diff(u(x, y, t), x), y))-3*(diff(diff(u(x, y, t), x), x))*(diff(u(x, y, t), y)), diff(diff(u(x, y, t), t), y)+diff(diff(diff(diff(u(x, y, t), x), x), x), y)+alpha*(diff(diff(u(x, y, t), x), y))+beta*(diff(diff(u(x, y, t), x), x))
eq := u(x, y, t) = -2*(diff(ln(f(x, y, t)), x))
u(x, y, t) = -2*(diff(f(x, y, t), x))/f(x, y, t)
eq1 := -(1/2)*numer(normal(eval(pde_linear, eq)))
f(x, y, t)^4*(diff(diff(diff(f(x, y, t), x), x), x))*beta+f(x, y, t)^4*(diff(diff(diff(f(x, y, t), x), x), y))*alpha-f(x, y, t)^3*(diff(f(x, y, t), y))*(diff(diff(f(x, y, t), x), x))*alpha-2*f(x, y, t)^3*(diff(diff(f(x, y, t), x), y))*(diff(f(x, y, t), x))*alpha-3*f(x, y, t)^3*(diff(f(x, y, t), x))*(diff(diff(f(x, y, t), x), x))*beta+2*f(x, y, t)^2*(diff(f(x, y, t), y))*(diff(f(x, y, t), x))^2*alpha+2*f(x, y, t)^2*(diff(f(x, y, t), x))^3*beta+(diff(diff(diff(f(x, y, t), t), x), y))*f(x, y, t)^4+(diff(diff(diff(diff(diff(f(x, y, t), x), x), x), x), y))*f(x, y, t)^4-(diff(diff(f(x, y, t), t), x))*(diff(f(x, y, t), y))*f(x, y, t)^3-(diff(diff(diff(diff(f(x, y, t), x), x), x), x))*(diff(f(x, y, t), y))*f(x, y, t)^3-(diff(diff(f(x, y, t), x), y))*(diff(f(x, y, t), t))*f(x, y, t)^3-4*(diff(diff(diff(f(x, y, t), x), x), x))*(diff(diff(f(x, y, t), x), y))*f(x, y, t)^3-(diff(f(x, y, t), x))*(diff(diff(f(x, y, t), t), y))*f(x, y, t)^3-4*(diff(diff(diff(diff(f(x, y, t), x), x), x), y))*(diff(f(x, y, t), x))*f(x, y, t)^3-6*(diff(diff(f(x, y, t), x), x))*(diff(diff(diff(f(x, y, t), x), x), y))*f(x, y, t)^3+2*(diff(f(x, y, t), x))*(diff(f(x, y, t), t))*(diff(f(x, y, t), y))*f(x, y, t)^2+8*(diff(diff(diff(f(x, y, t), x), x), x))*(diff(f(x, y, t), x))*(diff(f(x, y, t), y))*f(x, y, t)^2+6*(diff(diff(f(x, y, t), x), x))^2*(diff(f(x, y, t), y))*f(x, y, t)^2+24*(diff(diff(f(x, y, t), x), x))*(diff(f(x, y, t), x))*(diff(diff(f(x, y, t), x), y))*f(x, y, t)^2+12*(diff(diff(diff(f(x, y, t), x), x), y))*(diff(f(x, y, t), x))^2*f(x, y, t)^2-36*(diff(diff(f(x, y, t), x), x))*(diff(f(x, y, t), x))^2*(diff(f(x, y, t), y))*f(x, y, t)-24*(diff(f(x, y, t), x))^3*(diff(diff(f(x, y, t), x), y))*f(x, y, t)+24*(diff(f(x, y, t), x))^4*(diff(f(x, y, t), y))
T := f(x, y, t) = h*a[10]+m^2+n^2+a[9]
T1 := m = t*a[3]+x*a[1]+y*a[2]+a[4]
T2 := n = t*a[7]+x*a[5]+y*a[6]+a[8]
T3 := h = a[10]*exp(t*p[3]+x*p[1]+y*p[2])
L2 := expand(subs({T1, T2, T3}, T))
f(x, y, t) = a[10]^2*exp(p[3]*t)*exp(p[1]*x)*exp(p[2]*y)+t^2*a[3]^2+2*t*x*a[1]*a[3]+2*t*y*a[2]*a[3]+x^2*a[1]^2+2*x*y*a[1]*a[2]+y^2*a[2]^2+2*t*a[3]*a[4]+2*x*a[1]*a[4]+2*y*a[2]*a[4]+a[4]^2+t^2*a[7]^2+2*t*x*a[5]*a[7]+2*t*y*a[6]*a[7]+x^2*a[5]^2+2*x*y*a[5]*a[6]+y^2*a[6]^2+2*t*a[7]*a[8]+2*x*a[5]*a[8]+2*y*a[6]*a[8]+a[8]^2+a[9]
eq9a := eval(eq1, L2)
indets(%)
{alpha, beta, t, x, y, a[1], a[2], a[3], a[4], a[5], a[6], a[7], a[8], a[9], a[10], p[1], p[2], p[3], exp(p[1]*x), exp(p[2]*y), exp(p[3]*t)}
p2b := subs({exp(p[1]*x) = eX, exp(p[2]*y) = eY, exp(p[3]*t) = eT}, eq9a); indets(%)
{alpha, beta, eT, eX, eY, t, x, y, a[1], a[2], a[3], a[4], a[5], a[6], a[7], a[8], a[9], a[10], p[1], p[2], p[3]}
p2c := numer(normal(p2b))
eqns := {coeffs(collect(p2c, {eT, eX, eY}, distributed), {eT, eX, eY})}; nops(%)
5
solve(eqns, {a[1], a[2], a[3], a[4], a[5], a[6], a[7], a[8], a[9], a[10], p[1], p[2], p[3]})
Download parameters.mw
Can I define the creation and annihilation operator commutation relations with an explicit momentum dependence?
The goal is to implement an expression of a discrete scalar plane-wave solution to the Klein-Gordon equation that makes use of the creation and annihilation operators in the Physics package.
We don't bother solving the Klein-Gordon equation explicitly. Instead, we just take a solution from literature. This approach is sufficient to show the difficulty in defining the the creation and annihilation operators in this way.
how_to_define_creation_and_annihilation_operators_with_a_momentum_dependence.mw
Setup
NULL``
Goal
NULL``
Define Creation and Annihilation Operators for Quantum Field phi
Static Textbook Solution
Commutator Definition Attempt 1 FAIL
NULL``
Commutator Definition Attempt 2 FAIL
NULL``
Commutator Definition Attempt 3 FAIL
NULLNULL
Commutator Definition Attempt 4 FAIL
NULL``
Commutator Definition Attempt 5 FAIL
So, is defining the creation and annihilation operators with a momentum dependence even possible, using the physics MAPLE package?
Download how_to_define_creation_and_annihilation_operators_with_a_momentum_dependence.mw
Whenever I have local proc inside a proc, and use local variables from the outer proc inside it, Mint tells me that the variables are not used.
This can't be right. Why does it say that? Here is MWE. I have this foo.mpl file
foo := proc()
local C1;
local y,x;
    proc()
        C1:= `tools/genglobal`(_C);
        sol:=y(x)=  C1;
    end proc();
We see clearly that C1 is used, also x and y are used. There can be more code using these inside the inner proc. But this is what mint says
"C:\Program Files\Maple 2024\bin.X86_64_WINDOWS\mint.exe" foo.mpl
    |\^/|      Maple 2024 Diagnostic Program
._|\|   |/|_.  Copyright (c) Maplesoft, a division of Waterloo Maple Inc. 2024
 \  MINT   /   All rights reserved. Maple is a trademark of
 <____ ____>   Waterloo Maple Inc.
Procedure foo() on lines 1 to 11
  These local variables were never used:  C1, x, y
Any idea why it says these are not used?
Also, I noticed it did not warn me that variable sol is global inside the proc. i.e. I was expecting something like this
          These names were used as global names but were not declared: sol
Which is typical message mint gives when using a name inside a proc which was not declared,
Maple 2024.2 on Windows
I have a square matrix of data points. Each point is between 0 to 0.2. I wish to plot it and set the axes to values from 0 to 1. I want the 3D plot to be plotted with a constrained scaling. The two options I have are plots:-matrixplot and plots:-surfdata.
* matrixplot can constrain the data, but it isn't obvious how to change the axes so that it shows from 0 to 1 in both directions.
* In surfaceplot, it is easy to adjust the axes values, but scaling=constrained does nothing.
(I assume someone else might also appreciate the answer. So, instead of me continuing to struggle, I post here and hope someone can answer without the use of many brain cells.)
Example attached.
restart; N := 20; M := LinearAlgebra:-RandomMatrix(N, generator = rand(0 .. .2))
Scaling can be easily controlled, but labels are bad
plots:-matrixplot(N*M, labels = ["x", "y", "V"], scaling = constrained, axis = [tickmarks = [seq(0 .. 1, numelems = 10)]], size = [600, 600])
Axes are shown nicely, but scaling cannot be constrained.
plots:-surfdata(M, 0 .. 1, 0 .. 1, labels = ["x", "y", "V"], scaling = constrained, size = [600, 600])
Download Scaled_matrix_plot_with_axes.mw
If I understand right, in the following calling an exception should be raised since the return value of the matching coercion procedure is of course not of type “set”:
foo := (x::coerce(set, (y::rtable) -> convert(y, list))) -> x:
foo(<0>);
                              [0]
Did I miss something?
So just like the title illustrates, I found a paper authored by Gary Nicklason in 2022: Autonomous Planar Systems of Riccati Type and in the last section it mentioned about a class of Abel ODE, which belongs to AIA(Abel Inverse Abel) class. It is of First kind and the inverse of it(by swapping variables) is of second kind.
While the first kind is solvable in terms of Airy function, the inverse of it along with its equivalence class is not solvable by the existing dsolve.
I have tested it in my worksheet Nicklason_equation.mw. So is it possible to add this class into the dictionary for solvable Abel ODE, or, maybe there are some bugs within the internal procedure of dsolve, which results in failure for catching the solvable candidates?
I want to remove the Lambert function (LambertW) from my equation, but I don't know how. I tried using the explicit option, but it didn't work. How can I express the equation without LambertW?
with(PDEtools)
with(LinearAlgebra)
with(SolveTools)
undeclare(prime)
declare(u(x, y, z, t))
declare(f(x, y, z, t))
pde := diff(diff(u(x, y, z, t), t)+6*u(x, y, z, t)*(diff(u(x, y, z, t), x))+diff(u(x, y, z, t), `$`(x, 3)), x)-lambda*(diff(u(x, y, z, t), `$`(y, 2)))+diff(alpha*(diff(u(x, y, z, t), x))+beta*(diff(u(x, y, z, t), y))+gamma*(diff(u(x, y, z, t), z)), x)
diff(diff(u(x, y, z, t), t), x)+6*(diff(u(x, y, z, t), x))^2+6*u(x, y, z, t)*(diff(diff(u(x, y, z, t), x), x))+diff(diff(diff(diff(u(x, y, z, t), x), x), x), x)-lambda*(diff(diff(u(x, y, z, t), y), y))+alpha*(diff(diff(u(x, y, z, t), x), x))+beta*(diff(diff(u(x, y, z, t), x), y))+gamma*(diff(diff(u(x, y, z, t), x), z))
pde_nonlinear, pde_linear := selectremove(proc (term) options operator, arrow; not has((eval(term, u(x, y, t) = a*u(x, y, t)))/a, a) end proc, expand(pde))
0, diff(diff(u(x, y, z, t), t), x)+6*(diff(u(x, y, z, t), x))^2+6*u(x, y, z, t)*(diff(diff(u(x, y, z, t), x), x))+diff(diff(diff(diff(u(x, y, z, t), x), x), x), x)-lambda*(diff(diff(u(x, y, z, t), y), y))+alpha*(diff(diff(u(x, y, z, t), x), x))+beta*(diff(diff(u(x, y, z, t), x), y))+gamma*(diff(diff(u(x, y, z, t), x), z))
thetai := t*w[i]+x*k[i]+y*l[i]+z*r[i]+eta[i]; eval(pde_linear, u(x, y, z, t) = exp(thetai)); eq15 := isolate(%, w[i])
w[i]*k[i]*exp(t*w[i]+x*k[i]+y*l[i]+z*r[i]+eta[i])+12*k[i]^2*(exp(t*w[i]+x*k[i]+y*l[i]+z*r[i]+eta[i]))^2+k[i]^4*exp(t*w[i]+x*k[i]+y*l[i]+z*r[i]+eta[i])-lambda*l[i]^2*exp(t*w[i]+x*k[i]+y*l[i]+z*r[i]+eta[i])+alpha*k[i]^2*exp(t*w[i]+x*k[i]+y*l[i]+z*r[i]+eta[i])+beta*k[i]*l[i]*exp(t*w[i]+x*k[i]+y*l[i]+z*r[i]+eta[i])+gamma*k[i]*r[i]*exp(t*w[i]+x*k[i]+y*l[i]+z*r[i]+eta[i])
w[i] = -(t*k[i]^4+gamma*t*k[i]*r[i]+alpha*t*k[i]^2+beta*t*k[i]*l[i]-lambda*t*l[i]^2+LambertW(12*t*k[i]*exp(-(t*k[i]^4+alpha*t*k[i]^2+beta*t*k[i]*l[i]+gamma*t*k[i]*r[i]-lambda*t*l[i]^2-x*k[i]^2-y*k[i]*l[i]-z*k[i]*r[i]-eta[i]*k[i])/k[i]))*k[i])/(t*k[i])
sol := solve(eq15, w[i], explicit)
Download remove.mw
I have a system of polynomial equations where the unknowns are real numbers. The set of solutions is infinite (positive-dimensional). How can I compute the real dimension of the solution set (i.e. of a real algebraic variety)?
As it as mentioned in arXiv:2105.10255, this can be done using the RealTriangularize function from the RegularChains package. What is best way of getting the real dimension from the regular_semi_algebraic_system object, which is returned by this function?
I got email to register to "see" Maple 2025 :
for a special advanced look at Maple 2025
But I do not understand what does registering here means. Do I then get a link to some Maple internal URL to watch Video at that time? It says
Date/Time: Tuesday, March 18, 2025 at 11:00 AM
Language: English
Duration: 1 hour
If I register, then what happens?  do I get a link that opens at the time time to watch it? If so, why does one have to register to watch a Maple video? Why is the link not made public for any one to watch? Does one have to be at the browser at that exact time for the link to open?
I just do not know what a Maple webinar means.  Is it like a youtube video?
Would someone please help me with how to achieve this cool animation shown here.
3d plot
How i can add lebel inside graph  like this picture for some graph , in somecoding i have but i can't how it work i want add to  my code but i can't do the same as paper did
label.mw
I am trying to find the most compact form of the symbolic matrix exponential of the specific 4x4 input matrix with the following form:
where all variables are non-negative real constants, with the additional problem specific conditions:
1. omega__1 + omega__2 = 1
2. f__p + f__d1 + f__d2 = 1
There are many mathematically identical subterms at the matrix exponential, so I would like to use a few proper substitute subexpressions, but Maple does not apply it, without any error or warning message.
Moreover, I have no idea how to incorporate above-mentioned additional conditions into the simplification process.
expFT_compact.mw
I will be very happy for any help with this problem.
Michal
First 33 34 35 36 37 38 39 Last Page 35 of 2430
