hi I want to map these two phase portraits on sphere according.
Upper hemisphere:
Lower hemisphere:
I used code from this post
https://www.mapleprimes.com/posts/136598-Images-On-Surfaces
but I can't figure out how to delete this black half and add next part:
I found this idea in Elias Wegert's book Visual Complex Functions. Thanks in advance.
n := 3;
Digits := 10;
R_const := 8.314;
currentdir();
const := [1, 1, 1];
b := 20;
W := readdata("data20.txt", 2);
W := [seq([W[i, 2], W[i, 1]], i = 1 .. nops(W))];
Tempset := seq(W[i, 1], i = 1 .. nops(W));
Rateset := seq(W[i, 2], i = 1 .. nops(W));
Temp := [seq(W[i, 1], i = 1 .. nops(W))];
pdata := plots[pointplot](W, color = red);
pdata;
h[5] := 1;
h[4] := 8.5733287401;
h[3] := 18.059016973;
h[2] := 8.6347608925;
h[1] := 0.2677737343;
p[5] := 1;
p[4] := 9.5733223454;
p[3] := 25.6329561486;
p[2] := 21.0996530827;
p[1] := 3.9584969228;
r := x -> local m; exp(-x)*add(h[m]*x^(m - 1), m = 1 .. 5)/(x*add(p[m]*x^(m - 1), m = 1 .. 5));
q := (i, x) -> -Temp[1]*exp(-E_sim[i]/(R_const*Temp[1])) + E_sim[i]*r(E_sim[i]/(R_const*Temp[1]))/R_const + x*exp(-E_sim[i]/(R_const*x)) - E_sim[i]*r(E_sim[i]/(R_const*x))/R_const;
for i to n do
    R[i] := [seq(1 - exp(-A_sim[i]*const[i]*q(i, Temp[j])/b), j = 2 .. nops(Temp))];
for i to n do
    Der[i] := [seq(c_sim[i]*A_sim[i]*const[i]*exp(-E_sim[i]/(R_const*Temp[j]))*(1 - R[i][j]), j = 1 .. nops(Temp) - 1)];
Deriv := add(Der[i], i = 1 .. n);
model := [seq([Temp[i], Deriv[i]], i = 1 .. nops(R[1]))];
objective := add((W[i, 2] - model[i, 2])^2, i = 1 .. nops(Temp) - 1);
with(GlobalOptimization);
infolevel[GlobalOptimization] := 3;
Results := GlobalOptimization[GlobalSolve](objective, {add(c_sim[i], i = 1 .. 3) <= 1}, c_sim[1] = 0.05 .. 0.06, c_sim[2] = 0.85 .. 0.88, c_sim[3] = 0.05 .. 0.6, E_sim[1] = 33880 .. 33890, E_sim[2] = 40220 .. 41230, E_sim[3] = 23230 .. 23235, A_sim[1] = 2453 .. 2455, A_sim[2] = 190 .. 192, A_sim[3] = 1830 .. 1832, timelimit = 7200);
          [GetLastSolution, GlobalSolve, Interactive]
Results := [Float(undefined), [A_sim[1] = 2454.85789978944,
  A_sim[2] = 190.143107633747, A_sim[3] = 1831.19959951461,
  E_sim[1] = 33883.8826959700, E_sim[2] = 40796.6139830241,
  E_sim[3] = 23230.4022199775, c_sim[1] = 0.0558944062681716,
  c_sim[2] = 0.851532317382881, c_sim[3] = 0.0845465106500359]]
DEV_perc := 100*sqrt(Results[1]/(nops(Temp) - 3*n))/max(Rateset);
       DEV_perc := Float(undefined) + Float(undefined)
Unsolved for Maple?
Thanks for reading.
I am just evaluating Maple 2021 under Windows 10 and I have something strange happening when I press F1 for Help or I select Maple Help in Help Menu. The first time the help window will appear but if I close it then impossible to view it again by pressing F1 or by selecting it in the Help menu. Also the same for other choices in the help menu like
Maple Help F1
Maple Portal
Study Guides
What's New
But any choices inside On the web will always work.
I am using Windows 10 latest release in french and the keyboard layout in ENG I don't think it is related but just in case someone ask me.
Have you notice the same problem ?
I have used the open source maxima quite a bit, and variable replacement was easy. For example:
3x+2y,x=20,y=5
3x+2y,x=3m-4p,y=(a+b)^2
I could combine very easily, like:
a=3x+2y             (%1)
4a-2b,%1
%1,x=5,y=7
and so on...I use variable replacement in equations VERY regularly, and so far, all I have found is having to use a mouse and select "Evaluate at a point". I'm not even sure I could put other equations in there if I wanted to. Even if it does work, the more complicated scenarios that I did routinely in maxima would still be virtually impossible this way.
Thus, the question is, is there doc somewhere on how to make various variable replacements, and equation combining like this easy?
When I use piecewise like this
W :=piecewise(beta>=-Pi/2 and beta<=-Pi/2+Pi/200,1+eps/sin(Pi/200)+eps*cos(Pi/200)/sin(Pi/200)*sin(beta),
beta>=-Pi/2+Pi/200 and beta<=Pi/2,1+eps/sin(Pi/200)-eps*cos(Pi/200)/sin(Pi/200)*sin(beta),
      1+eps*(1+cos(beta)));
and eval the beta as following,
G:= eval(R,beta=(arctan(diff(f(x,y),y), diff(f(x,y),x))));
the calculation does not run well...because of the undefined
[[-eps sin(t_atan2((&PartialD;)/(&PartialD;y) pho(x,y),(&PartialD;)/(&PartialD;x) pho(x,y))),t_atan2((&PartialD;)/(&PartialD;y) pho(x,y),(&PartialD;)/(&PartialD;x) pho(x,y))<-Pi/2],[undefined,t_atan2((&PartialD;)/(&PartialD;y) pho(x,y),(&PartialD;)/(&PartialD;x) pho(x,y))=-Pi/2],[(eps cos(Pi/200) cos(t_atan2((&PartialD;)/(&PartialD;y) pho(x,y),(&PartialD;)/(&PartialD;x) pho(x,y))))/(sin(Pi/200)),t_atan2((&PartialD;)/(&PartialD;y) pho(x,y),(&PartialD;)/(&PartialD;x) pho(x,y))<-(99 Pi)/200],[undefined,t_atan2((&PartialD;)/(&PartialD;y) pho(x,y),(&PartialD;)/(&PartialD;x) pho(x,y))=-(99 Pi)/200],[-(eps cos(Pi/200) cos(t_atan2((&PartialD;)/(&PartialD;y) pho(x,y),(&PartialD;)/(&PartialD;x) pho(x,y))))/(sin(Pi/200)),t_atan2((&PartialD;)/(&PartialD;y) pho(x,y),(&PartialD;)/(&PartialD;x) pho(x,y))<Pi/2],[undefined,t_atan2((&PartialD;)/(&PartialD;y) pho(x,y),(&PartialD;)/(&PartialD;x) pho(x,y))=Pi/2],[-eps sin(t_atan2((&PartialD;)/(&PartialD;y) pho(x,y),(&PartialD;)/(&PartialD;x) pho(x,y))),Pi/2<t_atan2((&PartialD;)/(&PartialD;y) pho(x,y),(&PartialD;)/(&PartialD;x) pho(x,y))]]
Finally, when W is brought into the following formula for calculation,
R:=
-M*ElementInt( test(x,y)*((1-co(x,y))*Ha+co(x,y)*Hb))
     +M*ElementInt( test(x,y)*noise)
+M*gamma*(-ElementInt( W^2*( nab(test(x,y))[i] &t nab(f(x,y))[i])))
              +ElementInt( diff(W^2,beta)/2 * ( diff(test(x,y),x)*diff(f(x,y),y)
              -diff(test(x,y),y)*diff(f(x,y),x))):
the following error message will appear.
Error: Division by zero at (1)
I mentioned a similar problem just recently, but after two days of continuous attempts, I couldn't find a solution.
Look forward to receiving a reply.......
I'm solving this equation:
eq3 := 2*lambda*(q[1]+p[1]*exp(t))*(q[2]+p[2])^2*p[1]*exp(t) = s[1]
eq4 := 2*lambda*(q[1]+p[1])^2*(q[2]+p[2]*exp(u))*p[2]*exp(u) = s[2]
solve({eq3, eq4}, {t, u})
This is what I get:
{t = ln(RootOf(-s[1]+(2*lambda*p[2]*q[1]+2*lambda*q[1]*q[2])*_Z+2*lambda*_Z^2)/((q[2]+p[2])*p[1])), u = ln(RootOf(-s[2]+(2*lambda*p[1]*q[2]+2*lambda*q[1]*q[2])*_Z+2*lambda*_Z^2)/((q[1]+p[1])*p[2]))}
I'm completely new at maple.
I can't find what _Z  and _Z^2 mean. Can anybody help? and how I can solve this _z and _Z^2
i would like to continue to work on a code which was done With CodeBuilder some years ago.
i often like to print my code to be able to read without any computer.
Problem : the print function on a worksheet with several coderegion doesn t work well.
1) Do you have some ideas to circumvet this issue ,
2) i m thinking about using a text éditor which can give a nice printing with maple. Emacs is far to much complex for me. Consequently, i havé seen that some of you have testéd Sublime text. I think that it may be a good alternative. Do you have ideas about simple text editor that i can use to edit maple code ?
thank you for your help
hi, I wonder why this output is empty because I tried to get solution below partial equation:
with(PDEtools);
pe := diff(u(t, x, y), t) = u(t, x, y) - diff(u(t, x, y), x $ 2) - diff(u(t, x, y), y $ 2) + (1 + u(t, x, y)*I)*abs(u(t, x, y))*u(t,x,y)^2;
inc := u(0, x, y) = cos(Pi*x/50) - cos(Pi*x/150)*I;
sys := [pe, inc];
pdsolve(sys);
end after this pdsolve(sys); Maple doesn't show anything
thanks in advance
When I want to generate matlab code of the following symbolic expression I got very strange result:
with(CodeGeneration);
Matlab(Sum(a(i), i = 1 .. N));
Warning, the function names {Sum, a} are not recognized in the target language
Warning, precedence for Range unspecified
Warning, cannot translate range
cg = Sum(a(i), i == (1..N));
Problem:Sum(a(i), i == (1..N));
Right matlab code should look like:
cg = sum(a);
Where can I found compete list of supported matlab built-in function? Is there any possibility how to get proper matlab code?
Is there any way how to convert more complex symbilic expressions to the Matlab???
The last several times that I've tried to use the Delete As Spam feature I've gotten an error message Error Generating Page, and the spam was not deleted. Anyone know what's happening?
I'm trying to understand what I need to do to get Maple to solve the heat equation in spherical coordinates. I'm considering a test problem: a spherical shell with inner radius 1 and outer radius 2. Boundary conditions require the temperature of the inner and outer surfaces are to always equal zero. The initial condition requires the temperature inside the shell to be -sin(pi*r).
The attached worksheet provides my attempt to solve this problem. Executing this worksheet will quickly give a general solution but this does not include the initial condition. If this is included then Maple fails to give a solution even after a 20 min wait.
Could someone offer me guidance on how to proceed?
shell.mw
I have code which contains a data structure. This data structure was defined with Types and a Table.
I would like to know which is the best manner to do to build a data structure.
Is it better to use a Table or a MultiSet ?
May you precise me the pros and the cons of the 2 solutions?
Or indicate me if you have other ways to do.
Thanks a lot for your help.
I want to sum a series by getting multiple values from a list.  Based on the list L I was trying
add(A, [m2, m3] in L)   This seem to have dissapeared from the document but the error message remains.
A := factorial(2*m2+3*m3)*c0^(1+m2+2*m3)*c2^m2*c3^m3/(factorial(1+m2+2*m3)*factorial(m2)*factorial(m3)*c1^(2*m2+3*m3+1))
"P:=3, N:=4"
4
I found this code by Kitonum 16740  https://www.mapleprimes.com/questions/138955-How-Do-I-Create-A-Variable-Number-Of-Nested-Loops-
S := {seq(0 .. N)}; l := P-1; f := proc (T) options operator, arrow; [seq(seq([op(T[j]), S[i]], i = 1 .. nops(S)), j = 1 .. nops(T))] end proc; L := (f@@l)([[]])
[[0, 0], [0, 1], [0, 2], [0, 3], [0, 4], [1, 0], [1, 1], [1, 2], [1, 3], [1, 4], [2, 0], [2, 1], [2, 2], [2, 3], [2, 4], [3, 0], [3, 1], [3, 2], [3, 3], [3, 4], [4, 0], [4, 1], [4, 2], [4, 3], [4, 4]]
nops(L)
25
NULLNULL
nops(L)
25
Instead of using add(add(A, m2 = 0 .. 4)*m3 = 0 .. 4)I would like to map m2 and m3 to the values in list L and sum them. This should give a method for having a variable number of loops
I tried variants off without success
add(A, `in`([m2, m3], L))
Error, illegal use of an object as a name
for the next higher order would need to map m2,m3, m4 to the generated list.
B := factorial(2*m2+3*m3+4*m4)*c0^(1+m2+2*m3+3*m4)*c2^m2*c3^m3*c4^m4/(factorial(1+m2+2*m3+3*m4)*factorial(m2)*factorial(m3)*factorial(m4)*c1^(2*m2+3*m3+4*m4+1))
P := 4; S := {seq(0 .. N)}; l := P-1; f := proc (T) options operator, arrow; [seq(seq([op(T[j]), S[i]], i = 1 .. nops(S)), j = 1 .. nops(T))] end proc; L := (f@@l)([[]])
[[0, 0, 0], [0, 0, 1], [0, 0, 2], [0, 0, 3], [0, 0, 4], [0, 1, 0], [0, 1, 1], [0, 1, 2], [0, 1, 3], [0, 1, 4], [0, 2, 0], [0, 2, 1], [0, 2, 2], [0, 2, 3], [0, 2, 4], [0, 3, 0], [0, 3, 1], [0, 3, 2], [0, 3, 3], [0, 3, 4], [0, 4, 0], [0, 4, 1], [0, 4, 2], [0, 4, 3], [0, 4, 4], [1, 0, 0], [1, 0, 1], [1, 0, 2], [1, 0, 3], [1, 0, 4], [1, 1, 0], [1, 1, 1], [1, 1, 2], [1, 1, 3], [1, 1, 4], [1, 2, 0], [1, 2, 1], [1, 2, 2], [1, 2, 3], [1, 2, 4], [1, 3, 0], [1, 3, 1], [1, 3, 2], [1, 3, 3], [1, 3, 4], [1, 4, 0], [1, 4, 1], [1, 4, 2], [1, 4, 3], [1, 4, 4], [2, 0, 0], [2, 0, 1], [2, 0, 2], [2, 0, 3], [2, 0, 4], [2, 1, 0], [2, 1, 1], [2, 1, 2], [2, 1, 3], [2, 1, 4], [2, 2, 0], [2, 2, 1], [2, 2, 2], [2, 2, 3], [2, 2, 4], [2, 3, 0], [2, 3, 1], [2, 3, 2], [2, 3, 3], [2, 3, 4], [2, 4, 0], [2, 4, 1], [2, 4, 2], [2, 4, 3], [2, 4, 4], [3, 0, 0], [3, 0, 1], [3, 0, 2], [3, 0, 3], [3, 0, 4], [3, 1, 0], [3, 1, 1], [3, 1, 2], [3, 1, 3], [3, 1, 4], [3, 2, 0], [3, 2, 1], [3, 2, 2], [3, 2, 3], [3, 2, 4], [3, 3, 0], [3, 3, 1], [3, 3, 2], [3, 3, 3], [3, 3, 4], [3, 4, 0], [3, 4, 1], [3, 4, 2], [3, 4, 3], [3, 4, 4], [4, 0, 0], [4, 0, 1], [4, 0, 2], [4, 0, 3], [4, 0, 4], [4, 1, 0], [4, 1, 1], [4, 1, 2], [4, 1, 3], [4, 1, 4], [4, 2, 0], [4, 2, 1], [4, 2, 2], [4, 2, 3], [4, 2, 4], [4, 3, 0], [4, 3, 1], [4, 3, 2], [4, 3, 3], [4, 3, 4], [4, 4, 0], [4, 4, 1], [4, 4, 2], [4, 4, 3], [4, 4, 4]]
nops(L)
125
Download Sum_by_mapping_to_a_list_question.mw
sum2N := proc (N::integer) local summation, i, k; summation := 0; k := 0;
for i from 0 to N do if i = 1 then k := k+1
end if; summation := (i+k)^2 end do
sum2N(10);
the result shows 121 but its not correct i think the right answer show be 2985
First 419 420 421 422 423 424 425 Last Page 421 of 2432
