Hello! Hope everything fine with you. I am try to solve the three-point differential by numerical method in attached file but failed. Please see the attachement and solve my problem. I am very thankful your kind effort. Please take care.
three-point.mw
With my best regards and sincerely.
Muhammad Usman
School of Mathematical Sciences
Peking University, Beijing, China
What code to use in a maplet that would open the open file window?
ie when I push a button the open file window opens allowing the user to choose a file.
refresh
refresh
G := 6.6743*10^(-8); 1; c := 2.99792458*10^10; 1; pi := 3.143; 1; rho := 5.3808*10^14
0.6674300000e-7
0.2997924580e11
3.143
0.5380800000e15
diff(P(r), r) = -G*(rho*c^2+P(r))*((4*pi*r^3*(1/3))*rho+4*Pi*r^3*P(r)/c^2)/(c^2*(r^2-2*G*r*(4*pi*r^3*(1/3))*rho/c^2)), diff(v(r), r) = 1.485232054*10^(-28)*((4*pi*r^3*(1/3))*rho+4.450600224*10^(-21)*Pi*r^3*P(r))/(r^2-1.485232054*10^(-28)*r*(4*pi*r^3*(1/3))*rho)
diff(P(r), r) = -0.7426160269e-28*(0.4836021866e36+P(r))*(0.2254913920e16*r^3+0.4450600224e-20*Pi*r^3*P(r))/(r^2-0.3349070432e-12*r^4), diff(v(r), r) = 0.1485232054e-27*(0.2254913920e16*r^3+0.4450600224e-20*Pi*r^3*P(r))/(r^2-0.3349070432e-12*r^4)
condition; -1; P(0) = 0, v(1014030) = -.4283
Download maple_soft.mw
I found the solution of P(r) at P(0)=0, but could obtain the result of v(r) at v(1014030)=-0.4283, v(r) may have a graph such that i can goes from -0.4283 to 0.
I've posted  a code for a procedure, but it seems it does not execute with other versions of Maple the way it does with my version (5.4). Here is the link. I am curious to identify within the procedure code the cause of this divergence. Note: in 5.4 the code is preceded with readlib(eliminate).
I Have a problem with opening a document
When i open the document it shows a blanc document and this message
no matter wich i choose, maple just shows a plain document.
Is there any solution to this problem?
Hi guys, i'm working on a problem using the runge kutta method (4). The problem is, when I run this program, with the given starting values, it perfectly calculates every value of x[w-i] except x[0] and i have no idea why. Can anyone help? Thanks!
Hello.
In maple you can use the interactive menu and choose what axes you want to look at the plot, ie. I choose Z axes and see the plot from above, can i do this by using syntax as a plot option?
restart; with(plots); with(Student[Precalculus]); with(LinearAlgebra)
S1 := x^2+y^2 = 4;
x^2+y^2 = 4
z = 2-x
F := Vector(3, {(1) = cos(z), (2) = x^2, (3) = 2*y}, attributes = [vectorfield, coords = cartesian[x, y, z]])
F := VectorCalculus:-Curl(F)
F := Vector(3, {(1) = 2, (2) = -sin(z), (3) = 2*x}, attributes = [vectorfield, coords = cartesian[x, y, z]])
g := [diff(rhs(S2), x), diff(rhs(S2), y)]
[-1, 0]
intergrand := -F[1]*g[1]-F[2]*g[2]+F[3]
2+2*x
Integrasjons område er projeksjonen på z=0 planet, her sirkel med radius=2
Intersection := lhs(S1) = rhs(S2);
x^2+y^2 = 2-x
{x = x, y = (-x^2-x+2)^(1/2)}, {x = x, y = -(-x^2-x+2)^(1/2)}
X := solve(rhs(Y[1, 2]))
-2, 1
plot3d([lhs(S1), rhs(S2)], x = X[1] .. X[2], y = rhs(Y[2, 2]) .. rhs(Y[1, 2]), color = [red, green]);
Download stokes_start.mw
I have a vector x of this type:
x :=Vector[column]([A__11*u__1+A__12*u__2+...+A__1m*u__m,
A__21*u__1+A__22*u__2+...+A__2m*u__m,
A__n1*u__1+A__n2*u__2+...+A__nm*u__m]);
If I define u:=Vector[column]([u__1,u__2,...,u__m]), then it is clear that the equation has the form x=A*u.
I want to extract the matrix A, for the given vectors x and u.
IMPORTANT: I know I could create a loop (i=1 to m) and set u__i=1 and all other u__j=0 (for all j not equal i) and then reconstruct each column by this method, but it seems to be a overkill for such an easy problem.
I would be glad, if someone could show me a method how one can achive this in maple.
I am trying to reproduce some systems for multibody systems by using maple.
I want to define a rotation matrix
Rot__alpha:=Matrix([[ cos(alpha) , -sin(alpha) , 0 ], [ sin(alpha) , cos(alpha) , 0 ], [ 0 , 0 , 1 ]]);
Now I want to differentiate this matrix with respect to time t. I have tried the following but it does not work:
map(implicitdiff, Rot__alpha,alpha);
I actually want something like this:
d/dt (Rot(alpha))=Matrix([[ -sin(alpha)*a , -cos(alpha)*a , 0 ], [ cos(alpha)*a , -sin(alpha)*a , 0 ], [ 0 , 0 , 0 ]]);
where a is d(alpha)/dt. So alpha is not an explicit function of t.
It would be great if someone could provide me a method for performing these kind of calculations.
In C++, we use continue statement to continue with the loop. What is maple's equivalent statement of continue as used in C++?
Knowing that log[12](27) = a. How can I find log[36](24) in term a in Maple?
I need yours hepl.  I work with the physics paсkage and I set:
with(Physics)
 Coordinates(X)
Setup(Dgammarepresentation = standard)
Setup(spaceindices = uppercaselatin)
Define(m, m5, y, p, mm, pp)
I try to square the next value:
W := Dgamma[mu]*d_[mu]+M+Psigma[A]*aa[A]-mm*Dgamma[0]-m5*Dgamma[0]*Dgamma[5]+I*Dgamma[5]*Psigma[B]*pp[B]+I*Dgamma[5]*y
("*" is multiplication)
W*W
And after that I want to simplify it:
Simplify(W*W)
I guess that matter is owing to d_[`~mu`]. If I remove this term:
E:=Psigma[A]*aa[A]-mm*Dgamma[0]-m5*Dgamma[0]*Dgamma[5]+I*Dgamma[5]*Psigma[B]*pp[B]+I*Dgamma[5]*y
And if i do:
E*E
Then next error emerges:
What is it?
here is my homework, i am new to maple and need some help!
Consider the logistic equation:
dP/dt = 3/100 * (P(M - P)),
with seasonally varying population constraint
M(t) = 20 + 1.54sin(pi t / 6)
use maple to plot the solution curve for P(0) = 25
Given 3 surfaces:
x^2+y^2=1,z=0(the xy base plane) and z=1-x^2
To plot these I suggested to use cylindrical coordiates knowing x=r*cos(t) and y=r*sin(t)
Which leads to z=1-r^2*cos^2(t)
However i got problems knowing how to plot this object and dearly ask for help.
plothelp.mw
I am an error with the use of the function "Analytic" of the packpage RootFinding. These are the procedures:
CreaCos := proc (C, n, m, t) local k, F; F := C[1][1]+(C[1][2]-C[1][1])*t; for k to n-1 do F := F, C[k+1][1]+((1/2)*C[k+1][2]-(1/2)*C[k+1][1])*(1-cos(Pi*m^k*t)) end do; return F end proc;
Then, for k=50, 100, 150... the instruction
works correctly. However, for higher values of k (for instance, k=250) returns the below error. Some idea or suggets about occurs this error?
Many thanks for your time!
Error, (in RootFinding:-Analytic) unable to evaluate `@`(evalf, proc (x) option remember; table( [( 0.524900000000000000000000000000e-1+Float(undefined)*I ) = Float(undefined)+Float(undefined)*I ] ) 31250*Pi*sin(62500*Pi*x)/(7/18-(1/2)*cos(62500*Pi*x)) end proc) at the value 0.524900000000000000000000000000e-1+Float(undefined)*I. The expression to be solved was probably not analytic.
First 1074 1075 1076 1077 1078 1079 1080 Last Page 1076 of 2463
