When typing
z:=exp(I*2*Pi/3);
convert(z,'sincos')
Maple evaluates the intermediate result which is cos(2*Pi/3)+I*sin(2*Pi/3) and  gives
Is there a way to tell it not to do this? I'd like to see the result as when typing
'cos(2*Pi/3)+I*sin(2*Pi/3)'
Is there an option or method to tell Maple not to immediate evaluation in the above? it can do evaluate next time the expression is used.
How to solve a system of partial equations with boundary conditions.I used this formula
sys_Pde := diff(V(x, t), x, x) = 0, diff(T(x, t), x, x) = 0;
BC := eval(diff(V(x, t), x), x = 1) = 0, eval(V(x, t), x = 0) = 1+cos(w*t), eval(T(x, t), x = 0) = 0, eval(T(x, t), x = 1) = 1;
pdsolve({sys_Pde});
   {T(x, t) = _F1(t) x + _F2(t), V(x, t) = _F3(t) x + _F4(t)}
pdsolve({BC, sys_Pde});
Error, (in PDEtools:-ToJet) found functions to be rewritten in jet notation, {V(1, t)}, having different dependency than the indicated in [V(x, t)]
I
have the following function phi(x,y) which depends on two unknown functions F1 and F2 which are differentiable.
Phi(x,y)=y sin(x y) + F1(y) + y^2 F2(x y)
Note that F1 and F2 are obtained by hand when I solve a partial differential equation
I would like to find  phi(x,y)  that satisfies phi=1 and diff(phi(x,y),y)=1-x^2*cos(x^2) on line y=x
constraint.mw
Thanks for your help
Hi, given the function f(t)=t^2. Determine the Fourier coefficients a_0, a_1 and b_1 for f(t). Plot the graphs for f(t) and also plot the graphs for the Fourier sum F(t) with N=1 in the same coordinate system. Let the t-axis go from 0 to 2*Pi.
Can someone help with this?
I have a system of linear equations with a fixed number of equations, but the stracture of the system varies in T. I have solved the system for a fixed T and have to run for each value of T, which is quite boaring. I want to solve the system by a single run for multiple T values using a for loop. When I tried with the code, I got the following error.
Error, (in LinearAlgebra:-GenerateMatrix) invalid subscript selector
t.mw
L:=[1,2,0,4]:
s := sum(1/L[i], i=1..nops(L));
Error, (in limit/mrv/limsimpl) too many levels of recursion
So, this error cannot be caught by try
try    # bug
  catch:  s:=infinity
end try;
Strangely, for L:=[1, 2, 0.0, 4]  it's OK.
Everything works with add instead of sum, but this is another thing.
  I want list all  diameter-2  Nonisomorphismgraphs  of order n . I use the following code, but its running speed  is slow with  order of graph gradually increasing . (for example,n=10)
 Are there other ways to Improve it?
with(GraphTheory):
Graphs_data:=[NonIsomorphicGraphs(4,restrictto =[connected], output = graphs, outputform =graph)]:
Diameter_select:=select[flatten](t->Diameter(t)=2,Graphs_data):
DrawGraph(Diameter_select,size=[50,50]);
  By the way,  Why doesn't size=[50,50] work ?
How can find the range of  the parameter k, such that f(x)=b ( for a given b in the set of real number R) we have a unique solution of the equation f(x)=b
Many thanks for your help
I'm trying to solve a system of ODE in a model of infectious disease. But, unfortunately, when I try to plot the curves, I get the following error message: Error, (in fproc) unable to store '-1.*HFloat(0.0)[1]' when datatype=float[8]. The code is here
Q := 1000; a := .9; b := 0.8e-3; mu := 0.247e-2; k := .2; y := 0.2e-1; e := .5; g := .5; T := 8; n := 100;
sigma[1] := 0.5e-1; sigma[2] := 0.9e-1; alpha[1] := 0.52e-2; alpha[2] := 0.52e-2; delta[1] := .8; delta[2] := .904; delta[3] := .8; c[1] := 50; c[2] := 250; c[3] := 50; w[1] := 140; w[2] := 130; w[3] := 150; w[4] := 160;
u[1] := min(max(0, z), 1); z := (a*i[p](t)*(i[p](t)+i[pm](t))*(lambda[4](t)-lambda[3](t))+a*s(t)*(i[p](t)+i[pm](t))*(lambda[1](t)-lambda[2](t)))/(n.w[1]); u[2] := min(max(0, c), 1); c := (b*(i[m](t)+i[pm](t))*s(t)*(lambda[3](t)-lambda[1](t))+b*(i[m](t)+i[pm](t))*i[p](t)*(lambda[4](t)-lambda[2](t)))/(n.w[2]); u[3] := min(max(0, j), 1); j := (i[p](t)*lambda[2](t)+i[pm](t)*(lambda[4](t)-lambda[7](t))-(i[p](t)+i[pm](t))*lambda[5](t))/w[3]; u[4] := min(max(0, o), 1); o := (i[m](t)*lambda[3](t)-i[pm](t)*(lambda[4](t)-lambda[7](t))-(i[m](t)+i[pm](t))*lambda[6](t))/w[4]; u[2] := 0; u[3] := 0;
sys := diff(s(t), t) = Q+delta[1]*r[p](t)+delta[2]*r[m](t)+delta[3]*r[pm](t)-(a*(1-u[1])*(i[p](t)+i[pm](t))/n+b*(1-u[2])*(i[m](t)+i[pm](t))/n+mu)*s(t), diff(i[p](t), t) = (1-u[1])*a*(i[p](t)+i[pm](t))*s(t)/n-(1-u[2])*b*(i[m](t)+i[pm](t))*i[p](t)/n-(sigma[1]+u[3])*i[p](t)-(alpha[1]+mu)*i[p](t), diff(i[m](t), t) = (1-u[2])*b*(i[m](t)+i[pm](t))*s(t)/n-(1-u[1])*a*(i[p](t)+i[pm](t))*i[m](t)/n-(sigma[2]+u[4])*i[m](t)-(alpha[2]+mu)*i[m](t), diff(i[pm](t), t) = (1-u[2])*b*(i[m](t)+i[pm](t))*i[p](t)/n+(1-u[1])*a*(i[p](t)+i[pm](t))*i[m](t)/n-(y+u[3]+u[4])*i[pm](t)-(alpha[1]+alpha[2]+mu)*i[pm](t), diff(r[p](t), t) = (sigma[1]+u[3])*i[p](t)+(e*y+u[3])*i[pm](t)-(delta[1]+mu)*r[p](t), diff(r[m](t), t) = (sigma[2]+u[4])*i[m](t)+(y*g*(1-e)+u[4])*i[pm](t)-(delta[2]+mu)*r[m](t), diff(r[pm](t), t) = (y*(1-g)*(1-e)+u[3]+u[4])*i[pm](t)-(delta[3]+mu)*r[pm](t), diff(lambda[1](t), t) = lambda[1](t)*(a*(1-u[1])*(i[p](t)+i[pm](t))/n+b*(1-u[2])*(i[m](t)+i[pm](t))/n+mu)-lambda[2](t)*(1-u[1])*a*(i[p](t)+i[pm](t))/n-lambda[3](t)*(1-u[2])*b*(i[m](t)+i[pm](t))/n, diff(lambda[2](t), t) = -c[1]+lambda[1](t)*(1-u[1])*a*s(t)/n-lambda[2](t)*((1-u[1])*a*s(t)/n+b*(1-u[2])*(i[m](t)+i[pm](t))/n+sigma[1]+u[3]+alpha[1]+mu)-lambda[4](t)*(b*(1-u[2])*(i[m](t)+i[pm](t))/n+(1-u[1])*a*i[m](t)/n)-lambda[5](t)*(sigma[1]+u[3]), diff(lambda[3](t), t) = -c[2]+lambda[1](t)*(1-u[2])*b*s(t)/n+lambda[2](t)*(1-u[2])*b*i[p](t)/n-lambda[3](t)*(u[4]+alpha[2]+sigma[2]+a*(1-u[1])*(i[p](t)+i[pm](t))/n-(1-u[2])*b*s(t)/n)-lambda[4](t)*((1-u[2])*b*i[p](t)/n+a*(1-u[1])*(i[p](t)+i[pm](t))/n)-lambda[6](t)*(sigma[2]+u[4]), diff(lambda[4](t), t) = -c[3]+lambda[1](t)*((1-u[1])*a*s(t)/n+(1-u[2])*b*s(t)/n)-lambda[2](t)*((1-u[2])*b*i[p](t)/n+(1-u[1])*a*s(t)/n)-lambda[2](t)*((1-u[2])*a*i[m](t)/n+b*(1-u[1])*s(t)/n)-lambda[4](t)*(y+u[3]+u[4]+alpha[1]+alpha[2]+mu-(1-u[2])*b*i[p](t)/n-b*(1-u[1])*i[m](t)/n)-lambda[5](t)*(e*y+u[3])-lambda[6](t)*(y*g*(1-e)+u[4])-lambda[7](t)*(y*(1-g)*(1-e)+u[3]+u[4]), diff(lambda[5](t), t) = -lambda[1](t)*delta[1]+lambda[5](t)*(delta[1]+mu), diff(lambda[6](t), t) = -lambda[1](t)*delta[2]+lambda[6](t)*(delta[2]+mu), diff(lambda[7](t), t) = -lambda[1](t)*delta[3]+lambda[7](t)*(delta[3]+mu), i[p](0) = 300, i[m](0) = 200, i[pm](0) = 150, r[p](0) = 200, r[m](0) = 150, r[pm](0) = 150, s(0) = 1000, lambda[1](T) = 0, lambda[2](T) = 0, lambda[3](T) = 0, lambda[4](T) = 0, lambda[5](T) = 0, lambda[6](T) = 0, lambda[7](T) = 0;
p1 := dsolve({sys}, type = numeric, method = bvp[midrich], abserr = 0.1e-5, maxmesh = 2400);
p2o := odeplot(p1, [t, i[p](t)], 0 .. 3, numpoints = 100, labels = ["Time (Months)", " Population"], labeldirections = [horizontal, vertical], style = line, color = green, axes = boxed);
Can anyone help me please? I read some related problems here, but couldnt find a solution yet.
Thanks for your time
Best regards
hye, can someone help me to solve nonlinear schrodinger equation using maple? i attach with document
solution_nonlinear.pdf
  Hello:
     We know The FindMaximalElement(L) function returns the largest element of the list L .
   My questions is  How do I find the second largest element in a list and its index?
     Since there are so many lists to consider , Algorithmic Complexity may be as low as possible.
     More generally, we want to find the third-largest  element and so on.
     For instance, Given a list [3,2,3,6,8], we want to get 6 and 4 , since 6 is the  second largest element and 4 is its index.
  Licheng
Did someone already made a Pointplot3d for a Principal Components Analysis with projections for some data points on the eigenvectors?
I like this example very much:
http://www.joyofdata.de/public/pca-3d/
but I want to add projections on the three eigenvectors for some data points. I think it has to do something with the dot product, but I do not know how to do it in Maple.
Hopefully someone already did this and is willing to share it.
kind regards,
Harry
I'm new to Maple, and want to know what is the simpliest way to create additional electrical units like MVA and MVAr?
On the segment x ∈ [0,10] plot the numerical solution of the equation y '+ y = 2xsiny, satisfying the initial condition y (0) = 1.
What is wrong here? My solution:
I want to write a procedure called Resistance which calculates and displays the equivalent resistance to three resistors R1, R2 and R3
If the resistances are connected in series then Rser = R1 + R2 + R3
If the resistances are connected in parallel then (R1 * R2 * R3) / (R1 * R2 + R1 * R3 + R2 * R3) and after that, I must write an algorithm which I will test this resistance but it does not work please help me
"Resistance:=proc(R1,R2,R3) local Rser,Rpar,R; if(R=Rser)then Rser:=R1+R2+R3;   elif(R=Rpar)jthen Rpar:=(R1*R2*R3)/((R1*R2+R1*R3++R2*R3));  end if;  end proc;"
Error, unable to parse
"Resistance:=proc(R1,R2,R3) local Rser,Rpar,R; if(R=Rser)then Rser:=R1+R2+R3;   elif(R=Rpar) jthen Rpar:=(R1*R2*R3)/(R1*R2+R1*R3++R2*R3);  end if;  end proc;"
R1 := readstat(entrer*la*valeur*de*R1); R2 := readstat(entret*la*valeur*de*R2); R3 := readstat(entrer*la*valeur*de*R3); Resistance(R1, R2, R3); printf("la valeur en serie est:%f", Rser); printf("la valeur parallele est:%f", Rpar)
Download RESISTANCE.mw
First 701 702 703 704 705 706 707 Last Page 703 of 2433
