How to get tangent angle between two curves?
example for these : f(x)=((x^4+5)^(1/2))/(sinx+5) and g(x)=cosx^2   ; x>0
I am trying to simplify noncommutative expressions that use the 'dot' operator: `.`. The following is a minimal example:
a2 . (1/(a2 . (1/a1) . a2)) . a2, which evaluates to:   a2 . (1/(a2 . (1/a1) . a2)) . a2
This should simplify to 'a1', as I am expecting `.` to work like noncommutative multiplication. If there is any way to define this behavior I would appreciate some help. Alternatively, I would also be happy with reworking 'simplify' to work in this scenario. If it helps, I am working with finitely presented groups. If you see the Maple package 'GroupTheory', you'll see that the 'Group' function has this built in. If we input generators and relators it will simplify expressions of the above type, so I know it can be done!
Lastly, I would prefer displaying '1/a1' as 'a1^-1', but that is just for aesthetics.
Here is a minimal document: minimalexample.mw
I'm trying to solve a system of 9 ODE in a model of a chemical reactor. But, unfortunately, when I try to plot the curves, I get the following error message: Error, (in f) unable to store '[Float(undefined)]+8.5809018712796' when datatype=float[8]
Can anyone help me please? I read some related problems here, but couldnt find a solution yet.
Thanks for your time
Best regards
I have a optimization question in the following picture.
Question: find matrix T(t).
I writed a maple code. Could you view it ? You think that it is right?
The code file I writed: maple_code_of_theory.mw
 It is really very important for me. Can you help me?
This is not a new problem; it is a reoccuring nuisance. When doing a heavy calculation, pressing the 'Interrupt the current operation'-icon will sometimes not halt the execution; rather it continues happily, seemingly without ever stopping. The program does not seem to have stalled, because the executing-bullet at the lower left of the screen flashes back and forth. As the interrupt icon is no longer red, there is no idea in pressing that further. So in these cases, I usually have to resort to an ungraceful shut-down of Maple by way of the Windows job list (Ctrl+Alt+Delete). Is there really no other way?
Hello, How to do simple analyse on function? like find intervas where function negative and positive, monotone, critical points...
And also how to plot them on one graph?
I have this H(alpha,beta,eta) con ‡uent hypergeometric function, which I can easily adopt in Mathematica like this
Hypergeometric1F1[( (\[Alpha] + S \[Beta]))/\[Beta]^2,
 1 + ((\[Alpha] + S \[Beta]))/\[Beta]^2, -\[Alpha] ((
   E^(-\[Beta] \[Eta]))   )/\[Beta]^2]
But when I try to input this in maple using the built-in `hypergeom` it gives an error.
hypergeom((S*lambda2+alpha)/lambda2^2, 1+(S*lambda2+alpha)/lambda2^2, -alpha*exp(-lambda2*eta)/lambda2^2)
Any suggestions?
,Hello everyone
...I need code for save maple's project like a video
Thankyou
I'm trying to solve this integral, but maple does not show any result.
f := GAMMA(phi)*y^(mu*phi-1)*(1-y)^((1-mu)*phi-1)/(GAMMA(mu*phi)*GAMMA((1-mu)*phi))
int(log(1-y)*f, y = 0 .. 1) assuming phi >0 and 0<mu<1
What is the problem? Is there any way to solve this integral?
Hello! with the datapoints below I've calulated the results "manually"
I'm looking for a way to make Maple tell me the intersection of these datapoints with the x-axis and also, the area under it from e.g. 0 to 5.125, which i've also had to calculate by hand... I know I can use int comand to do this, but I think there is a lot wrong with the syntax, so after hours of failure I hope someone can show me the right commands..
krismalo
t1 := Matrix(14, 2, {(1, 1) = 0, (1, 2) = 0, (2, 1) = 0, (2, 2) = 4170, (3, 1) = 1, (3, 2) = 3966, (4, 1) = 1, (4, 2) = 3466, (5, 1) = 3, (5, 2) = 3058, (6, 1) = 3, (6, 2) = 3058, (7, 1) = 4, (7, 2) = 1854, (8, 1) = 4, (8, 2) = 1354, (9, 1) = 7, (9, 2) = -2258, (10, 1) = 7, (10, 2) = -2758, (11, 1) = 8, (11, 2) = -3962, (12, 1) = 8, (12, 2) = -3962, (13, 1) = 10, (13, 2) = -4370, (14, 1) = 10, (14, 2) = 0})plot(t1); =
The intersection of this plot with the x-axis should be ≈ 5.125 and the area from 0 to 5.125 (or from 5.125 to 10) should be ≈ 13810
Download primes_area_question.mw
i have solved the coupled equations .... and want to subtract a constant
i want to subtract constant from the result of last equation
r_p_m.mw
What is the best way for Maple to create datasets with attributes?
There must be a better way than just listlists  ie [[Honda, green, 2008],[Honda, red,civic,2004],[Hoda, blue, CRV, 2WD]] etc....
It would be similar to the table of elements using get properties.
I have this equation that I can not get all solutions symbolically:
eq1 := cos(lambda*ln(r1))*cos(lambda*ln(r2))+sin(lambda*ln(r1))*sin(lambda*ln(r2))-1 = 0:
solve(eq1, lambda, allsolutions) assuming r1>0, r2>0, r2>r1
when r1:=1: r2:=2: I get the solution
2*Pi*Z/ln(2)
when r1:=1.1: and r2:=2.1: # no solutions
How to get symbolique solution
Hi.
This is probably not very much maple related question, but to some extend it is.
After failing this question on my exam I have tried to solve it, but it seems like I cant get it right.
Given a sphere z^2+r^2=4 and a cylinder r=1 I was told to set up the volume integral for the element T enclose byt the outer sphere and the inner circle.
I tried to generate a plot but my skills are rather poor in plotting, if I could get the plot right I would be able to set up the volume integral. I have also tried to figure out how to do the surface integral and chose to use a task template as it is a bit more convinient when you find the syntax hard.
I would say I am familiar with the VectorCalculus:-SurfaceInt in cartesian for when i have intersection of two surfaces given in terms of z=
but this kind of problem is new to me.
Surface Integration over a Surface Defined Parametrically
Formulate and evaluate the surface integral of f(x, y, z) over a surface defined parametrically.
Surface Integral on a Surface Defined Parametrically
  Integrand
"f(x,y,z)="
   " x(u,v)="
"y(u,v)="
   " z(u,v)="
`&equiv;`(F(u, v), f(x(u, v), y(u, v), z(u, v)))
`&equiv;`(LinearAlgebra[Norm](N), sqrt((`&PartialD;`(y, z)/`&PartialD;`(u, v))^2+(`&PartialD;`(z, x)/`&PartialD;`(u, v))^2+(`&PartialD;`(x, y)/`&PartialD;`(u, v))^2))
"&int;(&int;)[S]f &DifferentialD;sigma =(&int;)[u=a]^(u=b)(&int;)[v=g(u)]^(v=h(u))F(u,v)||N|| &DifferentialD;v &DifferentialD;u"
"b="
"&int;(&int;)[S]f &DifferentialD;sigma=""(&int;)[v=a]^(v=b)(&int;)[u=G(v)]^(u=H(v))F(u,v)||N|| &DifferentialD;u &DifferentialD;v"
"a="
NULLNULL
p1 := plot3d([2*cos(u)*sin(v), 2*sin(u)*sin(v), 2*cos(v)], u = 0 .. 2*Pi, v = 0 .. Pi, color = green, transparency = .55):
p2 := plot3d([cos(u), sin(u), z], u = 0 .. 2*Pi, z = -2 .. 2, color = red, filled = true):
display(p1, p2)
p3 := plots:-sphereplot(2, theta = 0 .. 2*Pi, phi = 0 .. Pi, color = green, transparency = .55):
p4 := plots:-cylinderplot(1, theta = 0 .. 2*Pi, z = -2 .. 2, color = red):
plots:-display(p1, p2)
Download surface_int.mw
Dears
Hope everything fine with you. I want to solve the attached problem by numarically and want to plot it but failed. Please see the attachement and correct it. I am waiting your positive respone.
System_of_ODEs.mw
With my best regards and sincerely.
Muhammad Usman
School of Mathematical Sciences
Peking University, Beijing, China
First 1066 1067 1068 1069 1070 1071 1072 Last Page 1068 of 2463
