I am working on a physics problem where I will need to generate random unitaries of size N x N.
As I understand it this would require me to sample uniformly from U(N), where 'uniform' is in the sense of the Haar measure.  I believe this construction in Mathematica is called 'circular unitary ensemble' and was wondering if there was a similar routine in Maple or some simple code that would allow me to generate random unitaries of particular size.
I have the following two equations:
u=1-(8*(10.3968*t^2-5.8368*t*f-.229376*f^2-5.1984))/(4.56*t^2-2.56*t*f+.8192*f^2+2.28)^2;
x = f+t-(8*(-2.28*t+.64*f))/(2.28+2*(-t+.64*f)^2+2.56*t^2);
How can I plot the contours of u in the x-t plane (with its elevation value labelled in the line of each contour)?
Thank you a lot for your help!
As in title: How can I generate random numbers sampled from, say, the logarithmic distribution (with a given value of the parameter)?
Thank you very much.
Anyone can help me to convert the following maple solution expressed by the hypergeom function to the LegendreP(n,b,x) or Q function?
with(PDETools):
infolevel[pdsolve] := 3:
sol[1] := dsolve((1-x^2)*(diff(y(x), x, x))+n(n+1)*y(x) = 0)
y(x) = _C1*(-1+x^2)*hypergeom([3/4+(1/4)*(4*n(n+1)+1)^(1/2), 3/4-(1/4)*(4*n(n+1)+1)^(1/2)], [1/2], x^2)+_C2*(x^3-x)*hypergeom([5/4+(1/4)*(4*n(n+1)+1)^(1/2), 5/4-(1/4)*(4*n(n+1)+1)^(1/2)], [3/2], x^2)
convert(sol[1], LegendreP)
Download convert-Legendre.mw
https://math.stackexchange.com/questions/3254765/how-to-convert-a-hypergeom-function-to-the-legendre-function
I just want y(x) to be expressed in the form of LegendreP(n,b,x).
wave2.mw
Hellow!
I'm use Maple 13 (Linux)
I want save the value of u(x,t) at output file. This function is solution of PDE.
Can I get one file to each time value??
Ths
I am truing to simplify kretchmann variable in the following worksheet:
M >
# Obtaining Ricci and Kretchmann;
with(DifferentialGeometry):with(Tensor):
DGsetup([t, r, theta, phi], M);
g := evalDG(-(1-2*M*mu/r)^(1/mu)*dt &t dt+(1-2*M*mu/r)^(-1/mu)*`&t`(dr, dr)+r^2*(1-2*M*mu/r)^(1-1/mu)*(`&t`(dtheta, dtheta)+sin(theta)^2*`&t`(dphi, dphi)));
C := Christoffel(g):
`frame name: M`
_DG([["tensor", M, [["cov_bas", "cov_bas"], []]], [[[1, 1], -(-(2*M*mu-r)/r)^(1/mu)], [[2, 2], (-(2*M*mu-r)/r)^(-1/mu)], [[3, 3], r^2*(-(2*M*mu-r)/r)^((mu-1)/mu)], [[4, 4], r^2*(-(2*M*mu-r)/r)^((mu-1)/mu)*sin(theta)^2]]])
(1.1)
Rie := CurvatureTensor(C):
R := RicciScalar(g,Rie);
h := InverseMetric(g):
kretchmann := ContractIndices(RaiseLowerIndices(g, Rie, [1]), RaiseLowerIndices(h, Rie, [2, 3, 4]), [[1, 1], [2, 2], [3, 3], [4, 4]]);
2*(-(2*M*mu-r)/r)^(1/mu)*M^2*(mu^2-1)/(r^2*(2*M*mu-r)^2)
4*(-(2*M*mu-r)/r)^(-2*(mu-1)/mu)*M^2*(M*mu^2+2*M*mu+M-2*r)^2/(r^6*(2*M*mu-r)^2)+4*(-(2*M*mu-r)/r)^(2/mu)*M^2*(M*mu^2+M*mu-r)^2/((2*M*mu-r)^4*r^4)+20*(-(2*M*mu-r)/r)^(2/mu)*(M*mu+M-r)^2*M^2/((2*M*mu-r)^4*r^4)+4*(-(2*M*mu-r)/r)^(-2*(mu-1)/mu)*M^2*(M*mu^2+M*mu-r)^2/(r^6*(2*M*mu-r)^2)+4*(-(2*M*mu-r)/r)^(-2*(mu-1)/mu)*M^2*(M*mu+M-r)^2/(r^6*(2*M*mu-r)^2)
(1.2)
M >
# simplification
M >
simplify(normal(R),symbolic)
2*(-1)^(1/mu)*(2*M*mu-r)^((1-2*mu)/mu)*r^((-1-2*mu)/mu)*M^2*(mu^2-1)
(1.3)
M >
simplify(kretchmann,size,symbolic)
(1.4)
M >
Download RicciScalarKretchmann.mw
The problem is that I cannot obtain a good form of it. With Mathematica FullSimplify[] function I got the following form (LaTeX code incoming): $K =& 4 M^2 \Bigl(A-B r+C r^2\Bigr)(r-2 M \mu)^{\frac{2}{\mu}-4}r^{-\frac{2}{\mu}-4},\
    A =&M^2 (\mu (3 \mu+2)+7) (\mu+1)^2,\,B = 8 M (\mu+2) (\mu+1),\, C = 12$, i.e. terms $(r-2 M \mu)$ and $r$ got fully factorized. However, I could never achieve the same form in Maple. Any help?
I am sorry if this is a silly and many-times-answered question, but I tried consulting with Maple help and googling solutions without any success.
Nick
Is there anyway, i can using maple software command to create a symbol for either math or nursing.Math sumbol or nursing symbol..if there is a way, can u please let me kw the way, i need it urgently.Thanks
Hi Maple experts and others,
We want to make a graph with 6 vertical lines.  One end of every vertical line will be on the x axis.  The other end of the vertical lines will be on integers of data points.
3+2
5
ab := Vector[row](6); cd := Vector[row](6)
ab := Vector[row](6, {(1) = 5, (2) = 8, (3) = 11, (4) = 14, (5) = 17, (6) = 20})
cd := Vector[row](6, {(1) = 1, (2) = 2, (3) = 3, (4) = 4, (5) = 5, (6) = 6})
for count to 6 do ab[count] := 3*count+2; cd[count] := count end do;
5
11
14
4
17
5
20
6
ab
Vector[row]([5, 8, 11, 14, 17, 20])
cd
Vector[row]([1, 2, 3, 4, 5, 6])
Download a_try.mw
Please assist us.
Matt
I'm trying to do something very simple, but I can not do it. I would like to fill the chart with colors of my choice.
restart: with (plots):
plots [animate] (plot, [[sqrt (x), sqrt (x) -1], x = 0..t, filled = true, view = [0..20, 0..5]], t = 0..20);
The filled = true option fills the graph with random colors.
I tried to use filled = ["Blue", "Red"], but that does not work.
Any tips?
I got this solution from a PDE. I normally use unapply on the RHS of the solution to make it a function.
But in this, the PDE solution contain some extra stuff at the end. Which  "Where { .....}"
So the only way for me, was to manually copy the initial part of the solution shown on the screen in order to use it later.
I could not find a way to program this part.
Here is an example
f:=(r,z)->(r-a)*sin(z/H*Pi);
lap:=VectorCalculus:-Laplacian(u(r, z, t), cylindrical[r, theta,z]);
bc:=u(r,0,t)=0,u(r,H,t)=0, u(a,z,t)=0;
ic:=u(r,z,0) = f(r,z);
sol:=pdsolve([diff(u(r,z,t),t) = k*lap,bc,ic],u(r,z,t)) assuming a>0,k>0;
THis gives
Which I verified to be correct.
In case you are not able to get this solution (it needs Maple 2019.1 and Physics 368), here is the lprint
lprint(sol)
u(r,z,t) = `casesplit/ans`(Sum(-BesselJ(0,lambda[n]/a*r)*sin(z/H*Pi)*exp(-k*t*(
H^2*lambda[n]^2+Pi^2*a^2)/a^2/H^2)*a/lambda[n]^2*Pi*BesselJ(1,lambda[n])*
StruveH(0,lambda[n])/hypergeom([1/2],[1, 2],-lambda[n]^2),n = 1 .. infinity),{
And(lambda[n] = BesselJZeros(0,n),0 < lambda[n])})
Next to use it (plot., evaluate, etc...) changed the sum go to 15 terms (more than enough) and also replaced a->1,H->3,k->1/100 and  also replaced lambda[n] with BesselJ zeros as follows
sol:=subs({infinity=15,a=1,H=3,k=1/100,lambda[n]=BesselJZeros(0, n)},sol);
Before I use unapply, I had to extract the part of the solution up to where it says "where..." since I do not need the rest any more, since I allready replaced lambda[n] with BesselJZeros calls.
This I did by hand using copy/paste from the screen. Now I am able to finish the task:
solFiltered:=Sum(-BesselJ(0, BesselJZeros(0, n)*r)*sin(z*Pi/3)*
     exp(-t*(9*BesselJZeros(0, n)^2 + Pi^2)/900)*Pi*
     BesselJ(1, BesselJZeros(0, n))*
     StruveH(0, BesselJZeros(0, n))/(BesselJZeros(0, n)^2*
     hypergeom([1/2], [1, 2], -BesselJZeros(0, n)^2)), n = 1 .. 15):
mapleSol:=unapply(solFiltered,r,z,t);
value(mapleSol(.5,2,1));
Which prints -0.4107565091 which is the correct value. It matches my hand solution and also match numerical solution.
What would a better way to do the above than what I did? i.e. to obtain the solFitered above using code only?
Consider a wave y=f(x,t) with amplitude modulation such that it becomes
 y_new=(1+A)*f(x,t), where A=A(t) is a small perturbation.
How can I do the simulation to test the robustness of the system to see if the wave is stable / unstable under perturbation? As the time t goes to infinity, I want to see if the original wave is distorted or not under either random or prescribed perturbation.
P.S. For example,  f(x,t) = (sech(0.5*x-0.1*t))^2.
Thank you for your help.
Can someone please help me plot a bunch of tangent lines to approximate the given space curve? I know how to do it in another CAS system however I am trying to make the switch over to maple.  Question.mw.
William
Hi everyone.I need to solve this equation and find x:
(1+a×cos(theta1×x))×cos(theta2×x)=b;
theta2 is bigger than theta1.a and b are constant number.I need to know how solve it?
I installed Physics package 368 and when I run a test, I found that now the latex() command fails with internal  error which I have never seen before. I think this is first time I see latex() gives an error.
lap:=VectorCalculus:-Laplacian(u(r,z,t),'cylindrical'[r,theta,z]):
bc:=u(r,0,t)=0,u(r,H,t)=0, u(a,z,t)=0:
ic:=u(r,z,0) = f(r,z):
sol:=pdsolve([diff(u(r,z,t),t) = k*lap,bc,ic],u(r,z,t)) assuming a>0,r<a,H>0,k>0;
latex(sol);
u(r, z, t) = `casesplit/ans`(Sum(Sum(4*BesselJ(0, lambda[n1]*r/a)*sin(n*Pi*z/H)*exp(-k*t*(Pi^2*a^2*n^2+H^2*lambda[n1]^2)/(a^2*H^2))*(Int(BesselJ(0, lambda[n1]*r/a)*r*(Int(sin(n*Pi*z/H)*f(r, z), z = 0 .. H, AllSolutions)), r = 0 .. a, AllSolutions))/(H*a^2*hypergeom([1/2], [1, 2], -lambda[n1]^2)), n = 1 .. infinity), n1 = 1 .. infinity), {And(lambda[n1] = BesselJZeros(0, n1), 0 <= lambda[n1])})
Error, (in latex/int) invalid arguments
lprint(sol)
u(r,z,t) = `casesplit/ans`(Sum(Sum(4*BesselJ(0,lambda[n1]/a*r)*sin(n/H*Pi*z)*
exp(-k*t*(Pi^2*a^2*n^2+H^2*lambda[n1]^2)/a^2/H^2)*Int(BesselJ(0,lambda[n1]/a*r)
*r*Int(sin(n/H*Pi*z)*f(r,z),z = 0 .. H,AllSolutions),r = 0 .. a,AllSolutions)/H
/a^2/hypergeom([1/2],[1, 2],-lambda[n1]^2),n = 1 .. infinity),n1 = 1 ..
infinity),{And(lambda[n1] = BesselJZeros(0,n1),0 <= lambda[n1])})
Download bug_june_6_2019.mw
Is this a new bug? Why latex() command now fails? It failed on the above output. When I try latex() on simpler output. no error is generated. So something to do with the above specific output seems to be the issue.
Maple 2019.1 using Physics 368 on windows 10.
First 685 686 687 688 689 690 691 Last Page 687 of 2433
