I am new to Maple, bit I am getting familiar with it. My current interest is in Lie Symmetry analysis of systems of PDE's such as mass, momentum, and energy balance equations in fluid dynamics, for example.
I have carried out a Lie Symmetry analysis for a single PDE's -- attached herewith. I know it to be correct because it is already published. What I want to do now is how to write down more than 1 PDE's and carry out a similar Lie Symmetry analysis to this system of PDE's. I have been unable to find an example on the web.
Can you advise please - especially how to enter a systems of PDE's as apposed to just one PDE.
Nadeem Malik
Sheet9.mw
i have vector like
Lambda := Vector[row](4, {(1) = *x[1]+.987329667009504589705605634543*x[2]-.436101517853804204529756811668*x[3]+.129526898189138290691985450717*x[4]-u[1], (2) = -1.90060788691970327587464611304*x[1]+.73919873843577037910167897814*x[2]+.20740624192749301981208286864*x[3]-0.45997093443560123039115733769e-1*x[4]-u[2], (3) = -.90583425825293904132909638808*x[1]-.63522563126813377056284195404*x[2]+.28771415757341360851847098373*x[3]+.25334573194765920337346735830*x[4]-u[3], (4) = -1.09745135827817665891430946698*x[1]+.3569463183370574834390092104*x[2]-1.0463476282509211343139483201*x[3]+.78685266819204030978924857651*x[4]-u[4]})
i want to set 2 column till 4 equal zero, i mean
-1.90060788691970327587464611304*x[1]+.73919873843577037910167897814*x[2]+.20740624192749301981208286864*x[3]-0.45997093443560123039115733769e-1*x[4]-u[2]=0
-.90583425825293904132909638808*x[1]-.63522563126813377056284195404*x[2]+.28771415757341360851847098373*x[3]+.25334573194765920337346735830*x[4]-u[3]=0...
how can i do it
Why does Maple give me an answer like this?
How do I force Maple to automatically multiply the exponents in the denominator and eliminate the factor y^2?
Simplify will not do it.
mapleatha
PrimeCounting(6469693230)
It never finishes computing, but smaller values work.
Is there any way to speed it up for larger values(I'm looking to do quite large values.
https://primes.utm.edu/nthprime/index.php#piofx
returns instantly.
a1 := 5; b1 := 3; a2 := 3; b2 := 4; a3 := 3; b3 := 7; eq1 := expand((y-2)^2/b1^2+(x-5)^2/a1^2 = 1); 1 2 4 13 1 2 2 eq1 := - y - - y + -- + -- x - - x = 1 9 9 9 25 5 eq2 := expand((y+2)^2/b2^2+(x+1)^2/a2^2 = 1); 1 2 1 13 1 2 2 eq2 := -- y + - y + -- + - x + - x = 1 16 4 36 9 9 Sys := {eq1, eq2}; Sol := [solve(Sys, explicit)]; L := map(proc (t) options operator, arrow; eval([x, y], t) end proc, simplify(`~`[fnormal](evalf(Sol), 9), zero)):I don't want complex roots. Tank you.
I have solved the following linear system for 6 variables on Maple using the following code:
sys := {w = -2*Pi*i*k_2*v + 2*Pi*i*k_2*(4*K^2)/(5*Pi)*u, z = -2*Pi*i*k_1*v + 2*Pi*i*k_1*(4*K^2)/(5*Pi)*u, p*s*x = -2*Pi*i*k_1*u - 4*Pi^2*(k_1^2 + k_2^2)*x + a_1, p*s*y = -2*Pi*i*k_2*u - 4*Pi^2*(k_1^2 + k_2^2)*y + a_2, k_1*z + k_2*w = 0, k_1*x + k_2*y = 0}
solve(sys, [x, y, z, w, v, u])
However, the solution yields z = w = 0, I was wondering if this is correct as I feel that these quantities should not be 0 in the problem which I am studying, is there a way to find a solution which does not involve setting these two to 0?
I am looking help for solving this integral equation using the collocation method with 1.5<= x<=3.5 ?
I have used the successive approximation method and the solution seems to be increasing.
Error, (in PDEtools/NumerDenom) invalid input: `PDEtools/NumerDenom` expects its 1st argument, ee, to be of type algebraic, but received {[(s_j*e^sigma*b^m*`σ_m`*y_i-s_j*e^sigma*beta*`σ_i`+s_j*e^sigma*b_ilo+(1/2)*b^(m+2)*`σ_j`*e^sigma*`σ_m`*y_i-b^2*`σ_j`*e^sigma*beta*`σ_i`+(1/2)*b^2*`σ_j`*e^sigma*b_ilo-(1/2)*b^(2*m)*`σ_m`^2*b_j*e^sigma*y_i+(1/2)*b^m*`σ_m`*b_j*e^sigma*beta*`σ_i`-(1/2)*b^m*`σ_m`*b_j*e^sigma*b_ilo+b_j*(s_ilo+(1/2)*(b^2*`σ_i`-b^m*`σ_m`*beta)*_lo)+b_j*(s_jlo+(1/2)*(b^2*`σ_j`-b^m*`σ_m`*beta)*_lo)+s_i*e^sigma*b^m*`σ_m`*y_j-s_i*e^sigma*be... when I use simplify I have this error. please guide me Saberali
I need to take the inverse of a tensor which I have denoted as e[~mu,nu] which is defined by a rather larger Matrix. I had computed this matrix using Mathematica and then simply transferred the resulting matrix by using the calling sequence
with(MmaTranslator):
which worked swell for transferring said matrix in to Maple. Then using the Physics package I was able to define it as a tensor, with a contravariant and covariant index, respectively. Now, when trying to transfer the inverse of said matrix into Maple to define as a new tensor which I intend to call f[mu,~nu], I get an error saying that the number of free indices on the left hand side does not coincide with the number of free indices on the right hand side. Since, this "new" tensor will really just be the inverse of the matrix which I used to define e[~mu,nu], I was wondering if there was any way in which I can simply compute the inverse of the matrix defining e[~mu,nu] in Maple and then let it be equivalent to f[mu,~nu], afterwhich I would then define it as a new tensor itself.
Research_project.mw
Any help would be greatly appreciated.
I would like to plot a piecewise function. g := x -> piecewise(x < -1, x + 1, x = 1, 4, 2 < x, x^2) with showing the value of 4 using plot command. How to do that?
As I using the command plot(g, -5 .. 5, -5 .. 5, discont = true, thickness = 3), the value of 4 when x = 1 did not show up.
how I can I get MAPLe to simplify this to beta (inside a larger calculation)
simplify(arctan(sin(beta)/cos(beta)),trig) assuming beta<Pi/2,beta>0;
I am aware (and use this a lot, eeasiest formula for a sawtooth function plot).
plot(arctan(tan(x)),x=0..20);
i have a system of equations given below.
sys := {Eq[1], Eq[2], Eq[3], Eq[4], Eq[5], Eq[6], Eq[7], Eq[8], Eq[9], Eq[10], Eq[11], Eq[12], Eq[13], Eq[14], Eq[15], Eq[16], Eq[17], Eq[18], Eq[19]};
 /     2      7
{ a[-1]  b[-1]  = 0,
         2      6                          7
  7 a[-1]  b[-1]  b[0] + 2 a[-1] a[0] b[-1]  = 0,
            8       2     7                 7
  -a[0] b[1]  + a[1]  b[1]  + a[1] b[0] b[1]  = 0,
               8                   7                     7
-256 a[-1] b[1]  + 2 a[0] a[1] b[1]  + 247 a[0] b[0] b[1]
           2          6                      7
   + 7 a[1]  b[0] b[1]  + 256 a[1] b[-1] b[1]
                  2     6             2      6
   - 247 a[1] b[0]  b[1]  = 0, 7 a[-1]  b[-1]  b[1]
             2      5     2                      6
   + 21 a[-1]  b[-1]  b[0]  + 14 a[-1] a[0] b[-1]  b[0]
                       7              7            2      7
   + 2 a[-1] a[1] b[-1]  + a[-1] b[-1]  b[0] + a[0]  b[-1]
               8                       7                       7
   - a[0] b[-1]  = 0, 2 a[-1] a[1] b[1]  + 4257 a[-1] b[0] b[1]
         2     7                         6
   + a[0]  b[1]  + 14 a[0] a[1] b[0] b[1]
                         7                 2     6
   + 6552 a[0] b[-1] b[1]  - 4293 a[0] b[0]  b[1]
           2           6          2     2     5
   + 7 a[1]  b[-1] b[1]  + 21 a[1]  b[0]  b[1]
                               6                 3     5
   - 10809 a[1] b[-1] b[0] b[1]  + 4293 a[1] b[0]  b[1]  = 0, 42
       2      5                     2      4     3
  a[-1]  b[-1]  b[0] b[1] + 35 a[-1]  b[-1]  b[0]
                        6                           5     2
   + 14 a[-1] a[0] b[-1]  b[1] + 42 a[-1] a[0] b[-1]  b[0]
                        6                       7
   + 14 a[-1] a[1] b[-1]  b[0] + 256 a[-1] b[-1]  b[1]
                    6     2         2      6
   - 247 a[-1] b[-1]  b[0]  + 7 a[0]  b[-1]  b[0]
                      7                 7                      8
   + 2 a[0] a[1] b[-1]  + 247 a[0] b[-1]  b[0] - 256 a[1] b[-1]  =
                      7                          6
  0, 2 a[-1] a[0] b[1]  + 14 a[-1] a[1] b[0] b[1]
                           7                   2     6
   + 63232 a[-1] b[-1] b[1]  - 15703 a[-1] b[0]  b[1]
           2          6                          6
   + 7 a[0]  b[0] b[1]  + 14 a[0] a[1] b[-1] b[1]
                      2     5                             6
   + 42 a[0] a[1] b[0]  b[1]  - 69791 a[0] b[-1] b[0] b[1]
                    3     5          2                5
   + 15619 a[0] b[0]  b[1]  + 42 a[1]  b[-1] b[0] b[1]
            2     3     4                   2     6
   + 35 a[1]  b[0]  b[1]  - 63232 a[1] b[-1]  b[1]
                          2     5                  4     4
   + 85494 a[1] b[-1] b[0]  b[1]  - 15619 a[1] b[0]  b[1]  = 0, 21
       2      5     2            2      4     2
  a[-1]  b[-1]  b[1]  + 105 a[-1]  b[-1]  b[0]  b[1]
             2      3     4                      5
   + 35 a[-1]  b[-1]  b[0]  + 84 a[-1] a[0] b[-1]  b[0] b[1]
                        4     3                      6
   + 70 a[-1] a[0] b[-1]  b[0]  + 14 a[-1] a[1] b[-1]  b[1]
                        5     2                    6
   + 42 a[-1] a[1] b[-1]  b[0]  - 10809 a[-1] b[-1]  b[0] b[1]
                     5     3         2      6
   + 4293 a[-1] b[-1]  b[0]  + 7 a[0]  b[-1]  b[1]
            2      5     2                     6
   + 21 a[0]  b[-1]  b[0]  + 14 a[0] a[1] b[-1]  b[0]
                    7                       6     2
   + 6552 a[0] b[-1]  b[1] - 4293 a[0] b[-1]  b[0]
         2      7                  7                2     7
   + a[1]  b[-1]  + 4257 a[1] b[-1]  b[0] = 0, a[-1]  b[1]
                            6                           6
   + 14 a[-1] a[0] b[0] b[1]  + 14 a[-1] a[1] b[-1] b[1]
                       2     5                               6
   + 42 a[-1] a[1] b[0]  b[1]  - 150809 a[-1] b[-1] b[0] b[1]
                     3     5         2           6
   + 15493 a[-1] b[0]  b[1]  + 7 a[0]  b[-1] b[1]
            2     2     5                               5
   + 21 a[0]  b[0]  b[1]  + 84 a[0] a[1] b[-1] b[0] b[1]
                      3     4                    2     6
   + 70 a[0] a[1] b[0]  b[1]  - 331612 a[0] b[-1]  b[1]
                           2     5                  4     4
   + 187554 a[0] b[-1] b[0]  b[1]  - 15619 a[0] b[0]  b[1]
            2      2     5           2           2     4
   + 21 a[1]  b[-1]  b[1]  + 105 a[1]  b[-1] b[0]  b[1]
            2     4     3                    2          5
   + 35 a[1]  b[0]  b[1]  + 482421 a[1] b[-1]  b[0] b[1]
                           3     4                  5     3
   - 203047 a[1] b[-1] b[0]  b[1]  + 15619 a[1] b[0]  b[1]  = 0,
           2      4          2            2      3     3
  105 a[-1]  b[-1]  b[0] b[1]  + 140 a[-1]  b[-1]  b[0]  b[1]
             2      2     5                      5     2
   + 21 a[-1]  b[-1]  b[0]  + 42 a[-1] a[0] b[-1]  b[1]
                         4     2
   + 210 a[-1] a[0] b[-1]  b[0]  b[1]
                        3     4                      5
   + 70 a[-1] a[0] b[-1]  b[0]  + 84 a[-1] a[1] b[-1]  b[0] b[1]
                        4     3                    6     2
   + 70 a[-1] a[1] b[-1]  b[0]  - 63232 a[-1] b[-1]  b[1]
                      5     2                         4     4
   + 85494 a[-1] b[-1]  b[0]  b[1] - 15619 a[-1] b[-1]  b[0]
            2      5                    2      4     3
   + 42 a[0]  b[-1]  b[0] b[1] + 35 a[0]  b[-1]  b[0]
                       6                          5     2
   + 14 a[0] a[1] b[-1]  b[1] + 42 a[0] a[1] b[-1]  b[0]
                     6                             5     3
   - 69791 a[0] b[-1]  b[0] b[1] + 15619 a[0] b[-1]  b[0]
           2      6                        7
   + 7 a[1]  b[-1]  b[0] + 63232 a[1] b[-1]  b[1]
                     6     2             2          6
   - 15703 a[1] b[-1]  b[0]  = 0, 7 a[-1]  b[0] b[1]
                             6                     2     5
   + 14 a[-1] a[0] b[-1] b[1]  + 42 a[-1] a[0] b[0]  b[1]
                                  5                     3     4
   + 84 a[-1] a[1] b[-1] b[0] b[1]  + 70 a[-1] a[1] b[0]  b[1]
                        2     6                          2     5
   - 1099008 a[-1] b[-1]  b[1]  + 184950 a[-1] b[-1] b[0]  b[1]
                    4     4          2                5
   - 4419 a[-1] b[0]  b[1]  + 42 a[0]  b[-1] b[0] b[1]
            2     3     4                     2     5
   + 35 a[0]  b[0]  b[1]  + 42 a[0] a[1] b[-1]  b[1]
                             2     4                    4     3
   + 210 a[0] a[1] b[-1] b[0]  b[1]  + 70 a[0] a[1] b[0]  b[1]
                      2          5
   + 824931 a[0] b[-1]  b[0] b[1]
                           3     4                 5     3
   - 157617 a[0] b[-1] b[0]  b[1]  + 4293 a[0] b[0]  b[1]
             2      2          4           2           3     3
   + 105 a[1]  b[-1]  b[0] b[1]  + 140 a[1]  b[-1] b[0]  b[1]
            2     5     2                     3     5
   + 21 a[1]  b[0]  b[1]  + 1099008 a[1] b[-1]  b[1]
                       2     2     4
   - 1009881 a[1] b[-1]  b[0]  b[1]
                           4     3                 6     2
   + 162036 a[1] b[-1] b[0]  b[1]  - 4293 a[1] b[0]  b[1]  = 0, 35
       2      4     3            2      3     2     2
  a[-1]  b[-1]  b[1]  + 210 a[-1]  b[-1]  b[0]  b[1]
              2      2     4               2           6
   + 105 a[-1]  b[-1]  b[0]  b[1] + 7 a[-1]  b[-1] b[0]
                         4          2
                         3     3
   + 280 a[-1] a[0] b[-1]  b[0]  b[1]
                        2     5                      5     2
   + 42 a[-1] a[0] b[-1]  b[0]  + 42 a[-1] a[1] b[-1]  b[1]
                         4     2
   + 210 a[-1] a[1] b[-1]  b[0]  b[1]
                        3     4                     5          2
   + 70 a[-1] a[1] b[-1]  b[0]  + 482421 a[-1] b[-1]  b[0] b[1]
                       4     3                         3     5
   - 203047 a[-1] b[-1]  b[0]  b[1] + 15619 a[-1] b[-1]  b[0]
            2      5     2           2      4     2
   + 21 a[0]  b[-1]  b[1]  + 105 a[0]  b[-1]  b[0]  b[1]
            2      3     4                     5
   + 35 a[0]  b[-1]  b[0]  + 84 a[0] a[1] b[-1]  b[0] b[1]
                       4     3                    6     2
   + 70 a[0] a[1] b[-1]  b[0]  - 331612 a[0] b[-1]  b[1]
                      5     2                        4     4
   + 187554 a[0] b[-1]  b[0]  b[1] - 15619 a[0] b[-1]  b[0]
           2      6               2      5     2
   + 7 a[1]  b[-1]  b[1] + 21 a[1]  b[-1]  b[0]
                      6                             5     3
   - 150809 a[1] b[-1]  b[0] b[1] + 15493 a[1] b[-1]  b[0]  = 0, 7
       2           6           2     2     5
  a[-1]  b[-1] b[1]  + 21 a[-1]  b[0]  b[1]
                                  5                     3     4
   + 84 a[-1] a[0] b[-1] b[0] b[1]  + 70 a[-1] a[0] b[0]  b[1]
                        2     5
                              2     4                     4     3
   + 210 a[-1] a[1] b[-1] b[0]  b[1]  + 70 a[-1] a[1] b[0]  b[1]
                      2          5                        3     4
   + 36885 a[-1] b[-1]  b[0] b[1]  - 8167 a[-1] b[-1] b[0]  b[1]
                   5     3          2      2     5
   + 163 a[-1] b[0]  b[1]  + 21 a[0]  b[-1]  b[1]
             2           2     4          2     4     3
   + 105 a[0]  b[-1] b[0]  b[1]  + 35 a[0]  b[0]  b[1]
                        2          4
                             3     3                    5     2
   + 280 a[0] a[1] b[-1] b[0]  b[1]  + 42 a[0] a[1] b[0]  b[1]
                       3     5                    2     2     4
   + 2485288 a[0] b[-1]  b[1]  - 711051 a[0] b[-1]  b[0]  b[1]
                          4     3                6     2
   + 39956 a[0] b[-1] b[0]  b[1]  - 247 a[0] b[0]  b[1]
            2      3     4           2      2     2     3
   + 35 a[1]  b[-1]  b[1]  + 210 a[1]  b[-1]  b[0]  b[1]
             2           4     2         2     6
   + 105 a[1]  b[-1] b[0]  b[1]  + 7 a[1]  b[0]  b[1]
                       3          4
   - 2522173 a[1] b[-1]  b[0] b[1]
                      2     3     3
   + 719218 a[1] b[-1]  b[0]  b[1]
                          5     2                7
   - 40119 a[1] b[-1] b[0]  b[1]  + 247 a[1] b[0]  b[1] = 0, 140
       2      3          3            2      2     3     2
  a[-1]  b[-1]  b[0] b[1]  + 210 a[-1]  b[-1]  b[0]  b[1]
             2           5             2     7
   + 42 a[-1]  b[-1] b[0]  b[1] + a[-1]  b[0]
                        4     3
   + 70 a[-1] a[0] b[-1]  b[1]
                         3     2     2
   + 420 a[-1] a[0] b[-1]  b[0]  b[1]
                         2     4                                6
   + 210 a[-1] a[0] b[-1]  b[0]  b[1] + 14 a[-1] a[0] b[-1] b[0]
                         4          2
                         3     3
   + 280 a[-1] a[1] b[-1]  b[0]  b[1]
                        2     5                      5     3
   + 42 a[-1] a[1] b[-1]  b[0]  + 1099008 a[-1] b[-1]  b[1]
                        4     2     2
   - 1009881 a[-1] b[-1]  b[0]  b[1]
                       3     4                        2     6
   + 162036 a[-1] b[-1]  b[0]  b[1] - 4293 a[-1] b[-1]  b[0]
             2      4          2           2      3     3
   + 105 a[0]  b[-1]  b[0] b[1]  + 140 a[0]  b[-1]  b[0]  b[1]
            2      2     5                     5     2
   + 21 a[0]  b[-1]  b[0]  + 42 a[0] a[1] b[-1]  b[1]
                        4     2                          3     4
   + 210 a[0] a[1] b[-1]  b[0]  b[1] + 70 a[0] a[1] b[-1]  b[0]
                      5          2
                      4     3                       3     5
   - 157617 a[0] b[-1]  b[0]  b[1] + 4293 a[0] b[-1]  b[0]
            2      5                    2      4     3
   + 42 a[1]  b[-1]  b[0] b[1] + 35 a[1]  b[-1]  b[0]
                       6     2                    5     2
   - 1099008 a[1] b[-1]  b[1]  + 184950 a[1] b[-1]  b[0]  b[1]
                    4     4              2                5
   - 4419 a[1] b[-1]  b[0]  = 0, 42 a[-1]  b[-1] b[0] b[1]
             2     3     4                      2     5
   + 35 a[-1]  b[0]  b[1]  + 42 a[-1] a[0] b[-1]  b[1]
                              2     4                     4     3
   + 210 a[-1] a[0] b[-1] b[0]  b[1]  + 70 a[-1] a[0] b[0]  b[1]
                         2          4
                              3     3                     5     2
   + 280 a[-1] a[1] b[-1] b[0]  b[1]  + 42 a[-1] a[1] b[0]  b[1]
                        3     5                     2     2     4
   + 3998464 a[-1] b[-1]  b[1]  - 764601 a[-1] b[-1]  b[0]  b[1]
                           4     3                6     2
   + 23156 a[-1] b[-1] b[0]  b[1]  - 37 a[-1] b[0]  b[1]
             2      2          4           2           3     3
            2     5     2                     3     4
   + 21 a[0]  b[0]  b[1]  + 70 a[0] a[1] b[-1]  b[1]
                        2     2     3
   + 420 a[0] a[1] b[-1]  b[0]  b[1]
                             4     2                    6
   + 210 a[0] a[1] b[-1] b[0]  b[1]  + 14 a[0] a[1] b[0]  b[1]
                       3          4
   - 1045243 a[0] b[-1]  b[0] b[1]
                      2     3     3                       5     2
   + 142558 a[0] b[-1]  b[0]  b[1]  - 2193 a[0] b[-1] b[0]  b[1]
              7                2      3          3
   + a[0] b[0]  b[1] + 140 a[1]  b[-1]  b[0] b[1]
             2      2     3     2          2           5
   + 210 a[1]  b[-1]  b[0]  b[1]  + 42 a[1]  b[-1] b[0]  b[1]
         2     7                     4     4
   + a[1]  b[0]  - 3998464 a[1] b[-1]  b[1]
                       3     2     3
   + 1809844 a[1] b[-1]  b[0]  b[1]
                      2     4     2                       6
   - 165714 a[1] b[-1]  b[0]  b[1]  + 2230 a[1] b[-1] b[0]  b[1]
              8              2      3     4
   - a[1] b[0]  = 0, 35 a[-1]  b[-1]  b[1]
              2      2     2     3            2           4     2
   + 210 a[-1]  b[-1]  b[0]  b[1]  + 105 a[-1]  b[-1] b[0]  b[1]
            2     6                            3          3
   + 7 a[-1]  b[0]  b[1] + 280 a[-1] a[0] b[-1]  b[0] b[1]
                         2     3     2
                             5                         7
   + 84 a[-1] a[0] b[-1] b[0]  b[1] + 2 a[-1] a[0] b[0]
                        4     3
   + 70 a[-1] a[1] b[-1]  b[1]
                         3     2     2
   + 420 a[-1] a[1] b[-1]  b[0]  b[1]
                         2     4                                6
   + 210 a[-1] a[1] b[-1]  b[0]  b[1] + 14 a[-1] a[1] b[-1] b[0]
                        4          3
   - 2522173 a[-1] b[-1]  b[0] b[1]
                       3     3     2
   + 719218 a[-1] b[-1]  b[0]  b[1]
                      2     5                            7
   - 40119 a[-1] b[-1]  b[0]  b[1] + 247 a[-1] b[-1] b[0]
            2      4     3           2      3     2     2
   + 35 a[0]  b[-1]  b[1]  + 210 a[0]  b[-1]  b[0]  b[1]
             2      2     4              2           6
   + 105 a[0]  b[-1]  b[0]  b[1] + 7 a[0]  b[-1] b[0]
                        4          2
                        3     3                          2     5
   + 280 a[0] a[1] b[-1]  b[0]  b[1] + 42 a[0] a[1] b[-1]  b[0]
                       5     3                    4     2     2
                     3     4                      2     6
   + 39956 a[0] b[-1]  b[0]  b[1] - 247 a[0] b[-1]  b[0]
            2      5     2           2      4     2
            2      3     4                   5          2
   + 35 a[1]  b[-1]  b[0]  + 36885 a[1] b[-1]  b[0] b[1]
                    4     3                      3     5
   - 8167 a[1] b[-1]  b[0]  b[1] + 163 a[1] b[-1]  b[0]  = 0,
         2      2     5            2           2     4
-21 a[-1]  b[-1]  b[1]  - 105 a[-1]  b[-1] b[0]  b[1]
             2     4     3                       2          4
   - 35 a[-1]  b[0]  b[1]  - 210 a[-1] a[0] b[-1]  b[0] b[1]
                              3     3                     5     2
   - 280 a[-1] a[0] b[-1] b[0]  b[1]  - 42 a[-1] a[0] b[0]  b[1]
                        3     4
   - 70 a[-1] a[1] b[-1]  b[1]
                         2     2     3
   - 420 a[-1] a[1] b[-1]  b[0]  b[1]
                              4     2                     6
   - 210 a[-1] a[1] b[-1] b[0]  b[1]  - 14 a[-1] a[1] b[0]  b[1]
                        3          4
   - 2337507 a[-1] b[-1]  b[0] b[1]
                       2     3     3
   + 387342 a[-1] b[-1]  b[0]  b[1]
                          5     2               7
   - 8937 a[-1] b[-1] b[0]  b[1]  + 9 a[-1] b[0]  b[1]
            2      3     4           2      2     2     3
   - 35 a[0]  b[-1]  b[1]  - 210 a[0]  b[-1]  b[0]  b[1]
             2           4     2         2     6
   - 105 a[0]  b[-1] b[0]  b[1]  - 7 a[0]  b[0]  b[1]
                        3          3
   - 280 a[0] a[1] b[-1]  b[0] b[1]
                        2     3     2
   - 420 a[0] a[1] b[-1]  b[0]  b[1]
                            5                        7
   - 84 a[0] a[1] b[-1] b[0]  b[1] - 2 a[0] a[1] b[0]
                       4     4                    3     2     3
   + 4675014 a[0] b[-1]  b[1]  - 774684 a[0] b[-1]  b[0]  b[1]
                     2     4     2                     6
   + 17874 a[0] b[-1]  b[0]  b[1]  - 18 a[0] b[-1] b[0]  b[1]
            2      4     3           2      3     2     2
   - 35 a[1]  b[-1]  b[1]  - 210 a[1]  b[-1]  b[0]  b[1]
             2      2     4              2           6
   - 105 a[1]  b[-1]  b[0]  b[1] - 7 a[1]  b[-1] b[0]
                       4          3
   - 2337507 a[1] b[-1]  b[0] b[1]
                      3     3     2                  2     5
   + 387342 a[1] b[-1]  b[0]  b[1]  - 8937 a[1] b[-1]  b[0]  b[1]
                      7               2      2          4
   + 9 a[1] b[-1] b[0]  = 0, 105 a[-1]  b[-1]  b[0] b[1]
              2           3     3           2     5     2
   + 140 a[-1]  b[-1] b[0]  b[1]  + 21 a[-1]  b[0]  b[1]
                        3     4
                         2     2     3
                              4     2                     6
   + 210 a[-1] a[0] b[-1] b[0]  b[1]  + 14 a[-1] a[0] b[0]  b[1]
                         3          3
                         2     3     2
                             5                         7
   + 84 a[-1] a[1] b[-1] b[0]  b[1] + 2 a[-1] a[1] b[0]
                        4     4
   - 3998464 a[-1] b[-1]  b[1]
                        3     2     3
   + 1809844 a[-1] b[-1]  b[0]  b[1]
                       2     4     2
   - 165714 a[-1] b[-1]  b[0]  b[1]
                          6                  8
   + 2230 a[-1] b[-1] b[0]  b[1] - a[-1] b[0]
             2      3          3           2      2     3     2
   + 140 a[0]  b[-1]  b[0] b[1]  + 210 a[0]  b[-1]  b[0]  b[1]
            2           5            2     7
   + 42 a[0]  b[-1] b[0]  b[1] + a[0]  b[0]
                       4     3                      3     2     2
   + 70 a[0] a[1] b[-1]  b[1]  + 420 a[0] a[1] b[-1]  b[0]  b[1]
                        2     4                               6
   + 210 a[0] a[1] b[-1]  b[0]  b[1] + 14 a[0] a[1] b[-1] b[0]
                       4          3
                      3     3     2                  2     5
                    7           2      4          2
   + a[0] b[-1] b[0]  + 105 a[1]  b[-1]  b[0] b[1]
             2      3     3               2      2     5
   + 140 a[1]  b[-1]  b[0]  b[1] + 21 a[1]  b[-1]  b[0]
                       5     3                    4     2     2
   + 3998464 a[1] b[-1]  b[1]  - 764601 a[1] b[-1]  b[0]  b[1]
                     3     4                     2     6    \
   + 23156 a[1] b[-1]  b[0]  b[1] - 37 a[1] b[-1]  b[0]  = 0 }
values := solve(sys, {a[-1], a[0], a[1], b[-1], b[0], b[1]});
I applied this command but answes were tolltally change .I want to find such type of answer.{a−1 = 0, a0 = 0, a1 = b0, a2 = a2,
b−1 = 0, b0 = b0, b1 = a2, b2 = 0.}
sys := {x^3*a[1]*b[0]+x*a[1]^3*b[0]-x^3*a[0]-x*a[0]*a[1]^2+omega*a[1]*b[0]-omega*a[0] = 0, -x^3*a[-1]*b[-1]^2*b[0]+x^3*a[0]*b[-1]^3-omega*a[-1]*b[-1]^2*b[0]+omega*a[0]*b[-1]^3-x*a[-1]^3*b[0]+x*a[-1]^2*a[0]*b[-1] = 0, -4*x^3*a[1]*b[0]^2+4*x^3*a[0]*b[0]+8*x^3*a[1]*b[-1]+2*x*a[0]*a[1]^2*b[0]+2*x*a[1]^3*b[-1]+2*omega*a[1]*b[0]^2-8*x^3*a[-1]-2*x*a[-1]*a[1]^2-2*x*a[0]^2*a[1]-2*omega*a[0]*b[0]+2*omega*a[1]*b[-1]-2*omega*a[-1] = 0, 4*x^3*a[1]*b[-1]*b[0]^2-4*x^3*a[-1]*b[0]^2-32*x^3*a[1]*b[-1]^2+4*omega*a[1]*b[-1]*b[0]^2-32*x^3*a[-1]*b[-1]+4*x*a[-1]*a[1]^2*b[-1]+4*x*a[0]^2*a[1]*b[-1]-4*omega*a[-1]*b[0]^2+4*omega*a[1]*b[-1]^2-4*x*a[-1]^2*a[1]-4*x*a[-1]*a[0]^2-4*omega*a[-1]*b[-1] = 0, 4*x^3*a[-1]*b[-1]*b[0]^2-4*x^3*a[0]*b[-1]^2*b[0]+8*x^3*a[1]*b[-1]^3-8*x^3*a[-1]*b[-1]^2-2*omega*a[-1]*b[-1]*b[0]^2+2*omega*a[0]*b[-1]^2*b[0]+2*omega*a[1]*b[-1]^3-2*x*a[-1]^2*a[0]*b[0]+2*x*a[-1]^2*a[1]*b[-1]+2*x*a[-1]*a[0]^2*b[-1]-2*omega*a[-1]*b[-1]^2-2*x*a[-1]^3 = 0, x^3*a[1]*b[0]^3-x^3*a[0]*b[0]^2-18*x^3*a[1]*b[-1]*b[0]+omega*a[1]*b[0]^3-5*x^3*a[-1]*b[0]+23*x^3*a[0]*b[-1]+x*a[-1]*a[1]^2*b[0]+x*a[0]^2*a[1]*b[0]+5*x*a[0]*a[1]^2*b[-1]-omega*a[0]*b[0]^2+6*omega*a[1]*b[-1]*b[0]-6*x*a[-1]*a[0]*a[1]-x*a[0]^3+5*omega*a[-1]*b[0]-omega*a[0]*b[-1] = 0, -x^3*a[-1]*b[0]^3+x^3*a[0]*b[-1]*b[0]^2+5*x^3*a[1]*b[-1]^2*b[0]+18*x^3*a[-1]*b[-1]*b[0]-23*x^3*a[0]*b[-1]^2-omega*a[-1]*b[0]^3+omega*a[0]*b[-1]*b[0]^2+5*omega*a[1]*b[-1]^2*b[0]-x*a[-1]^2*a[1]*b[0]-x*a[-1]*a[0]^2*b[0]+6*x*a[-1]*a[0]*a[1]*b[-1]+x*a[0]^3*b[-1]-6*omega*a[-1]*b[-1]*b[0]+omega*a[0]*b[-1]^2-5*x*a[-1]^2*a[0] = 0}
I have a sequence defined by recurrence. I would like to simplify the code so that I can compute all elements of my sequence.
sequence.mw
Hi all, I have problem but can't solve
How to split a number into smaller numbers so that their sum return the original number?
Example, n = 5 then
1+1+1+1+1
2+1+1+1
3+1+1
4+1
2+3
Thank you very much.
First 595 596 597 598 599 600 601 Last Page 597 of 2433
