I have a set of nonlinear equations (transcendental) containing variables and one free parameter. I want to solve this system for variables while varying parameter's value. I have tried with fsolve and solve commands keeping fixed the parameter value, but they are not solving yet. Is there any way to solve this system for a range of parameter's value.
The systmem is like this, x,y,z are the variables and 'a' is the parameter:
f1(x,y,z,a)=0,
f2(x,y,z,a)=0,
f3(x,y,z,a)=0.
Many thanks in advance.
I submit you this strange result:
for somenumerical  values of a, b, c  (a, b, c real and b > a), Maple 2018 is not able to compute the mean of
c*U where U is a Uniform random variable with support [a, b].
with(Statistics):
`Standard Worksheet Interface, Maple 2018.0, Windows 7, March 10 2018 Build ID 1298750`
z := .4070716688*RandomVariable(Uniform(0.12-0.02*0.12, 0.12+0.02*0.12));
Mean(z);
.4070716688*_R
Error, (in Statistics:-Mean) the expression does not have a taylor expansion at t = 0
z := .4070716688*RandomVariable(Uniform(a, b));
Mean(z);
subs({a=0.12-0.02*0.12, b=0.12+0.02*0.12}, %);
.4070716688*_R0
.2035358344*a+.2035358344*b
0.4884860026e-1
Download Mean.mw
PLEASE: Maple still fails if I replace  a = 0.12 -0.02*0.12 by its value 0.1174
        and b = 0.12+0.02*0.12 by its value 0.1224
This is incomprehensible and could hide a more profound problem.
Good day everyone,
I am trying to write HAM code for coupled ODE but getting errors like "table(...)" or
"Error, (in dsolve) found the independent variables {eta} also present in the names of the functions of the system {(diff(diff(diff((table( [( 0 ) = proc (eta) options operator, arrow, function_assign; eta*exp(-eta)-F[w] end proc ] ))(eta), eta), eta), eta))(f[1](eta)), (diff(diff((table( [( 0 ) = proc (eta) options operator, arrow, function_assign; exp(-eta) end proc ] ))(eta), eta), eta))(theta[1](eta)), (diff((table( [( 0 ) = proc (eta) options operator, arrow, function_assign; eta*exp(-eta)-F[w] end proc ] ))(eta), eta))(f[1](eta)), ((table( [( 0 ) = proc (eta) options operator, arrow, function_assign; exp(-eta) end proc ] ))(eta))(theta[1](eta))}"
Anyone with useful informations should please help.
Below is the attached of the file
untitled22222.m
Does Maple have a way to upload a screenshot of a worksheet or a savefile of a worksheet to MaplePrimes?
Hi.
How I can Plot voltage (v) versus time (t) in nonlinear differential equation.
if possible please provide a simple example for me. for instance the command that I must use!!
plot.pdf
Hello everyone, i've a problem working with Maple because i have a really big system of equations and for everything that i have to do with them, for example, collect terms, coefficients, take a lot of time from me. The problem it is when, for example, i wait 30 minutes to take the coefficients from a equation and in the next command Maple might stop, then i have to close and start all over again... My question it is if have anyway to save my file in a way that if i close and re open i dont have to compile all again. Maybe this is pretty obvious but i really dont know how to do it, because if i close my work and open again, i have to compile everything again.
Following creates a list of 10 numbers 1..10:
  L := []; for i from 1 to 10 do L := [op(L), i] end do;
Now suppose I have equations labelled (1) ... (10). Can I place these equations into a list by some analogy of the above code using the label references?
Y = (-2*k^3+6*k^2+sqrt(k^8-12*k^7+64*k^6-198*k^5+448*k^4-636*k^3+369*k^2)-7*k-15)/((k^3-3*k^2+5*k-15)*(1+k))
I am in the process fo creating 2 sets of multivariable expressions and I need to create pairwise equations from these sets.
L={L1(a_1 .. a_n), L2(a1, .., an) .... }
R={R1(a_1 .. a_n), R2(a1, .., an) .... }
I need to create the array:
M=Array(1..(2c)!, 1..2^c) where the elements are:
L[1] = R[1],   L[1] = R[2],   L[1] = R[3] ...
L[2] = R[1],   L[2] = R[2],   L[2] = R[3] ...
L[3] = R[1], ...
I then need to pull out particular elements (equtions M[1,1], M[7,2], etc) from the array and plug in a lot of values for the variables of that equation
for a[1] from 1 to 10 do
   for a[2] from 1 to a[1] do
       for a[3] from 1 to a[2] do
if Equation holds (store the inputs somewhere)
end do
end do
end do
I last used Maple about 5 years and have since forgotten a lot, so any and all help is greatly appreciated.
Thanks, Ben
I have created my own costume package inspired from an already existing one but this package relies and uses many functions from the original package which I used to create mine. The question: is there an easy way to automatically import all the needed functions and commands from the original package without having to write the name of the original package followed by the name of each function or command ( which is really laborious and hard to complete) ?
I have a eigenvalue problem like:
[FF1]* {w}=N^2 *[FF2] *{w}
[FF1] and [FF2] are a*b matrices (non square matrix) , {w} are vectors(eigenvectors) and the values of N are eigenvalues.
I want to obtain eigenvalues and eigenvectors by computing Moore-Penrose pseudo-inverse of [FF2] and do the procedures below :
[FF2]^-1 * [FF1] *{w} =N^2 *{w}            ,        (assume  [FF2]^-1   is Moore-Penrose pseudo-inverse of [FF2]   )
[FF2]^-1 * [FF1] = [FF3]  ,  ( [FF3] is a b*b matrix- squre matrix)
so  [FF3] *{w}=N^2 *{w}
then I can use LinearAlgebra[Eigenvectors](FF3) to get eigenvalues and eigenvectors.
I know that Moore-Penrose pseudo-inverse of [FF2] * [FF1] isn't equal to Identity matrix. [FF2]^-1 * [FF1] <> [ I ] . But assume it can be. ( I have a solution for this problem) .
My biggest problem is [FF2] and [FF1] are large-scale sparse matrix and it takes hours or several days that maple can compute Moore-Penrose pseudo-inverse of [FF2]  and also LinearAlgebra[Eigenvectors](FF3).
Main question : can I compute Moore-Penrose pseudo-inverse and LinearAlgebra[Eigenvectors]  by using Parallel Programming?  if the answer is yes , how? give me an example please.
if the answer is No , is there any way (any algorithm) to find the inverse of a large non-sqaure matrix or eigenvalues of a large matrix faster?
please introduce some books for parallel programming in maple or general.
1.mw
Copied this from a webpage but it gives an error.
Grateful for all suggestions
PrintfError.mw
H := (alpha*(2-beta)*S__0^2+2*D*(S^(2-beta)-S__0^(2-beta)))/(2*D*alpha*(2-beta))
T := (S^(-beta+1)-S__0^(-beta+1))/(alpha*(-beta+1))+S__0/D
Profit1 := ((s-C)*S-C__1*H-C__3)/T
((s-C)*S-(1/2)*C__1*(alpha*(2-beta)*S__0^2+2*D*(S^(2-beta)-S__0^(2-beta)))/(D*alpha*(2-beta))-C__3)/((S^(-beta+1)-S__0^(-beta+1))/(alpha*(-beta+1))+S__0/D)
Profit1 := subs(D = alpha*S__0^beta, Profit1)
((s-C)*S-(1/2)*C__1*(alpha*(2-beta)*S__0^2+2*alpha*S__0^beta*(S^(2-beta)-S__0^(2-beta)))/(alpha^2*S__0^beta*(2-beta))-C__3)/((S^(-beta+1)-S__0^(-beta+1))/(alpha*(-beta+1))+S__0/(alpha*S__0^beta))
Profit1 := eval(Profit1, [alpha = 5, S__0 = 28, C__1 = .5, C__3 = 10])
((s-C)*S-0.1000000000e-1*(7840-3920*beta+10*28^beta*(S^(2-beta)-28^(2-beta)))/(28^beta*(2-beta))-10)/((1/5)*(S^(-beta+1)-28^(-beta+1))/(-beta+1)+(28/5)/28^beta)
DEF_Profit1 := diff(Profit1, S)
(s-C-.1000000000*S^(2-beta)/S)/((1/5)*(S^(-beta+1)-28^(-beta+1))/(-beta+1)+(28/5)/28^beta)-(1/5)*((s-C)*S-0.1000000000e-1*(7840-3920*beta+10*28^beta*(S^(2-beta)-28^(2-beta)))/(28^beta*(2-beta))-10)*S^(-beta+1)/(((1/5)*(S^(-beta+1)-28^(-beta+1))/(-beta+1)+(28/5)/28^beta)^2*S)
NULLNULL
sol1 := solve(DEF_Profit1, S)
RootOf(-100*_Z^(-beta+1)*28^beta*beta^2+300*_Z^(-beta+1)*28^beta*beta-10*C*_Z^(2-beta)*28^beta*beta^2+10*_Z^(2-beta)*28^beta*beta^2*s+20*C*_Z^(2-beta)*28^beta*beta-20*_Z^(2-beta)*28^beta*beta*s+_Z^(3-2*beta)*196^beta*7^(-beta)-200*28^beta*_Z^(-beta+1)+28*_Z^(2-beta)*beta^2-392*_Z^(-beta+1)*beta^2-56*_Z^(2-beta)*beta+392*_Z^(-beta+1)*beta+280*C*_Z*beta^2-280*_Z*beta^2*s-560*C*_Z*beta+560*_Z*beta*s)
Download doubt_case.mw
I am creating a randomised dataset in a workbook, I want the students to use this data but I also want to save the matrix within the same workbook as a csv file so that when I come to look at their work I will see the exact dataset they were supplied with. Can anyone advise on how I might do this:
The code is:
x := convert([seq(1..100)], Vector[column]):
y := 0.1*~x:
with(SignalProcessing):
tmp := GenerateGaussian(100, 2, .6):
tmp2 := convert(tmp*~y, Vector[column]):
ad1 := <<x>|<tmp2>>:
I tried - Export("this:///DataFiles/exdat.csv",ad1):
but get the Error message - Error, (in FileTools:-OpenURI) entry with path '/DataFiles/exdat.csv' is not found
Is what I'm trying to achieve even possible?
Jo (p.s. pretty new to Maple)
Please tell me how to calculate the derivative of a matrix function?
First 771 772 773 774 775 776 777 Last Page 773 of 2433
