I'm trying to approximate the solution of an IVP using Euler's method in the InitialValueProblem command and I keep getting this error (see attached worksheet). Can someone explain why? Thanks!
with(Student[NumericalAnalysis]):
InitialValueProblem((D(y))(t) = t*y(t)+1/y(t), y(0) = 3, t = 2, method = euler, numsteps = 5, output = solution)
Error, (in dsolve/numeric) array output cannot be obtained for problems containing global variables
Download ivp_error.mw
Hi all. I need to solve a large number of PDEs (partial differential equations) symbolically and simultaneously, to find the linearly independant answers for all of them, I use
ans := pdsolve({seq(PDE[i]=0,i=1..d)});
The PDEs are all linear first order and it is very easy to solve them one by one by hand, but in some cases I have 100 PDEs or more, so Maple is either very slow or doesn't work. For d=120, it was evaluating for hours without a result.
For example I have d=120 PDEs, and 200 variables. It works for d=30 of them (takes 13 minutes on my 16GB RAM  windows 7 computer). So if I do this:
ans1 := pdsolve({seq(PDE[i]=0,i=1..30)});
ans2 := pdsolve({seq(PDE[i]=0,i=31..60)});
ans3 := pdsolve({seq(PDE[i]=0,i=61..90)});
ans4 := pdsolve({seq(PDE[i]=0,i=91..120)});
Then how can I have only one vector of the linearly independent answers of all of them?
And in general, is Maple supposed to do this kind of calculations at all?
If yes, do you have any ideas on how to improve this procedure?
If not, do you know in which software or programming package I can solve a large number of PDEs symbolically?
Your help is much appreciated.
1.How can i solve 1000 simultaneous equations with 1000 unknoowns on maple?
2. how can apply thomas algorithm on maple?
I have noticed the second item in Description in
http://www.maplesoft.com/support/help/Maple/view.aspx?path=convert/binary
The item is:
“The binary number is returned as a base 10 number consisting of the digits 1 and 0 only.”
Does the existence of this item mean the following behavior will not be corrected ? ("10^(-6)" in the following should be "2^(-6)" .)
Hi, I am new in Maple. If I have an electric network as in the figure, I want to get the Transfer Function V2(s)/Vi(s) from this equation system:
Vi=R1.I1+V1
Vi=R2.I2+V2
I1-I2=C1.dV1/dt
I2=C2.dV2/dt
Which are the commands that I may write to get this?? Before hand, Thanks by your answers!
i don't know much about maple, i need to solve the following odes system... I study a little on the help page of maple about numeric[midrich] that takes bvp and deal singularity as well but dint know how to used in the following system
odes.mw
I use pdsolve to solve this system of equation but the graph I have is different from the author's graph. I think I'm missing out on something. Can anyone help me out with the solution using any Maple command and module.
PDE := {diff(phi(x, t), t) = (diff(phi(x, t), x, x))/S__c-K__r*phi(x, t)+S__r*(diff(theta(x, t), x, x)), diff(u(x, t), t) = diff(u(x, t), x, x)-M^2*(u(x, t)-m*w(x, t))/(m^2+1)-u(x, t)/`ϰ`-2*Omega^2*w(x, t)+Gr*theta(x, t)+Gm*phi(x, t), diff(w(x, t), t) = diff(w(x, t), x, x)+M^2*(m*u(x, t)-w(x, t))/(m^2+1)-w(x, t)/`ϰ`+2*Omega^2*u(x, t), diff(theta(x, t), t) = lambda*(diff(theta(x, t), x, x))/P__r}
With Inittial and boundary condition : {phi(0, t) = 1, phi(9, t) = 0, phi(x, 0) = 0, u(0, t) = t, u(9, t) = 0, u(x, 0) = 0, w(0, t) = 0, w(9, t) = 0, w(x, 0) = 0, theta(0, t) = 1, theta(9, t) = 0, theta(x, 0) = 0}
With the following parameter declared as:
I will appreciate the graph of the solution with time t:0.3, 0.5, 0.7 and 1.0.
When trying to perform the following:
p1 := proc (x, y) if x^2+y^2 <= 1 then x*y-y^2 else 0 end if end proc;
plot3d(p1, x = -1 .. 1, y = -1 .. 1);
Error, (in plot3d) expected ranges but received x = -1 .. 1 and y = -1 .. 1
I get this strange error message. To the best of my knowledge x and y ARE provided as ranges. What am I missing/not understanding?
If I omit the ranges in plot3d Maple returns a correct plot, but the default range (-10 .. 10) does not display sufficient details
This is what I'm trying to solve:
I literally just want it to plug in those values for n and spit out a value. This is easy enough for me to do by hand, but I obviously wanted to speed up the process by doing it with Maple. What's wrong here? I clicked the pink links and that didn't help.
I'm going back over QM homeworks to study for an exam. We're allowed to use Maple on our exam so I want to be sure I'm prepared for that part. I have the solution to a problem I'm working on, but I can't get Maple to simplify it how I want it.
Is that simplification something that Maple should be able to do or is it something I would need to know how to do because Maple isn't capable? (I assume it is.)
I am trying to solve several equations for some mechanics problem.
I made the following lines with variables: Az, Bz, Dz, Dx, Ma.
The equations are showed in the image below. I can use either Md equation or Mb to solve the problem, but using both is not allowed. I tried to solve the equations with the solve function, but cant find any answer though there should be?
Thank you in advance :)
I'd like to make a graph like the below. So I know that using the display command and putting graphs in matrix form produces something similar (display(<graph1|graph2|graph3>), however it doesn't allow me to export it as one graph. Any ideas?
I'm trying to get Maple to find integer number solutions using isolve.
For example, the equation eq:=2.5*x+5*y=15
isolve(eq)
Perhaps I need to specify a range?
Hello folks, i recently had really confusing times when i plotted the function (x^(5/3)-5*x^(2/3)) in maple 2016. I know how this graph looks like as i have it printed in my undergraduate textbook. But in maple i'm not getting function(above given) values plotted for negative numbers. When i evaluate the function for x=-1 i'm getting some complex numbers, when i'm supposed to have simply -6. Could anybody tell me what's going on?plot(x^(5/3)-5*x^(2/3))
First 1067 1068 1069 1070 1071 1072 1073 Last Page 1069 of 2463
