I have the following function which came from a collaborator of a collaborator. It computes a generating function for a family of function's we're using.
GF_Generate := proc (n)
	local summand, i, j;
	summand := U[0]^x[0]*mul(U[i]^y[i], i = 1 .. n)*mul(binomial(x[0]+add(w[j], j = 1 .. i), y[i])*p^y[i]*(1-p)^(x[0]+add(w[j], j = 1 .. i)-y[i])*binomial(x[0]-1+add(w[j], j = 1 .. i), x[0]-1+add(w[j], j = 1 .. i-1))*v[i]^(x[0]+add(w[j], j = 1 .. i-1))*(1-v[i])^w[i], i = 1 .. n);
	for j from n by -1 to 1 do summand := normal(sum(summand, y[j] = 0 .. infinity)) end do;
	for j from n by -1 to 1 do summand := normal(sum(summand, w[j] = 0 .. infinity)) end do;
	sum(summand, x[0] = 0 .. infinity)
For arguments of 2 and 3 it's quick and works fine on Maple18 (tested both GUI and terminal client on OS X), Maple2015 (tested terminal client only on RHEL linux), but generates a "too many levlels of recursion" error in Maple2016 (tested terminal client only on RHEL linux; same server as Maple2015 was tested). It's slow for arguments of 4 and above (45 minutes for n=4 on my mac laptop), so I haven't tested it thoroughly with larger arguments.
Any idea why this code fails in Maple 2016?
Hi Guys,
I will like to know how I can use Maple to plot a line of best fit given some data.
e.g for data like [x = 21.2, 24.7, 20.8, 20.8, 20.3] and [y = 16.6, 19.7,16.4,16.8,16.9].
I want to write a procedure ThirdDer := proc(f,x0,h) which, given the funcion f, the point x0 and the step size h returns the value of f'''(x0). where f'''(x0) = (f(x0 +2h)−2f(x0 +h)+2f(x0 −h)−f(x0 −2h))/2h^3
help
I tried splitting f''' up and assigning the 4 different parts as a letter then putting it all together but that didnt work..
Morning all,
I repeatedly solve (command solve) a collection of systems of inequalies. Some of them can have no solution, but I am able to check if a solution has been found or not, and then take some decision about the system in question.
I have placed a few print commands at different critical locations within the loop where those systems are constructed and possibly solved.
Every time solve fails finding a solution it returns me a "no solution found" warning.
In order to keep my printings readable, could it be possible to avoid those warnings ?
Is there some "try & catch" like mechanism to manage warnings ?
Thank you all in advance
I can't understand how to install this package "SADE" in Maple 17. Secondly, I am new to Maple. So Please guide me the process to install this package and how to use it. Thanks!
I'm trying plot  with implicitplot a expresion which involve Lambert W, but the result is very confuse, is it normal? Could i improve the result?, how?. Thank!
I've encountered a very strange issue with Maple.
The result returns differently with solve and fsolve after/before a variable is given a certain value. See attachment.
The result comes from solve (with variable epsilon) returns value of the same variable with imaginary part while the fsolve returns the correct answer.
Now how can I achieve the same result as fsolve via solve?
Maple_Question_Solve_Fsolve.mw
Maple_Question_Solve_Fsolve.pdf  (exported PDF from Maple)
Hi everyone,
I'm to simplify the expression cos(x)/sin(x) to cot(x). None of the "simplify" commands seem to work, I've tried assigning the expression to a name "a", then using the "simplify(a,trig)" command and it doesn't work either.
Anyone have any ideas on how I can tell maple to simplify this?
I've got some points:
I have to find the (equation of) line which has minimum distance from these points but the distance formula that I have to use is:
 (-m*x[i]-q+y[i])^2
I think we should settle with a for loop.
Hey guyz, I am in trouble with calculation attached integral. it is a simple function but a bit long. I can't solve it with maple, Do U have any idea?
intg.mw
hello, i just try to plot the relation between my outputs (u, and phat) with i from 0 to 10 , but i have aproblem any suggestions?
M := .4556;
.4556
K := 18;
18
c := .2865;
.2865
Nabla(t) := .1NULL
.1
Khat := 206.1055;
206.1055
N := 10NULL
10
a__1 := 4/.1^2*.4556+2/(.1)*.2865NULL
187.9700000
a__2 := 4/(.1)*.4556+.2865NULL
18.51050000
a__3 := .4556NULL
.4556
NULLNULL
fu := Array(0 .. 10):
p:=Array(0..10):
  p[0]:=0:
  for i from 0 to 4 do
      p[i+1]:=50*sin(3.14*(i+1)*(4)/0.6):
      phat[i+1]:= p[i+1]+((7)*u[i])+((8)*u__dot[i])+((9)*u__doubledot[i]):
      u[i+1]:= phat[i+1]/(5):
      u__dot[i+1]:=(20*(u[i+1]-u[i]))-u__dot[i]:
      u__doubledot[i+1]:= ((400*(u[i+1]-u[i]))-(40*u__dot[i])-(u__doubledot[i])):
for i from 5 to 9 do
      p[i+1]:=0.0:
24.98850513
24.98850513
.1212413309
2.424826618
48.49653236
43.28799198
133.0574982
.6455795610
8.061937982
64.24569494
49.99998414
349.8504158
1.697433673
12.97514426
34.01843056
43.32779001
618.0696023
2.998802081
13.05222390
-32.47683816
25.05744793
815.5490181
3.956949320
6.11072088
-106.3532218
0.
808.4457346
3.922485012
-6.80000704
-151.8613364
0.
542.2499525
2.630933927
-19.03101466
-92.7588160
0.
100.0021368
.4851987783
-23.88368831
-4.2946573
0.
-352.8528440
-1.712001106
-20.06030938
80.7622360
0.
-656.3359300
-3.184465868
-9.38898586
132.6642346
fd_table:=eval(seq[u(i),phat(i)],i=0..N);
seq[(table( [( 0 ) = 0, ( 1 ) = .1212413309, ( 2 ) = .6455795610, ( 3 ) = 1.697433673, ( 4 ) = 2.998802081, ( 5 ) = 3.956949320, ( 6 ) = 3.922485012, ( 7 ) = 2.630933927, ( 9 ) = -1.712001106, ( 8 ) = .4851987783, ( 10 ) = -3.184465868 ] ))('i'), (table( [( 1 ) = 24.98850513, ( 2 ) = 133.0574982, ( 3 ) = 349.8504158, ( 4 ) = 618.0696023, ( 5 ) = 815.5490181, ( 6 ) = 808.4457346, ( 7 ) = 542.2499525, ( 9 ) = -352.8528440, ( 8 ) = 100.0021368, ( 10 ) = -656.3359300 ] ))('i')]
plot([u(i+1), p(i+1)])
Error, (in plot) invalid input: assigned expects its 1st argument, n, to be of type assignable, but received table( [( 0 ) = 0, ( 1 ) = .1212413309, ( 2 ) = .6455795610, ( 3 ) = 1.697433673, ( 4 ) = 2.998802081, ( 5 ) = 3.956949320, ( 6 ) = 3.922485012, ( 7 ) = 2.630933927, ( 9 ) = -1.712001106, ( 8 ) = .4851987783, ( 10 ) = -3.184465868 ] )
Download hw_4_structural.mw
     I am having trouble trying to solve a system of differential equations. The modeling was made from the equilibrium equations of a pressure vessel. The set of equations is shown below:
     As you see it is a set of two second-order partial differential equations. So, we need four boundary conditions. This one is the first. It means that the left end of the pressure vessel is fixed.
This one is the second boundary condition. It means that the right end of the pressure vessel is free.
This one is the third boundary condition. It means that the inner surface of the pressure vessel is subject to an external load:
At last, we have the fourth boundary condition. It means that the outer surface of the pressure vessel is free.
     The first test I have been trying to do is the static case. In this case, the time terms (the right side of the two equations shown) is zero.
    The maple commands that I am using are the following:
restart; E := 200*10^9; nu := .33; G := E/(2*(1+nu)); RI := 0.254e-1; RO := 2*RI; p := proc (x) options operator, arrow; 50000000 end proc; sys := [E*(nu*(diff(v(x, r), x))/r+nu*(diff(diff(v(x, r), x), r))+(1-nu)*(diff(diff(u(x, r), x), x)))/(-2*nu^2-nu+1)+G*(diff(diff(u(x, r), r), r)+diff(diff(v(x, r), x), r)+(diff(u(x, r), r))/r+(diff(v(x, r), x))/r) = 0, E*((1-nu)*(diff(diff(v(x, r), r), r))+nu*(diff(diff(u(x, r), x), r))+(1-nu)*(diff(v(x, r), r))/r-(1-nu)*v(x, r)/r^2)/(-2*nu^2-nu+1)+G*(diff(diff(u(x, r), r), x)+diff(diff(v(x, r), x), x)) = 0]; BCs := {E*(nu*v(L, r)/r+nu*(D[2](v))(L, r)+(1-nu)*(D[1](u))(L, r))/(-2*nu^2-nu+1) = 0, E*(nu*v(x, RI)/RI+(1-nu)*(D[2](v))(x, RI)+nu*(D[1](u))(x, RI))/(-2*nu^2-nu+1) = -p(x), E*(nu*v(x, RO)/RO+(1-nu)*(D[2](v))(x, RO)+nu*(D[1](u))(x, RO))/(-2*nu^2-nu+1) = 0, u(0, r) = 0}
sol := pdsolve(sys, BCs, numeric)
I am getting the following error:
Error, (in pdsolve/numeric/process_IBCs) initial/boundary conditions must depend upon exactly one of the independent variables: 0.1459531181e12*v(L, r)/r+0.1459531181e12*(D[2](v))(L, r)+0.2963290579e12*(D[1](u))(L, r) = 0
In this case, my boundary conditions do depend on more than one independent variable. How do I proceed?
Thank you in advance,
Pedro Guaraldi
Is there anyone who has seen maple 2017 provide some details about what new features are being introduced. Is there a platform where we can suggest what features we would like to be added or enhanced?
I'm trying to define some multilinear forms to study differential geometry. What I need is only symbolic. My intention is symplify computations involving multilinear forms.
For example, to create an symbolic inner product "g" I used the command "define" like in this post:
http://www.mapleprimes.com/questions/203480-Define-And-Use-Abstract-Linear-Operator
So I tipped:
define(g, orderless, multilinear);
My doubt is: how can I declare that g(x,y) is always scalar?
With it I would simplify things like g(g(z,w)*x,y) = g(z,w)*g(x,y)
In my case, specifically, I type:
v:=(X,Y,Z)->g(Y,Z)*X-g(X,Z)*Y;
r:=(X,Y,Z,W)->g(v(X,Y,Z),W)-g(Y,T)*g(v(X,T,Z),W)+g(X,T)*g(v(Y,T,Z),W);
expand(r(X,Y,Z,W));
and the result is:
g(W,g(Y,Z)*X)-g(W,g(X,Z)*Y)-g(T,Y)*g(W,g(T,Z)*X)+g(T,Y)*g(W,g(X,Z)*T)+g(T,X)*g(W,g(T,Z)*Y)-g(T,X)*g(W,g(Y,Z)*T)
But I would enjoy that it were:
g(Y,Z)*g(W,X)-g(X,Z)*g(W,Y)-g(T,Z)*g(T,Y)*g(W,X)+g(X,Z)*g(T,Y)*g(W,T)+g(T,Z)*g(T,X)*g(W,Y)-g(Y,Z)*g(T,X)*g(W,T)
Is there a way to declare that g(x,y) is always scalar?
First 1041 1042 1043 1044 1045 1046 1047 Last Page 1043 of 2470
