Just came across actually a couple of applications but seem to be missing the mapleHDLS.src library .  Does anyone have it?
required for these digital electronics applications in Maple8
http://www.maplesoft.com/applications/view.aspx?SID=1419&view=html&L=G
http://www.maplesoft.com/applications/view.aspx?SID=1417&view=html&L=F
I don't know if they were just lost or removed.  Google can't find it, so I think unless someone has a copy of it from way back I might be out of luck.
Does anyone happen to have it?
I am working to minimize an objective function concerning a facility location problem (p-median technique).
Can somebody explain how to formulate the constraint equation that involves  1 or 0?
For instance, the constraint x[i,j]  is an element of {0,1}; namely, x[i,j] = 1 if a point is assigned to a facility located at the point j; 0 otherwise.
I am attempting to minimize an objective function that is related to a p-median problem (facility location). Can somebody please tell me how to impose a constraint that comprises 0 or 1? For instance, I wish to assign the condition, x[i,j] = 0 or 1; in other words, x[i,j] = 1 if the point i is assigned to facilty located at point j; 0 otherwise.
Thanks in advance!
I'm trying to add a new element to an array to a position that doesn't exist (length+1). According to the Maple help sheet, automatic resizing should take care of this. Instead I'm getting the error 'Error, invalid left hand side in assignment'. I tried this in a new worksheet. This is the entire code
L:=Array():
L:=(1,2,3,4,5):
L:=(6):
L;
When I run this, it kicks that error and only returns 1,2,3,4,5
When I do this to a 2D array it seems to work which has confused me more!
Thanks for your help
I'm currently using Maple 17 and I'm trying to programatically export .eps 3D plots using the following code:
plotsetup(eps, plotoutput = `square_of_x`, plotoptions = `color=rgb , portrait, noborder, height=4in,width=4in, shrinkby=0.1`)
The problem that I'm facing is:
1- The z-axis label is outside of my figure (see uploaded figure). This happens even if I try to save the figure in .png and it seems that the 'shrinkby' option its not working properly;
Could you help me solving this?
I have a set P which is filled with 2D elements e.g.
P:={[1,1],[1,2],[1,3]...}
Later I'm wanting to add a new element e.g. {[1,10]}
At the moment I have
P union {[10, 10]}
If I were to print this I get what I want, but I want to update P.
When I try and do
 P:= P union {[10,10]}
I get an error "Error, illegal use of an object as a name"
What am I doing wrong and how can I solve this? Much appreciated!
I have upload the attachment here. in this problem I want to find the comparison. Please check it and please tell me the correction
Ask.mw
AB44.mwAdded these tasks by highlighting object and then choosing
Edit > Create Task
Is there some way to delete a task from my Tasks palette
At some point I created "My second palette" is there a way
to delete individual items from this palette and how are tasks
added to a customized palette.
Any help appreciated, Thanks! Les
AB44.mw
Hope everything fine with you. Please check the following program
restart; a := 0; b := 1; Rd := .5; Ra := .2; Nc := .6; e := .2; Nr := .3; H := .9; Digits := 20;
with(LinearAlgebra);
L[0] := 1; L[1] := a+1-x;
M := 4; K := 1;
for n while n <= M do
L[n+1] := expand(-((x-2*n-a-1)*L[n]+(n+a)*L[n-1])/(n+1))
end do; printlevel := 2;
for m from 0 while m < M do
for n to 2^(K-1) do
psi[n, m] := simplify(sqrt(m+1/2.)*2^((1/2)*K)*(eval(L[m], x = 2^K*x-2*n+1)))
end do
f1 := simplify(sum(sum(c[p, q]*psi[p, q], q = 0 .. M-1), p = 1 .. 2^(K-1)));
u := collect(f1, [x], recursive);
u := -3.5276684147527874541*c[1, 3]*x^3+(4.4721359549995793928*c[1, 2]+21.166010488516724724*c[1, 3])*x^2+(-3.4641016151377545871*c[1, 1]-13.416407864998738178*c[1, 2]-34.394767043839677677*c[1, 3])*x+c[1, 0]+3.4641016151377545871*c[1, 1]+7.8262379212492639373*c[1, 2]+14.992590762699346680*c[1, 3]
f := 1+sum(A[i]*(x^(i+1)-(i+1)*x), i = 1 .. M-2)
f:=1+A[1]*(x^2-2*x)+A[2]*(x^3-3*x)
I want to equate the like powers of "x" in f ( mention as red) and u ( mention as red) for any values of M make a system of equations as
Eq[1]:=-3.5276684147527874541*c[1, 3] = A[2];
Eq[2]:=4.4721359549995793928*c[1, 2]+21.166010488516724724*c[1, 3] = A[1];
Eq[3]:=-3.4641016151377545871*c[1, 1]-13.416407864998738178*c[1, 2]-34.394767043839677677*c[1, 3] = -2*A[1]-3*A[2];
Eq[4]:=c[1, 0]+3.4641016151377545871*c[1, 1]+7.8262379212492639373*c[1, 2]+14.992590762699346680*c[1, 3] = 1;
and solve them for any values of A[1] and A[2];
Also attached the program Equate.mw
With my best regards and sincerely.
Muhammad Usman
School of Mathematical Sciences
Peking University, Beijing, China
For the PDE, I can't seem to plot T' as the y-axis, it gives me the error, "Warning, unable to evaluate the function to numeric values in the region; see the plotting command's help page to ensure the calling sequence is correct". Anyone knows what seem to be the problem? I am open to all ideas and would appreciate any help:)
fyp3.mw
I have just started using Maple, and it seems very powerful. I am trying to solve trigonometric equations and get all the solutions in a range, but when I use fsolve I only get one solution.
Is this by design of the function or is there another way to do this?
Tom
Im attempting some very basic calculations where numbers are stored in variables with correct units. However i wish to take a variable to the power 2 without altering it's unit. This is a really easy but strange calculation to make which is why i guess Maple is having trouble with it.
e.g. I have a variable A with a number 4 stored inside with unit in Meters. I want to take A2 = 16 meters and and not A2 = 16 meters2
Is there a function or way to select the base number without having to write an entire line about it?
convert(A,'unit_free')^(2)*Unit('m')
can do the trick but i believe there has to be an easier, less complicated, way to achieve this?
i need to find the graph of exp(v(r)) from 0 to 2e6.
i obtained the graph of v(r) by taking log but how to obtained in exp form
graph_of_exp_form_of_u(r).mw
restart; with(LinearAlgebra); with(Student[LinearAlgebra]);
Z := Matrix([[3, 1, 5, 4, 5], [0, 0, 0, 0, 0], [28, 6, 4, 5, 9], [98, 5, 82, 2, 4], [24, 55, 23, 22, 90]]);
B := Matrix([[0], [0], [0], [0], [0]]);
A := <Z|B>:
if Row(A, 2) = ZeroVector[row](6) then A; end if;
I used the code above but it didn't work...any help appreciated
I would like to know if it is possible to create a dll function from a maple function (a procedure) which would be directly usable in a excel sheet.
In other words, similary to the VBA function that it is possible to build in Excel, i would like to create a dll function that i could use in Excel.
If it is possible, can you help me to use a good process?
Thank you for your help and feedback.
First 1071 1072 1073 1074 1075 1076 1077 Last Page 1073 of 2463
