Recently a few questions concerning the sampling of the Cauchy distribution and the sampling of a truncated Normal distribution have been posted (mainly by  @jalale).
This post is concerned by the sampling of a truncated (standard) Cauchy distribution.
In a first part the efficiency fo two methods is adressed in the case of a non-truncated Cauchy distribution:
  • The "standard" Maple's command Statistics:-Sample(Cauchy(0, 1), N)
  • And a general method a priori very efficient if one knows the ICDF (Inverse Cumulative Function Distribution). It happens that this ICDF is just cot(U*Pi)  where U is a Uniform RV over [0, 1].
The second part adresses the sampling of a truncatedCauchy distribution with two methods:
  • The "standard" Maple's command Statistics:-Sample(Cauchy(0, 1), N, method=[envelope, range=...])
  • The method based on the use of the ICDF
Results:
Test1 (non-truncated Cauchy distribution)
  • "Standard" Maples sampling outperforms the ICDF based method in terms of :
    • memory occupation: ICDF is twice more demanding
    • cpu time: ICDF is ten times slower
Test2 (truncated Cauchy distribution)
  • ICDF based method i outperforms "Standard" Maples sampling oin terms of :
    • memory occupation: Maples "envelope sampling" method is twice more demanding
    • cpu time: Maples "envelope sampling" method is two times slower
But, beyond these simple observations, a disturbing problem is: the "envelope sampling" method seems to not return the correct distribution (at least when used this waymethod=[envelope, range=a..b]  with a < b)
This is confirmed by the two last plot where histogram and PDF are uperimposed.
Do you think this problem can be avoided by another parameterization of the "envelope sampling" method or that it reveals some underlying problem with it?
PS: I did not investigate further for other distributions .
Sampling the Cauchy distribution
Maple's default sampling method outperformes the adhoc method
with(Statistics):
C := RandomVariable(Cauchy(0, 1))
_R
f := unapply(CDF(C, t), t);
proc (t) options operator, arrow; 1/2+arctan(t)/Pi end proc
finv := unapply(-solve(f(t)=u, t), u)
proc (u) options operator, arrow; cot(u*Pi) end proc
# "natural" way to proceed
N  := 10^6:
S1 := CodeTools:-Usage(Sample(C, N)):
memory used=7.71MiB, alloc change=39.63MiB, cpu time=69.00ms, real time=69.00ms, gc time=8.72ms
# Let's try the sampling strategy based on the inverse of the CDF
# Usually it starts from sampling a Uniform RV on [0, 1] and
# next applies finv to the result.
# Smart but inefficient
U  := RandomVariable(Uniform(0., 1)):
S2 := CodeTools:-Usage(finv~(Sample(U, N))):
memory used=145.02MiB, alloc change=7.63MiB, cpu time=4.94s, real time=3.04s, gc time=2.61s
# Much more efficient
# Given the special form of finv it's simpler to sample a Unirorm RV
# on [0, Pi] and apply "cot" to the result
pi := evalf(Pi):
U  := RandomVariable(Uniform(0., pi)):
S2 := CodeTools:-Usage(cot~(Sample(U, N))):
memory used=15.28MiB, alloc change=0 bytes, cpu time=652.00ms, real time=237.00ms, gc time=577.78ms
Sampling a truncated Cauchy distribution
Example 1:
with(Statistics) + method=[envelope, range=-10..10]
The adhoc method outperforms Maple's default sampling method
S1 := CodeTools:-Usage(Sample(C, N, method=[envelope, range=-10..10])):
Histogram(S1);
memory used=8.88MiB, alloc change=-7.63MiB, cpu time=322.00ms, real time=260.00ms, gc time=93.77ms
p  := Probability(C < -10, numeric);
q  := 1-Probability(C > +10, numeric);
U  := RandomVariable(Uniform(p*pi, q*pi)):
Histogram(S2);
HFloat(0.03172551743055352)
HFloat(0.9682744825694465)
memory used=15.28MiB, alloc change=7.63MiB, cpu time=170.00ms, real time=113.00ms, gc time=92.11ms
Example 2:
with(Statistics) + method=[envelope, range=-1..1]
The adhoc method outperformes Maple's default sampling method
S1 := CodeTools:-Usage(Sample(C, N, method=[envelope, range=-1..1])):
scaling := Probability(C < +1, numeric) - Probability(C < -1, numeric);
plots:-display( Histogram(S1), plot(PDF(C, t)/scaling, t=-1..1, thickness=3, color=red) );
memory used=8.08MiB, alloc change=0 bytes, cpu time=246.00ms, real time=215.00ms, gc time=46.62ms
HFloat(0.5)
p  := Probability(C < -1, numeric);
q  := 1-Probability(C > +1, numeric);
plots:-display( Histogram(S2), plot(PDF(C, t)/scaling, t=-1..1, thickness=3, color=red) );
HFloat(0.25)
HFloat(0.75)
memory used=15.28MiB, alloc change=7.63MiB, cpu time=163.00ms, real time=106.00ms, gc time=85.93ms
Download CAUCHY_adhoc-sampling.mw
Please download the attachment.
I try to find a relation between EL and Lap(EL) in polar coordinate for one variable function w(r), where Lap is laplacian and EL is Euler Lagrange equation. Please check the Maple code and help me to do some manipulations to find a general relation (if any relation exists!).
In fact I need the inverse of Euler Lagrange equation to obtain f(r) for an arbitrary function g(r) in equation below
EL(f) = Lap(EL(g))
Or f=inverseEL(Lap(EL(g)))
Thank you for taking your time
restart; s := proc (f) subs(d[0] = w(r), seq(d[n] = diff(w(r), `$`(r, n)), n = 1 .. 10), f) end proc; ss := proc (f) subs(seq(diff(w(r), `$`(r, 11-n)) = d[11-n], n = 1 .. 10), w(r) = d[0], f) end proc; EL := proc (eq) s(diff(ss(eq), d[0]))+add((diff(s(diff(ss(eq), d[n])), `$`(r, n)))*(-1)^n, n = 1 .. 10) end proc
f := (diff(w(r), r, r))^2*r^4+4*r^6*(diff(w(r), r, r, r))^2:
a1 := EL(F):
a2 := VectorCalculus:-Laplacian(EL(f), 'polar[r, t]'):
simplify(a1-a2)
8*r^6*(diff(diff(diff(diff(diff(diff(diff(diff(w(r), r), r), r), r), r), r), r), r))+248*r^5*(diff(diff(diff(diff(diff(diff(diff(w(r), r), r), r), r), r), r), r))+2582*r^4*(diff(diff(diff(diff(diff(diff(w(r), r), r), r), r), r), r))+10910*r^3*(diff(diff(diff(diff(diff(w(r), r), r), r), r), r))+17786*r^2*(diff(diff(diff(diff(w(r), r), r), r), r))+8192*r*(diff(diff(diff(w(r), r), r), r))-92*(diff(diff(w(r), r), r))
Download EL.mw
Dear Experts,
I am new user. I need your help!
I have numerical values of omega (w) and a2F(w) (500 rows). I need to do cumulative summation to get lambda(w) using   lambd=2 int (a2F(w)/w  dw). Please help me how can I do it?
Best Wishes,
Enamul Haque
I am revising the unstable period orbits of the Logistic map, y[n]=4*y[n-1]*(1-y[n]), in Maple.  Although I have implemented the equation and use a loop for the iterations, I wonder whether there is a faster and concise way to code the equation in Maple.
Here it is what I did:
y[0] := (-sqrt(5)+5)*(1/8);
for n to 10 do y[n] := 4*y[n-1]*(1-y[n-1]) end do;
soly := [seq(simplify(expand(y[n]), radical), n = 0 .. 10)];
dat := [seq([n, Re(evalf(soly[n]))], n = 1 .. 10)]; plot(dat, labels = ["k", "x(k)"], style = pointline,title="Period 2");
Since only few iterations are needed, the solution is symbolic (and then convert to float).
Many thanks.
Ed
Hi guys,
This is the first time of solving partial differential equation, can some please help me point out some errows in my code.
ODEs := `<,>`(diff(v(y), y, y)+(diff(v(y), y))/y-(Ha^2/(1-eta)^2+1/y^2)*v(y)-Re*v(y)*(diff(v(y), y)) = 0, diff(theta(y), y, y)+Ec*Pr*(diff(v(y), y)-v(y)/y)^2-Pr*Re*v(y)*(diff(theta(y), y))+Nb*(diff(theta(y), y))*(diff(phi(y), y))+Nt*(diff(theta(y), y))^2 = 0, diff(phi(y), y, y)-Re*Sc*v(y)*(diff(phi(y), y))+Nt*(diff(theta(y), y, y)+(diff(theta(y), y))/y)/Nb = 0)
ODEs := Matrix(3, 1, {(1, 1) = diff(diff(v(y), y), y)+(diff(v(y), y))/y-(Ha^2/(1-eta)^2+1/y^2)*v(y)-Re*v(y)*(diff(v(y), y)) = 0, (2, 1) = diff(diff(theta(y), y), y)+Ec*Pr*(diff(v(y), y)-v(y)/y)^2-Pr*Re*v(y)*(diff(theta(y), y))+Nb*(diff(theta(y), y))*(diff(phi(y), y))+Nt*(diff(theta(y), y))^2 = 0, (3, 1) = diff(diff(phi(y), y), y)-Re*Sc*v(y)*(diff(phi(y), y))+Nt*(diff(diff(theta(y), y), y)+(diff(theta(y), y))/y)/Nb = 0})
BCs := `<,>`(phi(eta) = 1, v(eta) = 1, theta(eta) = 1, phi(1) = 0, theta(1) = 0, v(1) = 0)
BCs := Matrix(6, 1, {(1, 1) = phi(eta) = 1, (2, 1) = v(eta) = 1, (3, 1) = theta(eta) = 1, (4, 1) = phi(1) = 0, (5, 1) = theta(1) = 0, (6, 1) = v(1) = 0})
param_names := [eta, Ha, Ec, Nt, Nb, Re, Sc, Pr];
pdSolve := subs(_P = param_names, proc ({ eta::realcons := .5, Ha::realcons := 1, Sc::realcons := .8, Nt::realcons := .1, Nb::realcons := .1, Re::realcons := 2, Ec::realcons := 0.1e-1, Pr::realcons := 10 }) userinfo(1, Solve, `~`[`=`](param_names, _P)); dsolve(eval(`union`(convert(ODEs, set), convert(BCs, set)), `~`[`=`](param_names, _P)), numeric) end proc);
proc ({ Ec::realcons := 0.1e-1, Ha::realcons := 1, Nb::realcons := .1, Nt::realcons := .1, Pr::realcons := 10, Re::realcons := 2, Sc::realcons := .8, eta::realcons := .5 }) userinfo(1, Solve, `~`[`=`](param_names, [eta, Ha, Ec, Nt, Nb, Re, Sc, Pr])); dsolve(eval(`union`(convert(ODEs, set), convert(BCs, set)), `~`[`=`](param_names, [eta, Ha, Ec, Nt, Nb, Re, Sc, Pr])), numeric) end proc
infolevel[Solve] := 1:
Fig. 3 (changing values of Ha):
P:= Ha:
vals:= [1, 5, 10, 20]:
sols:= [seq(Solve(P= v), v= vals)]:
colors:= [red, green, blue]:
for F in [v,theta,phi](y) do
   print(plots:-display(
      [seq(
         plots:-odeplot(sols[k], [y,F], color= colors[k], legend= [P= vals[k]]),
         k= 1..nops(vals)
      labeldirections= [horizontal,vertical]
Error, pdeplot is not a command in the plots package
Download chapter5.mw
How can I use Maple to solve a difference quotient problem? How do I enter the basic difference quotient formula and the quadratic equation to be used in the problem?
1.47449729919434*10^10*c[0, 1]*c[0, 2]*c[2, 2]*c[3, 0]+3.38624318440755*10^8*c[0, 1]*c[0, 3]*c[1, 0]*c[2, 1]+1.54309415817260*10^10*c[0, 1]*c[0, 3]*c[1, 3]*c[2, 0]+1.69527735464914*10^14*c[0, 2]*c[0, 3]*c[1, 3]*c[3, 3]+5.64571777979530*10^11*c[0, 1]*c[1, 3]*c[3, 0]*c[3, 1]+5.64571777979530*10^11*c[0, 1]*c[1, 1]*c[3, 0]*c[3, 3]+3.44365358352662*10^11*c[0, 1]*c[1, 1]*c[3, 1]*c[3, 2]+4.56141047477722*10^11*c[0, 1]*c[0, 2]*c[2, 1]*c[3, 3]+1.47449729919434*10^10*c[0, 1]*c[0, 2]*c[2, 0]*c[3, 2]+1.00292015075684*10^10*c[0, 1]*c[0, 2]*c[2, 1]*c[3, 1]+4.96419365552208*10^14*c[1, 1]*c[2, 3]*c[3, 1]*c[3, 2]+2.41547661753786*10^16*c[1, 1]*c[2, 3]*c[3, 2]*c[3, 3]+3.09237360954284*10^11*c[0, 2]*c[1, 1]*c[1, 3]*c[3, 1]+2.07077209298372*10^13*c[0, 2]*c[2, 2]*c[2, 3]*c[3, 0]+2.77395036220550*10^11*c[0, 2]*c[1, 1]*c[1, 2]*c[3, 2]+3.25883571082134*10^15*c[1, 2]*c[2, 3]*c[3, 1]*c[3, 2]+2.77442234357198*10^11*c[0, 2]*c[1, 1]*c[2, 1]*c[2, 3]+7.80736282336175*10^14*c[2, 0]*c[2, 1]*c[3, 2]*c[3, 3]+3.25883571082134*10^15*c[1, 2]*c[2, 2]*c[3, 1]*c[3, 3]+5.35593751087840*10^15*c[1, 2]*c[2, 3]*c[3, 0]*c[3, 3]+3.63255405301248*10^15*c[1, 1]*c[2, 3]*c[3, 1]*c[3, 3]+3.25883571082134*10^15*c[1, 2]*c[2, 1]*c[3, 2]*c[3, 3]+1.48022406855142*10^13*c[1, 0]*c[2, 1]*c[2, 2]*c[3, 3]+5.19766484559825*10^15*c[0, 1]*c[2, 3]*c[3, 2]*c[3, 3]+3.63255405301248*10^15*c[1, 3]*c[2, 1]*c[3, 1]*c[3, 3]+1.03156027712140*10^14*c[0, 3]*c[1, 2]*c[1, 3]*c[2, 3]+6.84418565576730*10^13*c[1, 1]*c[1, 2]*c[1, 3]*c[3, 3]+1.36253689407226*10^13*c[0, 1]*c[1, 2]*c[2, 3]*c[3, 2]+4.50722523384354*10^11*c[0, 1]*c[0, 2]*c[1, 2]*c[3, 3]+4.63272867590191*10^14*c[1, 1]*c[1, 3]*c[2, 3]*c[3, 2]+9.56722337372450*10^9*c[0, 1]*c[0, 2]*c[1, 2]*c[1, 3]+7.56283392524430*10^14*c[0, 3]*c[1, 1]*c[2, 3]*c[3, 3]+1.51879056084535*10^13*c[0, 3]*c[1, 1]*c[2, 3]*c[3, 1]+8.15436050904650*10^14*c[1, 1]*c[2, 3]*c[3, 0]*c[3, 3]+1.51879056084535*10^13*c[0, 1]*c[1, 1]*c[2, 3]*c[3, 3]+3.05712170936082*10^11*c[0, 1]*c[1, 1]*c[1, 3]*c[2, 3]+2.21942429315476*10^9*c[0, 1]*c[0, 2]*c[1, 0]*c[3, 2]+1.50960286458333*10^9*c[0, 1]*c[0, 2]*c[1, 1]*c[3, 1]+6.37602806091310*10^9*c[0, 1]*c[1, 1]*c[1, 2]*c[1, 3]+2.22015380859375*10^7*c[0, 0]*c[1, 0]*c[1, 1]*c[3, 0]+2.24812825520834*10^6*c[0, 0]*c[0, 1]*c[1, 0]*c[2, 1]+2.24812825520834*10^6*c[0, 0]*c[0, 1]*c[1, 1]*c[2, 0]+4.45556640625000*10^5*c[0, 0]*c[0, 1]*c[0, 2]*c[1, 0]+1.80236816406250*10^7*c[0, 0]*c[0, 2]*c[0, 3]*c[1, 0]+9.99813988095240*10^6*c[0, 1]*c[1, 0]*c[1, 1]*c[2, 0]+1.64310515873016*10^7*c[0, 0]*c[0, 1]*c[1, 0]*c[3, 1]+1.09924316406250*10^7*c[0, 0]*c[0, 1]*c[0, 2]*c[1, 2]+1.22578938802084*10^7*c[0, 0]*c[0, 1]*c[0, 3]*c[1, 1]+6.74438476562500*10^5*c[0, 0]*c[0, 1]*c[1, 0]*c[2, 0]+3.27484130859375*10^7*c[0, 0]*c[0, 1]*c[2, 0]*c[3, 0]+4.96419365552208*10^14*c[1, 1]*c[2, 2]*c[3, 1]*c[3, 3]+1.48022406855142*10^13*c[1, 2]*c[2, 0]*c[2, 1]*c[3, 3]+1.48022406855142*10^13*c[1, 2]*c[2, 0]*c[2, 3]*c[3, 1]+7.00457388588595*10^14*c[1, 2]*c[2, 0]*c[2, 3]*c[3, 3]+9.01806926154510*10^12*c[1, 2]*c[2, 1]*c[2, 2]*c[3, 1]+4.26195329427362*10^14*c[1, 1]*c[2, 2]*c[2, 3]*c[3, 2]+8.70017911044035*10^14*c[1, 1]*c[3, 0]*c[3, 2]*c[3, 3]+1.64960358855012*10^13*c[1, 2]*c[1, 3]*c[3, 0]*c[3, 1]+8.70017911044035*10^14*c[1, 3]*c[3, 0]*c[3, 1]*c[3, 2]+4.11701503132284*10^16*c[1, 3]*c[3, 0]*c[3, 2]*c[3, 3]+1.32823657812862*10^13*c[2, 0]*c[2, 1]*c[2, 2]*c[2, 3]+2.49782355477406*10^13*c[0, 1]*c[0, 3]*c[3, 1]*c[3, 3]+1.86077008928572*10^7*c[0, 0]*c[0, 1]*c[0, 2]*c[0, 3]+4.50750425170068*10^11*c[0, 3]*c[1, 2]*c[1, 3]*c[2, 0]+2.41765159606934*10^10*c[0, 0]*c[0, 2]*c[2, 0]*c[3, 3]+1.28155946659681*10^15*c[2, 0]*c[2, 3]*c[3, 0]*c[3, 3]+7.80736282336175*10^14*c[2, 0]*c[2, 3]*c[3, 1]*c[3, 2]+2.95015059452266*10^13*c[2, 0]*c[2, 3]*c[3, 0]*c[3, 1]+1.64424324035644*10^10*c[0, 1]*c[0, 3]*c[2, 0]*c[3, 1]+7.80736282336175*10^14*c[2, 0]*c[2, 2]*c[3, 1]*c[3, 3]+3.38624318440755*10^8*c[0, 1]*c[0, 3]*c[1, 1]*c[2, 0]+6.83811849201320*10^14*c[0, 2]*c[2, 1]*c[2, 3]*c[3, 3]+4.96419365552208*10^14*c[1, 1]*c[2, 1]*c[3, 2]*c[3, 3]+4.50722523384354*10^11*c[0, 1]*c[0, 2]*c[1, 3]*c[3, 2]+2.74640085129511*10^12*c[0, 3]^2*c[1, 3]*c[3, 0]+4.53797990504672*10^10*c[0, 2]^2*c[2, 0]*c[2, 3]+2.76260943995885*10^10*c[0, 2]^2*c[2, 1]*c[2, 2]+5.63905988420760*10^10*c[0, 3]^2*c[1, 0]*c[3, 1]+2.74640085129511*10^12*c[0, 3]^2*c[1, 0]*c[3, 3]+5.63905988420760*10^10*c[0, 3]^2*c[1, 1]*c[3, 0]+1.67039675031390*10^12*c[0, 3]^2*c[1, 1]*c[3, 2]+1.67039675031390*10^12*c[0, 3]^2*c[1, 2]*c[3, 1]
When I try to calculate the derivative of a covariant metric with respect to the corresponding contravariant metric, or vice versa, the result is correct up to the sign, which is wrong:
diff(g_[nu, tau], g_[~mu, ~eta]);
Maple's result: g_[eta, nu] g_[mu, tau]
Correct result: -g_[eta, nu] g_[mu, tau]
diff(g_[~nu, ~tau], g_[mu, eta]);
Maple's result: g_[~eta, ~nu] g_[~mu, ~tau]
Correct result: -g_[~eta, ~nu] g_[~mu, ~tau]
I've loaded DifferentialGeometry, Tensor, Physics. Is this my fault, or Maple's?
Dear friends,
I have attached a document with two commands  in slider0 for plotting the same graph in two plot components.
use DocumentTools in
a := Do(%Slider0/100);
b := Do(%Slider1/100);
Do(%Plot0 = plot(sin(a*x)+cos(b*x^2),x=0..10,y=-3..3));
SetProperty("Plot1",value,plot(sin(a*x)+cos(b*x^2),x=0..10,y=-3..3));
end use;
I am just curious to know which one is better and when?
Download DoubtOnLatestCodesinEmbeddedPlot.mw
Thanks for answers.
Ramakrishnan V
A[0] := 0;
A[1] := sqrt(2*(k[1]^2-w[1]^2))/n;
                                       (1/2)
                    /      2         2\
                    \2 k[1]  - 2 w[1] /
                               n
A[2] := sqrt(2*(k[2]^2-w[2]^2))/n;
                                       (1/2)
                    /      2         2\
                    \2 k[2]  - 2 w[2] /
                               n
c[1] := 1;
c[2] := 1;
c[3] := 1;
c[4] := 1;
c[5] := 1;
c[6] := 1;
k[1] := 10.5;
                              10.5
k[2] := 3.5;
                              3.5
w[1] := 5.05;
                              5.05
w[2] := .5;
                              0.5
m := 1.9;
                              1.9
n := 1.75;
                              1.75
xi[1] := -t*w[1]+x*k[1];
                        -5.05 t + 10.5 x
xi[2] := -t*w[2]+x*k[2];
                         -0.5 t + 3.5 x
a := m/sqrt(2*(k[1]^2-w[1]^2));
                          0.1459402733
b := m/sqrt(k[2]^2-w[2]^2);
                          0.5484827558
g := a*(c[2]*exp(a*xi[1])+c[3]*exp(-a*xi[1]));
     0.1459402733 exp(-0.7369983802 t + 1.532372870 x)
        + 0.1459402733 exp(0.7369983802 t - 1.532372870 x)
h := c[1]+c[2]*exp(a*xi[1])+c[3]*exp(-a*xi[1]);
            1 + exp(-0.7369983802 t + 1.532372870 x)
               + exp(0.7369983802 t - 1.532372870 x)
G := b*(c[5]*exp(b*xi[2])+c[6]*exp(-b*xi[2]));
     0.5484827558 exp(-0.2742413779 t + 1.919689645 x)
        + 0.5484827558 exp(0.2742413779 t - 1.919689645 x)
H := c[4]+c[5]*exp(b*xi[2])+c[6]*exp(-b*xi[2]);
            1 + exp(-0.2742413779 t + 1.919689645 x)
               + exp(0.2742413779 t - 1.919689645 x)
u := A[0]+A[1]*[g/h]+A[2]*[G/H];
[(2.799416849 (0.5484827558 exp(-0.2742413779 t + 1.919689645 x)
   + 0.5484827558 exp(0.2742413779 t - 1.919689645 x)))/(1
   + exp(0.2742413779 t - 1.919689645 x)) + (7.439442594
  (0.1459402733 exp(-0.7369983802 t + 1.532372870 x)
   + 0.1459402733 exp(0.7369983802 t - 1.532372870 x)))/(1
   + exp(0.7369983802 t - 1.532372870 x))]
plot3d(u, x = -20 .. .20, t = -20 .. .20);
t := 0;
plot(u, x = -15 .. 15);
Error, (in plot) found points with fewer or more than 2 components
fgure set 1;
Error, missing operation
 Typesetting:-mambiguous(fgure Typesetting:-mambiguous(set 1,
   Typesetting:-merror("missing operation")))
l := 4;
                               4
m := 1;
n := 2;
k := 1/sqrt(-6*beta*l^2+24*beta*m*n);
                        4 (-3 beta)
w := alpha/(5*beta*sqrt(l^2-4*m*n));
                                 (1/2)
                          alpha 2
                            20 beta
B[0] := -(1/25)*alpha*(5*l^3/(5*sqrt(l^2-4*m*n))-20*l*m*n/(5*sqrt(l^2-4*m*n))-l^2+2*m*n)*sqrt(-6*beta*l^2+24*beta*m*n)*(5*sqrt(l^2-4*m*n))/((l^2-4*m*n)^2*beta);
                 /   (1/2)     \          (1/2)  (1/2)
           alpha \8 2      - 12/ (-3 beta)      2
                             40 beta
B[1] := -(12/5)*m*alpha*(5*l/(5*sqrt(l^2-4*m*n))-1)/sqrt(-6*beta*l^2+24*beta*m*n);
                               / (1/2)    \
                       3 alpha \2      - 1/
                                    (1/2)
                         5 (-3 beta)
B[2] := -12*m^2*alpha/(sqrt(-6*beta*l^2+24*beta*m*n)*(5*sqrt(l^2-4*m*n)));
                                  (1/2)
                         3 alpha 2
                                    (1/2)
                        20 (-3 beta)
theta := sqrt(l^2-4*m*n);
                               (1/2)
                            2 2
xi[0] := 1;
F := -l/(2*m)-theta*tanh((1/2)*theta*(xi+xi[0]))/(2*m);
                     (1/2)     / (1/2)         \
               -2 - 2      tanh\2      (xi + 1)/
beta := -2;
                               -2
alpha := -3;
                               -3
xi := k*x-t*w;
                   1   (1/2)     3     (1/2)
                   -- 6      x - -- t 2
                   24            40
u := B[0]+B[1]*F+B[2]*F*F;
  3  /   (1/2)     \  (1/2)  (1/2)   3  / (1/2)    \  (1/2) /
- -- \8 2      - 12/ 6      2      + -- \2      - 1/ 6      |-2
  80                                 10                     \
      (1/2)     / (1/2) /1   (1/2)     3     (1/2)    \\\   3
   - 2      tanh|2      |-- 6      x - -- t 2      + 1||| + --
                \       \24            40             ///   40
   (1/2)  (1/2)
  6      2
  /      (1/2)     / (1/2) /1   (1/2)     3     (1/2)    \\\
  |-2 - 2      tanh|2      |-- 6      x - -- t 2      + 1|||
  \                \       \24            40             ///
plot3d(u, x = -30 .. .30, t = -30 .. .30);
t := 0;
plot([u], x = -30 .. 30);
case2222;
                            case2222
l := 2;
m := 1;
n := 2;
                              (1/2)
                             6
                                 (1/2)
                          12 beta
                            -- I alpha
                            10
                               beta
                                 (1/2)
                          alpha 6
                                (1/2)
                          5 beta
                     /1   1  \        (1/2)
                     |- + - I| alpha 6
                     \5   5  /
                               (1/2)
                           beta
                       1           (1/2)
                       -- I alpha 6
                       10
                               (1/2)
                           beta
                              2 I
xi[0] := 1;
C := -2;
                               -2
F := -l/(2*m)-theta*tanh((1/2)*theta*xi)/(2*m)+sech((1/2)*theta*xi)/(C*cosh((1/2)*theta*xi)-2*m*sinh((1/2)*theta*xi)/theta);
                                   sec(xi)
              -1 + tan(xi) + --------------------
                             -2 cos(xi) - sin(xi)
beta := -2;
                               -2
alpha := 3;
xi := k*x-t*w;
                  1   (1/2)     (1/2)     3
                - -- 6      (-2)      x - -- I t
                  24                      20
  3   (1/2)     (1/2)   /  3    3   \  (1/2)     (1/2) /
- -- 6      (-2)      + |- -- - -- I| 6      (-2)      |-1
  10                    \  10   10  /                  \
        /1   (1/2)     (1/2)     3     \   /   /1   (1/2)
   - tan|-- 6      (-2)      x + -- I t| + |sec|-- 6
        \24                      20    /   \   \24
      (1/2)     3     \\//      /1   (1/2)     (1/2)     3     \
  (-2)      x + -- I t|| |-2 cos|-- 6      (-2)      x + -- I t|
                20    // \      \24                      20    /
        /1   (1/2)     (1/2)     3     \\\   3     (1/2)
   + sin|-- 6      (-2)      x + -- I t||| - -- I 6
        \24                      20    ///   20
      (1/2) /        /1   (1/2)     (1/2)     3     \   /   /1
  (-2)      |-1 - tan|-- 6      (-2)      x + -- I t| + |sec|--
            \        \24                      20    /   \   \24
   (1/2)     (1/2)     3     \\//
  6      (-2)      x + -- I t|| |
                       20    // \
      /1   (1/2)     (1/2)     3     \
      \24                      20    /
   + sin|-- 6      (-2)      x + -- I t|||^2
        \24                      20    ///
plot3d(Re(u), x = -30 .. .30, t = -30 .. .30);
t := 0;
plot([Re(u)], x = -30 .. 30);
plot3d(Im(u), x = -10 .. .10, t = -10 .. .10);
Error, (in plot3d) bad range arguments: x = -10 .. .10, 0 = -10 .. .10
t := 0;
plot([Im(u)], x = -30 .. 30);
fgure set 2;
 Typesetting:-mambiguous(fgure Typesetting:-mambiguous(set 2,
l := 4;
                               4
m := 1;
n := 2;
k := 1/sqrt(6*beta*l^2-24*beta*m*n);
                              (1/2)
                                 (1/2)
                          12 beta
w := alpha/((5*sqrt(l^2-4*m*n))*beta);
                                 (1/2)
                          alpha 2
                            20 beta
B[0] := (1/25)*alpha*(5*l^3/(5*sqrt(l^2-4*m*n))-20*l*m*n/(5*sqrt(l^2-4*m*n))+l^2-6*m*n)*sqrt(6*beta*l^2-24*beta*m*n)*(5*sqrt(l^2-4*m*n))/((l^2-4*m*n)^2*beta);
               alpha \8 2      + 4/ 3      2
                                 (1/2)
                          40 beta
B[1] := -(12/5)*m*alpha*(5*l/(5*sqrt(l^2-4*m*n))-1)/sqrt(6*beta*l^2-24*beta*m*n);
                          / (1/2)    \  (1/2)
                    alpha \2      - 1/ 3
                                 (1/2)
                           5 beta
B[2] := -12*m^2*alpha/(sqrt(6*beta*l^2-24*beta*m*n)*(5*sqrt(l^2-4*m*n)));
                              (1/2)  (1/2)
                       alpha 3      2
                                 (1/2)
                          20 beta
                       1           (1/2)
                       -- I alpha 6
                       10
                               (1/2)
                           beta
                               (1/2)
                            2 2
xi[0] := 1;
                     (1/2)     / (1/2)         \
beta := -2;
                               -2
alpha := -3;
                               -3
xi := k*x-t*w;
               1   (1/2)     (1/2)     3     (1/2)
             - -- 3      (-2)      x - -- t 2
               24                      40
 3  /   (1/2)    \     (1/2)  (1/2)  (1/2)   3  / (1/2)    \
 -- \8 2      + 4/ (-2)      3      2      - -- \2      - 1/
 80                                          10
    (1/2)     (1/2) /
   3      (-2)      |-2
       (1/2)     / (1/2) /  1   (1/2)     (1/2)     3     (1/2)
    - 2      tanh|2      |- -- 3      (-2)      x - -- t 2
                 \       \  24                      40
       \\\   3   (1/2)     (1/2)  (1/2) /
    + 1||| - -- 3      (-2)      2      |-2
       ///   40                         \
                 \       \  24                      40
    + 1|||^2
Error, (in plot3d) bad range arguments: x = -30 .. .30, 0 = -30 .. .30
t := 0;
plot3d(Im(u), x = -1 .. 1, t = -1 .. 1);
Error, (in plot3d) bad range arguments: x = -1 .. 1, 0 = -1 .. 1
t := 0;
case2222;
                            case2222
l := 2;
m := 1;
n := 2;
                              (1/2)
                             6
                                 (1/2)
                          12 beta
                            -- I alpha
                            10
                               beta
                                 (1/2)
                          alpha 6
                                (1/2)
                          5 beta
                     /1   1  \        (1/2)
                     |- + - I| alpha 6
                     \5   5  /
                               (1/2)
                           beta
                       1           (1/2)
                       -- I alpha 6
                       10
                               (1/2)
                           beta
                              2 I
xi[0] := 1;
C := -2;
                               -2
                                   sec(xi)
beta := -2;
                               -2
alpha := 3;
xi := k*x-t*w;
                  1   (1/2)     (1/2)     3
                  24                      20
  10                    \  10   10  /                  \
        \24                      20    /   \   \24
                20    // \      \24                      20    /
        \24                      20    ///   20
            \        \24                      20    /   \   \24
   (1/2)     (1/2)     3     \\//
                       20    // \
      /1   (1/2)     (1/2)     3     \
      \24                      20    /
        \24                      20    ///
t := 0;
t := 0;
You use curly braces, ie '{}' as a container. Within Maple such curly braces designate a set, and Maple will always display sets in "lexicographic" order.
Since order has no meaning for entries in a set, trying to "sort" a set is meaningless. You can only sort lists, Arrays etc where the concept of order meaningful
See the attached for examples of sorting sets, lists, Arrays, and note that sorting of sets doesn't do anything useful
For future reference
  1. This should be a "Question", not a "Post" (and if I knew how to move it I would!)
  2. When posting on this site, try to avoid using third party sites like dropbox. Upload code (not pictures of code) using the big green up-arrow in the Mapleprimes toolbar
  alpha:=[2,3,4,5];
# Try sorting sets - won't work because
# order is meaningless in a set
  sort( {abs(alpha[1]-30),abs(alpha[2]-30),abs(alpha[3]-30),abs(alpha[4]-30)}, `<`);
  whattype(%);
  sort( {abs(alpha[1]-30),abs(alpha[2]-30),abs(alpha[3]-30),abs(alpha[4]-30)}, `>`);
  whattype(%);
# Do the same thing with lists, where order is significant
  sort( [abs(alpha[1]-30),abs(alpha[2]-30),abs(alpha[3]-30),abs(alpha[4]-30)], `<`);
  whattype(%);
  sort( [abs(alpha[1]-30),abs(alpha[2]-30),abs(alpha[3]-30),abs(alpha[4]-30)], `>`);
  whattype(%);
# You can also sort entries in an Array()
  sort(Array([abs(alpha[1]-30),abs(alpha[2]-30),abs(alpha[3]-30),abs(alpha[4]-30)]), `<`);
  whattype(%);
  sort(Array([abs(alpha[1]-30),abs(alpha[2]-30),abs(alpha[3]-30),abs(alpha[4]-30)]), `>`);
  whattype(%);
alpha := [2, 3, 4, 5]
{25, 26, 27, 28}
set
{25, 26, 27, 28}
set
[25, 26, 27, 28]
list
[28, 27, 26, 25]
list
Vector[row](4, {(1) = 25, (2) = 25, (3) = 25, (4) = 25})
Array
Array(%id = 18446744074423548974)
Array
Array
Array
Download sortSet.mw
I face a problem using Tolerances:-NominalValue and Tolerances:-ToleranceValue on a quantity constructed from add.
Example
with(Tolerances):
x := 10 &+-1:
y := 20 &+- 2:
z := 3*x+2*y;
NominalValue(z);
# returns 70 as expected
ToleranceValue(z);   # returns 7 as expected
Now I define another quantity Z this way:
Z := add([3, 2] *~ [x, y]);
(or equivalently add(ListOfCoeffs[k]*ListOfVars[k], k=1..K) where ListOfCoeffs and ListOfVars are previously defined adhoc lists)
Both NominalValue(Z) and ToleranceValue(Z) return an error.
PS: already (and this probably explains that) Z does not appear as 70 +/- 7 but as 3*Interval(...)+2*Interval(...) (lprint confirmed)
How can I obtain NominalValue(Z) and ToleranceValue(Z) when Z comes from 'add' constructor?
Hellow
I want to create a function that sort an array with a parametric variable alpha[k]. But Maple ignores the sort command, so the array never gets sorted. Please see attached url to creen capture of the problem:
https://www.dropbox.com/s/gjy5zbm4gjwmwdv/sort.png?dl=0
Thnaks
Hi everyone, my question is how do I get maple to process these commands. It is currently not evaluating them, and output is also similar to the image above. This occurs when I open a workbook from my Professor, all the math commands that are already inserted into the worksheet output this when I try to execute them.
I have found a workaround, I simply copy and paste the code in a new command line but this is tedious and I was wondering if anyone knew how to fix this.
First 728 729 730 731 732 733 734 Last Page 730 of 2433
