For some strange reason my matrices are shown in a very bizarre format (see imgur link). All I want is to simply see the 6x6 matrix with the numerical values - any help would be greatly appreciated. http://imgur.com/a/qaQmb
    My profile picture was formerly animation and looked like this:
  It would be interesting to paint a triangle on a sphere. How can I do that?
> restart;
> with(plots); with(StringTools); with(plottools);
> INF := 999999999999999999999;
> NULL;
> MinoxAngle := 200; MikromaAngle := 350; MinicordAngle := 290; GamiAngle := 280; GamiFocal := 0.25e-1; SummitarDial := [1, 1.1, 1.2, 1.3, 1.4, 1.5, 1.6, 1.7, 2, 2.2, 3, 4, 5, 6, 7, 10, 20, INF]; Minox35MLDial := [3, 4, 6, 10, 20, INF]; Minox35Angle := 100; MinicordDial := [.35, .4, .5, .6, .7, .8, .9, 1, 1.2, 1.5, 2, 3, 4, 8, INF]; Mini := nops(MinicordDial); MikromaDial := [.5, .6, .7, .8, .9, 1, 1.2, 1.5, 2, 2.5, 3.5, 6, INF]; MinoxLXDial := [.2, .24, .3, .4, .6, 1, 2, 30]; MinoxLXAngle := 270; GamiDial := [.5, .6, .7, .8, 1, 1.2, 1.5, 2, 3, 5, 99990000000000]; MinoxBDial := [8*(1/12), 10*(1/12), 1, 1.5, 2, 3, 6, INF]; MinoxBAngle := 270;
                              200
                              350
                              290
                              280
                             0.025
  20, 999999999999999999999]
            [3, 4, 6, 10, 20, 999999999999999999999]
                              100
 [0.35, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9, 1, 1.2, 1.5, 2, 3, 4, 8,
                               15
    [0.5, 0.6, 0.7, 0.8, 0.9, 1, 1.2, 1.5, 2, 2.5, 3.5, 6,
              [0.2, 0.24, 0.3, 0.4, 0.6, 1, 2, 30]
                              270
   [0.5, 0.6, 0.7, 0.8, 1, 1.2, 1.5, 2, 3, 5, 99990000000000]
         [2  5                                        ]
         [-, -, 1, 1.5, 2, 3, 6, 999999999999999999999]
         [3  6                                        ]
                              270
> NULL;
> dd := GamiDial; N := nops(dd); dstx := [seq(convert(dd[i], string), i = 1 .. N)];
                               11
  [".5", ".6", ".7", ".8", "1", "1.2", "1.5", "2", "3", "5",
    "99990000000000"]
> NULL;
                              290
> NULL;
> LensDial := proc (LensName, focal, Angle, scale, dr) local p1, p2, p3, p8, pk, pt, rk, R, R2, R3, Rc, c1, ds2; R := 1600; R2 := 1400; R3 := 1200; Rc := 1500; CaptionTail1 := "EXTENSION ANGLE"; CaptionTail2 := "LENS FOCUSING DIAL"; Caption1 := Join([LensName, CaptionTail1]); Caption2 := Join([LensName, CaptionTail2]); q := 180/Pi; rotation := 90; dir := dr; ds := scale; N := nops(ds); dstx := [seq(convert(ds[i], string), i = 1 .. N)]; ds2 := subs(dstx[N] = infinity, dstx); MaxAngle := Angle; f := focal; degr := -(-ds[1]+f)*Angle/(D-f)+rotation; g1 := degr/q; for j to N do deg[j] := subs(D = ds[j], degr) end do; for i to N do rdn[i] := evalf(deg[i]/q); xv[i] := R2*cos(rdn[i]); yv[i] := R2*sin(rdn[i]); wx[i] := R3*cos(rdn[i]); wy[i] := R3*sin(rdn[i]) end do; pk := {seq([ds[i], deg[i]], i = 1 .. N)}; rk := {seq([dir*xv[i], yv[i]], i = 1 .. N)}; txt := {seq([dir*wx[i], wy[i], ds2[i]], i = 1 .. N)}; p3 := pointplot(rk, caption = Caption2, captionfont = ["ROMAN", bold, 22], symbol = solidcircle, symbolsize = 15, color = red, axes = none); c1 := circle([0, 0], Rc, thickness = 8); p8 := textplot(txt, 'font' = ["times", "bold", 14]); display(p3, c1, p8, scaling = constrained) end proc;
Warning, `CaptionTail1` is implicitly declared local to procedure `LensDial`
Warning, `CaptionTail2` is implicitly declared local to procedure `LensDial`
Warning, `Caption1` is implicitly declared local to procedure `LensDial`
Warning, `Caption2` is implicitly declared local to procedure `LensDial`
Warning, `q` is implicitly declared local to procedure `LensDial`
Warning, `rotation` is implicitly declared local to procedure `LensDial`
Warning, `dir` is implicitly declared local to procedure `LensDial`
Warning, `ds` is implicitly declared local to procedure `LensDial`
Warning, `N` is implicitly declared local to procedure `LensDial`
Warning, `dstx` is implicitly declared local to procedure `LensDial`
Warning, `MaxAngle` is implicitly declared local to procedure `LensDial`
Warning, `f` is implicitly declared local to procedure `LensDial`
Warning, `degr` is implicitly declared local to procedure `LensDial`
Warning, `g1` is implicitly declared local to procedure `LensDial`
Warning, `j` is implicitly declared local to procedure `LensDial`
Warning, `deg` is implicitly declared local to procedure `LensDial`
Warning, `i` is implicitly declared local to procedure `LensDial`
Warning, `rdn` is implicitly declared local to procedure `LensDial`
Warning, `xv` is implicitly declared local to procedure `LensDial`
Warning, `yv` is implicitly declared local to procedure `LensDial`
Warning, `wx` is implicitly declared local to procedure `LensDial`
Warning, `wy` is implicitly declared local to procedure `LensDial`
Warning, `txt` is implicitly declared local to procedure `LensDial`
> NULL;
> LensDial("MEOPTA MICROMA  HELGOR 25mm", 0.25e-1, 350, MikromaDial, 1);
> LensDial("GOERZ MINICORD  25mm", 0.25e-1, 335, MinicordDial, 1);
> LensDial("MINOX LX MINOX 15mm", 0.15e-1, 270, MinoxLXDial, 1);
> LensDial("GAMI ESAMITAR 25mm", 0.25e-1, 290, GamiDial, 1);
infinity symbol looks like an  "8" lying down.
How to use Maple to plot  the  infinity( lay flat  "8") symbol at 12 o'clock position of a circle
I'm creating a randomly generated question bank that generates the following STYLE or problem:
12x-4y2
3x6y-5
I'm currently trying to use the answer type "formula without simplification," as I'd like to avoid the students putting the questions in as the answer, and this has been driving me crazy for hours now.
I have tried the "maple" function to simplify. E.g.:
$ANS = maple("( $C1*( $V1^$A1 )*( $V2^$B1 ) ) / ( $C2*( $V1^$A2 )*( $V2^$B2 ) )");
But it always throws an error.
I have simply done the math in the algorithm section, so you end up with an answer variable like this:
$ANS = -4.0*(((z)^2.0)/(5.0*((p)^9.0)))
However, it will still count all answers submitted as incorrect.
Any help would be GREATLY appreciated =/.
Variable name clarification
I have $C1 and $C2, which are the constants of the numerator and denominator, respectively ("12" and "3" in the example).
I have $V1 and $V2 which are the first and second variable, respectively, (in the example, "x" and "y").
I have $A1 and $A2, which are the exponents for the variable $V1 in the numerator and denominator, respectively.
I have $B1 and $B2, which are the exponents for the variable $V2 in the numerator and denominator, respectively.
All these generate from some interesting conditions to create the problems I want (no variables named i, e, or o, for example,) but all properly initialize.
 Hi, I got an error (the code below) when using subsop in procedure. But when I replace "NULL" with an integer, it would work.
> phephoi := proc (A, B)
local check, i, j, C, E;
C := A;
E := B;
for i from 1 to nops(C) do
   check := 0;
   for j from 1 to nops(E) do
      if E[j] = C[i] then check := 1; break; end if;
   if check = 0 then C := subsop(i = NULL, eval(C)); end if;
return C;
> A := [1, 2, 3, 5, 6, 7];
B := [2, 4, 7, 11, 8];
phephoi(A, B);
                             [1, 2, 3, 5, 6, 7]
                              [2, 4, 7, 11, 8]
Error, (in phephoi) invalid subscript selector
How to put number 1,2,3...12  around a circle, like a clock face using Maple code ?
Right now I can only do this manually by plotting a circle, then save the file and use Windos paint to
mannual put in the numbers
Hi all
I would like to plot a quadrilaterial (  spherical quadrilaterial)  on the sphere ( the vertices are known)
How can I do this
Many thanks
I have not been using Maple for the last couple of years because I have Maple installed on my big and heavy laptop. Such laptop forces me to sit at a desk when I work which I dont like. This has resulted in that I have only (for the most part) used my ipad for the last couple of years hence dropping my laptop and Maple. The problem with such approach has been that is more difficult to write scientific papers because you cant run a full version of word on the ipad hence you cant use a citation manager. There does not exist an app on the ipad that offer one. This leads to a lot of extra work!
I have therefore now bought a Microsoft Surface Pro 4 which is a tablet (like the ipad) but its a not a "toy" tablet like the ipad or android tablets because it has Windows 10 Pro (64-bit) which means that you can run full versions of pc software like word 2016 and Maple. The version of Surface Pro 4 I bought has an Intel Core m3-6Y30 processor with 2 cores, 4GB RAM, 128 GB of storage, no fan and a processor base frequency of 0.9 GHz. The m3-6Y30 processor has something called dynamic frequency scaling which means (as I understand it) that the processor can go up to 2.2 GHz when it is under heavy load. Since Maple recommend that you have a system with a cpu with at least 1 GHz to run Maple 2016 I am not anticipating any problems here.
http://www.maplesoft.com/products/system_requirements.aspx
However, I am not completly sure if maplesoft means that the base frequency needs to be 1 Ghz or not? Since my tablet has not been delivered yet I cant comment on how Maple runs on it but as I said I am not anticipating any problems.
Now to my question: When will Maple 2017 come out? Since it is already 2017 I dont want to buy an old version of Maple now that I want to update my Maple software.
I want to do matrix operation,vis-a-vis,addition,inverse of a 15 x 15 matrix. I already typed the matrix,but remains the operation.
Raji
I have never seen DEtools:-odeadvisor hang before. I've seen dsolve itself hang many times, but not odeadvisor. Is this a bug? Maple 2016.1 on windows.
eq:=(2*y(x)*diff(diff(y(x),x),x)-diff(y(x),x)^2)^3+32*diff(diff(y(x),x),x)*(x*diff(diff(y(x),x),x)-diff(y(x),x))^3 = 0;
DEtools:-odeadvisor(eq);
Now it hangs. Waited for more than one hr. This is an ODE from a book. Do others see the hang as well?
I can't find in the Linear Algebra package the command for creating the duplication matrix.
The duplication matrix is the n * n rows and n * ( n + 1 ) / 2 columns that transforms vech(A)
to vec(A) where A is a symmetric n by n matrix (Magnus & Neudecker).
If it not yet in Maple itself, has someone already made a proc for it?
Harry Garst
I want  to find the parametrs that verify the below inequalities at the same time:
beta*(v+u)>phi*(alpha+lamda+u+delta)
phi>beta
beta> (alpha+lamda+u+delta)
phi* (alpha+lamda+u+delta)>beta*(u+v+alpha),
question : find the values of u,v,delta,lamda,phi,beta,alpha such as all these parameters are in the intervall ]0,1]
can anyone help me ?
I have a second order, linear, non-homogeneous differential equation and for the solution Maple takes the particular solution under a indefinite integral form. After I substitute the values of the coefficients I want Maple to perform the integration. The integration is possible because I individually integrated one small part of the expression. The full expression has a lenghty sumation of different indefinite integrals so it would be cumbersome to perform each integration by hand.
Can somebody help me force Maple to perform these integrations?
I already tried eval, evalf, simplfy and it doesn't work.
Thanks a lot.
I have two vectors of angle Theta and Phi  given by
Theta=[ 0, Pi/3, 2*Pi/3, Pi];
Phi=[ 0, Pi/3 , 2*Pi/3 , Pi,4*Pi/3, 5*Pi/3, 2*Pi, 7*Pi/3];
I would like a general procedure how can I put on the unit sphere only the point
x=cos(Phi).*sin(Theta);
 y=sin(Theta).*sin(Phi);
 z=cos(Theta);
where
(Theta, Phi) in the set {(0,Pi/3),  (0,Pi),  , (0,5*Pi/3),
(Pi/3,0),   (Pi/3,2*Pi/3),   (Pi/3,4*Pi/3),   (Pi/3,2*Pi),
(2*Pi/3,Pi/3),   (2*Pi/3,Pi),   (2*Pi/3,5*Pi/3),   (2*Pi/3,7*Pi/3),
(PI,2*Pi/3),   (Pi,4*Pi/3),   (Pi,2*Pi) }
can we extract these set of point fro the definition of the two vectors Phi and Theta and then make the plot
of course we use
Many thanks
First 1055 1056 1057 1058 1059 1060 1061 Last Page 1057 of 2460
