I wanted to create an Array() to store only objects of specific type in it.
Array() supports the datatype=value  telling it the type of elements to store. But when I try to create an Array() using datatype of the class, it fails. I must be doing something wrong. Here is an example
module solution_class()
      option object;
      local sol::anything;
end module;
sol:=Object(solution_class); #create an object
Now the following works:
A:=Array();
A(1):=sol;
But I wanted to do
A:=Array(datatype=solution_class);
A(1) := sol;
 Error, unable to store '0' when datatype=module solution_class () local sol::anything; option object; end module
Help says
And this is the case here, because type(sol,solution_class)  gives true
So 'solution_class' is valid type name.
Where is my error?
Dear maple users,
Greetings.
Q1.How to plot a figure for different values of M?
      like M=1,2,3,4:
Code:Mplot.mw
Q2. How to assign all the expressions are "remember table assignment"
Hi:
what is the value of this expression(eq) in Maple:
eq:=(x+I*y)^2-4*exp(I*x*y)
tnx...
I try import a big Excel file with the first row as column labels for performing statistical etc.
I use this command :
data := Import(FileTools:-JoinPath(["d:", "directory", "subset2.xlsx"], platform = "windows"))
i need a dataframe for performing statistical with column label as first row, but i have this error :
Error, (in Import) invalid input: MatrixToDataFrame uses a 3rd argument, columns, which is missing
I can not understand what is this error...so, what i can do ?
Thanks, regards
Trying to use Curl tutorial when doing vector calculus
when I enter F:=VectorField(⟨y,-x,0⟩); it tells me unknown operator.
with(VectorCalculus);
SetCoordinates('cartesian'[x, y, z]);
                       cartesian[x, y, z]
Error, unknown operator
Typesetting:-mambiguous(FAssignVectorFieldApplyFunction(acirc
  Typesetting:-mambiguous(?,
  Typesetting:-merror("unknown operator"))umlycommauminus0xcomma0
  acirc?copy))
I am having problems with VectorCalculus[Norm] with argument passing.
In certain cases I get the error message:
     "Error, (in VectorCalculus:-GetCoordinates) the first argument, when present, must be a Vector"
In all cases, the first argument IS a vector.
Here is the case I need to succeed:
VectorCalculus[Norm](DeleteRow(Vector[column](5, [x, y, z, w, 1]), RowDimension(Vector[column](5, [x, y, z, w, 1]))))
or more completely:
here is the test Document with several cases of the problem explored:
Failure_on_Calculus_Verctor_Norm.mw
Background.  Calculus Vector Norm doesn't know about Homogenous systems so it inculdes an unwanted term in its norm.  Trimming off the last row of the vector fixes this problem.
(Note: as I am new, so if there is an existing cononical notation that will take care of that without further ado, then I could leave CalculusVector[Norm] to its own devices and move on.
Also, if I knew how to peek at the underside of such gotchas, I might have been able to sort it out myself.  Any leads in this direction would be taken to heart.  Thanks)
 I want to find AutomorphismGroup  of star S4 (ie, K1,3).
with(GraphTheory):
with(GroupTheory):
with(SpecialGraphs):
S4:=CompleteGraph(1,3);
G1 := AutomorphismGroup(S4); # out is GroupTheory:-PermutationGroup({module() ... end module,module() ... end module},degree=4)
the S_4 has six automorphisms: (1, 2, 3), (1, 3, 2), (2, 1, 3), (2, 3, 1), (3, 1, 2,), (3, 2, 1):
GraphAutomorphismStar
For the output of maple ,I cannot understand.
Maybe I don’t understand the group enough. May somebody explain in detail,  Thanks!
There is a whole chapter in programming guide on OO in Maple.
How much is OO actually used by Maple programmers? Is OO used much internally at Maplesoft itself in implementing internal code? I do not see questions about OO in Maple in the forum. May be it has not taken off?
Any one knows of packages in Maple written in OO style, using the Object module? I think OO was added in Maple 16, which is 2012?
p.s. I myself like OO programming. Done alot of it in Java. I think it can be useful for large applications.
Hi I have product of function Q along with its derivative.
Q'j(x)*Qi(x) for j=0,1 and i=0,...n.
how can i make loop  to collect all coefficeints for this function for j=0,1 and i=0,1,..n.
i hope some one will help me.
Hello, i'm a newbie in maple. I need to simulate the movement of the conical pendulum.
The equations of motion  https://www.cyberforum.ru/cgi-bin/latex.cgi?\ddot{\theta }=cos\theta sin\theta {\dot{\varphi }}^2-\frac{gsin\theta}{l} and https://www.cyberforum.ru/cgi-bin/latex.cgi?\ddot{\varphi }=-\frac{2cos\theta \dot{\varphi }\dot{\theta }}{sin\theta }
I include a link to a description of the conical pendulum.http://olewitthansen.dk/Physics/Conical_pendulum.pdf
Thanks in advance!
How can I find the RMS of a function like x(t) in maple? the help is not clear
x(t) := -3.703703704*10^(-7)*(0.000111668023*cos(1000/33*sqrt(1122)*t) - 0.0001214712007*sin(1000/33*sqrt(1122)*t) - 0.0002325581396*sqrt(561)*sqrt(2)*(-0.0004467462845*sqrt(1122)*sin(1000/33*sqrt(1122)*t) + 0.0004467462845*sqrt(1122)*cos(1000/33*sqrt(1122)*t)))/((2.074226433*10^14*cos(1000/33*sqrt(1122)*t) + 2.074226433*10^14*sin(1000/33*sqrt(1122)*t))*(4.895037587*10^(-11) + 0.01685634229*(0.00001474262739*cos(1000/33*sqrt(1122)*t) + 0.00001474262739*sin(1000/33*sqrt(1122)*t))^2)^2);
Baharm31
Sorry, I have not used Maple for a long time...
I would like to know the derivative of Jy w.r.t. py1 in the following. I expect the answer to be 2 Wy6 py1-2 Wy6 py10 but I get 0. Am I not using the subscripts properly that Maple is not understanding me?
J__y := (1/2)[W__y1(a[c]^y-(diff(S[1](t), t, t))^y)^2+W__y2((diff(S[1](t), t))^y)^2+W__y3(S[1]^y)^2+W__y4(`#mscripts(mi("φ",fontstyle = "normal"),mi("c"),none(),none(),mo("."),none(),none())`-`#mscripts(mi("φ",fontstyle = "normal"),mi("S"),none(),none(),mo("."),none(),none())`)^2+W__y5(`φ__S`)^2+W__y6(p__y1-p__y10)^2+W__y7(p__y2-p__y20)^2+W__y8(p__y3-p__y30)^2+W__y9(p__y4-p__y40)^2]
(1/2)[W__y1(a[c]^y-(diff(diff(S[1](t), t), t))^y)^2+W__y2((diff(S[1](t), t))^y)^2+W__y3(S[1]^y)^2+W__y4(`#mscripts(mi("φ",fontstyle = "normal"),mi("c"),none(),none(),mo("."),none(),none())`-`#mscripts(mi("φ",fontstyle = "normal"),mi("S"),none(),none(),mo("."),none(),none())`)^2+W__y5(phi__S)^2+W__y6(p__y1-p__y10)^2+W__y7(p__y2-p__y20)^2+W__y8(p__y3-p__y30)^2+W__y9(p__y4-p__y40)^2]
diff(p[y*i](t), t) := K[yp*i](p[y*i]-p[y0*i])-K[py*i]*(diff(Jy, p[y*i]))
Diff(J__y, p__y1)
Diff((1/2)[W__y1(a[c]^y-(diff(diff(S[1](t), t), t))^y)^2+W__y2((diff(S[1](t), t))^y)^2+W__y3(S[1]^y)^2+W__y4(`#mscripts(mi("φ",fontstyle = "normal"),mi("c"),none(),none(),mo("."),none(),none())`-`#mscripts(mi("φ",fontstyle = "normal"),mi("S"),none(),none(),mo("."),none(),none())`)^2+W__y5(phi__S)^2+W__y6(p__y1-p__y10)^2+W__y7(p__y2-p__y20)^2+W__y8(p__y3-p__y30)^2+W__y9(p__y4-p__y40)^2], p__y1)
Download cost_function_partial_derivative.mw
f1 := 0.001;
f2 := 0.002;
c1 := 0.002;
c2 := 0.005;
w1 := 0.1;
W := 0.14;
p1 := 0.65;
p2 := 0.28;
p := 1.167;
r := 0.004;
alpha := 0.2;
ze := 0.14;
mu := 0.05;
ga := 0.01;
cp := 9.3;
Rp := 100;
sigma2 := 0;
l[1] := 3*W^2*(-1+W^2)/(4*(-1+4*W^2));
l[2] := Rp^2*w1^2*mu*ga*cp/(2*(Rp^2*w1^2*cp^2+1));
l[3] := (Rp.w1.mu.ga)/(2*(Rp^2*w1^2*cp^2+1));
l[4] := W*(-1-7*W^2+8*W^4)/(8*(-2+8*W^2));
eq1 := (-x*t+l[2]*x+l[1]*x*y^2+(3/2)*alpha*ze^2*x)^2+((1/2)*c1*x+l[3]*x)^2-(1/4)*f1^2;
eq2 := (-l[4]*y^3+l[1]*x^2*y)^2+(1/4)*y^2*c2^2-f2^2/(4*W^2);
I need to solve these two equation for the variable x and y in terms of  t because I want to plot x with a range for t
and the same plot y with a range for t and if it is possible to plot x vs y for the previuos same range for t
ode.mw
I found an assignment question concerning an ODE from 20 years ago. This was before I had discovered Maple.
So I put it through Maple and got a complex solution, But the lecturer's solution was non-imaginary.
For a) gamma <> Beta and b) gamma = beta.
Actually for b) I couldn't follow his solution
Consider
L := [1,2,3,4];
x[j];
seq(%, x[j] in L);
x[j];
What would you expect the output of the last line to be?
Answer:   Maple says 4.   Why?
First 546 547 548 549 550 551 552 Last Page 548 of 2433
