Hello, consider 0<x<1, 0<y<1 and t >0 (t: fixed)
Let the region:
R={(x,y) | x*(1-y)/y*(1-x) < t}
How can I draw the region R in Maple. thanks.
I am attaching the sheet, I want to solve for w or find range of w.
q1.mw
I noticed sometimes Maple dsolve solves an ode using a method different than what odeadvisor says it is.
In this example ode, advisor said it is separable. But when solving it, dsolve actually solved it as dAlembert.
Why is that? Should not these be the same?
I also noticed Maple does not verify the solution of the ode when asked to solve it as separable, which is what the advisor says. But it does verify the solution using dAlembert.
So in this example, should not advisor have said this ode is dAlembert and not separable then?
`The "Physics Updates" version in the MapleCloud is 1786 and is the same as the version installed in this computer, created 2024, August 10, 8:50 hours Pacific Time.`
ode:=y(x) = x + 3*ln(diff(y(x), x));
DEtools:-odeadvisor(ode);
y(x) = x+3*ln(diff(y(x), x))
[_separable]
infolevel[dsolve]:=5:
sol_1:=dsolve(ode);
Methods for first order ODEs:
-> Solving 1st order ODE of high degree, 1st attempt
trying 1st order WeierstrassP solution for high degree ODE
trying 1st order WeierstrassPPrime solution for high degree ODE
trying 1st order JacobiSN solution for high degree ODE
trying 1st order ODE linearizable_by_differentiation
trying differential order: 1; missing variables
trying d'Alembert
<- d'Alembert successful
y(x) = x, y(x) = x+3*ln(exp(-(1/3)*x)*c__1/(-1+exp(-(1/3)*x)*c__1))
map(X->odetest(X,ode),[sol_1]);
[0, 0]
sol_2:=dsolve(ode,[separable]);
Classification methods on request
Methods to be used are: [separable]
* Tackling ODE using method: separable
trying separable
<- separable successful
y(x) = -3*ln(exp(-(1/3)*x)-(1/3)*c__1)
#notice, solution does not verify.
odetest(sol_2,ode);
-3*ln(3*exp(-(1/3)*x)-c__1)-x-3*ln(exp(-(1/3)*x)/(3*exp(-(1/3)*x)-c__1))
Download why_different_method_used_august_13_2024.mw
I use a procedure called Isee  to print to screen procedures from my packages.
However if the procedure is overloaded it Isee doesn't print it. Is there a way around this.
I have inserted screen shots to show the outputs for the package.
Test:=proc(a::{vector})
print(a);
proc (a::{vector}) print(a) end proc
Test1:=overload([ proc(a::{vector})
                  option overload;
                  print(a);
                  end proc,
                  proc(a::{Matrix})
                  option overload;
                  print(a);
                  end proc
proc () option overload; [proc (a::{vector}) option overload; print(a) end proc, proc (a::{Matrix}) option overload; print(a) end proc] end proc
Isee := proc(a)
interface(verboseproc = 3);
printf("%P", eval(a));
proc (a) interface(verboseproc = 3); printf("%P", eval(a)) end proc
Isee(Test)
proc(a::{vector})
    print(a);
end proc
Isee(Test1)
proc()
    option overload;
    [proc(a::{vector}) option overload; print(a); end proc,
        proc(a::{Matrix}) option overload; print(a); end proc];
end proc
#with(Routines);
#An non overloaded procedure in a package
Isee(ConicMatrix);
                                  ConicMatrix
#An overloaded procecure in a package
Isee(FactReduce);
                                  FactReduce
Download 2024-08-12_print_overloaded_procedure.mw
I was looking at the application center about attractors and found the Rossler attractor app that illustrates the Rossler Attractor with animations, as you can see below. But when I try to run it on my laptop  the two last plots remain empty. Why is this happening?
Rossler Flow System - Rossler Attractor
by Yufang Hao, <yhao@student.math.uwaterloo.ca>
This worksheet contains the images of the Rossler Attractor and the animations that follow the trajectory.
restart; with(DEtools): with(plots):
The Rossler attractor is defined by a set of three Differential equations:
x' = -(y+z)
y' = x+a*y
z' = b + x*z - c*z
where the coefficients a, b, and c are adjustable constants.
rosslerEqns := [
diff(x(t),t) = -(y(t)+z(t)),
diff(y(t),t) = x(t) + a*y(t),
diff(z(t),t) = b + x(t)*z(t) - c*z(t) ];
rosslerEqns := [diff(x(t), t) = -y(t)-z(t), diff(y(t), t) = x(t)+a*y(t), diff(z(t), t) = b+x(t)*z(t)-c*z(t)]
a:=0.17: b:=0.4: c:=8.5:
DEplot3d(rosslerEqns, {x(t),y(t),z(t)}, t=0..300,
         [[x(0)=0, y(0)=0, z(0)=0]],
         x =-15..15, y=-15..15,z=-5..25,
         stepsize=0.05, linecolour=1+sin(t*Pi/3)/2,
         thickness=1, orientation = [-110,71]);
display(
  [seq(
    DEplot3d(rosslerEqns, {x(t),y(t),z(t)}, t=0..4*i,
         stepsize=0.05, linecolour=1+sin((i-t)*Pi/5)/2,
         thickness=2, orientation = [-110,71]),
    i=1..25) # end seq
  ], # end DEplot3d list
insequence=true);
display(
  [seq(
    i=1..25) # end seq
insequence=true);
Download rossler_attractor.mws
Good morning, please help me with 2 questions I have:
1) Maple gives me the result in radians and I want it in degrees, example:
evalf(17*sin(34)/sin(115)) = 9.513506993
The result in degrees should be 10.48901874
2) How do I transform degrees into degrees, minutes and seconds?
Example: 15.925º
= 15º 55' 30''
when i do the convert in maple to latex  is do but not fully simplify and some kind of clearer must write for paper and i must do this case by case by hand but how i can simplify before i convert to latex and remove all extra thing like multiply between two squar root
K := [A[1] = 0, A[0] = 0, B[1] = `&-+`(sqrt(2)*sqrt(a[5])/sqrt(a[4])), k = k, a[2] = -a[5], w = -2*a[5]*a[3]*(4*k^2-1)/(3*a[4]), a[1] = 8*a[5]*a[3]/(3*a[4]), v = 2*a[1]*k]
[A[1] = 0, A[0] = 0, B[1] = `&-+`(2^(1/2)*a[5]^(1/2)/a[4]^(1/2)), k = k, a[2] = -a[5], w = -(2/3)*a[5]*a[3]*(4*k^2-1)/a[4], a[1] = (8/3)*a[5]*a[3]/a[4], v = 2*a[1]*k]
latex(K)
\left[A_{1} = 0, A_{0} = 0, B_{1} =
\mp \frac{\sqrt{2}\, \sqrt{a_{5}}}{\sqrt{a_{4}}}, k = k, a_{2} =
-a_{5}, w = -\frac{2 a_{5} a_{3} \left(4 k^{2}-1\right)}{3 a_{4}},
a_{1} = \frac{8 a_{5} a_{3}}{3 a_{4}}, v = 2 a_{1} k\right]
Download K.mw
In this post about a vibrating T-shaped structure, the ends of the T are traced over time.
The trace of the end encircled below in yellow fades with time
How to do the same with Maple? For example, can an attractor be animated this way?
_local(D, O);
A := [0, 0, 0];
B := [a, 0, 0];
C := [a, b, 0];
D := [0, b, 0];
S := [0, 0, h];
O := [x, y, z];
lineSC := Line(S, C);
lineSD := Line(S, D);
H := Projection(A, lineSC);
K := Projection(A, lineSD);
OH := H - O;
OK := K - O;
OC := C - O;
M := Matrix([OH, OK, OC]);
O := eval(O, %);
simplify(Distance(O, H));
                               O
Error, invalid input: eval received Matrix(3, 3, {(1, 1) = -x+h^2*a/(a^2+b^2+h^2), (1, 2) = -y+h^2*b/(a^2+b^2+h^2), (1, 3) = -z+h*(a^2+b^2)/(a^2+b^2+h^2), (2, 1) = -x, (2, 2) = -y+h^2*b/(b^2+h^2), (2, 3) = -z+h*b^2/(b^2+h^2), (3, 1) = -x+a, (3, 2) = -y+b, (3, 3) = -z}), which is not valid for its 2nd argument, eqns
How to correct this error ? Thank you.
i am writing code for an iterative process at the end i want to evaluate the summation expression with two loops but it is not evaluating kindly help me out here automatic_differentiation.mw
v := 1; a := 2; t := 0.1e-2; dt := 0.1e-3; N := 40; h := 1/40; K := 4
for i from 0 to N do x[i] := i*h end do
x[5]
1/8
initial_condition := []; for i to N do initial_condition := [op(initial_condition), evalf(2*v*Pi*sin(Pi*x[i])/(a+cos(Pi*x[i])))] end do
u := proc (i) local u_x, u_xx, expr, j; u_x := (1/2)*(u[i+1]-u[i-1])/h; u_xx := (u[i-1]-2*u[i]+u[i+1])/h^2; expr := -alpha*u[i]*u_x+v*u_xx; expr end proc
odes := [seq(u(i, [seq(u[j], j = 1 .. N-1)]), i = 1 .. N-1)]
for i to N-1 do assign(o[i] = odes[i]) end do
for i to N-1 do printf("u_%d = %s\n", i, convert(u(i), string)) end do
u_1 = -alpha*u[1]*(20*u[2]-20*u[0])+1600*u[0]-3200*u[1]+1600*u[2]
u_2 = -alpha*u[2]*(20*u[3]-20*u[1])+1600*u[1]-3200*u[2]+1600*u[3]
u_3 = -alpha*u[3]*(20*u[4]-20*u[2])+1600*u[2]-3200*u[3]+1600*u[4]
u_4 = -alpha*u[4]*(20*u[5]-20*u[3])+1600*u[3]-3200*u[4]+1600*u[5]
u_5 = -alpha*u[5]*(20*u[6]-20*u[4])+1600*u[4]-3200*u[5]+1600*u[6]
u_6 = -alpha*u[6]*(20*u[7]-20*u[5])+1600*u[5]-3200*u[6]+1600*u[7]
u_7 = -alpha*u[7]*(20*u[8]-20*u[6])+1600*u[6]-3200*u[7]+1600*u[8]
u_8 = -alpha*u[8]*(20*u[9]-20*u[7])+1600*u[7]-3200*u[8]+1600*u[9]
u_9 = -alpha*u[9]*(20*u[10]-20*u[8])+1600*u[8]-3200*u[9]+1600*u[10]
u_10 = -alpha*u[10]*(20*u[11]-20*u[9])+1600*u[9]-3200*u[10]+1600*u[11]
u_11 = -alpha*u[11]*(20*u[12]-20*u[10])+1600*u[10]-3200*u[11]+1600*u[12]
u_12 = -alpha*u[12]*(20*u[13]-20*u[11])+1600*u[11]-3200*u[12]+1600*u[13]
u_13 = -alpha*u[13]*(20*u[14]-20*u[12])+1600*u[12]-3200*u[13]+1600*u[14]
u_14 = -alpha*u[14]*(20*u[15]-20*u[13])+1600*u[13]-3200*u[14]+1600*u[15]
u_15 = -alpha*u[15]*(20*u[16]-20*u[14])+1600*u[14]-3200*u[15]+1600*u[16]
u_16 = -alpha*u[16]*(20*u[17]-20*u[15])+1600*u[15]-3200*u[16]+1600*u[17]
u_17 = -alpha*u[17]*(20*u[18]-20*u[16])+1600*u[16]-3200*u[17]+1600*u[18]
u_18 = -alpha*u[18]*(20*u[19]-20*u[17])+1600*u[17]-3200*u[18]+1600*u[19]
u_19 = -alpha*u[19]*(20*u[20]-20*u[18])+1600*u[18]-3200*u[19]+1600*u[20]
u_20 = -alpha*u[20]*(20*u[21]-20*u[19])+1600*u[19]-3200*u[20]+1600*u[21]
u_21 = -alpha*u[21]*(20*u[22]-20*u[20])+1600*u[20]-3200*u[21]+1600*u[22]
u_22 = -alpha*u[22]*(20*u[23]-20*u[21])+1600*u[21]-3200*u[22]+1600*u[23]
u_23 = -alpha*u[23]*(20*u[24]-20*u[22])+1600*u[22]-3200*u[23]+1600*u[24]
u_24 = -alpha*u[24]*(20*u[25]-20*u[23])+1600*u[23]-3200*u[24]+1600*u[25]
u_25 = -alpha*u[25]*(20*u[26]-20*u[24])+1600*u[24]-3200*u[25]+1600*u[26]
u_26 = -alpha*u[26]*(20*u[27]-20*u[25])+1600*u[25]-3200*u[26]+1600*u[27]
u_27 = -alpha*u[27]*(20*u[28]-20*u[26])+1600*u[26]-3200*u[27]+1600*u[28]
u_28 = -alpha*u[28]*(20*u[29]-20*u[27])+1600*u[27]-3200*u[28]+1600*u[29]
u_29 = -alpha*u[29]*(20*u[30]-20*u[28])+1600*u[28]-3200*u[29]+1600*u[30]
u_30 = -alpha*u[30]*(20*u[31]-20*u[29])+1600*u[29]-3200*u[30]+1600*u[31]
u_31 = -alpha*u[31]*(20*u[32]-20*u[30])+1600*u[30]-3200*u[31]+1600*u[32]
u_32 = -alpha*u[32]*(20*u[33]-20*u[31])+1600*u[31]-3200*u[32]+1600*u[33]
u_33 = -alpha*u[33]*(20*u[34]-20*u[32])+1600*u[32]-3200*u[33]+1600*u[34]
u_34 = -alpha*u[34]*(20*u[35]-20*u[33])+1600*u[33]-3200*u[34]+1600*u[35]
u_35 = -alpha*u[35]*(20*u[36]-20*u[34])+1600*u[34]-3200*u[35]+1600*u[36]
u_36 = -alpha*u[36]*(20*u[37]-20*u[35])+1600*u[35]-3200*u[36]+1600*u[37]
u_37 = -alpha*u[37]*(20*u[38]-20*u[36])+1600*u[36]-3200*u[37]+1600*u[38]
u_38 = -alpha*u[38]*(20*u[39]-20*u[37])+1600*u[37]-3200*u[38]+1600*u[39]
u_39 = -alpha*u[39]*(20*u[40]-20*u[38])+1600*u[38]-3200*u[39]+1600*u[40]
initial_conditions := [.1644933719, .3289856976, .4934717144, .6579375992, .8223563570, .9866828090, 1.150848028, 1.314753051, 1.478261707, 1.641192349, 1.803308276, 1.964306617, 2.123805434, 2.281328760, 2.436289364, 2.587968970, 2.735495794, 2.877819368, 3.013682762, 3.141592654, 3.259788188, 3.366210070, 3.458472370, 3.533840560, 3.589220824, 3.621167336, 3.625916040, 3.599455182, 3.537643690, 3.436388151, 3.291886154, 3.100937330, 2.861312732, 2.572157998, 2.234388242, 1.851015873, 1.427342882, .9709526944, .4914580366, 0.]; u := table(); for i to N do u[i] := initial_conditions[i] end do
.1644933719
.3289856976
.4934717144
.6579375992
.8223563570
.9866828090
1.150848028
1.314753051
1.478261707
1.641192349
1.803308276
1.964306617
2.123805434
2.281328760
2.436289364
2.587968970
2.735495794
2.877819368
3.013682762
3.141592654
3.259788188
3.366210070
3.458472370
3.533840560
3.589220824
3.621167336
3.625916040
3.599455182
3.537643690
3.436388151
3.291886154
3.100937330
2.861312732
2.572157998
2.234388242
1.851015873
1.427342882
.9709526944
.4914580366
0.
for i from 2 to N-1 do T1[i] := (u[i+1]-u[i-1])/(2*h); T2[i] := u[i]*T1[i]; T3[i] := (u[i-1]-2*u[i]+u[i+1])/h^2; uN[i][1] := v*T3[i]-T2[i] end do
6.579566850
2.164583390
-0.100942400e-1
-2.174677630
6.579038030
3.246569176
-0.322112000e-1
-3.278780376
6.577692850
4.327711442
-0.754025600e-1
-4.403114002
6.574904195
5.406914261
-.1476892800
-5.554603541
6.569833420
6.482341694
-.257972800
-6.740314494
6.561404840
7.551179821
-.416313600
-7.967493421
6.548273580
8.609362668
-.634187200
-9.243549868
6.528785960
9.651254278
-.924822400
-10.57607668
6.500931380
10.66927884
-1.303544000
-11.97282284
6.462285360
11.65349267
-1.788137600
-13.44163027
6.409943160
12.59109376
-2.399238400
-14.99033216
6.340442860
13.46586700
-3.160785600
-16.62665260
6.249678600
14.25757153
-4.100355200
-18.35792673
6.132804200
14.94128564
-5.249596800
-20.19088244
5.984128600
15.48673913
-6.644451200
-22.13119033
5.797007960
15.85769089
-8.325200000
-24.18289089
5.563739360
16.01143689
-10.33628800
-26.34772489
5.275465720
15.89858010
-12.72560320
-28.62418330
4.922108520
15.46325997
-15.54297280
-31.00623277
4.492348320
14.64410399
-18.83784320
-33.48194719
3.973683640
13.37625388
-22.65533120
-36.03158508
3.352609800
11.59490836
-27.03057600
-38.62548436
2.614969080
9.240883798
-31.98068160
-41.22156540
1.746535520
6.268701658
-37.49400320
-43.76270486
.7339043200
2.657590351
-43.51649280
-46.17408315
-.4342430800
-1.574528949
-49.93529920
-48.36077025
-1.765447000
-6.354647353
-56.56101440
-50.20636705
-3.261340620
-11.53746107
-63.11047520
-51.57301413
-4.915150720
-16.89036569
-69.19433280
-52.30396711
-6.709016420
-22.08531826
-74.31492320
-52.22960494
-8.611468440
-26.70362395
-77.88123840
-51.17761445
-10.57558664
-30.26006070
-79.24821760
-48.98815690
-12.53848980
-32.25097682
-77.78403520
-45.53305838
-14.42284250
-32.22622970
-72.96418080
-40.73795110
-16.14090720
-29.87707543
-64.48099520
-34.60391977
-17.60126357
-25.12303827
-52.34751456
-27.22447629
-18.71769691
-18.17399825
-36.96715264
-18.79315439
-19.41905389
-9.543650097
-19.14140608
-9.597755983
for i from 3 to N do for k to 4 do T1[i][k] := (uN[i+1][k]-uN[i-1][k])/(2*h); T2[i][k] := 0; for j from 0 to k do T2[i][k] := T1[i][k-j]*uN[i][j]+T2[i][k] end do; T3[i][k] := (uN[i-1][k]-2*uN[i][k]+uN[i+1][k])/h^2; uN[i][k+1] := (-T2[i][k]+T3[i][k])/(k+1) end do end do
"for i from1 to N do          for j  from 1 to 10  do      uNew[i]:=sum(uN[i][k] *( j*dt)^(k), k=0..K);      end do;      end do;"
Error, controlling variable of for loop must be a name or sequence of 2 names
"for i from1 to N do         for j  from 1 to 10  do  uNew[i]:=sum(uN[i][k] * j*dt, k=0..K);      end do;    end do;"
Download automatic_differentiation.mw
How to get Li(x) to display as result of int(1/ln(x),x) in Maple instead of -Ei(1,-ln(x))
I'd like to match result of Maple with another software I use and it is also simpler to look at
int(1/ln(x),x)
Now gives
             -Ei(1,-ln(x))
How to make it show  Li(x) instead?
The Maple help page for Li is this
And the other software Li help page is this
I tried simplify in Maple but it does not do anything. How to get Li(x) in Maple for int(1/ln(x),x);  instead of -Ei(1, -ln(y)) ?
Note that
diff(Li(x),x)
Gives 1/ln(x) so Li(x) is the correct antiderivative.
Here is also the wiki page
I know that Maple's result is correct, I am just asking about the form it is shown. Since Maple has Li(x) function, why not use it for this result?
Maple 2024.1
Hi everyone...
How can I remove the warning (Warning, (in anonymous procedure created in Typesetting:-FI) `m` is implicitly declared local
) from this for command in Maple 2024? I know the warning can be ignored but I want to remove it anyway.
for k from 1 to 4 do
    A[k] := Matrix(k, k, (i, j) -> local m; ifelse(i + j < k + 2, add(Y[i - m + j - 1]*binomial(i - 1, m)*(-1)^m, m = 0 .. i - 1), 0));
end do
tnx...
Hey!
I am having difficulties inputting in text and math mode in my Maple 2023 document. It was working fine in the beginning, but all of a sudden the problem occured. I was restarting maple initially which would temporarily solve the problem, now I cannot input anything after restart. I am doing exam excercises and have been copy/pasting text from a pdf into the document.
I have tried to install Maple 2024 and open the file but to no avail.  Any help/ pointers would be greatly appreciated.
The attached file -
ml.mw
How do I stop truncation in Maple 2023?  Everything was working fine yesterday but today all of a sudden all assignments are truncated to only 10 digits.
If:
with(Units) :
a_Terra := 149598023.*Unit(km) :
A_Luna := 0.136 :
L_Sol := 3.75E28*Unit(lm) :
S_sphere := r -> 4*Pi*r^2 :
J_Luna := A_Luna*L_Sol/S_sphere(a_Terra) :
Then:
"" gives ""
but
"" gives ""
"" without "evalf" also provides a truncated number instead of showing the "Pi" for an exact value.  So something is wrong in the assignment settings.
Somehow the settings must have changed for how assignments are stored. The answer is irrational with a factor of "1/Pi" and so should not be truncated for calculations.  "a_Terra" is assigned with 9 significant digits ("" km) which I am wondering if maybe why "evalf" is truncating to 10 digits (though it should round and not truncate in that case) but it wasn't doing this before.
"Tools --> Options --> Precision" hasn't changed is set globally to round screen display to 32 decimal places and to round calculation to 64 significant digits.
I do not think I ever saw this warning messages from dsolve. This is _Clairaut first order ode. When adding the option singsol=all in the dsolve call, Maple replies with
I do not have earlier version of Maple to try as my C: drive died and lost all my Maple's installed versions. I need to to try to install older version of Maple sometime and check.
Is this new warning and why does it show? Is this suppose to happen?
`The "Physics Updates" version in the MapleCloud is 1782 and is the same as the version installed in this computer, created 2024, August 8, 16:5 hours Pacific Time.`
ode:=a*(1 + diff(y(x), x)^3)^(1/3) + x*diff(y(x), x) - y(x) = 0;
a*(1+(diff(y(x), x))^3)^(1/3)+x*(diff(y(x), x))-y(x) = 0
dsolve(ode,y(x),singsol=all)
Warning, only 1 systems are considered
y(x) = a*(c__1^3+1)^(1/3)+x*c__1
Download strange_warning_message_from_dsolve.mw
I also noticed these warning messages show up only the first time dsolve is called on this ode.
Calling it again right after, using the same command, the warning messages no longer show up, which is  even more strange.
First 86 87 88 89 90 91 92 Last Page 88 of 2430
