What are the most efficient way to write and evaluate a procedure in maple? Thank you.
Dear sir,
I am using the Maple to solve pde equations but I am not getting analytical solutions for some of the equations. Can you please help me on how to solve one of the pde, like as I have
(sin(theta)^2*(diff(a(r, theta), r, r))+cos(theta)^2*(diff(a(r, theta), r))/r-sin(2*theta)*(diff(a(r, theta), theta))/r^2+sin(2*theta)*(diff(a(r, theta), theta, r))/r+cos(theta)^2*(diff(a(r, theta), theta, theta))/r^2)*`α__d`^2+cos(theta)^2*(diff(a(r, theta), r, r))+sin(theta)^2*(diff(a(r, theta), r))/r+sin(2*theta)*(diff(a(r, theta), theta))/r^2-sin(2*theta)*(diff(a(r, theta), theta, r))/r+sin(theta)^2*(diff(a(r, theta), theta, theta))/r^2 = 0
this equation is in polar corrdinates, this is analogous to diff(a(x, y), x, x)+`α__d`^2*(diff(a(x, y), y, y)) = 0
in cartesian coordinates
Duo:=proc(a)  #a nombre congruent connu
local u,v,n,m,k,t:
t:=8000:
for m to t do
  for n to m do
    if (igcd(m,n)=1 and m>n) then
      u:=(m^2-n^2-2*m*n)^2:v:=(m^2+n^2)^2:
      k:=op(2,sqrt(v-u))^2: # k nombre congruent réduit
        if k=a then return (m,n): break
        elif n=t then break fi:
    fi:
end:
Duo(30);
                              3, 2
Duo(1794);
                             26, 23
Duo(6);
                              2, 1
u, v, w sont des carrés en progression arithmétique dont la raison est un nombre congruent
Procédure permettant de trouver un triplet pythagoricien primitif correspondant au nombre congruent a connu
TriPy:=proc(m,n)# triangles pythagoriciens
local a,a1,b1,c1,d,k,q,u,v,w:
 u:=(m^2-n^2-2*m*n)^2:v:=(m^2+n^2)^2:w:=(m^2-n^2+2*m*n)^2:
 a:=(op(2,sqrt(v-u)))^2:#nombre congruent réduit
 a1:=2*m*n:b1:=(m^2-n^2):c1:=m^2+n^2:
 q:=sqrt((v-u)/a)/2:#rapport de réduction
 print(a1/q,b1/q,c1/q):fi
end:
TriPy(Duo(34));
                              17  145
                          24, --, ---
                              6    6
TriPy(Duo(39));
                          156  5  313
                           5   2  10
TriPy(Duo(111));
                         444  35  1513
                         35   2    70
TriPy(Duo(1794));
                         1196      1205
                         ----, 21, ----
                          7         7
TriPy(Duo(23));don't work, "part dans les choux"
Hi, how can you in maple take the derivitve of a function that consists of sum terms in it? (preferable in document mode)
For example I have this expression (from a math book):
f = N+k*(sum(ln(x__i-B), i = 1 .. N))-N*k*(sum((x__i-B)^k*ln(x__i-B), i = 1 .. N))/(sum((x__i-B)^k, i = 1 .. N))
What I then want to do is to derive this function with respect to k.
However just writing the expression like above it seems like mable doesn't keep the summation terms but evaluates them in a sense. So not sure how to set it up correctly in order to make the derivitive.
Taking the derivitive of f with respect to k, the solution should give something like this:
How  I can use from equations 1-6 and repleacing them into equation 7 to remove qx,qy,qz?
simpl2.mw
A := q__x(x, y, z, t)+`τ__q`*(diff(q__x(x, y, z, t), t))+(1/2)*`τ__q`^2*(diff(q__x(x, y, z, t), t, t)) = -k*(diff(T(x, y, z, t), x))-k*`τ__T`*(diff(T(x, y, z, t), x, t))-(1/2)*k*`τ__T`^2*(diff(T(x, y, z, t), x, t, t))
q__x(x, y, z, t)+tau__q*(diff(q__x(x, y, z, t), t))+(1/2)*tau__q^2*(diff(diff(q__x(x, y, z, t), t), t)) = -k*(diff(T(x, y, z, t), x))-k*tau__T*(diff(diff(T(x, y, z, t), t), x))-(1/2)*k*tau__T^2*(diff(diff(diff(T(x, y, z, t), t), t), x))
A__x := diff(A, x)
diff(q__x(x, y, z, t), x)+tau__q*(diff(diff(q__x(x, y, z, t), t), x))+(1/2)*tau__q^2*(diff(diff(diff(q__x(x, y, z, t), t), t), x)) = -k*(diff(diff(T(x, y, z, t), x), x))-k*tau__T*(diff(diff(diff(T(x, y, z, t), t), x), x))-(1/2)*k*tau__T^2*(diff(diff(diff(diff(T(x, y, z, t), t), t), x), x))
B := q__y(x, y, z, t)+`τ__q`*(diff(q__y(x, y, z, t), t))+(1/2)*`τ__q`^2*(diff(q__y(x, y, z, t), t, t)) = -k*(diff(T(x, y, z, t), y))-k*`τ__T`*(diff(T(x, y, z, t), y, t))-(1/2)*k*`τ__T`^2*(diff(T(x, y, z, t), y, t, t))
q__y(x, y, z, t)+tau__q*(diff(q__y(x, y, z, t), t))+(1/2)*tau__q^2*(diff(diff(q__y(x, y, z, t), t), t)) = -k*(diff(T(x, y, z, t), y))-k*tau__T*(diff(diff(T(x, y, z, t), t), y))-(1/2)*k*tau__T^2*(diff(diff(diff(T(x, y, z, t), t), t), y))
B__y := diff(B, y)
diff(q__y(x, y, z, t), y)+tau__q*(diff(diff(q__y(x, y, z, t), t), y))+(1/2)*tau__q^2*(diff(diff(diff(q__y(x, y, z, t), t), t), y)) = -k*(diff(diff(T(x, y, z, t), y), y))-k*tau__T*(diff(diff(diff(T(x, y, z, t), t), y), y))-(1/2)*k*tau__T^2*(diff(diff(diff(diff(T(x, y, z, t), t), t), y), y))
C := q__z(x, y, z, t)+`τ__q`*(diff(q__z(x, y, z, t), t))+(1/2)*`τ__q`^2*(diff(q__z(x, y, z, t), t, t)) = -k*(diff(T(x, y, z, t), z))-k*`τ__T`*(diff(T(x, y, z, t), z, t))-(1/2)*k*`τ__T`^2*(diff(T(x, y, z, t), z, t, t))
q__z(x, y, z, t)+tau__q*(diff(q__z(x, y, z, t), t))+(1/2)*tau__q^2*(diff(diff(q__z(x, y, z, t), t), t)) = -k*(diff(T(x, y, z, t), z))-k*tau__T*(diff(diff(T(x, y, z, t), t), z))-(1/2)*k*tau__T^2*(diff(diff(diff(T(x, y, z, t), t), t), z))
C__z := diff(C, z)
diff(q__z(x, y, z, t), z)+tau__q*(diff(diff(q__z(x, y, z, t), t), z))+(1/2)*tau__q^2*(diff(diff(diff(q__z(x, y, z, t), t), t), z)) = -k*(diff(diff(T(x, y, z, t), z), z))-k*tau__T*(diff(diff(diff(T(x, y, z, t), t), z), z))-(1/2)*k*tau__T^2*(diff(diff(diff(diff(T(x, y, z, t), t), t), z), z))
expand(simplify(-A__x-B__y-C__z+Q = rho*c__p*(diff(T(x, y, z, t), t))))
(-(diff(q__x(x, y, z, t), x))-tau__q*(diff(diff(q__x(x, y, z, t), t), x))-(1/2)*tau__q^2*(diff(diff(diff(q__x(x, y, z, t), t), t), x))-(diff(q__y(x, y, z, t), y))-tau__q*(diff(diff(q__y(x, y, z, t), t), y))-(1/2)*tau__q^2*(diff(diff(diff(q__y(x, y, z, t), t), t), y))-(diff(q__z(x, y, z, t), z))-tau__q*(diff(diff(q__z(x, y, z, t), t), z))-(1/2)*tau__q^2*(diff(diff(diff(q__z(x, y, z, t), t), t), z))+Q = k*(diff(diff(T(x, y, z, t), x), x))+k*tau__T*(diff(diff(diff(T(x, y, z, t), t), x), x))+(1/2)*k*tau__T^2*(diff(diff(diff(diff(T(x, y, z, t), t), t), x), x))+k*(diff(diff(T(x, y, z, t), y), y))+k*tau__T*(diff(diff(diff(T(x, y, z, t), t), y), y))+(1/2)*k*tau__T^2*(diff(diff(diff(diff(T(x, y, z, t), t), t), y), y))+k*(diff(diff(T(x, y, z, t), z), z))+k*tau__T*(diff(diff(diff(T(x, y, z, t), t), z), z))+(1/2)*k*tau__T^2*(diff(diff(diff(diff(T(x, y, z, t), t), t), z), z))+Q) = rho*c__p*(diff(T(x, y, z, t), t))
Download simpl2.mw
for x to 10 do Disp[x] := plot([x+cos(a), sin(a), a = 0 .. 2*Pi], colorscheme = ["Red", "Green"]) end do;
display(seq(Disp[i], i = 1 .. x-1), insequence = true, scaling = constrained);
What coding in the color or colorscheme parameter in the plot command above would rotate the circle's colors in conjunction with the circle's movement along the x axis to give the appearance of a rolling wheel?
I am submitting a maple job written in vim editor through windows 10 command line. but no result is obtained.I found maple gui version hang most of the time. So i decided to submit through command line by writing codes using an editor. Thank you
I'm trying to plot a function involving exp but keep getting warnings.
How can i avoid this?
plot(2*cos(t)/sqrt((1+exp(-eps*t))*(4/a^2-1)))
but getting the warning message
"Warning, unable to evaluate the function to numeric values in the region; complex values were detected"
I have made a document to give the results for a problem in table form and graph form.
The tables work out well. The graph results also come out well when I have that section alone in the document. But it does not give the updated curve here. Please correct me where I made mistake.
Cost in $:
Present Value:
Interest in % per year:         ``
 Period in years:
Additional Months
Principal $
Interest % per year
Year
Present value at the year end
4
5
UpdateExpr procedure does not update equation, instead turns out a value on LHS
Cost:
Interest % per year (float)
Startup Code Region contains all the codes.
Download Doubt_x_symbolic_required.mw
RC-Circuit:         (dv_c)/dt=((V(t)-v_c ))/RC
Assume thatV(t)=2 cos⁡(3t),R=4 ,C=0.5 . Use Euler’s method with a step size ofΔt=0.1to approximate the solution of IVP with initial conditionv_c (0)=2over the interval0≤t≤10 .
I can't find anything online on how to use Maple to solve this question, I have attempted it but want to make sure I did it correctly.
Use Maple to plot the approximate solution, the slope field, and (if possible) the exact solution on the same axes. Also compute the error between the approximate solution obtained from Euler’s Method and the exact solution at the right end-point of the given interval.
 1.      dy/dt=(3-y)(y+1)   ,   y(0)=4 ,        0≤t≤5 ,        Δt=1.0
LP_Matrix.pdf
I'm missing something basic here, I'm sure, and would love to know how to proceed.
I have extracted solutions to a particular optimization problem using LPSolve and have obtained the binary solutions in matrix form, for matrices, say .. X and Y.
The solutions are obtained using the routine in the attached pdf; these outputs are sufficient for the basic problem.
Now, I wish to use directed graphs to illustrate the solutions, so I need to take the output matrices to draw the graphs. However, I cannot seem to find a way to do this. The solutions are given, in this case, by 'X' and 'Y'.
Can anyone advise me on how to extract the matrices that can be used to draw the graphs using with(Graph Theory)?
Thanks in advance ...
I use MapleSim to model the dynamics of motorcycles.
I have been at MapleSim2018 for a few months and I have a problem of simplifying the equations generated by MapleSim from my model.
In MapleSim2018, he tells me:
Processing Equations...
SelectCompiler: Check for installed compiler successful
Simplifying system with 8919 equations
DSN/ix1lite: Warning, equation size increased past 100000 while performing equation simplification. Model will be simulated in partially unsimplified form
Simplification removed 8428 equations. Remaining equations: 491
Generating simulation code
the same model (exactly the same) in MapleSim2016, he tells me :
Simplifying system with 8942 equations
Simplification removed 8494 equations. Remaining equations: 448
When I generate code from two versions of Maple (2016 and 2018) and compile it into an executable, the MapleSim 2018 executable runs 20% slower than the MapleSim 2016 version of the executable (the results and the behavior of both models are equivalent)
It is very strange that a new version of MapleSim generates a slower code than the old version. it may be due to the limitation of DSN / ix1lite in MapleSim2018 ... while MapleSim2016 does not have this limitation (with more equations to simplify!).
I need help, if it is possible to activate the complete simplification in DSN / ix1lite?
it is a big problem for me, the use of MapleSim2018 is not possible because of that. My model does not pass in real time.
thanks.
> solve({lambda[2]*mu[2]^2*(lambda[2]+mu[2])*lambda[1]/(4*mu[2]^4+4*mu[2]^3*lambda[2]+3*mu[2]^2*lambda[2]^2+2*mu[2]*lambda[2]^3+lambda[2]^4)+lambda[2]*mu[2]*(mu[2]^2+mu[2]*lambda[2]+lambda[2]^2)*lambda[1]/(4*mu[2]^4+4*mu[2]^3*lambda[2]+3*mu[2]^2*lambda[2]^2+2*mu[2]*lambda[2]^3+lambda[2]^4)+mu[2]^4*lambda[2]*lambda[1]/((lambda[1]+mu[2])*(4*mu[2]^4+4*mu[2]^3*lambda[2]+3*mu[2]^2*lambda[2]^2+2*mu[2]*lambda[2]^3+lambda[2]^4))+(1/2)*(mu[2]^3*lambda[1]+mu[2]^3*lambda[2]+lambda[1]*lambda[2]*mu[2]^2+mu[2]^2*lambda[2]^2+mu[2]*lambda[2]^3+mu[2]*lambda[1]*lambda[2]^2+lambda[1]*lambda[2]^3)*lambda[2]*lambda[1]/((lambda[1]+mu[2])*(4*mu[2]^4+4*mu[2]^3*lambda[2]+3*mu[2]^2*lambda[2]^2+2*mu[2]*lambda[2]^3+lambda[2]^4))+3*mu[2]^4*lambda[1]/(4*mu[2]^4+4*mu[2]^3*lambda[2]+3*mu[2]^2*lambda[2]^2+2*mu[2]*lambda[2]^3+lambda[2]^4)+mu[1]*mu[2]^4*lambda[1]/((4*mu[2]^4+4*mu[2]^3*lambda[2]+3*mu[2]^2*lambda[2]^2+2*mu[2]*lambda[2]^3+lambda[2]^4)*(lambda[2]+mu[1]))+mu[2]^4*lambda[2]*lambda[1]/((4*mu[2]^4+4*mu[2]^3*lambda[2]+3*mu[2]^2*lambda[2]^2+2*mu[2]*lambda[2]^3+lambda[2]^4)*(lambda[2]+mu[1]))+mu[2]^3*lambda[2]*lambda[1]/(4*mu[2]^4+4*mu[2]^3*lambda[2]+3*mu[2]^2*lambda[2]^2+2*mu[2]*lambda[2]^3+lambda[2]^4)+(1/2)*(mu[2]^3*lambda[1]+mu[2]^3*lambda[2]+lambda[1]*lambda[2]*mu[2]^2+mu[2]^2*lambda[2]^2+mu[2]*lambda[2]^3+mu[2]*lambda[1]*lambda[2]^2+lambda[1]*lambda[2]^3)*lambda[2]*lambda[1]/(4*mu[2]^5+4*mu[2]^4*lambda[1]+4*mu[2]^4*lambda[2]+4*mu[2]^3*lambda[1]*lambda[2]+3*mu[2]^3*lambda[2]^2+3*lambda[1]*lambda[2]^2*mu[2]^2+2*mu[2]^2*lambda[2]^3+2*lambda[1]*lambda[2]^3*mu[2]+mu[2]*lambda[2]^4+lambda[1]*lambda[2]^4)-3*mu[1]*mu[2]^4/(4*mu[2]^4+4*mu[2]^3*lambda[2]+3*mu[2]^2*lambda[2]^2+2*mu[2]*lambda[2]^3+lambda[2]^4)+mu[1]*mu[2]^4*lambda[2]/((4*mu[2]^4+4*mu[2]^3*lambda[2]+3*mu[2]^2*lambda[2]^2+2*mu[2]*lambda[2]^3+lambda[2]^4)*(lambda[2]+mu[1]))+mu[1]^2*mu[2]^4/((4*mu[2]^4+4*mu[2]^3*lambda[2]+3*mu[2]^2*lambda[2]^2+2*mu[2]*lambda[2]^3+lambda[2]^4)*(lambda[2]+mu[1])) < 0}, [lambda[1]]);
Here's a problem that's been bothering me for a long time:
The Statistics[Distribution] help page describes the way to construct one's own Random Variable (RV).
All the examples construct a distribution foo := Distribution(...) next used to define the RV X by typing
X := RandomVariable(foo)
On the other way, constructing a RV Y from predefined Maple's distributions writes
Y := RandomVariable(bar(sequence of parameters))
The "user defined RV feature" (MyRV := RandomVariable(foo)) seems to be restricted to distributions where all the parameters are numerically instanciated, contrary to "Maple's defined distributions" where these parameters can be kept formal).
So my question: Is it possible to define your own Distribution (module foo) in such a way that the definition of the RV X writes
X := RandomVariable(foo(sequence of parameters))
The attached file contains an example for the Levy distribution (the second part is just a workaround where a substitution is used to balance my inability to define a RV the way above)
with(Statistics):
A particular Levy distribution
Levy Distribution  Levy(m=0, s=1)
m : location parameter
s := dispersion parameter
m := 0:
s := 1:
pdf := unapply(piecewise(x<0, 0, sqrt(s/2/Pi)*exp(-s/2/(x-m))/(x-m)^(3/2)), x);
cdf := unapply(erfc(sqrt(s/2/(x-m))), x);
samplingMethod := proc(N)
                     m +~ s /~ ( Quantile~(Normal(0, 1), Sample(Uniform(1/2, 1), N)) )^~2
proc (x) options operator, arrow; piecewise(x < 0, 0, (1/2)*2^(1/2)*exp(-(1/2)/x)/(Pi^(1/2)*x^(3/2))) end proc
proc (x) options operator, arrow; erfc((1/2)*2^(1/2)*(1/x)^(1/2)) end proc
proc (N) `~`[:-`+`](m, ` $`, `~`[:-`/`](s, ` $`, `~`[:-`^`](`~`[Statistics:-Quantile](Normal(0, 1), Statistics:-Sample(Uniform(1/2, 1), N)), ` $`, 2))) end proc
Levy := Distribution(
                      PDF=(x->pdf(x)),
                      CDF= (x->cdf(x)),
                      RandomSample = (N->samplingMethod(N))
_m4561537536
X := RandomVariable(Levy):
PDF(X, x);
Sample(X, 5);
piecewise(x < 0, 0, (1/2)*sqrt(2)*exp(-1/(2*x))/(sqrt(Pi)*x^(3/2)))
Vector[row]([.569870365734461, .357020836498979, 39.1445163385190, .340597592385078, 1.23209867072410])
How should I define a formal Levy distribution in such a way that, as for any predefined RV in Maple,
a particular instance is defined by  X := RandomVariable(Levy(M, S))
where M and S are numerical values?
m := 'm':
s := 's':
proc (x) options operator, arrow; piecewise(x < 0, 0, (1/2)*2^(1/2)*(s/Pi)^(1/2)*exp(-(1/2)*s/(x-m))/(x-m)^(3/2)) end proc
proc (x) options operator, arrow; erfc((1/2)*2^(1/2)*(s/(x-m))^(1/2)) end proc
                      PDF=(x->pdf(x)),
                      CDF= (x->cdf(x)),
PDF(X, x);
print();
# here is an inelegant workaround
ms := {m=0, s=1};
subs(ms, PDF(X, x));
piecewise(x < 0, 0, (1/2)*sqrt(2)*sqrt(s/Pi)*exp(-(1/2)*s/(x-m))/(x-m)^(3/2))
ms := {m = 0, s = 1}
piecewise(x < 0, 0, (1/2)*2^(1/2)*(1/Pi)^(1/2)*exp(-(1/2)/x)/x^(3/2))
u := Sample(X, 2);
# The substitution doesn't work
subs(ms, u);
u := Vector[row](2, {(1) = m+HFloat(1.7545213270590625)*s, (2) = m+HFloat(0.332342758403606)*s})
Vector[row]([m+1.75452132705906*s, m+.332342758403606*s])
# just a copy-paste of lprint(u): the substitution does work
lprint(u);
subs(ms, Vector[row](2, {1 = m+HFloat(2.49542958430755446)*s, 2 = m+HFloat(4.80772083491271562)*s}, datatype = anything, storage = rectangular, order = Fortran_order, shape = []))
Vector[row](2, {1 = m+HFloat(.529024707466874800)*s, 2 = m+HFloat(1.50334452451578438)*s}, datatype = anything, storage = rectangular, order = Fortran_order, shape = [])
Vector[row]([2.49542958430755, 4.80772083491272])
Download My-own-random-variable.mw
First 718 719 720 721 722 723 724 Last Page 720 of 2433
