The worksheet below contains an example of the tiling of the hyperbolic plane.
I would like to produce this and other hyperbolic plane tilings from Maple worksheets, but I don't know the math technique for doing so.
Please direct me to a source of the requisite knowledge or an example worksheet which I can study and imitate.
Hyperbolic_Plane_Tiling.mw
On virtually any webpage is a mixture of images and text. I can go to the page, select all contents, copy the contents into an Excel spreadsheet, save the spreadsheet file and then use the ExcelTools:-Import function to read the file into a DataFrame. At that point, I can work with the data.   All the text on the webpage, even if it is embedded in some HTML command, is copied as text into the spreadsheet which eventually can be read as text by Maple.
My quesiton is, what is the method for me to bypass Excel and import the webpage directly into Maple, striped of the HTML code? Can someone point me to an example? (The only examples I have seen use the Sockets package, but I thought this mode has been superceded with Import.)
Here is an example. Why not apply the minus sign to the numerator?
Is there a simple way to change this behavior.
t__FET_TurnOff := solve(-C__iss2*V__gs_th2 + Q__total = i__GateDriveN*t__off, t__off);
Preferred result
Programatically assigning colors to points in geom3d not working.  I just want all the points drawn by the draw command, to be the same color.  The output does not respond to programatic specification of the object color.
Maple 2021 Help says: "
geom3d: draw command
calling sequence:
draw(obj,...)
draw([obj_1,...,obj_n],...)
A typical call to the draw function is draw([ obj_1(localopts_1),...,obj_n(localopts_n) ], globalopts) where obj_1, ..., obj_n are geometric objects, localopts_1, ..., localopts_n are local options for a particular object, and globalopts are  options which apply to all of the objects.
localopts_i is a sequence of type equation. The set of options allowed for localopts_i is color = red."
I tried: color = "Red", color = "red", color = Red, color=red.  The command goes through but the colors remain distinct per point.  You can use the context menu to change the color after the command goes through but it is inefficient for my purposes.
Here is an image of it not working:
Hello, There seems to be a bug in the int() routine when CPV is being used i.e.
f1 := (int(t^(2*a - 1)/(-t^2 + 1), t = 0 .. infinity, CPV = true) assuming (0 < a, a < 1));
the result given is
f1 := Pi/(2*sin(Pi*a)*(-1)^(1 - a))
but the correct result is
f1 := Pi/2*cot(Pi*a).
I need to use a remote machine with an outdated Maple 2016. But I have written my own package in Maple 2019 / 2020 on my laptop. When I try to load my code in Maple 2016, I got the error
Error, unexpected export declaration in module body
What are the main changes to the module system in the Maple language since the 2016 version? How should I modify the code to run it successfully? (I encounter no errors for other code which only contains procedures but not modules.)
I create a table of 3D points in one worksheet and would like to use these values at a later time in a separate worksheet.
What is the simplest way to do this?
with(LinearAlgebra)
InvT := Matrix([[c^2, s^2, -2*s*c], [s^2, c^2, 2*s*c], [s*c, -s*c, c^2-s^2]])
Matrix(%id = 18446746411704779590)
T := Matrix([[c^2, s^2, 2*s*c], [s^2, c^2, -2*s*c], [-s*c, s*c, c^2-s^2]])
Matrix(%id = 18446746411704773678)
c := cos(p)
cos(p)
s = sin(p)
s = sin(p)
Q := Matrix([[Q11, Q12, 0], [Q12, Q22, 0], [0, 0, Q66]])
Matrix(%id = 18446746411704759470)
Q11 := E1/(-v12*v21+1); Q12 := E2/(-v12*v21+1); Q66 := G12
E1/(-v12*v21+1)
E2/(-v12*v21+1)
G12
E1 := 0.233e12; E2 := 0.231e11; v21 := 0.2e-1; v12 := .2; G12 := 0.717e10
0.233e12
0.231e11
0.2e-1
.2
0.717e10
R := Matrix([[1, 0, 0], [0, 1, 0], [0, 0, 2]])
Matrix(%id = 18446746411704747062)
Qbar := Matrix([[Qb11, Qb12, Qb16], [Qb12, Qb22, Qb26], [Qb16, Qb26, Qb66]])
Matrix(%id = 18446746411704742726)
InvR := MatrixInverse(R)
Matrix(%id = 18446746411704745726)
eq1 := Qbar = InvT.Q.R.T.InvR
Matrix(%id = 18446746411704742726) = Matrix(%id = 18446746411704732718)
plot(Qb11, p = 0 .. 9)
Warning, expecting only range variable p in expression Qb11 to be plotted but found name Qb11
Download plotting_elements_of_matrix.mw
How to solve these systems of BVP and obtain values for gamma term.
I was trying to find the inverse of a function where the domain has been restricted. For example
solve(x=subs(x=y, x^2+8*x), y, useassumptions) assuming x::RealRange(-4, Open(infinity));
and my hope was that including the assumption would result in a single solution but it still gives me two solutions as it would without the assumption.
I would like to algorithmically end up with a single solution. Currently I am only working with functions that have variables to the power of 0, 1 or 2 and additionally square roots, but a more general method would be optimal. What am I doing wrong?
Can you use the Dirac function in different coordinate systems?
I have a second order PDE, i used pdesolve but no solution obtained, why?
pdsolve_pde.mw
Is there a way to ask Maple to re-write the expression
a:=1/3 -exp(-3)/3 into a:=1/3*(1-exp(-3))  ?
The command "factor" doesn't seem to work. Thank you.
Can the number of frames per second be changed programmatically in animate and/or animatecurve ?
First 397 398 399 400 401 402 403 Last Page 399 of 2443
