all in real domain, sqrt(A)*sqrt(B) can be combined to sqrt(A*B) when both A,B are non-negative.
Is there a way in Maple to  find the conditions when sqrt(A)*sqrt(B)=sqrt(A*B) ? i.e. the conditions on A,B where this is true?
A,B will only be functions of x,y.
An example will make things clear.
expr1:=sqrt(x^2*y - 4)*sqrt(x^2*y);
expr2:=sqrt(  (x^2*y - 4)*(x^2*y));
By looking at the above, we see that expr1 = expr2 when  x^2*y-4>=0 and x>0 or x^2*y-4>=0 and x<0. Actually I think only x^2*y-4>=0 is needed, since x is being squared anyway.
How to make Maple show this? I can't get Maple to show this
solve(expr1=expr2,[x,y]) assuming real;
But this is wrong. it says it is true for all x and all y?.   Mathematica can do it using Reduce command
I know I can force the combination by using the command
combine(expr1,sqrt,symbolic);
ps. Maple took the x outside the sqrt. So x>0 is assumed here.
pps. I do not understand why simplify(expr1,symbolic) did not work here, and neither  simplify(expr1,symbolic,size=false) worked. Only combine worked.
But I wanted to see if Maple could tell the condition when this is allowed, so I can write these down.
It would be nice if the command above would also tell the conditions under which it combined the sqrts. But this information is not given.
This is all done non-interactive in a program without being able to look at the screen and decide what to do. Only thing I know is that if an expression has sqrts and functions of x,y.
Is there a way in Maple to have tell conditions when expr1=expr2?
Maple 2020.2
 I installed maple calculator on iphone. I have problem with function x=y^2.
the arms of the chart should point to the right, not up
Other calculators like Graph Calculator showing in proper way generated chart/plot. But on maple I have problem - what I’m doing wrong.. I spent a lot of time to find answer but without success.
The result below surprises me.
Why does  rgf_findrecur return a result instead of saying that there is no homogeneous linear recurrence of order 1?
interface(version)
Standard Worksheet Interface, Maple 2015.2, Mac OS X, December 21 2015 Build ID 1097895
genfunc:-rgf_findrecur(1, [1, 2, 3, 4], t, n);
                       t(n) = 2 t(n - 1)
PS: maybe this was a problem in Maple 2015, if it has been corrected since just let me know
By using equation x^2+y^2=4 for cylinder and plane z=0 and the plane z=3-x, plot the solid.
I would like to split the expression 1 / (x²+i)² into partial fractions, but Maple (2020) doesn't seem to know:
convert(1/(z^2+I)^2, parfrac, z);
How do i fix this?
I wanna shade/fill different areas in a single graph and provide a legend for the graph. Areas are defined as follows where 0<=x<=1 and 0<=z<=1.
(label = c1) \quad if 0<x<1/13*(5-2sqrt(3)),0<z<1/2(2x+x^2)+1/2sqrt(4x^3+x^4)
(label = c2) \quad if 0<x<1/13*(5-2sqrt(3)),1/2(2x+x^2)+1/2sqrt(4x^3+x^4)<z<2x
I am trying solve on the outout of odetest, in order to determine range of which x makes this output zero.
It works sometimes and  does not work another times. I mean, it gives correct domain something, and other times, it overlooks some domain.
Here is an example
ode:=x*diff(y(x),x)*y(x) = (y(x)^2-9)^(1/2):
ic:=y(exp(4)) = 5:
sol:=dsolve([ode,ic],y(x)):
res:=odetest(sol,ode);
solve(simplify(res),x,allsolutions = true) assuming real;
It is true than when x=1, then is zero.  But so all values x>1 as well.
How to get solve to find those values as well and not just x=1?
I tried PDEtools:-Solve as well. It did not better
PDEtools:-Solve(simplify(res),x,allsolutions = true) assuming real;
Compare to Mathematica
Are there other commands in Maple which could obtain all the solutions like in the above?
Maple 2020.2 on windows 10
My problem is a hickup in the Maple 2020 version as compared to earlier versions :
In the Maple 2020 listtorec from package gfun asks for unknown value u(0) in recognition of series.
Example from the Maple help page:
with(gfun);
l := [1, 1, 2, 5, 14, 42, 132, 429, 1430, 4862, 16796, 58786];
rec := listtorec(l, u(n));
Error, (in gfun:-listtorec) invalid unknown function, u(0)
This error also happens with the second example in the Maple help page:
rec2 := seriestorec(series(add(l[i]*x^(i - 1)*(i - 1)!, i = 1 .. nops(l)), x, 12), u(n), ['egf']);
Error, (in gfun:-seriestorec) invalid unknown function, u(0)
How to feed this unknown value in the  call?
I have the following piece of code:
beta := 16250.25391;
tlow := 11.92817468;
y0 := t -> 1/4*4^(7/8)/(beta*(tlow - t))^(1/8);
r0 := 1;
r2 := 1.194444444;
r3 := -2.071877530;
dyr := t -> M*(-2*r0*diff(y0(t), t)/y0(t)^3 + 2*r2*y0(t)*diff(y0(t), t) + 4*r3*y0(t)^3*diff(y0(t), t));
plot(dyr(t))
Everything seems to work out fine until this point and I obtain a good plot. The problem occurs when I try calling the value of dyr at a specific point t. Here is an example:
dyr(5)
Error, (in dyr) invalid input: diff received 5, which is not valid for its 2nd argument
I understand there is something wrong with the diff part. I tried writing the following simple code and I have the same problem.
y := t -> t^2
z := t -> diff(y(t), t)
z(1);
Error, (in z) invalid input: diff received 1, which is not valid for its 2nd argument
I start with a function that has only one argument and it seems like introducing the diff requires that I use two arguments. y0 is a function of t solely and I would like dyr to have the same argument, so that I can call dyr(t) at any point t I want. Please take a look at this. Thanks in advance.
I can't figure exactly why adding export on module wide variable when using option package makes the variable not writable from a function inside the module
dsolver :=module()
option package;
export X::boolean := true;
export foo:=proc()
   dsolver:-X :=false;
end module;
dsolver:-foo();
Error, (in foo) attempting to assign to `X` which is protected.  Try declaring `local X`; see ?protect for details.
But this works
dsolver :=module()
export foo:=proc()
   dsolver:X :=false;
end module;
dsolver:-foo();
    false;
I wanted to make the variable export, so it can be set from anywhere (by other modules for example, directly). if I make it local, then other modules can no longer access it?
I know I can change the export to local as the error says. But why is this needed? Only thing I found so far, is this
"Not all modules are packages. Package semantics differ from module semantics in two ways. First, (module-based) package exports are automatically protected. Second, packages can be used as the first argument to"
So the above says function inside module, can't change module wide variable, if this variable is exprted, when using option package? Why?
In general, I am still not sure when to use option package or not.
Are there any general rules as to when one needs to add option package vs. Not using this option? i.e. just use module() without this option? or the question is: When must one use option package?
I put everything (all modules) eventually in an .mla file and both cases work the same in this respect, so not sure when to use this option now.
Hello everyone;
There is itterative scheme and i have written a code. I want to know time and bytes used in each itteration. I have used the command "Usage" and code is showning results which are not right i thin becasue momery used should increase with itterations i.e., computaion is increasing so. CPU time is alos a issue here in my code.
Note: Code is also uploaded.
The code
S:=sum(1/x__i,i=1..5)
will give us the following ouput
Why not
S:=add(1/x__i,i=1..5)
 also give same result. why?How to do?
I also note that:
S:=add(1/x||i,i=1..5)
S:=sum(1/x||i,i=1..5)
Hey everyone,
f_1 and f_2  are satisfying the set of non-linear integral equations I have attached to this message.
I know that I need to solve them numerically by iterations. Probably, the first guest of the function f_1 and f_2  is the driving term. a is just a parameter which can be fixed (I guess smaller than \pi/4). * is the convolution product and k is the momentum space parameter. I learnt that in order to solve them I should solve them in the Fourier space. I know also that I need to discretize these function in the “real ” space between {-L,+L} before applying the FFT or one of its relatives. Thank you for any suggestions or leads.
Hi to all community. I am trying to integrate a lengthy-expression but could not get the result after waiting of 1 and 2 hours even. is there any way to control such integration
Integration_Help.mw
This is the context
A mathematical expression f has been coded by a two stage process of the form
(u and s are character strings)
I do not know what f is, but I know what P1, P2 are and I know s too.
I would like to recover f.
Here is the particular couple of coding processes that I consider
f := sqrt(x);    # assumed to be unknown
u  := sprintf("%Zm", f);                     # "process" P1
s  := StringTools:-Encode(u,':-base64');     # "process" P2
# The "inverse" of P2 is
v := StringTools:-Decode( s, 'encoding' = ':-base64' );
# Does it exist an operation to recover f from v?
First 462 463 464 465 466 467 468 Last Page 464 of 2432
