I have a procedure, and I want to use it so many times whthin my equations, because all notation in my equations are in indicial format, it will be so nice if I can call the procedure in indicial form rather than paranthesis form.
Is there anyone knows how is it possible in Maple?
Rr is my procedure that accepts 2 inputs, So there is no problem to call it using Rr(x,y), I am trying to call it with Rr[x,y] (indicial form
Is it possible to do so in Maple? It will be so great to do so.
Dear Maple experts,
I am struggling with a difference between the symbolic and numerical solution of an eigendecomposition of a symmetric positive definite matrix. Numerically the solution seems correct, but the symbolic solution puzzles me. In the symbolic solution the reconstructed matrix is different from the original matrix (although the difference between the original and the reconstructed matrix seems to be related to an unknown scalar multiplier.
with(LinearAlgebra);
Lambda := Matrix(5, 1, symbol = lambda);
Theta := Matrix(5, 5, shape = diagonal, symbol = theta);
#Ω is the matrix that will be diagonalized.
Omega := MatrixPower(Theta, -1/2) . Lambda . Lambda^%T . MatrixPower(Theta, -1/2);
#Ω is symmetric and in practice always positive definite, but I do not know how to specify the assumption of positivess definiteness in Maple
IsMatrixShape(Omega, symmetric);
# the matrix Omega is very simple and Maple finds a symbolic solution
E, V := Eigenvectors(Omega);
# this will not return the original matrix
simplify(V . DiagonalMatrix(E) . V^%T)
# check this numerically with the following values.
lambda[1, 1] := .9;lambda[2, 1] := .8;lambda[3, 1] := .7;lambda[4, 1] := .85;lambda[5, 1] := .7;
theta[1, 1] := .25;theta[2, 2] := .21;theta[3, 3] := .20;theta[4, 4] := .15;theta[5, 5] := .35;
The dotproduct is not always zero, although I thought that the eigenvectors should be orthogonal.
I know eigenvector solutions may be different because of scalar multiples, but here I am not able to understand the differences between the numerical and symbolic solution.
I probably missed something, but I spend the whole saturday trying to solve this problem, but I can not find it.
I attached both files.
Anyone? Thank in advance,
Harry
eigendecomposition_numeric.mw
eigendecomposition_symbolic.mw
Ho, I try series taylor of tanh, but I want that result is in function of tanh(sqrt(q)*z/y) and not exponential e.
f1 := taylor(tanh(sqrt(q)*z/y+x*m/y), m, 2)
f1 := ((exp(sqrt(q)*z/y))^2-1)/((exp(sqrt(q)*z/y))^2+1)+4*(exp(sqrt(q)*z/y))^2*x*m/(((exp(sqrt(q)*z/y))^2+1)^2*y)+O(m^2)
That is, it should look like:
tanh(sqrt(q)*z/y+.....+tanh^2(tanh(sqrt(q)*z/y)m
Regards.
Hello, I'd like to generate some data from an audio file, like get the amplitude and the time, so that I can plot it with x = time and y = amplitude, do you know how to do that ?
tf:=2:
n:=2:
X[1]:=t->t^2:
A[1]:=diff(X[1](t),t,t):
plot(A[1](t),t=0..tf,labels=["Time t","n times derivative of X[1](t)"]);
I have a code like above. I run it. Then,
in the labels; it was written "n times derivative of X[1](t)"] why not "2 times derivative of X[1](t)"]) ? and why was not the subscript appeared ? I mean that I want to see X1 instead of  X[1]?
Help me please.
Hi Maple Community,
I just got my Maple licence and currently I'm going thorugh some basic tutorials in which I've encountered a problem I can't seem to fix:
I'm trying to use the 'LinearSolve' solver as it is shown in the examples on the Maplesoft.com support page:
But I can't seem to get Maple to display a result like it is shown in the picture above.
Instead Maple displays this:
I would be very grateful if someone could tell me what I'm doing wrong.
regards, Alex
Hi, I´m try take out common factor with "collect"
collect(-(1/4)*G*r^2/eta-(1/4)*G*(ri^2-ro^2)*ln(r)/(eta*(ln(ri)-ln(ro)))-(1/4)*G*(ln(ri)*ro^2-ri^2*ln(ro))/(eta*(ln(ri)-ln(ro))), -(1/4)*G/eta)
  But this does not work well.
Regards.
I want to use the solutuion of a DE as a function, including the possibility to plot it.
I have found out that the following comands work, but I cannot undesrtand why. Is there a simpler way?
Truly, Roberto R. Baldino
sol := dsolve({eq, icon}, i(t));
i := unapply(eval(i(t), sol), t);
plot(i(t), t = 0 .. 20, view = [-1 .. 20, -3 .. 3], gridlines);
If not define a procedure
just pass day(hello(a,b), c)
as parameter how to get hello , this function name and day this function name
Hello everybody,
i'm searching for a data-structure similar to the C++ std::unordered_map, so that the access time is konstant O(1) and no matter about the order. What access time does a table() in Maple have, it seems to be not O(1).
If algebra use factorise method,
Which method do maple use to dsolve differential equation?
I am trying to perform the following integral:
Which spits the integral back out at me.
I've also tried
Which, again, spits the integral back out at me.
My last attempt was this
Which... Still spit back out the integral.
Is there something special I should be doing for functions I'm integrating with a natural log? I need to get an exact value for this, not an approximation (because I am trying to check the accuracy of an approximation with this!).
How call each column of matrix by loop?
Hello there, my first time posting in this forum and using Maple, so sorry if I make some mistakes.
I'm trying to read a wav audio file, but there's this weird error that I can't understand :
with(AudioTools);
[Audio, Clip, Convolution, Create, Duration, Extract, FormatFromName, Formats, Modulate, Normalize, Play, Preview, Read, Record, Resample, Scale, ToMono, ToStereo, Write]
audio := Read("C:\\Users\\Simon\\Desktop\\Test\\440.wav");
Error, (in readbytes) WAVE Error: unexpected end of file
Do you know what it can mean ? I'm sure it's a wave file, so I don't really get it
hi,
i'am beginers in  the maple programmation, i want to solve the einstien equation in the spherical coordinate,
First 1045 1046 1047 1048 1049 1050 1051 Last Page 1047 of 2470
