I am trying to evaluate some functions when u=v so function goes to 0/0
Example given below of the expansion series I need to produce first. But I can't produce it.
"How do I get this expansion and sum"?""
eq := (u^m-v^m)/(u-v)
(u^m-v^m)/(u-v)
eval(eq, u = v)
Error, numeric exception: division by zero
eq1 := convert(eq, Sum, method = rational, include = powers)
(Sum((1-u)^_k1*binomial(-m+_k1-1, _k1), _k1 = 0 .. m)-(Sum((1-v)^_k1*binomial(-m+_k1-1, _k1), _k1 = 0 .. m)))*(Sum((-1)^_k1*(-1+u-v)^_k1, _k1 = 0 .. infinity))
-(Sum((-1)^_k1*(-1+u-v)^_k1, _k1 = 0 .. infinity))*m*(Sum((1-u)^_k1*binomial(-m+_k1, _k1)/(-m+_k1), _k1 = 0 .. m))+(Sum((-1)^_k1*(-1+u-v)^_k1, _k1 = 0 .. infinity))*m*(Sum((1-v)^_k1*binomial(-m+_k1, _k1)/(-m+_k1), _k1 = 0 .. m))
eval(eq1, u = v)
for m to 5 do m, "   ", simplify(eq); eval(simplify(eq), u = v) end do
5*v^4
unassign('m')
``eq2 := sum(u^(m-1-i)*v^i, i = 0 .. m-1)
-u^(m-1)*(v/u)^m*u/(u-v)+u^(m-1)*u/(u-v)
-u^m*((v/u)^m-1)/(u-v)
eval(eq2, u = v)
u := v
v
eq3 := sum(u^(m-1-i)*v^i, i = 0 .. m-1)
v^m*m/v
v^(m-1)*m
Download Convert_to_Sum.mw
I'd like Maple to return ln(abs(x)) for int(1/x,x) instead of ln(x).
I tried convert MMA code,but I failed.
realIntegrate[f_, x_Symbol] :=
 Simplify[Integrate[f, x] /. Log[expr_] :> Log[Abs[expr]],
  x \[Element] Reals]; Unprotect[Integrate];
Integrate[f_, x_Symbol] /; ! TrueQ[$flag] :=
 Block[{$flag = True}, realIntegrate[f, x]]; Protect[Integrate];
My maple code works only for very simple cases.
REALINT := proc (f, x)
if typematch(int(f, x), ln(y::anything), 's') then
`assuming`([simplify(ln(abs(rhs(s[1]))))], [x in real])
else int(f, x)
end if
REALINT(1/x, x);
#ln(abs(x))
REALINT(1/(x+1), x);
#ln(abs(x+1))
REALINT(1/x+1, x);
#x+ln(x) dosen't work.
I have an expression involving a sqrt, and i'd like to simplify it, but simplify(expression,sqrt) doesn't seem to fully help.
Eq1 := [(1/2)*(R[b]*kh[a2]+R[m]*kh[a2]-Rh[m]*kh[a2]+sqrt(R[b]^2*kh[a2]^2+2*R[b]*R[m]*kh[a2]^2-2*R[b]*Rh[m]*kh[a2]^2+R[m]^2*kh[a2]^2-2*R[m]*Rh[m]*kh[a2]^2+Rh[m]^2*kh[a2]^2))/kh[a2] = 0, 0 = 0, -(1/2)*(R[b]*kh[a2]+R[m]*kh[a2]-Rh[m]*kh[a2]+sqrt(R[b]^2*kh[a2]^2+2*R[b]*R[m]*kh[a2]^2-2*R[b]*Rh[m]*kh[a2]^2+R[m]^2*kh[a2]^2-2*R[m]*Rh[m]*kh[a2]^2+Rh[m]^2*kh[a2]^2))/kh[a2] = 0]
simplify(Eq1, sqrt)
gives
[(1/2)*(R[b]*kh[a2]+R[m]*kh[a2]-Rh[m]*kh[a2]+sqrt(kh[a2]^2*(R[b]+R[m]-Rh[m])^2))/kh[a2] = 0, 0 = 0, -(1/2)*(R[b]*kh[a2]+R[m]*kh[a2]-Rh[m]*kh[a2]+sqrt(kh[a2]^2*(R[b]+R[m]-Rh[m])^2))/kh[a2] = 0]
which on paper simplifies to:
[R[b]+R[m]-Rh[m]=0,0=0,R[b]+R[m]-Rh[m]=0]
is there a way to get maple to show this?
[In part I am trying to better understand how to manipulate sqrt expressions in maple]
I have a complicated expression which includes RootOf( a quadratic ) but holds for all x what i'd like to do is turn it into a polynomial in x[1], x[2], x[3] so i can start looking at the monomial coefficients.
k[a1]*((x[1]+x[3])*k[d1]+C[T]*k[m])*(R[b]-x[1]-2*x[2])/((R[b]+R[m]-x[1]-2*x[2]-x[3])*k[a1]+k[m])-k[d1]*x[1]-k[a2]*x[1]*(R[b]-x[1]-2*x[2])+2*k[d2]*x[2] = (-R[b]*k[a2]+2*k[a2]*x[1]+2*k[a2]*x[2])*(k[a1]*kh[m]*((x[1]+x[3])*k[d1]+C[T]*k[m])*(R[b]+R[m]-Rh[m]-x[1]-2*x[2])/(k[m]*((R[b]+R[m]-x[1]-2*x[2]-x[3])*k[a1]*kh[m]/k[m]+kh[m]))-k[d1]*x[1]-kh[a2]*x[1]*(R[b]+R[m]-Rh[m]-x[1]-2*x[2])+2*kh[d2]*x[2])/(2*kh[a2]*RootOf(kh[a2]*_Z^2+(-R[b]*kh[a2]-R[m]*kh[a2]+Rh[m]*kh[a2]+2*kh[a2]*x[2])*_Z-2*k[a2]*x[1]*x[2]-k[a2]*x[1]^2+k[a2]*x[1]*R[b]+2*kh[d2]*x[2]-2*k[d2]*x[2])-R[b]*kh[a2]-R[m]*kh[a2]+Rh[m]*kh[a2]+2*kh[a2]*x[2])+(-2*kh[a2]*RootOf(kh[a2]*_Z^2+(-R[b]*kh[a2]-R[m]*kh[a2]+Rh[m]*kh[a2]+2*kh[a2]*x[2])*_Z-2*k[a2]*x[1]*x[2]-k[a2]*x[1]^2+k[a2]*x[1]*R[b]+2*kh[d2]*x[2]-2*k[d2]*x[2])+2*k[a2]*x[1]+2*k[d2]-2*kh[d2])*(kh[a2]*x[1]*(R[b]+R[m]-Rh[m]-x[1]-2*x[2])-2*kh[d2]*x[2])/(2*kh[a2]*RootOf(kh[a2]*_Z^2+(-R[b]*kh[a2]-R[m]*kh[a2]+Rh[m]*kh[a2]+2*kh[a2]*x[2])*_Z-2*k[a2]*x[1]*x[2]-k[a2]*x[1]^2+k[a2]*x[1]*R[b]+2*kh[d2]*x[2]-2*k[d2]*x[2])-R[b]*kh[a2]-R[m]*kh[a2]+Rh[m]*kh[a2]+2*kh[a2]*x[2])
If this were something like q(x)=p1(x)/sqrt(p2(x)) where p1 and p2 are polynomials and q is a quotient- this would be as simple as making sqrt(p2(x)) the subject and squaring both sides, and then movinbg everything onto one and multiplying out denominators. However RootOf is something I'm not used to manipulating.
Is there anyway of converting this expression to a polynomial using maple commands?
I am working on a problem that involves finding a map lambda(x) which maple stores using RootOf:
LambdaMap := [lambda[1] = RootOf(kh[a2]*_Z^2+(-R[b]*kh[a2]-R[m]*kh[a2]+Rh[m]*kh[a2]+2*kh[a2]*x[2])*_Z-2*k[a2]*x[1]*x[2]-k[a2]*x[1]^2+k[a2]*x[1]*R[b]+2*kh[d2]*x[2]-2*k[d2]*x[2]), lambda[2] = x[2], lambda[3] = x[1]+x[3]-RootOf(kh[a2]*_Z^2+(-R[b]*kh[a2]-R[m]*kh[a2]+Rh[m]*kh[a2]+2*kh[a2]*x[2])*_Z-2*k[a2]*x[1]*x[2]-k[a2]*x[1]^2+k[a2]*x[1]*R[b]+2*kh[d2]*x[2]-2*k[d2]*x[2])]
(as an aside, after a few years of using maple and reading the help page I find RootOf confusing, and I think this is the root of this question, I'd love to get some recomended reading on it in the answers)
I want to use the restriction lambda(0,0,0)=(0,0,0) to find relationships between the parameters (kh,k,Rh,R etc)
I tried:
`~`[`=`](`~`[rhs](subs([x[1] = 0, x[2] = 0, x[3] = 0], LambdaMap)), [0, 0, 0]);
solve(%);
which returned:
[RootOf(kh[a2]*_Z^2+(-R[b]*kh[a2]-R[m]*kh[a2]+Rh[m]*kh[a2])*_Z) = 0, 0 = 0, -RootOf(kh[a2]*_Z^2+(-R[b]*kh[a2]-R[m]*kh[a2]+Rh[m]*kh[a2])*_Z) = 0]
{R[b] = R[b], R[m] = R[m], Rh[m] = Rh[m]}
which seems wrong (both the first and third equations are quadratics sharing roots, the first root is _Z=0, and the second is _Z=-R[b]-R[m]+Rh[m]- i'm not sure how either result in this solve)
Is this the right way to do this? i.e. do solve and subs, work intuitively with RootOf expressions.
I am doing some calculus on lambda next - is there anything i should be mindful of when calculating its Jacobean or using diff?
Please help me with the following worksheet containg a sample ODE. I need to integrate this ode untill at least one of the terms is derivative free
odetemp := -(diff(U(z), z))*c*v+U(z)*(diff(U(z), z))*c-(diff(U(z), z, z))*c^2
-(diff(U(z), z))*c*v+U(z)*(diff(U(z), z))*c-(diff(diff(U(z), z), z))*c^2
Download maplerpimes.mw
I am going to plot a surface using plotpoint3d with color bar. The code is:
restart; with(ExcelTools); with(plottools); with(plots);
Q := Import("e.xlsx"); X2 := Vector(28800, [seq(Q(i, 1), i = 1 .. 28800)]); X3 := Vector(28800, [seq(Q(i, 2), i = 1 .. 28800)]); zz := Vector(28800, [seq(Q(i, 3), i = 1 .. 28800)]); pointplot3d(X2, X3, zz)
 I imported data from excel. Then I plotted it but I want to have a color bar like matlab for it.
Can anyone help me regarding this issue?
I am using Scientific notations and it constatly reminds me of the units and conversion challenges of using Maple.  I am using 2018 and am an engineer where units are our life blood for calculations.
Ive attached the file in ref where the constants shows J/Kg-mol   but outputs in a converted base unit of m^2 kg / s^2 mol K.  This modifies the value normally used by tables or other references as verification (often without units except in a column header)
The real problem is without units the caculated value 34.52 (or 0.03452) is meaningless when the real value has to be 287.05 if used without units or has correction applied within the SW internally.
Units is my singular frustration with Maple as a really useful tool.  2018 moved this forward in so many ways which is very benficial.  I am really wondering if it may be how I'm setting the session up, or it is what it is.
Units_conversion_issue.mw
Trying to read the docs, I find a lot of information in section that appear closed, and I'm supposed to move my hand from the keyboard to the mouse to bounce a laser off my desk to click triangles on the screen to make the information I need visible. Sometimes when I click a triangle, it opens the section and lets me read the docs. Other times I click a triangle, it does nothing, so I click again, and eventually it works. This process is unpleasant. Is there any way predictable way to view the docs, or just click triangles and hope?
New user. Start a new "Worksheet Mode". Type "3" and press Enter. Maple evaluates it to 3. Decide I want to add a section-heading above the original first line. Head into the docs and emerge several hours later still not having found any way to add a section-heading above the original first line. How did I lose so many hours of time on something so basic? Where was this routine task documented?
Hi. I wrote a command for finding second derivative.
#secondderiv test of f(x,y)
f:=x^2+2*x*y+2*y^3:
Gradient(f,[x,y]);
soln:=solve(Equate(Gradient(f,[x,y]),<0,0>));
H:=hessian(f,[x,y]);
seq([subs(soln[k],eval(H)),det(subs(soln[k],eval(H)))],k=1..nops(op(soln)))
Everything runs fine ... except if I change the function f to
f:=x^2+2*x*y+2*y^2
Then I get error :
Error, invalid input: nops expects 1 argument, but received 2
I sort of understand the error, when there is a single solution
{x=0,y=0} , then the op removes the parentheses to get x=0, y=0
which is now two arguments, and nops requires one argument.
I tried to use  nops(op({soln} ) , but that is not the correct approach
since it overcounts. Also it throws an error if change back f to the original expression.
I have an implicit function and I have plotted the graph of the same in maple 18 worksheet. Now I would like to export the data of the same graph into an excel file so that I can use it further. Kindly provide the solution and if some kind of example is provided I'll be highly grateful to you.
when i evaluate integration and my result s are HFloat what does it mean ?
how to avoid it ?
and how to distribute integration when the expand command doesnt work?
Can someone please explain to me why i would be getting the error that i do not have permission to read a text file, when i can clearly open that text file under the same account.
first := readline("infile.text")
Error, (in readline) permission denied: no read access (infile.text)
Download 111.mw
First 792 793 794 795 796 797 798 Last Page 794 of 2433
