Does anyone know how to open .mm file in Maple, as well as using the program or function in .mm file in Maple? Many thanks.
Hello colleagues,
I would like to get a suggestion on how to utilize an existing `simplify` function or to define an operator, which allows the following simplification:
O(x^n)/x = O(x^(n - 1))
— Alexander
I need to test a huge amount of subsets and for doing that I was thinking of using combinat:-subset, since it avoids allocating memory for all subsets.  The problem with subset for my specific application is that it generates sets with all possible sizes and I just need subsets with a chosen number of elements.  Can that be done in maple?
Many thanks
Ed
I have a plot of points in a graphical plot on the domain (x,y).  At each point xi (i=1..N) , there is a numerical value yi = S(xi) from which I plot a series of points (xi, S(xi)) in the (x,y) domain.
Each point (xi,yi) represents a transient plot of two variables u(x,t) and v(x,t) in a plot file.  Is it possible to define a graph of the points (xi, S(xi)), such that clicking on any such point in the graph opens up a graphical file which is parameterised by (xi, S(xi))?
Would welcome help on this...
Melvin
when running a for do cycle the first two solutions are exact the same numbers, which is not correct. Can someone plesa help me fix this problem?
Thanks a lot.
tmin:=10: #°C
tmax:=70: #°C
Tmin:=tmin+273.15:
Tmax:=tmax+273.15:
T:='T':
i:=0:
for T from Tmin by 2 to Tmax+1.25 do
i:=i+1:
a12:=2305.28444347652 - 9.14490843016421*T + 0.00680052257590234*T^2:
a21:=-6665.24838284836 + 46.0897018087247*T - 0.0694991633494123*T^2:
alfa:=0.3:
x2:=1-x1:
lng1:=x2^2*(tau21*(G21/(x1+x2*G21))^2+tau12*(G12/((x2+x1*G12)^2))):
lng2:=x1^2*(tau12*(G12/(x2+x1*G12))^2+tau21*(G21/((x1+x2*G21)^2))):
G12:=exp(-alfa*tau12):
G21:=exp(-alfa*tau21):
tau12:=a12/T:
tau21:=a21/T:
lnga1:=subs(x1=xa1,lng1):
lngb1:=subs(x1=xb1,lng1):
lnga2:=subs(x1=xa1,lng2):
lngb2:=subs(x1=xb1,lng2):
r1:=lnga1+ln(xa1)=lngb1+ln(xb1):
r2:=lnga2+ln(1-xa1)=lngb2+ln(1-xb1):
r:=fsolve({r1,r2},{xa1=0..0.22,xb1=0.22..1}):
assign(r):
xA1[i]:=xa1: xB1[i]:=xb1:
print(i,T,xA1[i],xB1[i]);
unassign('r1','r2','r','xa1','xb1'):
1, 283.15, 0.4086195757e-1, .7650860222
2, 285.15, 0.4086195757e-1, .7650860222
3, 287.15, 0.4109304612e-1, .7564109743
4, 289.15, 0.4094687104e-1, .7455613500
5, 291.15, 0.4092946881e-1, .7345259571
6, 293.15, 0.4103899093e-1, .7233142804
7, 295.15, 0.4127502108e-1, .7119337099
8, 297.15, 0.4163857511e-1, .7003892047
9, 299.15, 0.4213210541e-1, .6886831535
10, 301.15, 0.4275956094e-1, .6768151230
11, 303.15, 0.4352648605e-1, .6647816285
12, 305.15, 0.4444014482e-1, .6525760020
13, 307.15, 0.4550971743e-1, .6401880864
14, 309.15, 0.4674655982e-1, .6276039487
15, 311.15, 0.4816452203e-1, .6148056135
16, 313.15, 0.4978038925e-1, .6017705621
17, 315.15, 0.5161445760e-1, .5884711603
18, 317.15, 0.5369126350e-1, .5748739966
19, 319.15, 0.5604059678e-1, .5609387793
20, 321.15, 0.5869882131e-1, .5466171048
21, 323.15, 0.6171072215e-1, .5318505354
22, 325.15, 0.6513208559e-1, .5165679944
23, 327.15, 0.6903339246e-1, .5006820935
24, 329.15, 0.7350533414e-1, .4840835134
25, 331.15, 0.7866732744e-1, .4666324128
26, 333.15, 0.8468127263e-1, .4481446382
27, 335.15, 0.9177527543e-1, .4283678555
28, 337.15, .1002878317, .4069372077
29, 339.15, .1107594115, .3832836608
30, 341.15, .1241550103, .3564111567
31, 343.15, .1425634130, .3241972432
Download lle.mw
lle.mw
Dear MaplePrimes community,
I am currently struggling to use the simplify-command in my toolbox for symbolic generation of robot dynamics.
I created a procedure which calls the simplify command with some extra checks. There are symbolic expressions in the term to be simplified that also occur in the workspace of the worksheet calling the procedure.
The simplify command (called from within the procedure) shall regard them as symbolic expressions unaware of the content of the variable in the workspace. Nevertheless, the simplifications are performed with the global variables, even though they are declared local to the procedure.
Minimal example: The variable "l1" stands for "length 1" in a mechanic problem as well as "length of the expression"
with(LinearAlgebra): with(ArrayTools): with(codegen): with(CodeGeneration): with(StringTools):
read proc_simplify2:
T := m2*(l1+l2)*(qD2)^2: # dummy-expression for kinetic energy
l1 := length(T);
T_simpl := simplify2(T):
l2 := length(T_simpl);
Code for the file proc_simplify2:
simplify2 := proc (Term)
  # Simplify a term. Additionally check if the simplification is advantageous.
  # In some cases the term gets longer after the simplification. Then discard.
  # Give the local procedure variable a long name. They must not be identical in Term.
  local simplify_tmpvar_c1, simplify_tmpvar_c1sum, simplify_tmpvar_c2, \
        simplify_tmpvar_c2sum, simplify_tmpvar_nms, simplify_tmpvar_k, Term2:
  # Assume all contents of the Term to be local variables to this procedure
  # Otherwise, variables like "l1" can be overwritten by occurences in the calling worksheet.
  simplify_tmpvar_nms:=convert(indets(Term,name),list): # get list of symbols
  for simplify_tmpvar_k from 1 to ColumnDimension(simplify_tmpvar_nms) do
    if simplify_tmpvar_nms[simplify_tmpvar_k] = Pi or simplify_tmpvar_nms[simplify_tmpvar_k] = 0 then
      next: # 0 and Pi can not be variables
    end if:
    eval(sprintf("local %s;", String(simplify_tmpvar_nms[simplify_tmpvar_k]))); # assume local
  # Get computational effort before simplification
  simplify_tmpvar_c1:=add(cost~(Term)):
  simplify_tmpvar_c1sum := diff(simplify_tmpvar_c1,functions)+ \
                           diff(simplify_tmpvar_c1,additions)+ \
                           diff(simplify_tmpvar_c1,multiplications)+\
                           diff(simplify_tmpvar_c1,divisions):
  # Perform simplification. Attention: tries to use global variables to simplify the expression (see above)
  Term2 := simplify(Term):
  # Get effort after simplification
  simplify_tmpvar_c2:=add(cost~(Term2)):
  simplify_tmpvar_c2sum := diff(simplify_tmpvar_c2,functions)+\
                           diff(simplify_tmpvar_c2,additions)+\
                           diff(simplify_tmpvar_c2,multiplications)+\
                           diff(simplify_tmpvar_c2,divisions):
  if simplify_tmpvar_c2sum > simplify_tmpvar_c1sum then
    # The simplification was not successful. Take old version.
    Term2 := Term:
  end if:
  return Term2:
I would be glad for suggestions how to define the symbolic expressions in Term as local to the procedure or perhaps a better way to perform simplifications. As my program extends over several worksheets and the user may define an input file, I would not like to have to control all names of temporary variables that may occur at some point in the project. Until I tried to use the simplify-command, there was no problem regarding variable names. Is it perhaps possible that the variables are now only declared local in the for loop and not in the procedure?
Why
evalf(evalf(''Pi''))
Produces
But
evalf(''Pi''):
evalf(%)
Produces
      3.141592654
How do I calculate the derivative of the function f(x)=( (x^3) / (2) ) - 5x + 2 and plot the function and it's derivative on the same graph.
I am newcommer in Maple. I am using Maple 2019. Just a simple question;
solve(x^2-3*x+4=0, x);
gives
1.50000000000000 + (9.09238836013723*10^(-59))*I, 1.50000000000000 - (9.09238836013723*10^(-59))*I
instead I need to show in the forms of radiacal. I have also the problem in dsolve command;
dsolve(2*diff(y(x),x$2)+3*diff(y(x),x)+4*y(x),y(x));
with the result
y(x) = (2.73949338633639*10^(-116) + (2.73949338633639*10^(-116))*I)*_C1 + (1. + (2.73949338633639*10^(-116))*I)*_C2
Thanks indeed in advance
Sayed
Considering the follwoing expr:
A(x):=mue+(mun/gama)+(u0^2)-mud*x-mue*exp(x)-(mun/gama)*exp(gama*x)-(u0^2)*(1-2*x/u0^2)^(1/2);
where
mue:=1/(1+alpha+beta);
mun:=alpha/(1+alpha+beta);
mud:=beta/(1+alpha+beta);
u0:=(mue+mun*gama)^(-1/2);
 and assuming the values of alpha and beta lie between 0.1..0.6 and gama=15 ro 20.
How do I determine those values of (alpha,beta,gama) satisfying conditions [(3), (4)], [(3), (5)] or [(3),(6)]?
conditions:
A(x[m] <> 0) = 0:
where x_m is an extreme point of A(x) (other than x=0),
d*A(x)/dx, x = x[m] < 0:
d*A(x)/dx, x = x[m] > 0:
d*A(x)/dx, x = x[m] = 0:
Can anyone please help me out with the following integration
                      f(x) = tanh(x)/sqrt(x^2+1)
limits x_initial =1, x_final =100
Does it exist a way to get all the types a variable verifies?
For instance
x:=4;
type(x, t); # true for t in {positive, posint, algebraic, ...}
How do I simplify the following polynomial:
 -(729 beta (1/2 (-1/9 (-5/27 beta-1/9) lambda^6-1/9 (1/9 beta^2 TT+(10/9 TE+2/3 TT) beta-1/9 TE) lambda^4+5/27 (2/5 TT (3/2 TT+TE) beta+TE (TE-2/5 TT)) beta lambda^2-1/9 TE beta^2 TT (-TT+TE)) p1(m,t)^2+(beta TT-1/3 lambda^2)^2 (-1/3 lambda^2+TE)^3 ((p2(m,t))/(lambda^2-3 TE)+3/2 ((lambda^2+TE) p1(m,t)^2)/((lambda^2-3 TE)^3))))/((3 beta TT-lambda^2)^3 (3 TE-lambda^2)^2),
as follows:
-3*beta*p2(m,t)/(lambda^2-3*beta*TT)+3*beta^2*(5*lambda^2-3*beta*TT)*p1(m,t)^2/(2*(lambda^2-3*beta*TT)^3)
solve({l*(2*l^2*lambda^4*sigma*w*a[2]+l^2*lambda^2*mu*w*b[1]+6*l*lambda^2*m*sigma*a[0]^2-6*l*lambda^2*m*b[1]^2+6*l*m*mu^2*a[0]^2-l*lambda^2*rho*sigma*a[0]-l*mu^2*rho*a[0]+4*lambda^2*sigma*w*a[0]+4*mu^2*w*a[0]) = 0, l*(2*l^2*lambda^3*sigma*w*a[1]+6*l^2*lambda^2*mu*w*b[2]+2*l^2*lambda*mu^2*w*a[1]+12*l*lambda^2*m*sigma*a[0]*a[1]-12*l*lambda^2*m*b[1]*b[2]-l*lambda^2*rho*sigma*a[1]+12*l*m*mu^2*a[0]*a[1]-l*mu^2*rho*a[1]+4*lambda^2*sigma*w*a[1]+4*mu^2*w*a[1]) = 0, l*(5*l^2*lambda^3*sigma*w*b[2]-3*l^2*lambda^2*mu*sigma*w*a[1]-7*l^2*lambda*mu^2*w*b[2]-3*l^2*mu^3*w*a[1]+12*l*lambda^2*m*sigma*a[0]*b[2]+12*l*lambda^2*m*sigma*a[1]*b[1]-l*lambda^2*rho*sigma*b[2]+24*l*lambda*m*mu*b[1]*b[2]+12*l*m*mu^2*a[0]*b[2]+12*l*m*mu^2*a[1]*b[1]-l*mu^2*rho*b[2]+4*lambda^2*sigma*w*b[2]+4*mu^2*w*b[2]) = 0, l*(8*l^2*lambda^3*sigma*w*a[2]+6*l^2*lambda*mu^2*w*a[2]+12*l*lambda^2*m*sigma*a[0]*a[2]+6*l*lambda^2*m*sigma*a[1]^2+l^2*lambda*mu*w*b[1]-6*l*lambda^2*m*b[2]^2-l*lambda^2*rho*sigma*a[2]+12*l*m*mu^2*a[0]*a[2]+6*l*m*mu^2*a[1]^2-6*l*lambda*m*b[1]^2-l*mu^2*rho*a[2]+4*lambda^2*sigma*w*a[2]+4*mu^2*w*a[2]) = 0, -l*(4*l^2*lambda^3*mu*sigma*w*a[2]-l^2*lambda^3*sigma*w*b[1]+l^2*lambda*mu^2*w*b[1]-12*l*lambda^2*m*sigma*a[0]*b[1]+l*lambda^2*rho*sigma*b[1]-12*l*lambda*m*mu*b[1]^2-12*l*m*mu^2*a[0]*b[1]+l*mu^2*rho*b[1]-4*lambda^2*sigma*w*b[1]-4*mu^2*w*b[1]) = 0, 6*l^2*(l*lambda^2*sigma*w*a[2]+lambda^2*m*sigma*a[2]^2+l*mu^2*w*a[2]+m*mu^2*a[2]^2-lambda*m*b[2]^2) = 0, 2*l^2*(l*lambda^2*sigma*w*a[1]+6*lambda^2*m*sigma*a[1]*a[2]+3*l*lambda*mu*w*b[2]+l*mu^2*w*a[1]+6*m*mu^2*a[1]*a[2]-6*lambda*m*b[1]*b[2]) = 0, -2*l^2*(5*l*lambda^2*mu*sigma*w*a[2]-l*lambda^2*sigma*w*b[1]+5*l*mu^3*w*a[2]-6*lambda^2*m*sigma*a[1]*b[2]-6*lambda^2*m*sigma*a[2]*b[1]-l*mu^2*w*b[1]-6*lambda*m*mu*b[2]^2-6*m*mu^2*a[1]*b[2]-6*m*mu^2*a[2]*b[1]) = 0, 6*l^2*b[2]*(l*w+2*m*a[2]) = 0}, {a[0], a[1], a[2], b[1], b[2]});
{a[0] = 0, a[1] = 0, a[2] = 0, b[1] = 0, b[2] = 0},
   /       l rho - 4 w                                        \
  { a[0] = -----------, a[1] = 0, a[2] = 0, b[1] = 0, b[2] = 0 }
   \          6 l m                                           /
Problems with incomplete worksheet.
I have saved a .mw worksheet, which i cannot open in Maple, and i get an error code:
"There were problems during the loading process. Your worksheet may be incomplete"
I have attached a link, where a user is helped with the same problem, but i cannot understand the solution there has been given:
https://www.mapleprimes.com/questions/125503-Incomplete-Worksheet
I have attached the worksheets, and would be so gratefull for any help:
Beregningsdokument.mw
Beregningsdokument_2.mw
Best regards
Henrik Jorgensen
First 568 569 570 571 572 573 574 Last Page 570 of 2433
