I can't find in the Linear Algebra package the command for creating the duplication matrix.
The duplication matrix is the n * n rows and n * ( n + 1 ) / 2 columns that transforms vech(A)
to vec(A) where A is a symmetric n by n matrix (Magnus & Neudecker).
If it not yet in Maple itself, has someone already made a proc for it?
Harry Garst
I want  to find the parametrs that verify the below inequalities at the same time:
beta*(v+u)>phi*(alpha+lamda+u+delta)
phi>beta
beta> (alpha+lamda+u+delta)
phi* (alpha+lamda+u+delta)>beta*(u+v+alpha),
question : find the values of u,v,delta,lamda,phi,beta,alpha such as all these parameters are in the intervall ]0,1]
can anyone help me ?
I have a second order, linear, non-homogeneous differential equation and for the solution Maple takes the particular solution under a indefinite integral form. After I substitute the values of the coefficients I want Maple to perform the integration. The integration is possible because I individually integrated one small part of the expression. The full expression has a lenghty sumation of different indefinite integrals so it would be cumbersome to perform each integration by hand.
Can somebody help me force Maple to perform these integrations?
I already tried eval, evalf, simplfy and it doesn't work.
Thanks a lot.
I have two vectors of angle Theta and Phi  given by
Theta=[ 0, Pi/3, 2*Pi/3, Pi];
Phi=[ 0, Pi/3 , 2*Pi/3 , Pi,4*Pi/3, 5*Pi/3, 2*Pi, 7*Pi/3];
I would like a general procedure how can I put on the unit sphere only the point
x=cos(Phi).*sin(Theta);
 y=sin(Theta).*sin(Phi);
 z=cos(Theta);
where
(Theta, Phi) in the set {(0,Pi/3),  (0,Pi),  , (0,5*Pi/3),
(Pi/3,0),   (Pi/3,2*Pi/3),   (Pi/3,4*Pi/3),   (Pi/3,2*Pi),
(2*Pi/3,Pi/3),   (2*Pi/3,Pi),   (2*Pi/3,5*Pi/3),   (2*Pi/3,7*Pi/3),
(PI,2*Pi/3),   (Pi,4*Pi/3),   (Pi,2*Pi) }
can we extract these set of point fro the definition of the two vectors Phi and Theta and then make the plot
of course we use
Many thanks
Can somebody suggest an efficient way to specify / input a large list of binary variables in the LPSolve command, for example:
> LPSolve(objective function, constraints, binaryvariables={ x[0,0,1], .x[0,0,2], ...., x[i,j,k]}
Is it possible to assign a name to the set rather than input each element, x[i,j,k], manually?
Thanks in advance!
The map[inplace] operation can apply a function to the elements of an rtable, replacing these elements with the result.  Using map[inplace,evalhf] can be numerically quite efficient but I would like something more general.  For example
x += x +~ v*~dt
where += in some other languages denotes an inplace addition operation and x and v are Vectors (rtable). Is there a way to do this in Maple?
If a:=[1,4,2,6,8]  create all combinations of numbers with this list below 50
I am writting a program that needs to rename variables by increasing the second index of a variable, all the variables will be named y[something,number].
e.g.
y[a,2]->y[a,3]
If I was doing this outside maple I can see how I could use regular expressions, but I can't see how to do it in maple
i got this code, but for any n = 2N (par) i get some high errors, my M goes nuts.  anyone knwos wheres my mistake?
With(CurveFitting); Digits; 5; f := proc (x) options operator, arrow; abs(x) end proc; n := 8; h := 2/n; for i from 0 to n do x[i] := h*i-1 end do; for i from 0 to n-1 do L[i] := (product((x-x[j])/(x[i]-x[j]), j = 0 .. i-1))*(product((x-x[k])/(x[i]-x[k]), k = i+1 .. n-1)) end do; lagr := sum(f(x[p])*L[p], p = 0 .. n-1); P := expand(lagr); plot({P, f(x)}, x = -1 .. 1, y = 0 .. 2); M := maximize(abs(abs(x)-P), x = -1 .. 1); M1 := numapprox:-infnorm(abs(abs(x)-P),
x = -1 .. 1)
I didn't even know the erf function existed until doing this problem. I looked up how to use it, so I tried plugging in the explicity form into Maple, hoping it'd solve it, but it just spit back out the erf function.
I am trying to get a number answer.  A decimal. Because this is calculating a probability. How do I get Maple to give me a number here? Thanks!
so i  got this code:
But it cannot Find a value for M (wich would be the maximum distance between) it literaly stays working for severeal minutes and necer gives an answer, also i cant find a function to do this for every value for n (n-1 steps from a to b), also would mean that xy would need to get more points, any idea of how can i solve this for any n? or at least fix the problem with M, and i do the steps from a to b Manually.
heeeelp me please this is driving me nuts
thanks a lot :)
hi
why this equation does not any answer?
s-s.mw
eq:={-J*g[1]*(diff(w(x), x, x, x, x, x, x))+J*c[1]*(diff(w(x), x, x, x, x))+A*g[113113]*(diff(w(x), x, x, x, x))+(beta[11]*A*0)*`ΔT`*(diff(w(x), x, x))+2*b*f[1133]*(Pi/L)^2*(d[33]*lambda[3]*`ΔT`*L/mu[33]-2*f[1133]*a*Pi/L-P[3]*`ΔT`*L)*sin(Pi*x/L)*sinh(h*Pi/(2*L))/(2*cosh(h*Pi/(2*L))*(-a33+d[33]^2/mu[33])) = 0, w(0) = 0, w(L) = 0, (D(w))(0) = 0, (D(w))(L) = 0, ((D@@3)(w))(0) = 0, ((D@@3)(w))(L) = 0}
{-J*g[1]*(diff(diff(diff(diff(diff(diff(w(x), x), x), x), x), x), x))+J*c[1]*(diff(diff(diff(diff(w(x), x), x), x), x))+A*g[113113]*(diff(diff(diff(diff(w(x), x), x), x), x))+b*f[1133]*Pi^2*(d[33]*lambda[3]*`ΔT`*L/mu[33]-2*f[1133]*a*Pi/L-P[3]*`ΔT`*L)*sin(Pi*x/L)*sinh((1/2)*h*Pi/L)/(L^2*cosh((1/2)*h*Pi/L)*(-a33+d[33]^2/mu[33])) = 0, w(0) = 0, w(L) = 0, (D(w))(0) = 0, (D(w))(L) = 0, ((D@@3)(w))(0) = 0, ((D@@3)(w))(L) = 0}
dsolve(eq, w(x))
Download s-s.mw
I'm trying to solve a Quantum Mechanics problem that requires me to normalize a wavefunction before I proceed. I have the book solutions to these problems (I'm just trying to practice solving using Maple) so I know what the answers are SUPPOSED to be. But I'm not getting the answers I expected when dumping it into Maple.
What I put into Maple:
What I was SUPPOSED to get:
I assume this is a radical simplication I need to make. But in highlighting the expression, right clicking, and trying the different simplification options, nothing worked.
http://www.maplesoft.com/applications/view.aspx?SID=4229
from book example, it seems assumed that input size of data such as list size or matrix size is the same as
trained data set size, but this need to hard code infinite number of types of size
What is the method to programming neural network when input size is smaller or changing and not equal to size of trained data set?
I have a list of equations. I would like to display this list in column.
Problem : as each term of my list is an equation, i can not transform my list in a vector.
How can I do to display a list of equations in column ?
Thank you for your help.
First 1059 1060 1061 1062 1063 1064 1065 Last Page 1061 of 2463
