 To Whom It Might Concern,
I purchased Maple on Jun 5, 2017 for my Window laptop. However, my harddrive in my laptop was broken and i lost all my stuff including Maple. I am using my husband's laptop right now. How can re install Maple? I still have the transaction number (removed). Would you let me know what I can do to re-install the software? Also, my husband's laptop is a Mac.
I am looking forward to hearing from you.
Nancy Phu.
I would like to create a Maple Workbook of my Lattice Package so I can put it on MapleCloud. I had an email exchange with Daniel Skoog from Maplesoft about this, and he even sent me an example that looked easy enough to adapt to my purposes. Alas, it does not work. Here is the code I wrote to assemble the already extant files:
                "Maple Initialization loaded..."
# Build Lattice workbook following example from Daniel Skoog, MapleSoft:
currentdir();
 "/Applications/Math_Calc/Maple 2015/Packages/Lattice/Lattice
    Version 1.1.0 release files"
# We have all files already from the App Center submission, so just assemble the workbook
PackageTools:-Create("Lattice.maple",\
"MLA file"="Lattice.mla",\
"Lattice.help",\
"Source"="Lattice1.1.mpl",\
"Build procedure"="Lattice1.1.mw",\
"Manual"="The Lattice Package Users Guide.mw",\
"Release Notes"="V1.1 Release Notes.rtf");
Error, (in march) unable to attach worksheet file The Lattice Package Users Guide.mw
When I look at the created workbook (Lattice.maple), the only members included are Lattice.help, the Build procedure Lattice1.1.mw and the source file Lattice.mpl. In particular, Lattice.mla is not there, which is the most important one.
What am I doing wrong? What does "march" (which sounds like machine architecture) have to do with it??
I also don't quite know how to "install" it. I assume I just put the whole workbook into a directory accessible through libname ?
Mac Dude
PS: I could have sorted this privately with Daniel, but this may be of interest to others as well so I hope he'll answer through this forum.
Lattice1.1_workbook_maker.mw
I want to solve this equation with assumptions!!!
assume(d::real, d>0):
assume(a::real, -0.01 < a, a < 0):
sys:={-800*Pi*a*cos(6.557377048*Pi*(3.470797713+d))/(a+1)^3 = -.9396060697, 800*Pi*a*sin(6.557377048*Pi*(3.470797713+d))/(a+1)^3 = -.3238482794};
solve(sys, {a,d},useassumptions=true, AllSolutions=true);
one of the solutions has true "a" but "d" is wrong, I want one true solution!
Maple help pages are terrible.  Sorry, but this is true.
I am looking for one example of how one is supposed to open a file and correctly check that the open was successful and no error occured, all done in code. As in a script.
All what help in fopen says is that if this and that, it generates an error.
OK. But to check for this in code? Why not show an example? the help page on iostatus just lists possible errors. Again, not a SINGLE example of actual Maple code showing how to actually check or handle an error. It just says to call iostatus() and shows the output without an example of what to do next and what to check for.
Lets say one does this:
fileName := "C:\\foo.txt";
fd       := fopen(fileName,WRITE):
Now what? How to check the above was successful? Do I need a trap and catch? catch what? Do I need to check for fd being greater or equal to zero and also use trap in addition? And if an error happens, how to know what it is? How to to format the message, etc.. all in CODE (not interactive) and not by saying just look at the screen and see if there is an error message.
Spend 30 minutes in the help pages and could not find ONE example that shows how to actually check for errors.
I have no idea who writes Maple helps pages, but I find the help pages useless most of the time.
Compare the help for linux fopen for example, where is gives exact details of how to handle the error and find the exact error, all in code.
I solve a mechanical exercise but i had a problem.
I know M (mass) and K (stifness) matrices (4x4).
I want to solve the (λ2M+K)v=0  eigenvalue problem, where λ are the eigenvalues and v eigenvectors.
How can i solve this problem.  I tried with the Eigenvectors() command but it didn't give the right solution.
The Eigenvalues are okay, but the eigenvectors not
K := Matrix([[4*10^7,-1.50*10^7,2*10^7,0],[-1.50*10^7,1.50*10^7,0,1.50*10^7],[2*10^7,0,8*10^7,2*10^7],[0,1.50*10^7,2*10^7,4*10^7]]);
M:=Matrix([[121.90,99.048,-91.429,0],[99.048,594.29,0,-99.048],[-91.429,0,243.81,-91.429],[0,-99.048,-91.429,121.90]]);
w1,w2:=Eigenvectors(K,M);
Acoording with the book the right eigenvectors(shape mode) are:
[0.013 991,  0.034 233,  0.073 683,  0.090 573]
[0.035 637, 0, -0.032 213, 0]
[0 ,-0.034 233, 0, 0.090 573]
[-0.013 991, 0.034 233, -0.073 683, 0.090 573]
I have aproblem saving procedures. I am using Linux Mint 18.2, KDE, 64 Bit. Everything works (at least what I used until now) except:
when trying to use save "save(kgVnat,"kgVnatproc.m") I get an error message "Error, permission denied: no write access (kgVnatproc.m)". Now - the work direcxtory is "/home/username" - in the status bar as well as per currentdir() or currentdir(kernelopts(homedir)) . I can create and save files there - and also in the working directory of maple "/home/username/Studium/Maple" by using a file manager or a text editor - everything else would anyway be surprising when using home/username directory. So it has to be something else ...
I can save the worksheet as a whole without any problems in "/home/username/Studium/Maple". Also I tried to use currentdir(..) to change to the directory explicitely and then saving the proecdure, but again, "..access denied" even though worksheets are saved without error...
Anyone any idea?
Kind regards Udo
Hi, i have a problem with subs instruction. I'd like to change a function D(s) with symbol d/ds d(t), but i won't to calculate derivate, I want only change symbol. Thanks a lot.
Sometimes dsolve returns solution as implicit, even when not using the `implicit` option. For example
ode:=diff(y(x),x)=(x*y(x))^(1/2):
sol:=dsolve(ode,y(x));
Gives
Which is the same result if I had used 'implicit'.
Is there a way to tell dsolve not to do this? is it becuase it can't solve for y(x) from the above?
Maple 2017.1
i want to draw plot Y[1] . but i cant. thank you
with(LinearAlgebra); Digits := 15; with(plots); with(Optimization);;
NewM := Matrix(5, 5, [[4119700.0000, 0., 0., 0., 0.], [0., 175900.0000, 0., 0., 0.], [0., 0., 52796., 0., 0.], [0., 0., 0., 2002900.0000, 0.], [0., 0., 0., 0., 21711.]]); NewK := Matrix(5, 5, [[18278000.0000, 0., 0., 0., 0.], [0., 8478500.0000, 0., 0., 0.], [0., 0., 3874800.0000, 0., 0.], [0., 0., 0., 494710000.0000, 0.], [0., 0., 0., 0., 7707500.0000]]); L := Vector[column](5, [400689.480747934, 36882.2103608425, 24223.1756570268, 7197.48654698287, 5007.64668721342]); V := Vector[column](5, [4.43679672962542, 48.2014976972537, 73.3916065733549, 246.999805581163, 355.012621460930]);
Phi := Matrix(5, 5, [[1., 1., 1., 1., 1.], [1.96506022575420, 1.62041320563413, 1.42204109823483, 0.548765310483432e-1, -.795724394004826], [9.21473910149806, 2.36597630710861, -.837387679777313, -8.23805381555997, 0.930594200639915e-1], [10.5672146719479, 1.26937656539014, -.710851068914949, 12.5801876194058, -0.564138989400088e-1], [12.4282433098880, -2.02516824673162, .481291188486771, -1.71479964168293, 0.513709374343217e-2]]);
NS := ImportMatrix("D:/tabas.txt", datatype = float[8]);
t_NS := NS[() .. (), 1];
acc_NS := NS[() .. (), 2];
plot(NS, t = 0 .. 4.5, size = [800, 400]);
acc := unapply(CurveFitting:-Spline(t_NS, acc_NS/(9.81), t, degree = 1), t);
eq := seq(diff(x[i](t), t$2)+(2*0.5e-1)*sqrt(V[i])*(diff(x[i](t), t))+V[i]*x[i](t) = L[i]*acc(t)/NewM[i, i], i = 1 .. 5, 1);
ic := [seq({x[i](0) = 0, (D(x[i]))(0) = 0}, i = 1 .. 5, 1)];
sol := seq(dsolve({eq[i], ic[i][]}, numeric, output = listprocedure), i = 1 .. 5, 1);
Z := `<,>`(seq(sol[i][2], i = 1 .. 5));
#Y := Phi . Z;
#odeplot(Y[1], t = 0 .. 10);
tabas.txt
1.mw
when i want to get awenser i have to solve it for 36 equation and 36 variabales
but maple will not give me a solution (just toss me back my variabales ) i dont know whats wrong
it will give me an awenser for lower like 20equ and 20var ?
parameters :
there is m for power an equation (equation^m) its between 2 , 2.5 , 3 , 4
and N give 2N+2var and 2N+2equ
its a hard calculation i copy it here hope u get it
h= "a number "
p := proc (x) c[-N-1]*x^2+1 end proc
dp := diff(p(x), x)
ddp := diff(p(x), x, x)
DELTA2 := piecewise(k <> j, -2*(-1)^(j-k)/(j-k)^2, k = j, -(1/3)*Pi^2)/h^2
DELTA1 := piecewise(k <> j, (-1)^(j-k)/(j-k), k = j, 0)/h
DELTA0 := piecewise(k <> j, 0, k = j, 1)
PHI := proc (x) ln(sinh(x)) end proc
dPHI := diff(PHI(x), x)
ddPHI := diff(PHI(x), x, x)
for i from -N-1 to N do x[i] := ln(exp(i*h)+(exp(2*i*h)+1)^(1/2)) end do
variabales : c[-N-1],c[-N],c[-N+1]...c[N-1],c[N] total 2N+2 var
My equations
POL := seq(simplify(eval(sum(c[k]*((eval(2*dPHI*DELTA1), x = x[j])+eval(x[j]*ddPHI*DELTA1, x = x[j])+x[j]*(eval(dPHI^2, x = x[j]))*DELTA2), k = -N .. N)+eval(ddp, x = x[j])+2*(sum(c[k]*(eval(x[j]*dPHI*DELTA1, x = x[j])+DELTA0), k = -N .. N)+eval(dp, x = x[j]))/x[j]+(c[j]*x[j]+p(x[j]))^m, x = x[j])), j = -N-1 .. N)
solving
K := fsolve({seq(POL[v] = 0, v = 1 .. 2*N+2)})
it can calculate for m=2.5 , N=15 , h=0.29669
if you can calculate it for m=3 , N=17 , h=0.41600
i want to draw plot Y[1] . but i cant. thank for you
i want to take this equation
with(LinearAlgebra); Digits := 70; with(plots);
K := Matrix(5, 5, [[18278000.0000, 0., 0., 0., 0.], [0., 8478500.0000, 0., 0., 0.], [0., 0., 3874800.0000, 0., 0.], [0., 0., 0., 494710000.0000, 0.], [0., 0., 0., 0., 7707500.0000]]); M := Matrix(5, 5, [[4119700.0000, 0., 0., 0., 0.], [0., 175900.0000, 0., 0., 0.], [0., 0., 52796., 0., 0.], [0., 0., 0., 2002900.0000, 0.], [0., 0., 0., 0., 21711.]]); L := Vector[column](5, [400689.48, 36882.21, 24223.175, 7197.4865, 5007.6466]); V := Vector[column](5, [4.4368, 48.201, 73.39160, 246.999, 355.012]);
eq := seq(diff(x[i](t), t$2)+(2*0.5e-1)*sqrt(V[i])*(diff(x[i](t), t))+V[i]*x[i](t) = L[i]/M[i, i], i = 1 .. 5, 1);
ic := [seq({x[i](0) = 0, (D(x[i]))(0) = 0}, i = 1 .. 6, 1)];
res := evalf(seq(dsolve({eq[i], ic[i][]}, numeric, method = rkf45), i = 1 .. 5, 1));
Z := `<,>`(res[1], res[2], res[3], res[4], res[5]);
Y := Phi . Z;
#odeplot(rhs(Y[1]), t = 0 .. 4)
import file text
tabas.txt
res := dsolve({25*(diff(y(t), t, t))+4*(diff(y(t), t))-3*y(t) = cos(3*t), y(0) = 0, (D(y))(0) = 1}, numeric, method = rkf45);
with(Optimization);
Maximize(res, t = 0 .. 4);
Everytime I start Maple 2017 I get a window asking me to accept incoming connection even though I did not put any restriction in System Preferences-Security-Firewall.
Is it normal?
hello...how i can remove this error?
33.mw
restart; Digits := 15
15
sys3 := {-.233333333333333*(diff(g5(y), y, y))+0.5e-1*g3(y)-.820000000000000*g5(y)*omega2-0.150000000000000e-1*g4(y)*omega2+0.500000000000000e-4*(diff(g1(y), y))*omega2-0.999999999999999e-4*(diff(g2(y), y))*omega2-1.44142830009497*(diff(g2(y), y, y, y, y, y))+864.856980056984*(diff(g5(y), y, y, y, y)), 2.61572184429325*10^(-10)*(diff(g3(y), y, y, y, y, y, y, y, y))+3.32396399331216*10^(-7)*(diff(g3(y), y, y, y, y, y, y))-0.193818732289211e-2*(diff(g3(y), y, y, y, y))+0.199166451610413e-1*(diff(g1(y), y, y, y, y, y))+0.598690451303844e-1*(diff(g2(y), y, y, y, y, y))-5.40849801271536*(diff(g1(y), y, y, y))-5.40846938859685*(diff(g2(y), y, y, y))-.101409302553410*(diff(g3(y), y, y))+0.240924444444445e-5*(diff(g4(y), y, y, y, y)), -.233333333333333*(diff(g4(y), y, y))-0.5e-1*g3(y)-.820000000000000*g4(y)*omega2-0.150000000000000e-1*g5(y)*omega2+0.999999999999999e-4*(diff(g1(y), y))*omega2-0.500000000000000e-4*(diff(g2(y), y))*omega2-0.225354497440541e-3*(diff(g3(y), y, y, y, y, y, y))-76.1509512630580*(diff(g1(y), y, y, y, y, y))-11.7785283950617*(diff(g2(y), y, y, y, y, y))+1874.44512820514*(diff(g4(y), y, y, y, y))+6.88355555555557*10^(-7)*(diff(g3(y), y, y, y, y))-8413.23456790121*(diff(g2(y), y, y, y))+8413.23456790121*(diff(g1(y), y, y, y)), 7118.49071746442*(diff(g2(y), y, y, y, y))+0.266666666666666e-2*(diff(g3(y), y))-93.3333333333333*g2(y)+93.3333333333333*g1(y)+.820000000000000*g2(y)*omega2-0.999999999999999e-4*(diff(g5(y), y))*omega2+1.66666666666666*10^(-7)*(diff(g1(y), y, y))*omega2-0.500000000000000e-4*(diff(g4(y), y))*omega2-3.33333333333333*10^(-7)*(diff(g2(y), y, y))*omega2+0.150000000000000e-1*g1(y)*omega2+980.282047736626*(diff(g1(y), y, y, y, y))+0.987816663816580e-2*(diff(g3(y), y, y, y, y, y))-2.84647769547324*(diff(g1(y), y, y, y, y, y, y))-1.77181281840245*(diff(g2(y), y, y, y, y, y, y))+5.40846577473014*(diff(g3(y), y, y, y))+5.07598485596708*10^5*(diff(g1(y), y, y))-5.07598485596708*10^5*(diff(g2(y), y, y))-16826.4691358025*(diff(g4(y), y, y, y))-0.210330864197531e-4*(diff(g3(y), y, y, y, y, y, y, y)), 1.66666666666666*10^(-7)*(diff(g2(y), y, y))*omega2+0.500000000000000e-4*(diff(g5(y), y))*omega2-3.33333333333333*10^(-7)*(diff(g1(y), y, y))*omega2+0.999999999999999e-4*(diff(g4(y), y))*omega2+0.150000000000000e-1*g2(y)*omega2+.820000000000000*g1(y)*omega2-5.53911151967922*(diff(g1(y), y, y, y, y, y, y))-2.55201448559671*10^5*(diff(g4(y), y, y, y))-0.355523547493069e-4*(diff(g3(y), y, y, y, y, y, y, y))+0.266666666666666e-2*(diff(g3(y), y))-4.05637062704760*(diff(g3(y), y, y))-11.4677117829418*(diff(g3(y), y, y, y))-0.338031746031747e-2*(diff(g3(y), y, y, y, y))-0.890132662315342e-2*(diff(g3(y), y, y, y, y, y))-378.595555555555*(diff(g2(y), y, y, y))-482.358781893005*(diff(g2(y), y, y, y, y))-2.84647769547324*(diff(g2(y), y, y, y, y, y, y))-93.3333333333333*g1(y)-4.35805550617285*10^5*(diff(g1(y), y, y))-378.595555555555*(diff(g1(y), y, y, y))+45299.9927158183*(diff(g1(y), y, y, y, y))+93.3333333333333*g2(y)+5.07598485596708*10^5*(diff(g2(y), y, y))}:
bcs3 := {-0.350267076923078e-2*((D@@3)(g2))(0)+7.00534153846156*((D@@2)(g5))(0) = 0, -0.350267076923078e-2*((D@@3)(g2))(1)+7.00534153846156*((D@@2)(g5))(1) = 0, -0.2100e-1*(D(g5))(0)+0.350267076923078e-2*((D@@5)(g2))(0)-7.00534153846156*((D@@4)(g5))(0) = 0, -0.2100e-1*(D(g5))(1)+0.350267076923078e-2*((D@@5)(g2))(1)-7.00534153846156*((D@@4)(g5))(1) = 0, 1.71617510204081*10^(-14)*((D@@4)(g3))(0)+2.93357776746121*10^(-11)*((D@@2)(g3))(0)+0.912685714285722e-5*(D(g1))(0)-0.912685714285712e-5*(D(g2))(0)-5.09278628571429*10^(-7)*((D@@2)(g4))(0)+8.04988799999997*10^(-9)*((D@@3)(g1))(0)+4.59993600000001*10^(-9)*((D@@3)(g2))(0) = 0, 1.71617510204081*10^(-14)*((D@@4)(g3))(1)+2.93357776746121*10^(-11)*((D@@2)(g3))(1)+0.912685714285722e-5*(D(g1))(1)-0.912685714285712e-5*(D(g2))(1)-5.09278628571429*10^(-7)*((D@@2)(g4))(1)+8.04988799999997*10^(-9)*((D@@3)(g1))(1)+4.59993600000001*10^(-9)*((D@@3)(g2))(1) = 0, -1.64283428634155*10^(-7)*((D@@4)(g3))(0)-.133295923200000*((D@@3)(g1))(0)-0.286218240000000e-1*((D@@3)(g2))(0)+15.1830055384616*((D@@2)(g4))(0)+5.57568000000000*10^(-9)*((D@@2)(g3))(0)-227.157333333333*(D(g2))(0)+227.157333333333*(D(g1))(0) = 0, -1.64283428634155*10^(-7)*((D@@4)(g3))(1)-.133295923200000*((D@@3)(g1))(1)-0.286218240000000e-1*((D@@3)(g2))(1)+15.1830055384616*((D@@2)(g4))(1)+5.57568000000000*10^(-9)*((D@@2)(g3))(1)-227.157333333333*(D(g2))(1)+227.157333333333*(D(g1))(1) = 0, -1.71617510204081*10^(-14)*((D@@5)(g3))(0)-2.12981181756245*10^(-10)*((D@@3)(g3))(0)+0.813595871901550e-5*(D(g3))(0)-0.393365900022856e-4*((D@@2)(g1))(0)-0.136355081430858e-3*((D@@2)(g2))(0)+5.09278628571429*10^(-7)*((D@@3)(g4))(0)-8.04988799999997*10^(-9)*((D@@4)(g1))(0)-4.59993600000001*10^(-9)*((D@@4)(g2))(0) = 0, -1.71617510204081*10^(-14)*((D@@5)(g3))(1)-2.12981181756245*10^(-10)*((D@@3)(g3))(1)+0.813595871901550e-5*(D(g3))(1)-0.393365900022856e-4*((D@@2)(g1))(1)-0.136355081430858e-3*((D@@2)(g2))(1)+5.09278628571429*10^(-7)*((D@@3)(g4))(1)-8.04988799999997*10^(-9)*((D@@4)(g1))(1)-4.59993600000001*10^(-9)*((D@@4)(g2))(1) = 0, -0.2100e-1*(D(g4))(0)+1.64283428634155*10^(-7)*((D@@6)(g3))(0)+.185046811569231*((D@@5)(g1))(0)+0.286218240000000e-1*((D@@5)(g2))(0)-15.1830055384616*((D@@4)(g4))(0)-5.57568000000000*10^(-9)*((D@@4)(g3))(0)+227.157333333333*((D@@3)(g2))(0)-227.157333333333*((D@@3)(g1))(0) = 0, -0.2100e-1*(D(g4))(1)+1.64283428634155*10^(-7)*((D@@6)(g3))(1)+.185046811569231*((D@@5)(g1))(1)+0.286218240000000e-1*((D@@5)(g2))(1)-15.1830055384616*((D@@4)(g4))(1)-5.57568000000000*10^(-9)*((D@@4)(g3))(1)+227.157333333333*((D@@3)(g2))(1)-227.157333333333*((D@@3)(g1))(1) = 0, 371.200498864795*((D@@2)(g1))(0)-0.125033665514056e-4*((D@@3)(g3))(0)-0.454911629784616e-2*((D@@4)(g1))(0)-0.207508224000000e-2*((D@@4)(g2))(0)-.90862933333333*((D@@2)(g2))(0)-.219044470756571*(D(g3))(0)+.317542124307693*((D@@3)(g4))(0)-7.77529998367344*10^(-9)*((D@@5)(g3))(0) = 0, 371.200498864795*((D@@2)(g1))(1)-0.125033665514056e-4*((D@@3)(g3))(1)-0.454911629784616e-2*((D@@4)(g1))(1)-0.207508224000000e-2*((D@@4)(g2))(1)-.90862933333333*((D@@2)(g2))(1)-.219044470756571*(D(g3))(1)+.317542124307693*((D@@3)(g4))(1)-7.77529998367344*10^(-9)*((D@@5)(g3))(1) = 0, -1.71617510204081*10^(-14)*((D@@8)(g3))(0)-2.42316975112457*10^(-10)*((D@@6)(g3))(0)+0.156993173154261e-4*((D@@4)(g3))(0)-0.483974477413303e-4*((D@@5)(g1))(0)-0.145481779666834e-3*((D@@5)(g2))(0)+.146029446343315*((D@@3)(g1))(0)+.146028673492115*((D@@3)(g2))(0)+0.912683722980687e-2*((D@@2)(g3))(0)-1.95148800000000*10^(-8)*((D@@4)(g4))(0) = 0, -1.71617510204081*10^(-14)*((D@@8)(g3))(1)-2.42316975112457*10^(-10)*((D@@6)(g3))(1)+0.156993173154261e-4*((D@@4)(g3))(1)-0.483974477413303e-4*((D@@5)(g1))(1)-0.145481779666834e-3*((D@@5)(g2))(1)+.146029446343315*((D@@3)(g1))(1)+.146028673492115*((D@@3)(g2))(1)+0.912683722980687e-2*((D@@2)(g3))(1)-1.95148800000000*10^(-8)*((D@@4)(g4))(1) = 0, 54.7703335314617*((D@@2)(g2))(0)+5.87769600000000*((D@@2)(g1))(0)+0.148770877878858e-4*((D@@3)(g3))(0)-0.207508224000000e-2*((D@@4)(g1))(0)-0.129031719384616e-2*((D@@4)(g2))(0)+.146028885677714*(D(g3))(0)+.143109120000000*((D@@3)(g4))(0)+0.350267076923078e-2*((D@@3)(g5))(0)-4.59993600000001*10^(-9)*((D@@5)(g3))(0) = 0, 54.7703335314617*((D@@2)(g2))(1)+5.87769600000000*((D@@2)(g1))(1)+0.148770877878858e-4*((D@@3)(g3))(1)-0.207508224000000e-2*((D@@4)(g1))(1)-0.129031719384616e-2*((D@@4)(g2))(1)+.146028885677714*(D(g3))(1)+.143109120000000*((D@@3)(g4))(1)+0.350267076923078e-2*((D@@3)(g5))(1)-4.59993600000001*10^(-9)*((D@@5)(g3))(1) = 0, 1.71617510204081*10^(-14)*((D@@6)(g3))(0)+2.42316975112457*10^(-10)*((D@@4)(g3))(0)-0.715265022412607e-5*((D@@2)(g3))(0)+0.483974477413303e-4*((D@@3)(g1))(0)+0.145481779666834e-3*((D@@3)(g2))(0)-3.28345600000000*10^(-7)*(D(g1))(0)+3.28345600000000*10^(-7)*(D(g2))(0)+2.11875840000000*10^(-8)*((D@@2)(g4))(0)-5.09278628571429*10^(-7)*((D@@4)(g4))(0)+8.04988799999997*10^(-9)*((D@@5)(g1))(0)+4.59993600000001*10^(-9)*((D@@5)(g2))(0) = 0, 1.71617510204081*10^(-14)*((D@@6)(g3))(1)+2.42316975112457*10^(-10)*((D@@4)(g3))(1)-0.715265022412607e-5*((D@@2)(g3))(1)+0.483974477413303e-4*((D@@3)(g1))(1)+0.145481779666834e-3*((D@@3)(g2))(1)-3.28345600000000*10^(-7)*(D(g1))(1)+3.28345600000000*10^(-7)*(D(g2))(1)+2.11875840000000*10^(-8)*((D@@2)(g4))(1)-5.09278628571429*10^(-7)*((D@@4)(g4))(1)+8.04988799999997*10^(-9)*((D@@5)(g1))(1)+4.59993600000001*10^(-9)*((D@@5)(g))(1) = 0, g1(0) = 0, g1(1) = 0, g2(0) = 0, g2(1) = 0, ((D@@2)(g1))(0) = 0, ((D@@2)(g1))(1) = 0, ((D@@2)(g2))(0) = 0, ((D@@2)(g2))(1) = 0}:
dsys4 := {bcs3, sys3}:
Typesetting:-mrow(Typesetting:-mo("for", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("bb", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("in", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("extra_bcs", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("do", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("try", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("print", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("bb", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-msup(Typesetting:-mn("10", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mrow(Typesetting:-mo("&uminus0;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2222222em", rspace = "0.2222222em"), Typesetting:-mn("13", font_style_name = "2D Input", mathvariant = "normal")), superscriptshift = "0")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("res", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("bb", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo("&coloneq;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("dsolve", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("newsys2", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("union", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("bb", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-msup(Typesetting:-mn("10", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mrow(Typesetting:-mo("&uminus0;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2222222em", rspace = "0.2222222em"), Typesetting:-mn("13", font_style_name = "2D Input", mathvariant = "normal")), superscriptshift = "0")), font_style_name = "2D Input", mathvariant = "normal", open = "{", close = "}"), Typesetting:-mo("union", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("bcs3", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("numeric", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("method", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("bvp", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("middefer", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("output", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("listprocedure", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("initmesh", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mn("3024", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("approxsoln", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("omega3", italic = "false", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mn("0.0000000001", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("g1", italic = "false", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("y", italic = "false", font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-msup(Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mrow(Typesetting:-mn("5", font_style_name = "2D Input", mathvariant = "normal")), superscriptshift = "0"), Typesetting:-mo("&sdot;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-msup(Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("&minus;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2222222em", rspace = "0.2222222em"), Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mrow(Typesetting:-mn("5", font_style_name = "2D Input", mathvariant = "normal")), superscriptshift = "0"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("g2", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-msup(Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mrow(Typesetting:-mn("5", font_style_name = "2D Input", mathvariant = "normal")), superscriptshift = "0"), Typesetting:-mo("&sdot;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-msup(Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("&minus;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2222222em", rspace = "0.2222222em"), Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mrow(Typesetting:-mn("5", font_style_name = "2D Input", mathvariant = "normal")), superscriptshift = "0"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("g4", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-msup(Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mrow(Typesetting:-mn("3", font_style_name = "2D Input", mathvariant = "normal")), superscriptshift = "0"), Typesetting:-mo("&sdot;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-msup(Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("&minus;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2222222em", rspace = "0.2222222em"), Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mrow(Typesetting:-mn("3", font_style_name = "2D Input", mathvariant = "normal")), superscriptshift = "0"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("g3", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-msup(Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mrow(Typesetting:-mn("7", font_style_name = "2D Input", mathvariant = "normal")), superscriptshift = "0"), Typesetting:-mo("&sdot;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-msup(Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("&minus;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2222222em", rspace = "0.2222222em"), Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mrow(Typesetting:-mn("7", font_style_name = "2D Input", mathvariant = "normal")), superscriptshift = "0"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("g5", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mrow(Typesetting:-msup(Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mrow(Typesetting:-mn("3", font_style_name = "2D Input", mathvariant = "normal")), superscriptshift = "0"), Typesetting:-mo("&sdot;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-msup(Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("&minus;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2222222em", rspace = "0.2222222em"), Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mrow(Typesetting:-mn("3", font_style_name = "2D Input", mathvariant = "normal")), superscriptshift = "0")), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("abserr", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mn("1e&minus;9", font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("catch", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("print", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("lasterror", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("end", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("try", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("end", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("do", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("indx", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("&coloneq;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("indices", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("res", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("nolist", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mi("nops", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("indx", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mi("res", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("indx", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("P", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("&coloneq;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("seq", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("subs", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("res", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("indx", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("i", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("0", font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("omega3", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("0", font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("i", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("..", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2222222em", rspace = "0.0em"), Typesetting:-mi("nops", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("indx", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]")), font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo("for", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("i", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("from", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("by", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("to", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("nops", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("indx", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("do", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mfrac(Typesetting:-mrow(Typesetting:-mi("sqrt", italic = "false", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("10", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("^", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.1111111em", rspace = "0.1111111em"), Typesetting:-mn("25", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("*", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.1666667em", rspace = "0.1666667em"), Typesetting:-mi("P", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("i", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]")), font_style_name = "2D Input", mathvariant = "normal")), Typesetting:-mrow(Typesetting:-mn("2", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("&sdot;", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("Pi", italic = "false", font_style_name = "2D Input", mathvariant = "normal")), linethickness = "1", denomalign = "center", numalign = "center", bevelled = "false"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("od", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(";", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mi("plots", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(":-", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("odeplot", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("res", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("indx", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi(""), Typesetting:-mrow(Typesetting:-mi("seq", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("cat", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("g", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("i", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("i", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("..", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2222222em", rspace = "0.0em"), Typesetting:-mn("5", font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal")), Typesetting:-mi("")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mn("0", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("..", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2222222em", rspace = "0.0em"), Typesetting:-mn("1", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("thickness", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("=", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mn("3", font_style_name = "2D Input", mathvariant = "normal")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mi(""))
"unable to store %1 when datatype=%2", -HFloat(9.659865599999965e-7)+0.459993600000001e-8*((D@@5)(g))(1), float[8]
Download 33.mw
I'm new of Mapel trying to get basics.
How do I collect on the square terms in the numerator?
First 961 962 963 964 965 966 967 Last Page 963 of 2434
