Below I wanted Maple to calculate the 4. degree Taylorpolynomium of a function f around x = 7. As shown below, Maple delivers a polynomial, but not a function definition. In other words one cannot have the polynomial evaluated at a specific value. The reason for this is obvious: The value 3 of x is passed to the command, implying 3 = 7 is a parameter to the command: Therefore the error message. I solved the problem by using the unapply command, but this operation is a bit tedious. I think I remember there is another more simple operator to make the same happen in Maple. I hope someone can remind me of that one!
Erik
Is there any idea using Maple  to compute the leg lengths  in Stewart-Gough platform ( see the following figure)
I would like to make a code using cross-product and the unit Normal N
·       P is of length 13 and displaced in the Y direction by 10 degrees from the vertical (Z axis)
·       N is displaced in the X direction by 18 degrees from the vertical (Z axis)
·       LB is position [7 5] from the bottom plate centre in the XY plane
·       LT is in position [3.5 4.2] from the top-plate centre in the AB plane
Many thanks for any help
I need to calculate the following complex integral:
oint_C { [(z^4exp(2z)+1)/(z+i)^3] - [(z^3+z)/{(z-2i)(z-5)}] + 8*Pi*exp } dz,
Where C is the circumference |z-1| = sqrt(11/2), positively oriented.
Someone can help me, I already researched but I can not integrate.
I know that is easy for you but i am new in this topics.I want to write a code to generate a matrix which have entries consist of matrices(it has differnt dimensions)
L := sum( 1/ln(k), k=2..n ) * ln(n)/n;
limit(L, n=infinity);
# Should be 1
Just curious: in Maple 2017, is it OK?
First at all, congratulation for the new update Maple 2017!!.                                        I'm a personal developer about renewable energy hybrid systems models. It is possible get data about irradiance or wind speed from the new world maps?. It will be very interesting!!!        Thanks!!!!
Hi, i don't know what happened but every time that I run the simulation appears this:
invalid input: Multibody:-GetMultibodyData expects its 4th argument, lsProbes, to be of type list(list), but received registerMultibodyVariable
If anyone can solve this problem, I am going to be very grateful. Thanks
Main
I want to perform curvefitting on my data but Maple is not importing the data from the Excel file. Below is the command I used.
restart: with(ExcelTools): Q := Import("Curvefitting", "QReport", "C4:M6");
Error, (in ExcelTools:-Import) Could not open the file.
Q := Import("Curvefitting.xlsx", "QReport", "C4:M6");
What is the Phi function.  And more importantly how do I find out in general waht a symbol represents.  I input Phi in help menu, nothing useful comes up.  I use Function advisor, don't see a Phi symbol or anything beginning with Phi.  Isn't there a way I can select the symbol in the output and get help on it by pressing a F key?
Ok so I try FunctionAdvisor(describe Phi) - it gives me general Lerch Phi function.  But when I go to help page on LerchPhi, nowhere does it use Greek letter Phi to describe the function.  So I finally figured it out as I was composing this question.  But in why does the help page not use the symbol for the function that is displayed in the worksheet?
I can't figure how to use the showsource() command. There are no examples given.
kernelopts(version);
Maple 2017.0, X86 64 WINDOWS, May 17 2017, Build ID 1231047
If I use it on a local proc() it gives an error. Since it needs a file name
f := proc(x) if x <= 2 then print(x); print(x^2) end if; print(-x); x^3 end proc:
showsource(f);
Error, (in fopen) file or directory does not exist
From help:
The showsource command is similar to showstat, but displays the original
source code corresponding to the requested statements, if that source
code is available and, in the case of procedures retrieved from
libraries, kernelopts(keepdebuginfo) is true. If source code is
not available, showsource raises a warning and then produces
the same output as showstat.
But there is not one single example of how to use this command. I tried it on a local file (.mpl) in the same folder, but it complained.
currentdirName :="C:\\bla\\bla";
currentdir(currentdirName);
showsource("maple_proc.mpl");
Error, invalid input: showsource expects its 1st argument, p,
to be of type {`::`, name}, but received maple_proc.mpl
If I try
showsource(int);
Warning, no source information available; using showstat instead
Just looking for an example on how to use this command. (why help does not show an example?)
I am getting the following error while calculating function containing diffrential. Thankz in advance
KK := proc (x) options operator, arrow; diff(diff(x^2, x)) end proc;
KK(2)
Error, (in KK) invalid input: diff received 2, which is not valid for its 2nd argument
Download FUNCTION_(1).mw
I want to solve the system of differential equations
sys :=
  diff(x(t,s),t) = y(t,s),
  diff(y(t,s),t) + x(t,s) = 0;
subject to the initial condition
ic := x(0,s) = a(s),
      y(0,s) = b(s);
where a(s) and b(s) are given.
This looks like a system of PDEs but actually it is a system
of ODEs because there are no derivatives with respect to s.
It is easy to obtain the solution by hand:
x(t,s) = b(s)*sin(t) + a(s)*cos(t)
y(t,s) = b(s)*cos(t) - a(s)*sin(t)
I don't know how to get this in Maple, either through dsolve()
or pdsolve().
Actually both dsolve({sys}) and pdsolve({sys}) do return
the correct general solution, however dsolve({sys, ic})
or pdsolve({sys, ic}) produce no output.  Is there a trick
to make the latter work?
Dear sir,
in the program boundary conditions D(f)(0)=0 doesn't showing result but when use d(f)(0)=1 it will execute, why is this can you explain this ?program.mw
First 980 981 982 983 984 985 986 Last Page 982 of 2434
