This is a new question came up from a follow up to https://www.mapleprimes.com/questions/225083-Maple-Command-To-Find-Domain-Of-Function
Does Maple have support for removing points from an interval automatically? An example will make this clear. This is all on the real line. No complex domain.
Given one interval,. say real_domain :=  x>-infinity and x<infinity: and now I want to remove from this interval, another interval. This second interval can be defined as single point(s) or as interval(s) itself.
I will give an example of both.
when the singularity interval to remove is defined as one or more single points, here is an example using one point:
singlarity_pt := 1/2:
So I want Maple to give me automatically the new interval as   {x>-infinity and x<1/2} , {x>1/2 and x<infinity}:
Becuase the singularity point was "removed" from the real domain. I tried solve, but it did not work
solve(x<>singlarity_pt and real_domain,{x})
I know I could probably code this by hand, and add logic to figure it if the singularities are points. But this can get complicated if the real domain itself has many sub intervals itself. I thought Maple should be able to do this. fyi, In Mathematica, this is done as follows
singularity = 1/2;
realDomain = -Infinity < x < Infinity;
Reduce[x != singularity && realDomain , x, Reals]
Here is second example where now the singulartiy interval to remove, is not single point, but an interval itself. I found that in this case, solve did the right thing
singlarity_domain := x>-1/2 and x<1/2:
Now the final domain should be   -infinity<x<-1/2 , 1/2<x<infinity,
solve( not(singlarity_domain) and real_domain,{x})
The question is, why it worked when the singulaity is an interval, but it did not work when it is a specific point? And how can one make it work for single points? Is there a different command to use other than solve for this?
In general, singularities can contain single points and also intervals, but single points is more commin. So I need it to work for both cases.
This has to be done non-interactivally and without plotting or such, as it will be part of a script.
Thanks for any hints
In the following problem at two example are given. For Z=2 the sum is converging whereas at Z=4 it is not converging. Thank you
PROBLEM.mw
I have a polynomial in the variables ya[i] and yd[i] where i are integers. I want to divide each of the coefficients by the 'shortest' coeficient. What i mean by that is the coefficient that is going to cause me the least trouble when i later do things with groebner bases of on the coefficients - I expect a good proxy for that is the one that has the smallest number of terms.
For example, for the polynomial:
2*yd[0]*k[a1]*k[d1]*ya[1]+(alpha*C[T]*k[a1]*k[m]-alpha*R[b]*k[a1]*k[d1]-alpha*R[m]*k[a1]*k[d1]-alpha*k[d1]*k[m])*ya[1]-2*k[a1]*k[d1]*yd[1]*yd[0]+(-alpha*C[T]*k[a1]*k[m]+alpha*R[b]*k[a1]*k[d1]+alpha*R[m]*k[a1]*k[d1]+alpha*k[d1]*k[m])*yd[1]
2*k[a1]*k[d1] is the shortest monomial coefficient
I have a program that produces lists of polynomails in multiple variables; I want to remove any polynomials that have the variable x[i] where i is a number.
An example list would be:
y[a0]-y[d0],
k[d1]*y[a1]-k[d2]*y[d2],
k[d1]*y[a1]*x[1]-k[d2]*y[d2]*x[2],
int(int(x,y^4..16),y=0..2);
yields the output $\int_0^2\int_{y^4}^{16} x(x) dx dy$.
any one can help me to get the output of the plot in 3 rows and 2 columns here is my codes. thanks in advance.
  h:=z->1-(delta2/2)*(1 + cos(2*(Pi/L1)*(z - d1 - L1))):
  K1:=((4/h(z)^4)-(sin(alpha)/Gamma2)-h(z)^2+Nb*h(z)^4):
  lambda:=unapply(Int(K1,z=0..1), Gamma2):
  L1:=0.2:
  d1:=0.2:
  alpha:=Pi/6:
  display
  ( Vector[row]
    ( [ seq
        ( plot
          ( [ seq
              ( eval(lambda(Gamma2), Nb=j),
                j in [0.1,0.2,0.3]
            delta2=0.02..0.1,
            legend=[Nb=0.1,Nb=0.2,Nb=0.3],
            labels=[typeset(`&delta;1`), typeset(conjugate(`&Delta;p`))],
            title=typeset("Effect of ", ''alpha'', " when ", Gamma,"2=", Gamma2)
          Gamma2 in [10,20,30,40,50,-10]
After run a batch to cmaple to run a prettyprint=0 and screenwidth=500
it use lprint in window
i set prettyprint=2
still can not set back to original print for matrix
Excel tool import can not be used in cmaple.exe
Plot the first 20 Fibonacci numbers.
I have this so far..
nums := [seq(i, i = 1 .. 20)]*with(combinat, fibonacci);
fibnums;
  here my loop; after  8 iteration maple couldnt solve the equations and give me this error .
Is there any method to garentee that fsolve could work intire the 1000 iteration
Download exp_new_for_alpha_more_than_22.mw
f[1] := VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`*`(n, 1/R), sum(x[i], i = 1 .. n)), VectorCalculus:-`-`(sum(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`+`(2, a[i]), x[i]), exp(VectorCalculus:-`*`(R, x[i]))), 1/VectorCalculus:-`+`(VectorCalculus:-`+`(exp(VectorCalculus:-`*`(R, x[i])), -1), Q)), i = 1 .. n))):
f[2] := VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`*`(m, 1/S), sum(y[j], j = 1 .. m)), VectorCalculus:-`-`(sum(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`+`(2, b[j]), y[j]), exp(VectorCalculus:-`*`(y[j], S))), 1/VectorCalculus:-`+`(VectorCalculus:-`+`(exp(VectorCalculus:-`*`(y[j], S)), -1), Q)), j = 1 .. m))):
f[3] := VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`+`(n, m), sum(a[i], i = 1 .. n)), sum(b[j], j = 1 .. m)), 1/Q), VectorCalculus:-`-`(sum(VectorCalculus:-`*`(VectorCalculus:-`+`(2, a[i]), 1/VectorCalculus:-`+`(VectorCalculus:-`+`(exp(VectorCalculus:-`*`(R, x[i])), -1), Q)), i = 1 .. n))), VectorCalculus:-`-`(sum(VectorCalculus:-`*`(VectorCalculus:-`+`(2, b[j]), 1/VectorCalculus:-`+`(VectorCalculus:-`+`(exp(VectorCalculus:-`*`(y[j], S)), -1), Q)), j = 1 .. m))):
E1[1] := 0.5e-1:
E2[1] := 0.5e-1:
E3[1] := 0.5e-1:
n := 45:
n := 45:
a := [seq(0, i = 1 .. 21), 2, 2, 1, seq(0, i = 1 .. 21)]:
K := 1000:
for so from 0 to K do W := GenerateUniform(n, 0, 1); for iii to n do vv[iii] := W[iii]^(1/(iii+sum(a[jjj], jjj = n-iii+1 .. n))) end do; for sss to n do uu[sss] := 1-product(vv[n-jjj+1], jjj = 1 .. sss); x[sss] := fsolve(1-3/(exp(.3*t)-(1-3)) = uu[sss], t = 0 .. infinity) end do; U := GenerateUniform(m, 0, 1); for ii to m do v[ii] := U[ii]^(1/(ii+sum(b[jj], jj = m-ii+1 .. m))) end do; for ss to m do u[ss] := 1-product(v[m-jj+1], jj = 1 .. ss); y[ss] := fsolve(1-3/(exp(.1*t)-(1-3)) = u[ss], t = 0 .. infinity) end do; c := describe[quartile[1]]([seq(x[i], i = 1 .. n)]); cc := describe[quartile[3]]([seq(x[i], i = 1 .. n)]); L := describe[quartile[1]]([seq(y[i], i = 1 .. m)]); LL := describe[quartile[3]]([seq(y[i], i = 1 .. m)]); R[1] := fsolve(9*exp(R*c)-exp(R*cc) = 8, R = 0 .. infinity); S[1] := fsolve(9*exp(S*L)-exp(S*LL) = 8, S = 0 .. infinity); Q[1] := 3*(exp(R[1]*c)-1+(exp(S[1]*L)-1))*(1/2); for h to 40 while `and`(`and`(`and`(`and`(`and`(abs(E1[h]) > 0.5e-3, abs(E2[h]) > 0.5e-3), abs(E3[h]) > 0.5e-3), Q[h] > 2), S[h] > 0), R[h] > 0) do Q[h+1] := fsolve(eval(f[3], {R = R[h], S = S[h]}) = 0, Q = 2 .. infinity); R[h+1] := fsolve(eval(f[1], Q = Q[h+1]) = 0, R = 0 .. infinity); S[h+1] := fsolve(eval(f[2], Q = Q[h+1]) = 0, S = 0 .. infinity); KK := Matrix([[R[h]], [S[h]], [Q[h]]]); E1[h+1] := abs(R[h+1]-R[h]); E2[h+1] := abs(S[h+1]-S[h]); E3[h+1] := abs(Q[h+1]-Q[h]) end do; A[so] := Determinant(KK[1]); B[so] := Determinant(KK[2]); C[so] := Determinant(KK[3]); P[so] := simplify(int(A[so]*C[so]^2*exp(A[so]*x)/((exp(A[so]*x)-1+C[so])^2*(exp(B[so]*x)-1+C[so])), x = 0 .. infinity, numeric)) end do
W := Vector(4, {(1) = ` 1 .. 45 `*Array, (2) = `Data Type: `*float[8], (3) = `Storage: `*rectangular, (4) = `Order: `*C_order})
U := Vector(4, {(1) = ` 1 .. 45 `*Array, (2) = `Data Type: `*float[8], (3) = `Storage: `*rectangular, (4) = `Order: `*C_order})
c := 2.251942600
cc := 6.413093396
L := 8.631577783
LL := 25.39584518
R[1] := .4287243564
S[1] := .1043333848
Q[1] := 4.630481096
A[0] := .4247642181
B[0] := .1149899971
C[0] := 6.627593396
P[0] := .8815279215
c := 2.918917328
cc := 5.547621812
L := 3.857225847
LL := 21.10240063
R[1] := .8018219086
S[1] := 0.5213484487e-1
Q[1] := 14.41300577
A[1] := .3666457947
B[1] := .1191082759
C[1] := 3.847329446
P[1] := .8226338823
c := 2.442365249
cc := 7.394009487
L := 4.713824874
LL := 24.79260797
R[1] := .3468711931
S[1] := 0.4792653690e-1
Q[1] := 2.379817029
A[2] := .2337020019
B[2] := 0.7824619488e-1
C[2] := 2.252708122
P[2] := .7880876611
c := 1.950620121
cc := 7.490968154
L := 7.989340649
LL := 22.40840798
R[1] := .2570696142
S[1] := .1248268277
Q[1] := 3.543022180
A[3] := .3254617069
B[3] := .1177911768
C[3] := 4.708933240
P[3] := .8124474245
c := 1.973241013
cc := 7.005418646
L := 6.495611086
LL := 22.94839275
R[1] := .3034319432
S[1] := 0.9318350072e-1
Q[1] := 2.477406387
A[4] := .3446953632
B[4] := .1065224704
C[4] := 4.241185270
P[4] := .8370643415
c := 1.839457984
cc := 7.186959772
L := 6.911480924
LL := 24.15316459
R[1] := .2619901249
S[1] := 0.8971740871e-1
Q[1] := 2.217385534
A[5] := .2889717346
B[5] := 0.8838227764e-1
C[5] := 2.965514897
P[5] := .8196572233
c := 2.075842156
cc := 6.451509594
L := 7.355551514
LL := 22.57154486
R[1] := .3857437868
S[1] := .1118795995
Q[1] := 3.756557664
A[6] := .3672067772
B[6] := .1169243938
C[6] := 4.269406267
P[6] := .8320277948
c := 2.052084434
cc := 5.954773664
L := 7.287571569
LL := 19.13650694
R[1] := .4519986760
S[1] := .1574582015
Q[1] := 5.517824640
A[7] := .3834726657
B[7] := .1300598692
C[7] := 4.443377611
P[7] := .8222904412
1.288903514
6.337860209
6.623173031
20.57453160
.2114575385
.1210220497
2.313450170
Error, (in fsolve) Q is in the equation, and is not solved for
a := [seq(A[i], i = 1 .. 1000)]:
for i to 1000 do aa_[i] := `if`(0 < P[i] and P[i] < 1, a[i], 0); bb_[i] := `if`(0 < P[i] and P[i] < 1, b[i], 0); cc_[i] := `if`(0 < P[i] and P[i] < 1, c[i], 0); gg_[i] := `if`(0 < P[i] and P[i] < 1, p[i], 0) end do:
Tau := [seq(aa_[i], i = 1 .. 1000)]:
rr := [seq(`if`(Tau[i] = 0, NULL, i), i = 1 .. 1000)]:
r := Tau[rr]:
1000
1000
1000
1000
lambda[1] := Mean([seq(r[i], i = 1 .. nops(r))]); lambda[2] := Mean([seq(s[i], i = 1 .. nops(s))]); alpha := Mean([seq(q[i], i = 1 .. nops(q))]); Pro := Mean([seq(w[i], i = 1 .. nops(w))]); Bi_ := .647737-Pro; ME_ := Bi_^2
Error, (in Statistics:-Mean) unable to evaluate `if`(0 < P[8] and P[8] < 1, a[i], 0) to floating-point
Error, (in Statistics:-Mean) unable to evaluate `if`(0 < P[8] and P[8] < 1, b[i], 0) to floating-point
Error, (in Statistics:-Mean) unable to evaluate `if`(0 < P[8] and P[8] < 1, c[i], 0) to floating-point
Error, (in Statistics:-Mean) unable to evaluate `if`(0 < P[8] and P[8] < 1, p[i], 0) to floating-point
.647737-Pro
(.647737-Pro)^2
I am calling a function (GTS2) multiple times with varying inputs, using the curry function, and i want to record how long/how much RAM the function takes with each input, and put those in seperate matrices that i can plot later
Sols3 := proc (H::algebraic, F::(list(algebraic)), i::posint, j::posint) options operator, arrow; GTS2(H, F, i, j) end proc;
n, m := 5, 4;
M=Matrix(n, m, curry(Sols3, H, F))
You can find all the functions required in this worksheet. The curried call to this function is in section 4.
MHD_cchf_2.mw
w := .572433:
for j to nops(N, m) do sol1 := dsolve([diff(diff(diff(f(eta), eta), eta), eta)+w*x(f(eta)*(diff(diff(f(eta), eta), eta))-(m[j]*m[j])*(diff(f(eta), eta))-(diff(f(eta), eta))^2) = 0, y*(diff(diff(theta(eta), eta), eta))/(pr*z)-b*f(eta)*(diff(f(eta), eta))*(diff(theta(eta), eta))-b*f(eta)^2*(diff(diff(theta(eta), eta), eta))+f(eta)*(diff(theta(eta), eta)) = 0, f(0) = N[j], (D(f))(0) = 1, (D(f))(20) = 0, theta(0) = 1, theta(20) = 0], numeric, method = bvp); plots[odeplot](sol1, [eta, ((D@@2)(f))(eta)], color = red); plots[odeplot](sol1, color = red); plots[odeplot](sol1, [eta, theta(eta)], color = K[j], linestyle = L[j]); fplt[j] := plots[odeplot](sol1, [eta, f(eta)], color = K[j], axes = boxed, linestyle = L[j]); tplt[j] := plots[odeplot](sol1, [[eta, theta(eta)]], color = K[j], axes = box, linestyle = L[j]) end do; plots:-display([seq(fplt[j], j = 1 .. nops(N, m))]); plots:-display([seq(tplt[j], j = 1 .. nops(N, m))])
Error, invalid input: nops expects 1 argument, but received 2
Download MHD_cchf_2.mw
Respected sir, I try to plot graphs using two parameters once. But it showing the error as
can anybody do help in this regard?
I have a problem writing a program for the numerical solution of nonlinear volterra integral equation using the method of reproducing kernel space. I have my algorithm as well as the program I tried to write, though they are full of error messages. Please could anyone give me a clue on how to go about my challenges. The algorithm is as follows:
Step 1. Fix π‘Ž ≤ π‘₯ and 𝑑 ≤ 𝑏.
If 𝑑 ≤ π‘₯, set 𝑅π‘₯(𝑑) = 1 − π‘Ž + 𝑑.
Else set 𝑅π‘₯(𝑑) = 1 − π‘Ž + π‘₯.
Step 2. For 𝑖 = 1, 2, . . . , π‘š set π‘₯i = (𝑖 − 1)/(π‘š − 1).
Set πœ“i(π‘₯) = 𝐿t𝑅π‘₯(𝑑)|𝑑=π‘₯i .
Step 3. Set 𝑒0(π‘₯1) = 𝑒(π‘₯1).
Step 4. For 𝑖 = 1, 2, . . . , π‘š set 𝛾ij = [πœ“-1]ij.
Step 5. 𝑛 = 1.
Step 6. Set Sn = Σ𝑛
π‘˜=1 𝛾nk𝑒k-1(π‘₯k).
Step 7. Set 𝑒n(π‘₯) = Σ𝑛
𝑖=1 Siπœ“i(π‘₯).
Step 8. If 𝑛 < π‘šthen set 𝑛 = 𝑛 + 1 and go to step 6.
Else stop.
how can i plot outside of an sphere? for example x^2+y^2+z^2>1 ? tnx for help
First 804 805 806 807 808 809 810 Last Page 806 of 2434
ο»Ώ
