Very new to using Maple or coding in general. Ran into a problem that I couldn't figure it out.
Any help would be greatly appreciated.
Has anyone been able to do multivariate partial fraction decomposition in maple (here is a paper introducing the idea https://arxiv.org/pdf/1206.4740.pdf)
I often find maple generating complicated rational functions that it would be nice to visualise in other ways
Here is an example of such a function if anyone wants to have a play:
(a*x^3+b*x*y^2+a*x*y+b*y^2)
/(a*x^3+a*b*x*y^2+a*b*y*x^2+b*y^3)
Hi There:
i have big expressions with many variables of the form (say)  Q__T(t). I would like to simplify my visual parsing of them.
I was wondering if there is a way to tell maple to print particular symbols/variables in specific colors (something akin to what the Physics package does). I.e. I would imagine saying something like:
setup_print_color(Q__T(t), "red");
and then every time Q__T(t) would come up, it would be printed in my desired color.
is this easily possible? I've looked through docs and this site, but can't find any info.
Hello guys
I am trying to solve a non-linear 2nd order diffential equation in order to describe the turbulence phenomena for tip vortices .
The initial conditions that i have are
b(0)=1
b(8)=exp(.1842068074*ln(-(2.*(-1.+b(x)))/(2.*b(8)-7.))+9.670857391)
Moreover i know that b from 0 to 1 equals one and then it  increases propably parabololoid(from the experimntal measurements)with respect o Re(Reynolds)
I tried to solve the eqution using maple solve de interactivelly but doesnt seem to work
Do you have any suggestions?
giorgio_3.mw
I attempted to use convolution in AudioTools to convolve 2 vectors with arbitrary values, but could not since the operation is expecting numeric values.  Can this be done?    Is there not a convolution operastor in the LinearAlgebra package?  See attached:
convolutionWithAu[1].mw
I have a base class with a lot of assignements. The classes that I let my students use are all child classes of that. I used to be able to hide all the assignements except those, that the students should actually work on, but now I can no longer do that. The base class is shared with several colleges and not "owned" by me, but that didn't ust to be an issue. Is there a solution to this problem?
I am new to Maple.
If i have a list (or a table) A:=[[1,2],[3,4],[5,6]
how can i split it into two lists B:=[1,3,5] and C:=[2,4,6] ? (all the 1st numbers in one list, and all 2nd numbers in another list).
Hello guys
Before starting, i must tell you that english is not my mother tongue, so sorry for my spelling errors :)
I have a work to do that ask me to solve the equation : e^((x))-x-5 with the Fixed Point Iteration method. (starting value=2 ; shutoff parameter = 10^(-8) and maximum number of iterations = 100).
I already try and at this time, I did that :
http://imgur.com/PGvmusk
But it doesn't seem to work.
I am not very good with Maple...
I need some help :)
Thanks !
I'm trying to plot the lines that are based on eigenvectors of the matrix. (Functions r1(t),r2(t), q(t) are defined earlier. I can upload file if necessary)
x1:=t->-r1(t)*cos(Pi/2-q(t)/2):
y1:=t->-r1(t)*sin(Pi/2-q(t)/2):
z1:=t->0:
x2:=t->r2(t)*cos(Pi/2-q(t)/2):
y2:=t->-r2(t)*sin(Pi/2-q(t)/2):
z2:=t->0:
Ixx:=t->m*(y1(t)^2+z1(t)^2)+m*(y2(t)^2+z2(t)^2):
Iyy:=t->m*(x1(t)^2+z1(t)^2)+m*(x2(t)^2+z2(t)^2):
Izz:=t->m*(x1(t)^2+y1(t)^2)+m*(x2(t)^2+y2(t)^2):
Ixy:=t->-m*x1(t)*y1(t)-m*x2(t)*y2(t):
Ixz:=t->-m*x1(t)*z1(t)-m*x2(t)*z2(t):
Iyz:=t->-m*y1(t)*z1(t)-m*y2(t)*z2(t):
InertiaTensor:=t-><<Ixx(t),Ixy(t),Ixz(t)>|<Ixy(t),Iyy(t),Iyz(t)>|<Ixz(t),Iyz(t),Izz(t)>>:
 Here I define the matrix as a function of time.
EV:=t->Eigenvectors(InertiaTensor(t));
V1:=t->Column(Re(EV(t)[2]),1);
V2:=t->Column(Re(EV(t)[2]),2);
Producing two eigenvectors also as functions of time.
InertiaAxis1 := t->plot(x, V1(t)[2]*x/V1(t)[1], x = -2 .. 2);
InertiaAxis2 := t->plot(x, V2(t)[2]*x/V2(t)[1], x = -2 .. 2);
InertiaAxis1(1);
And here I've got an error:
Error, (in plot) unexpected options: [-HFloat(7.378655652881484e-6)*x, x = -2 .. 2]
I tried to set "datatype=float"-option in plot function, to evaluate the coefficient by eval-function, it wouldn't help. What does this error mean exactly?
I can not find a solution to the integral of the function below the maple, can anyone help me?
with(Student[MultivariateCalculus]);
with(Student[Calculus1]);
assume(-1 < rho and rho < 1, alpha1 > 0, beta1 > 0, alpha2 > 0, beta2 > 0, t1 > 0, t2 > 0)
f := proc (t1, t2, alpha1, beta1, alpha2, beta2, rho) options operator, arrow; (1/4)*(sqrt(beta1/t1)+(beta1/t1)^(3/2))*(sqrt(beta2/t2)+(beta2/t2)^(3/2))*exp(-((sqrt(t1/beta1)-sqrt(beta1/t1))^2/alpha1^2+(sqrt(t2/beta2)-sqrt(beta2/t2))^2/alpha2^2-2*rho*(sqrt(t1/beta1)-sqrt(beta1/t1))*(sqrt(t2/beta2)-sqrt(beta2/t2))/(alpha1*alpha2))/(2-2*rho^2))/(alpha1*beta1*alpha2*beta2*Pi*sqrt(1-rho^2)) end proc
int(int(f(t1, t2, alpha1, beta1, alpha2, beta2, rho), t2 = 1 .. infinity), t1 = 0.1e-2 .. y)
I run into a problem that really suprised me. I have a program that solves a system of differential equations with different initial conditions. I wrote a cycle that goes through initial conditions, solves differential equations and saves the picture (displaying dynamic behaviour of the system) in the given directory. All seemed fine and working until I once checked one of the pictures by running the program on the only one initial condition. It turned out that the picture program gave me this time is not the one that program gave me earlier (while running through cycle). So I panicked and started checking other pictures and it turned out that some of them are right and some of them are not, remarkably, with no particular pattern.
I reckon that I somehow need to manage the memory, clear it after every iteration. (I'm not absolutely sure that problem is here but I just don't have another explanation why this thing could happen.)
File:ClassicalTrajectoriesH2X_morse_pictures.mw
Quite often when i use maple I generate expressions that are of vast length, that with a pen and paper can be reduced in length by carefully factorizing, multiplying out and dividing through.
I am wondering if i am missig somethig- if this is a problem all maple users deal with, or if its just a limitation of the program.
Today, maple generated:
d*B[2211](t)/dt = 2*k[a2]*beta*k[d2]*B[2211]*(alpha*beta*R[b]*k[a1]^2+alpha*beta*R[b]*k[a1]*k[a2]+2*alpha*R[b]*k[a1]*k[d1]+2*alpha*R[b]*k[a1]*k[d2]+alpha*R[b]*k[a2]*k[d1]+alpha*R[b]*k[a2]*k[d2]+beta*k[a1]*k[d1]+beta*k[a1]*k[d2]+k[d1]^2+3*k[d1]*k[d2]+2*k[d2]^2)
/(alpha*beta^2*R[b]*k[a1]^2*k[a2]+alpha*beta^2*R[b]*k[a1]*k[a2]^2+alpha*beta*R[b]*k[a1]^2*k[d1]+alpha*beta*R[b]*k[a1]^2*k[d2]+3*alpha*beta*R[b]*k[a1]*k[a2]*k[d1]+3*alpha*beta*R[b]*k[a1]*k[a2]*k[d2]+alpha*beta*R[b]*k[a2]^2*k[d1]+alpha*beta*R[b]*k[a2]^2*k[d2]+alpha*R[b]*k[a1]*k[d1]^2+3*alpha*R[b]*k[a1]*k[d1]*k[d2]+2*alpha*R[b]*k[a1]*k[d2]^2+2*alpha*R[b]*k[a2]*k[d1]^2+3*alpha*R[b]*k[a2]*k[d1]*k[d2]+alpha*R[b]*k[a2]*k[d2]^2+beta^2*k[a1]*k[a2]*k[d1]+beta^2*k[a1]*k[a2]*k[d2]+2*beta*k[a1]*k[d1]^2+3*beta*k[a1]*k[d1]*k[d2]+beta*k[a1]*k[d2]^2+beta*k[a2]*k[d1]^2+3*beta*k[a2]*k[d1]*k[d2]+2*beta*k[a2]*k[d2]^2+2*k[d1]^3+7*k[d1]^2*k[d2]+7*k[d1]*k[d2]^2+2*k[d2]^3)
+(-2*k[d1]-2*k[d2])*B[2211]
+2*k[d1]*B[2211]*(alpha*beta*R[b]*k[a1]*k[a2]+alpha*beta*R[b]*k[a2]^2+alpha*R[b]*k[a1]*k[d1]+alpha*R[b]*k[a1]*k[d2]+2*alpha*R[b]*k[a2]*k[d1]+2*alpha*R[b]*k[a2]*k[d2]+beta*k[a2]*k[d1]+beta*k[a2]*k[d2]+2*k[d1]^2+3*k[d1]*k[d2]+k[d2]^2)*k[a1]*beta
quite clearly there are expressions in there that can be factorised by (k[a1]+k[a2]) and the two quotients have the same denominator. Is there any way of minimizing the length of this expression by factorizing where appropriate, merging denominators when appropriate etc?
I am interested in the behaviour of a system of equations close to the origin- these equations are quite long, and there are a lot of them so i would like to have commands that i can use to assume products of variables are zero.
here are the first two polynomials:
alpha*k[a1]*B[1]^2+(-alpha*k[a1]-alpha*k[a2])*B[2]*B[1]+2*alpha*k[a1]*B[1]*B[11]+alpha*k[a1]*B[12]*B[1]+2*alpha*k[a1]*B[1]*B[211]+alpha*k[a1]*B[221]*B[1]+2*alpha*k[a1]*B[1]*B[2211]+(-alpha*R[b]*k[a1]-k[d1])*B[1]+2*B[11]*k[d1]+B[12]*k[d2]+k[d1]*B[211]+k[d2]*B[221]
(-alpha*k[a1]-alpha*k[a2])*B[2]*B[1]+alpha*k[a2]*B[2]^2+2*alpha*k[a2]*B[2]*B[22]+alpha*B[2]*B[12]*k[a2]+alpha*k[a2]*B[2]*B[211]+2*alpha*k[a2]*B[2]*B[221]+2*alpha*k[a2]*B[2]*B[2211]+(-alpha*R[b]*k[a2]-k[d2])*B[2]+B[12]*k[d1]+2*B[22]*k[d2]+k[d1]*B[211]+k[d2]*B[221]
the varables are the terms with B and a subsript and everything else is a parameter.
My intuition was to use coeffs but I couldn't get anything helpful
I have tried everything to find out how to customise the header and footer for my tutor marked assignments.
I want to have a heading on the top of the page which has a continuous line running underneath the text of the heading. And I want to have a footing on the bottom of each page which has a continuous line running above the text of the footing text.
I noticed that the 2015 Maple user manual has this feature so it must be possible.
I cannot see how to do this using the standard customise header and footer menu.
Thanks in anticipation of an answer.
DLW
Hello guys, i have some matrix equations.
A^(T)*X+X*A+Q = 0 , where A,Q - matrixs, X - unknown matrix, i need to solve this.
i tried to solve this from http://www.mapleprimes.com/questions/200940-How-To-Solve-Matrix-Equation-Problem-In-Maple#answer203570 methods, but not successfully.
How can to solve this problem?
multMatrix.mw
thx.
First 1102 1103 1104 1105 1106 1107 1108 Last Page 1104 of 2463
