I have the following ODE perturbation problem which I want maple to solve for me:
q'(\tau)=f(p(eps*\tau)+eps*q(\tau),r(eps*\tau)+s(\tau))-f(p(eps*\tau,r(eps*\tau)+s(\tau))-f(p(eps*\tau),r(eps*\tau))
where q(\tau)=q_0(\tau)+eps*q_1(\tau)
p(eps*\tau)=p_0(eps*\tau)+eps*p_1(eps*\tau)
s(\tau)=s_0(\tau)+eps*s_1(\tau)
r(eps*\tau)=r_0(eps*\tau)+eps*r_1(eps*\tau)
I want maple to expand every function that depends on eps in its arguments by a Taylor series around eps=0, i.e h(eps)=h(0)+eps*h'(0)
and also expand the difference above the fs with an eps-expansion around eps=0.
I did all this manually now I want to check if my calculations are correct, eventaully I want to equate same powers of eps of the RHS and LHS of the first ODE I wrote above.
Then how to use maple for this?
Thnaks.
While using the RKF45 in MAPLE to solve ODE w.r.t. time, analysis results came out without any information regarding a total number of iterations or a total number of time steps used in the actual analysis.
I would like to know how can this information be checked in the MAPLE.
Thank you very much.
Does there exist a Maple command that on its own calculates the residual standard error of two regression lists?
Let p(x) be a real polynomial of degree 6.  You are given that p(−4+i)=0.  Find a real quadratic factor of p(x) and enter it in the box below using Maple syntax.  (Don't forget to use * for mulitplication.)
Ans=x^2+8*x+17
Please tell me how to combine the two graphics. I can't bring them together. question.mws
I have been using fsolve to derive constants for a polynomial. These are presented clearly in blue, but I am unable to reference these numbers for further calculations other than by typing them in manually. e.g. output is:
{d = 520.9032305, c = .41478630e-1, b = -.84548378e-5, a = .125070852e-8}
fsolve({y[1]=a*x[1]^3+b*x[1]^2+c*x[1]+d,y[2]=a*x[2]^3+b*x[2]^2+c*x[2]+d,
> y[3]=a*x[3]^3+b*x[3]^2+c*x[3]+d,y[4]=a*x[4]^3+b*x[4]^2+c*x[4]+d},{a,b,c,d});
I use dsolve( sys ode, ics)  and  dsolve( sys, ics, numeric) but both does not gives any solution of the system proposed.
May be I must fix some parameter or something else.
problemdisplaysolution.mw
many thinks
Help create file Excel in ExcelTools, but error row 564?
thu_file.mw
Please help me?
hi
i have a vector [V] and want to calculate f:=V^2;  and plot(V,f);how to do that?
i tried this but you can see in fig uploaded that an error occured.
I want to solve the transient heat diffusion equation in a semi-infinite solid, both analyticall and numerically:
BVP1 := { diff( theta(eta), eta, eta) +2 * eta * diff(theta(eta), eta), theta(infinity) = 0, theta(0) = 1 };
Analytically:
sol1 := dsolve(BVP1);
                   theta(eta) = 1 - erf(eta)
which is the correct exact self-similar solution.
Numerically:
dsolve(BVP1, numeric) ;
and I got this error message:
Error, (in dsolve/numeric/bvp/convertsys) too few boundary conditions: expected 3, got 2
Why does Maple need three conditions and what is this extra condition?
Thanks for your help.
restart:with(geometry):with(plots):
> S:=segment:L:=line:Per:=PerpendicularLine:
> R:=5:xA:=0:yA:=0:point(A,xA,yA):xI:=R/3:yI:=0:point(I1,xI,yI):
> circle(C,[A,R]):
> quadri:=proc(t)
> local xM,yM,xN,yN,xE,yE,dr1:
> xM:=evalf(R*cos(t)):yM:=evalf(R*sin(t)):point(M,xM,yM):L(lMI,[M,I1]):
> intersection('h',C,lMI,[M,N]):L(lAM,[A,M]):L(lAN,[A,N]):
> Per(lME,M,lAM):Per(lNE,N,lAN):intersection(E,lME,lNE):
> S(sAM,[A,M]):S(sAN,[A,N]):S(sME,[M,E]):S(sNE,[N,E]):
> dr1:=draw({lMI(color=blue),sAM(color=black),sAN(color=black),
> sME,sNE}):
> display({dr1}):
> end:
> dr:=draw({C},view=[-6..17,-10..6]):
> display([dr,quadri(0.7),quadri(1),quadri(1.2)],view=[-6..17,-10..6]); Thanks you.
Hii,
I am using a command -NLPSolve(Ecost1, Q = 10 .. 20, initialpoint = {Q = 10}, assume = nonnegative, maximize = false). I am looking for solution that find the Q value at the minimum value of Ecost1. But Ecost1 should not go below 0.
and also I am getting an error -Warning, initialpoint option ignored by solver.
Kindly tell how to deal with these issues.
Hi, How can I  to assign a sequence number once. For example,
I want to ‘a0,a1,......an is assigned to variables x0 , x1,......, xn,’
I used command line as following :
seq(x[i], i = 1 .. 5) := [1, 2, 3, 4, 5],error as follows,‘Error, invalid left hand side in assignment’
Any  suggestion?
I need help on solving the following PDE by Maple:
https://math.stackexchange.com/questions/3177491/how-to-solve-the-given-partial-differential-equation
I couldn't write the partial differential equation in Mapleprimes so provided the link from somewhere else. Please help. Thank you.
f :=2*sin(x^2/2)-sin(1*x/2)^2 In the interval [1,2] Find to the 10 significant figures the value of the second derivative at turning point
First 708 709 710 711 712 713 714 Last Page 710 of 2433
