Hello again
I need to find the position of the elements of one list in another list.  Here it is a simple example
L1:=[837, 526, 283, 216, 93, 512, 161, 202, 76, 851, 503, 437, 147, 36, 922];
L2:=[526, 283, 202, 437, 922, 865, 879, 804, 473, 325];
remove(has,map(x->ListTools:-Search(x,L1),L2),0)
the position of the elements in list L1 is [2, 3, 8, 12, 15].
For huge lists, this solution is not efficient.  Can that be done faster and less memory demanding? (Threads or Grid safe?).
Many thanks.
Ed
I am creating a largish package (i.e., for use by others with the “with” command).
Most of the exported procedures have some derivations associated with the code.  This is at least a partial reason for using Maple.  So, I had organized a worksheet so that each exported procedure has its own section that included pre-coding derivations, the procedure, and some post-coding validation of the code (serious testing is done elsewhere).  At the end of the worksheet I had a section that built the module and saved it to the appropriate library.  If I execute the worksheet it runs through everything and builds a new version of the library containing the package.
Getting these exported procedures to bind to a local helper procedure that is shared among several exported procedures was a bit tricky.  The way I ended up doing it is illustrated in the attached worksheet.
From a life cycle perspective is there a better way to think about this?
with(InertForm)
[Display, FromMathContainer, MakeInert, NoSimpl, Parse, SameStructure, ToMathContainer, ToMathML, Typeset, Value]
DistWorkSheet := proc (A, B) F(A[1]-B[1])+F(A[2]-B[2]) end proc
"Test:=module()"
"  export Dist"
_local(Sqr)
"  option package;"
Sqr := proc (A) A*A end proc
Dist := eval(subs(F = eval(Sqr), eval(DistWorkSheet)))
"end module"
_m2052587788544
eval(Test:-Dist)
proc (A, B) (proc (A) A*A end proc)(A[1]-B[1])+(proc (A) A*A end proc)(A[2]-B[2]) end proc
Test:-Dist([0, 0], [1, 1])
Download PackageBuild.mw
Given some expression, I want to replace each exp(.....) in it with something else.
This is what I currently do. First I find all the exp() terms, then using a loop and use subs  like this
expr:=1/exp(z)*arcsinh(x*exp(C[1]))+x*sin(exp(x))+3*exp(C[1]*y)*sqrt(sin(exp(3*h)));
#find all exp terms
s:=select(x->has(x,exp),indets(expr));
s:=select(x->op(0,x)='exp',s)
Now, lets says I want to replace each with Z
I tried to use but that did not work.
So now I am doing this
for item in s do
    expr:=subs(item=Z,expr);
expr
is it possible do this without a loop? could not do it using ~
With map, I can do this map(x->subs(x=Z,expr),s) but this does not replace it inside expr where I want.
Assignment is not allowed inside the above so I can not do  this map(x->expr:=subs(x=Z,expr),s)
And if I do expr:=map(x->subs(x=Z,expr),s)  it does not work either. it gives
How to do the replacement without using a do loop?
I have the following question, plot the graph of mu=5*log_10(D_L/10) where D_L=(c/H_0)*\int_0^z dz'/[A(1+z')^4+B(1+z)^3+C]^{1/2} with resepct to z, where A,B,C are numerical values given beforehand, and c is the speed of light and H_0 is the current Hubble constant.
Can someone please help with this simple plotting assignment.
Thanks, just by experience, can I learnt these syntax languages.
Peace out!
Might anyone be able to tell me what I am doing wrong trying to solve for this ODE?
Thanks so much!
thoughts_about_cost_functions.mw
Hi there,
Can someone explain to me why is it happening? If smaller equal than coloured well, if smaller then just the equal line appears. Why?
dm1 := .23; pm12 := .7; dm12 := .23;
inequal(pm1*(dm12+am21)-pm12*(dm1+am21) <= 0, pm1 = 0 .. 1, am21 = 0 .. 1, color = "Nautical 1");
inequal(pm1*(dm12+am21)-pm12*(dm1+am21) < 0, pm1 = 0 .. 1, am21 = 0 .. 1, color = "Nautical 1")
PDEtools[declare](f(x), prime = x);
N := 4;
f(x) :=  sum(p^i*f[i](x), i = 0..N):
HPMEq := (1 - p)*diff(f(x), x $ 3) + p*(diff(f(x), x $ 3) + 1/2*diff(f(x), x, x)*f(x));
for i from 0 to N do
    equ[1][i] := coeff(HPMEq, p, i) = 0;
cond[1][0] := f[0](0) = 0, D(f[0])(0) = 0, D(f[0])(5) = 1
for j to N do
    cond[1][j] := f[j](0) = 0, D(f[j])(0) = 0, D(f[j])(5) = 0;
end do
    dsolve({cond[1][i], equ[1][i]}, f[i](x));
    f[i](x) := rhs(%);
f(x) := evalf(simplify(sum(f[n](x), n = 0 .. N)))
convert(f(x), 'rational')
subs(x = 2.4, diff(f(x), x))
How to sort a matrix based on one particular column in that matrix
Matrix ([[21,30],[8,4]]).  Has to sorted on column one only and output. Matrix ([[8,4],[21,30]]). In this I have given only 2×2  it could be a n×n
Without too much code
Is it  possible to draw an ellipse inscribled in a given triangle and we know its orthoptist circle ? Thank you very much.
Prime_Derivative_Notation_for_Explicit_X_Values.mwPrime_Derivative_Notation_for_Explicit_X_Values.mw
## I hope this works. I can't seem to paste my MW file in this window in a readable format.
This is the Maple code
result:=int(1/tanh(u),u)
simplify(result,size) ;
simplify(result,symbolic);
simplify(result,ln);
simplify(result,trig);
Any suggestions?
How to find a rational function with give horizontal asymptotes: y=0.7, y=-0.7 and vertical asymptotes: x=0.001, x=-0.001?
I have a list with a large number of elements and I need to partition it in chunks of a specific size.  Here is my attempt
listpart := proc(cond::list,nchunk::nonnegint:=1000)
if numelems(cond) < nchunk then
	newcond:=[cond]:
	ss:=[`$`(1..numelems(cond))]:
	sss:=map(`mod`,ss,nchunk):
	ind:=[ListTools:-SearchAll(0,sss)]:
	ind:=[0,op(ind),ifelse(ss[numelems(ss)]=ind[numelems(ind)],[],ss[numelems(ss)])]:
	newcond:=[Threads:-Seq(cond[(ind[j]+1)..ind[j+1]],j=1..(numelems(ind)-1))];
end if:
return(newcond):
It does not run as fast as I thought.  I am not even sure if Threads:-Seq could be used in this case.  Please tell me what I am doing wrong and how I can modify the code to get a faster response.
Many thanks
Ed
Hello all
could anyone tell how to solve following nonliner equations numerically.
f '''' - c1(g'') + R(f ' f '' - f f ''' )=0
g'' + c2(f '' -2g) -c3(f g' - f ' g)=0
f ' (-1)=0,   f ' (1)=0,   f(-1)=1-A, F(1) =1, g(-1)=0, g(1)=0
c1=3.2, c2=3.3, c3=3.4, R= -10 and A=1.6 are constants.
please help to find solution  numerically and how to plot.
Thanks in advence
I am trying to calculate an integral involving dirac delta as given below
int(Dirac(sin(x)),x=-3/2*Pi..3/2*Pi)
However, Maple returns the integral unevaluated as
How can I get it evaluated? the result should be 3 here.
First 541 542 543 544 545 546 547 Last Page 543 of 2433
