I assume I'm missing the verb here, but how does one display the elements of a vector and an array?
I can only do it with browsing or changing the "number format".
v := `<,>`(v1, v2); v1 := 3.2; v2 := b
Vector[column](%id = 18446745611378162974)
v, eval(v), value(v), evalf(v), evalm(v), print(v)
Vector(2, {(1) = v1, (2) = v2})
Vector[column](%id = 18446745611378162974), Vector[column](%id = 18446745611378162974), Vector[column](%id = 18446745611378162974), Vector[column](%id = 18446745611378152862), array( 1 .. 2, [( 1 ) = (v1), ( 2 ) = (v2)  ] )
v
Download Vector_Display_Problem.mw
I get error on Maple code
N := 4
f(x):=sum(p^i*fi, i = 0 .. N);
HPMEq := (1-p)(diff(f(x), x$3))+p(diff(f(x), x$3)+(1/2)(diff(f(x), x, x))*f(x));
for i from 0 to N do equ[2][i] := coeff(HPMEq, p, i) = 0 end do
Error, unable to compute coeff
I'm trying to solve this schrodinger equation for a quantum oscillator:
E = n + 1/2 where n = 0,1,2,3,4
If I just use dsolve then I get a bunch of Bessell functions and I'm not sure why.
Can anyone point me in the right direction?
How can I analytially evaluate the following definite integral ?
int(1/(c*x + d), x = a .. b)
My Output is as follows:
is there any library or tools to design index of Grassmannian and its k and n for Schubert use?
is there any library to relate poset with index of Grassmannian and its k and n for Schubert use
RandomMatrix(n, 1);
does not seem too work with Vectors of dimension d in elementwise multiplication ;/ Even though it is an nx1 matrix = an n vector.
This seems like a limitation maple!
RandomVector(n);
Does seem to work with Matrix and Vector.
Matrix(5,1)*~Vector(5);
Both have the same dimensions and should be possible to multiply them pointwise!
with(RegularChains);
R := PolynomialRing([x, y, z]);
p1 := x^2+5-2*x*z;
p2 := z^3*y+x*y^2;
p3 := -8*z^3+3*y^2;
F := [p1, p2, p3];
MainVariable(p1, PolynomialRing([x, y, z]));
MainVariable(p1, PolynomialRing([z, y, x]));
prem(p1, p2, x);
prem(p2, p1, z);
prem(p3, p2, y);
premcustom := proc(Fparam,Gparam, xparam)
local R, G, F, lcg, lcr, dr, dg:
R := Fparam:
G := Gparam:
F := Fparam:
if degree(G,xparam) = 0 then
 print("return 0"):
 return 0:
elif degree(F, xparam) < degree(G, xparam) then
 print("return R"):
 return R:
 lcg := coeff(G, xparam, degree(G, xparam)):
 dg := degree(G, xparam):
 while degree(R, xparam) > degree(G, xparam) do
  lcr := coeff(R, xparam, degree(R, xparam)):
  dr := degree(R, xparam):
  R := lcg * R - lcr * G * (x^(dr - dg)):
end if:
return R:
coeff(p1, x, degree(p1, x));
coeff(p2, x, degree(p2, x));
prem(p1,p2,x);
prem(p2,p1,z);
premcustom(p1,p2,x);
premcustom(p2,p1,z);
why premcustom looping?
is this coeff(p1, x, degree(p1, x)); wrong ?
should this to get real coefficient in number instead of variable and how?
is there equivalent function as dprem?
with(diffalg):with(diffalg):
FlessThanG := proc(Fparam, Gparam, PRing)
F := Fparam:
G := Gparam:
if leader(F,PRing) < leader(G,PRing) or (leader(F,PRing) = leader(G,PRing) and degree(F, leader(F,PRing)) < degree(G, leader(G,PRing))) then
 return True:
 return False:
end if:
dprem := proc(Fparam, Gparam, x, PRing)
local R, theta, thetax, thetaG, F, G;
F := Fparam:
G := Gparam:
R := F:
thetax := leader(G, PRing);
while FlessThanG(R, G, PRing) or FlessThanG(G, R, PRing) do
theta := leader(R, PRing);
R := prem(R, thetaG, theta)
return R:
R := differential_ring(ranking = [[x,y,r]], derivations = [t], field_of_constants=[m,l], notation = diff):
p1 := m*x[2] + r*x;
p2 := m*y[2] + r*y - g;
p3 := x^2 + y^2 - l^2;
dprem(p1, p3, x, R);
is x[2] = diff(x,t$2) in diffalg ?
if not how to write in this way?
i had defined constant
but got error
Error, (in DifferentialAlgebra:-Tools:-LeadingDerivative) unknown symbol (approx. error location: [m*x[2 --> ] <-- +r*x])
        Hello, everyone,I can not find a function that can do convolution, so if you know please tell me. Thanks!
what is the Taylor Series of
F(x,y+q,G(x+q,z) )
where x,y,z is variables and q is constant
Just a quick question, I know we can use "%" to obtain the las result in maple. what if I want to obtain the second last result? or in general the n-last result ? Thx
Hi, I'm trying to solve 1-D thermal equation defined below, but I end up with an error : Error, (in pdsolve/numeric/process_PDEs) PDEs can only contain dependent variables with direct dependence on the independent variables of the problem, got {f(t, 1)}.
Could you please point out what am I doing wrong? Perhaps it's how I define the PDe or how I write the boundaries? Any help appreciated!
with(PDEtools)
PDE := cp*diff(T(t, r), t) - k_1*diff(diff(T(t, r), r), r) - k_1*diff(T(t, r), r)/r = Q;
all variables for now have dummy values of 1
cp := 1;
k_2 := 1;
A := 1;
k_3 := 1;
k_4 := 1;
k_5 := 1;
k_6 := 1;
T_amb := 1;
bcs_1 := eval(diff(T(t, r), r), r = 1) = k_3*T_amb;
bcs_2 := eval(diff(T(t, r), r), r = 0) = 0;
bcs_3 := eval(diff(T(t, r), t), t = 0) = 25;
PDE_all := {PDE, bcs_1, bcs_2, bcs_3};
sol := pdsolve(PDE_all, numeric);
Int not working with GlobalSolve why? It shows that bounds should be specified to all variable. but i have given bounds to all variables already. Thank you
How do I solve an overdetermined system of algebraic equations in Maple? solve command returns trivial solution for variables which are not actually trivial when I solve them by hand.
Hi all
When I solve using maple the first-order differential equation: diff(y,x)=0  for x in the closed interval [0,1] we obtain a constant function as a solution
but one can define the piecewise constant function see please the attached code
diff_piecewise.mw
why when we differentiate the piecewise function gives undefined derivative at point zero and a half.
Whats is the relationship between this example and Existence and uniqueness theorem for fist order ode
Many thanks
First 626 627 628 629 630 631 632 Last Page 628 of 2433
