When you are solving an ode of degree 4 in maple you get an answer like this : f(x)=aZ1(x)+ bZ2(x)+ cZ3(x) + dZ4(x) Now I want to pick Z1 and Z2 and others one by one to form a list. What should I do ? (I have tried to use coeff but it did not work)
Task_1_-_Step_2_-_Attempt_2.mw
Hello, I have two main questions involving the attached file.
1. In the first error, I am trying to put a vector in the exponential, however I am getting an error. Is there any way around this?
2. I am then trying to integrate an OuterProductMatrix, however I am getting another error. Is there another way around this?
Is there another way in maple to code `union`. I am not confident using this function and was wondering if there was a perhaps longer/different way to do the same thing?
I have the following inequality system :
              [ U1,2 + U1,3 -1 = 0,
U2,3 - U1,2 = 0,
-U1,3 -U2,3+1 = 0,
0 <=U1,2,
0 <= U1,3,
0 <= U2,3]
I want to solve it using LinearMultivariateSystem, namely I excuted a command :
Then the following is return :
Error, (in Utilities:-SimpleAnd) invalid input: a string/name list is expected for sort method `lexorder`
 I tried that
My question is that how do you use LinearMultivariateSystem for varibles indexed by two params.
Thank you.
Hiya
from this
>with(combinat):
>A:=choose([CPC__h, SIZE__h,CPC__m, SIZE__m,CPC__l, SIZE__l],2):
where h denotes high, m=medium, l=low
I want to select CPC and SIZE all the combinations w.r.t h, m and l
[[CPC__h, SIZE__h], [CPC__h, SIZE__l], [CPC__h, SIZE__m], [CPC__l, SIZE__h], [CPC__l, SIZE__l], [CPC__l, SIZE__m], [CPC__m, SIZE__h], [CPC__m, SIZE__l], [CPC__m, SIZE__m]]
>nops(A)-3
9
I want to apply the methodology to
choose([CPC__h, SIZE__h, SH__h,CPC__m, SIZE__m, SH__m,CPC__l, SIZE__l, SH__l],3)
hi , I want to solve a problem of structural analysis (slope deflection) in maple but .... ?
convert(...,Int) in Maple 2018.2 works for fourier, invfourier, laplace, but does not work for invlaplace.
Why is that? Is there a workaround?
expr:=fourier(f(x), x, w):
convert(expr,Int);
expr:=invfourier(f(w), w, x):
convert(expr,Int);
expr:=laplace(f(s),s,t):
convert(expr,Int)
expr:=invlaplace(f(s),s,t):
convert(expr,Int)
Was expecting to see the Mellin's inverse formula.
Maple 2018.2 on windows 10
In the snip from Maple help: please expaln (a) the meaning, (b) how do I enter e1..-1,2 in the last statement?
Hi I am trying to solve the following system of equation. I could solve it for approximate value of s(0)=0.9999 using middefer method of bvp, but as soon as I give the b.c. as s(0)=1, Maple gives me an error that there is an numeric exception. Can someone explain it what is going wrong with s(0)=1? Any sugesstion to solve the equation?
error.mw
b := 1;
r := .1;
l := 3;
a := 10; p := 1.5; ds := 100; dk := 1;
sol3 := dsolve({ds*(diff(i(x), x)) = exp(eta(x)), s(x)^3*i(x)*b*r+(1-s(x))^3*a*l*(diff(s(x), x))/s(x)^1.5 = (1-s(x))^3, diff(eta(x), x) = dk*(i(x)-1)/s(x)^p, i(0) = 0, i(1) = 1, s(0) = 1}, {eta(x), i(x), s(x)}, approxsoln = [eta(x) = .5, i(x) = .5, s(x) = 1], initmesh = 100000, type = numeric, maxmesh = 100000, range = 0 .. 1, output = listprocedure, method = bvp[middefer], abserr = 0.1e-3, adaptive = true);
Error, (in dsolve/numeric/bvp) numeric exception: division by zero
plots[odeplot](sol3, [[x, s(x)]], 0 .. 1, color = ["Green"]);
Thanks and regards,
 write a programe for fractional calculus and it shows subscript error plzz help me with that
Using Latest Physics updates (I am not sure when this started), pdsolve gives Error, (in PDEtools/eval/2) numeric exception: division by zero on the following problem from a HW from text book.
PackageTools:-IsPackageInstalled("Physics Updates");
                             "220"
pde:=diff(w(x,t),t)+3*t*diff(w(x,t),x)=w(x,t);
ic:=w(x,0)=f(x);
sol:=pdsolve([pde,ic],w(x,t));
Mathematica answer btw is
pde = D[w[x, t], t] + 3 t D[w[x, t], x] == w[x, t];
ic = w[x, 0] == f[x];
sol = Simplify[DSolve[{pde, ic}, w[x, t], {x, t}]]
This is on Maple 2018.2 on windows 10 64 bit.
Any idea what is causing this and any workaround? Do others get the same exception?
hai,
greetings,
I require help to plot graphs by changing differernt parameters. i am enclosing my codes and sample codes,
 my_codes.mw
nanofluid_sample.mw
Thanks in advance.
Let us consider L be the following list of 6 lists of polynomials which all of their polynomials are linear combination of B=[x^2,x*y,z^2,1].
L:=[[a*x^2+b*x*y-1, -(a*b-b)*x*y/a-z^2+(a-1)/a, -a*c*z^2/(b*(a-1))+(b+c)/b], [a*x^2+b*x*y-1, -(a*b-b)*x*y/a-z^2+(a-1)/a, 1],
[a*x^2+b*x*y-1, -z^2+(a-1)/a, c*x*y+1], [b*x*y-1, -x^2-z^2, (b+c)/b], [-1, -x^2-z^2, c*x*y], [-1, -x^2-z^2]].
Now, I need the matrix coefficients of any member of L (please note that any matrix has 4 columns according to the list B) . Is there any command for this?
Thank you in advanced.
Ok so when a module is loaded, there is a .dll file that loads a list of symbols into maple.exe, what can be done if an error occurs for which the debugging output declares that the PDB file for the module could not be found?
I have read that the program database file stores debugging information related to the locating symbols, how can i fix this if my computer isn't finding theres files for a list of .dll it attempts to load into maple.exe, or is there a way for which i can make these files for each corresponding module?
u(vu)+ uvvuu - 2vvu = 0
using maple show that the ode has an eighth dimensional lie symmetry group
First 754 755 756 757 758 759 760 Last Page 756 of 2433
