Hi, after solving an equation and inserting it in the original equation the result is not equal to zero!!
What is the problem?
in the attached file below I obtained 'q' and then I put it in the eq (3), but the result is not zero!!
Please help me.
555.mw
I am looking for an elegant way in which to find a vector that is perpendicular to another vector.  The attached worksheet shows one method, but this can result in a divide by zero error.  I could write a procedure to detect and avoid the divide by zero error, but this feels like a sledgehammer to crack a nut :-)
Another method might be to rotate the vector by PI/2, but I'm not sure how to do this.
Any suggestions would be gratefully received!
Perpendicular_Vectors.mw
I need do generate a large number of matrices (always with the same dimensions) whose each column is a random sample of a different random variable.
I wrote a rather simple procedure to do that (see below a notional example). Let T and S the time and the memory size required for a single execution of this procedure, then its execution N times needs a time N*T and a size N*S.
If time is not a problem, the increase in memory size is extremely constraining.
How should I write this procedure in order that N executions of it use a memory of the order of S and not N*S?
Download Not_Efficient.mw
I keep getting this datatype float[8] error, can some1 please help me.
upload the mw file here faq.mw
Also i have a working for lopp and want to make a procedure.
Any suggestions will be helpful as well. Thanks.
This is a given set of equations (from a classifier problem in deep learning):
I tried to replicate the expression in Maple, but it was unsuccessful.
Q_MaplePrime20200417.mw
Would you tell me how to make it work?
Then, please let me know how to refer to a previous result (equation number) in the current expression.
The last line above (and the attached Maple document) shows my attempt, It did not work.
Thank you/Be healthy!
How to solve this error? Thank you
Sistem := diff(E[1](t), t) = subs(E[1] = E[1](t), L[1] = L[1](t), P[1] = P[1](t), M[1] = M[1](t), E[2] = E[2](t), L[2] = L[2](t), P[2] = P[2](t), M[2] = M[2](t), Data, dE1), diff(L[1](t), t) = subs(E[1] = E[1](t), L[1] = L[1](t), P[1] = P[1](t), M[1] = M[1](t), E[2] = E[2](t), L[2] = L[2](t), P[2] = P[2](t), M[2] = M[2](t), Data, dL1), diff(P[1](t), t) = subs(E[1] = E[1](t), L[1] = L[1](t), P[1] = P[1](t), M[1] = M[1](t), E[2] = E[2](t), L[2] = L[2](t), P[2] = P[2](t), M[2] = M[2](t), Data, dP1), diff(M[1](t), t) = subs(E[1] = E[1](t), L[1] = L[1](t), P[1] = P[1](t), M[1] = M[1](t), E[2] = E[2](t), L[2] = L[2](t), P[2] = P[2](t), M[2] = M[2](t), Data, dM1), diff(E[2](t), t) = subs(E[1] = E[1](t), L[1] = L[1](t), P[1] = P[1](t), M[1] = M[1](t), E[2] = E[2](t), L[2] = L[2](t), P[2] = P[2](t), M[2] = M[2](t), Data, dE2), diff(L[2](t), t) = subs(E[1] = E[1](t), L[1] = L[1](t), P[1] = P[1](t), M[1] = M[1](t), E[2] = E[2](t), L[2] = L[2](t), P[2] = P[2](t), M[2] = M[2](t), Data, dL2), diff(P[2](t), t) = subs(E[1] = E[1](t), L[1] = L[1](t), P[1] = P[1](t), M[1] = M[1](t), E[2] = E[2](t), L[2] = L[2](t), P[2] = P[2](t), M[2] = M[2](t), Data, dP2), diff(M[2](t), t) = subs(E[1] = E[1](t), L[1] = L[1](t), P[1] = P[1](t), M[1] = M[1](t), E[2] = E[2](t), L[2] = L[2](t), P[2] = P[2](t), M[2] = M[2](t), Data, dM2);
Error, invalid input: subs received Data, which is not valid for its 9-th argument
I am using Direct Search Optmization package for a procedure using Search command and everytime I run it it'll give me a different answer. same procedure, same code, when executed few times every time it generates a different answer. Can anyone help me with this ?
When executing DEBUG within inline code (not within a procedure) the values displayed in successive debug windows (on clicking continue) are added to the end of my worksheet. How can the latter display be prevented?
This Anti-derivative of  arccos(x)*arcsin(x), Maple  2020 cannot do that? It seems not difficult.
int(arccos(x)*arcsin(x),x)
In Mathematica, we can easily to get output :
2 x - Sqrt[1 - x^2] ArcSin[x] +  ArcCos[x] (Sqrt[1 - x^2] + x ArcSin[x])
When pressing !!! (Execute entire worksheet) it seems to me that startup code is executed.
Is that correct, and if - why is that so?
How can I transform the following differential equation from (x,t) to (X,T) coordinate, where, for example, X=x-alpha*t, T=beta*t (alpha and beta are constant)
diff(z, t)+(diff(R, x))*L+A*(diff(L, x))+diff(k, x, x)-(diff(k, t, t)) = 0
D(u(x,t),t,t)=c^2*D(u(x,t),x,x);
Where u(x,0)=f(x),D[2](u)(x,0)=g(x),u(0,t)=0=u(L,t),L=2
please do this as mentioned above
I use Maple 2018 and have following problem:
I define following procedure and want to plot it. However Maple displays the coordinate system but does not plot anything nor gives and error message. Hope you can help.
Murad
b:=proc(n)
local b,i:
 for i from 0 to n do
  if i=0 then
   b[0]:=0:
  elif i=1 then
   b[1]:=1:
   b[i]:=(b[i-1]+b[i-2])/2:
  end if:
return b[n]
plot(b,0..10)
First 571 572 573 574 575 576 577 Last Page 573 of 2433
