how draw a line x+y = 1 on a sphere x^2+y^2+z^2 = 1 in maple
Hi guys, I'm currently having a lot of trouble with Maple and can't seem to get stuff to work. I have the task of solving and modelling the Klien Gordon equation, with a chosen potential. The equation I'm trying to solve is:
> KGE := diff(psi(x, t), x, x)-(diff(psi(x, t), t, t))-12*psi(x, t)^5+10*psi(x, t)^4+6*psi(x, t)^3-3*psi(x, t)^2-psi(x, t) = 0
I'm doing this by changing the pde into an ode via a transformation
>tr := {t = tau, x = c*tau+z, psi(x, t) = U(z)}
>ode1 := dchange(tr, KGE, [z, tau, U(z)])
 >ode1 := collect(ode1, diff(U(z), z, z))
>c := 1/4
>ode2 := subs({U(z) = U, diff(U(z), z, z) = V(U)*(diff(V(U), U))}, ode1)
>sol := dsolve({ode2, V(0) = 0}, V(U))
>sol1:= sol[2]
>z := -c*t+x = int(1/rhs(sol2), U)
>solwave := psi(x, t) = solve(z, U)
I then checked if my solution, solwave actually solved the pde via pdetest(solwave,KGE) and it did. Hence this is what I took as one of the kinks. Although the kink solution looks hideous and I have no idea how to try and take the limit as x goes to infinity, as to show it tends to a vacuum of the potential. I've tried taking the limit but all Maple does is replace all the x with infinity signs...
I then tried animating it to see if it worked, but it just looks wrong, there are breaks within the curve and also very random spikes which I cannot explain at all..
I tried this code exactly for the Sine Gordon equation and it works perfectly, it just all goes wrong when I try to change the potential.
Here is a picture of the frame:
as you can see it has spikes.. and breaks in the curve as well
Another issue I had was with dealing with the potential on it's own, every time I try inputting
>1/2(u^2)(1-u)^2(1+2u)^2
into maple it changes the expression into something completely different and wrong, it somehow comes out with an exponential of 8.. This is what I get:
(1/2)*(u(1-u))(1+2*u)^8
I also have a problem integrating, I try and plug in a value, i.e.
>int(1/(x(1-x))(1+2*x), x)
but all this does is show me what I inputted but with a integral sign...
I'm very very new to Maple and have spent over a week doing this, but it just isn't working out at all :( Please help!!
I have studied most posts about plot quality, still confused.
When I export 2d graphs and import the to microsoft word, the quality is horrible. How can I presents my results in a reseanably good way?
what command should I add to my code that the quality increase notoceably?
Any suggestion about 3d plots?
If I export as an eps file, how can I import that in microsoft word? I did, but I guess they are not compatibble.
thank you
Hello, I have a somewhat math and Maple question I'm hoping some can help with.
I have this curve,
curve:=alpha^2*beta^10-alpha^2*beta^9+4*alpha*beta^7-2*alpha*beta^6-2*alpha*beta^5-alpha*beta^4+alpha*beta^3-2*beta+1;
and if I solve this system (numerically);
sol:= solve([curve=0,diff(curve,beta)=0],[alpha,beta]);
I get 6 special points (8 actually but two are critical). So I'll refer to them by subscript "i".
If I then do a coordinate transformation by;
alpha=exp(u)
beta=exp(v)
and convert the 6 coordinates and curve, I'll get everything in terms of (u,v) coordinates.
curve2:=subs([alpha=exp(u),beta=exp(v)],curve);
soluv:=map(ln,sol);  (this is just pseudo - I don't know how to do it this way)
So now the 6 points are referred to by (u_i,v_i).
Next, I want to expand this curve locally around these six points, using the following (where "z" is the local coordinate);
u -> u_i + z^2
v -> v_i + sum(a_j*z^j,j=1..n)
where n is reasonable, though around 15.
curve3(i):=subs(u=z^2 + cat(Ubp,i),curve2);
curve4(i,n):=subs(v=cat(Vbp,i)+sum(a[i,j]*z^j,j=1..n),curve3(i));
Here, I'm not sure of the pros/cons of cat() vs a[i,j]....
Anyway, I'll then have an equation in terms of only the local coordinate "z". If I then solve each coefficient of "z", at each order, I should then be able to determine the power series v(z). I reason that since the curve is initially equal to zero, that every non-zero power of z will have a coefficient/equation (in terms of unknowns a[i,j]) that should be equal to zero.
This is analagous to solving differential equations with power series...
However, I'm a little lost in implementing this,
I am currently trying, for instance,
l1:= series(curve4(1,10),z,0,9);
e1:= seq(coeff(l1,z,i),i=1..4):
s1:=seq(a[1,j],j=1..4):
sol:=solve(e1,s1);
I believe I am doing something wrong though bcause every odd power is zero.
Thank you a lot for any suggestions and/or help,
sbh
PS>
Ubp and Vbp are those 6 points - I just kept them as symbols initially because I was still getting odd-powered coefficients as zero, regardless of their actual values. Hence a little bit of the "math" side of the problem...
Hi;
To compute higher-order lie derivatives we need to pass a vector field to LieDerivative(..) function. What follows is the result of LieDerivative(..) command:
To compute 2nd-order lie derivative we should first create a vector field as follows:
L1fh := ((1/2)*(x+u)*(-2*y+2*x)/sqrt((y-x)^2+L^2))*D_x + ((1/2)*(y+v)*(2*y-2*x)/sqrt((y-x)^2+L^2))*D_y + (L^2/sqrt((y-x)^2+L^2))*D_L;
Is there a function to extraxt components of an expression which is the result of the LieDerivative(..)? For example how we can extract the first term. i.e. :
sample code:
with(DifferentialGeometry):
DGsetup([x, y, L], R3);
h := sqrt((y-x)^2 + L^2);
f := evalDG((x+u)*D_x + (y+v)*D_y + L*D_L);
L1fh := LieDerivative(f, h);
simplify(L1fh);
L2fh := LieDerivative(L1fh, h);
simplify(L2fh);
In a paper due to Borwein
http://www.cecm.sfu.ca/personal/pborwein/PAPERS/P172.pdf
it is shown a (very beautiful) graph of the zeros of a partial sum of the Zeta-Riemann, where he indicates that the plot is "the normalized zeros of the 5th partial sum of the Zeta function". Somebody know how one can plot this with Maple?
✐♦❝❄t✉⑥♠❧❄❞❢❤❡⑦⑧❛❋⑨⑤⑦⑧❛✯ts❝⑩❦✑❝❄❜❚qs❴❇❛ ✈❇❜❶q✉❴❷♥♦❧❄t✇q✉❤❡❧❄❞★❦sr❇⑥✤❝❄❜✫qs❴❇❛❹❸✫❤❡❛⑧⑥✜❧❺✐❇✐❻⑦⑧❛⑧q✉❧❈❼❽❜❀r❇✐♦♣✒qs❤❡❝❄✐
>teksbiasa:=`Hello!`;
teksbiasa:=Hello!
>nilaiASCII:=convert(teksbiasa,bytes);
nilaiASCII:=[72,101,108,108,111,33]
>E:=nilaiASCII+~nops(nilaiASCII);
E:=[78,107,114,114,117,39]
Hi, how i need to modify my command so the length of each word can be detected if enter a sentence instead of 1 word ?
For example, if i entered >> `Hello! Bob`, so the length of each word is [6, 3], so what i need is
>teksbiasa:=`Hello! Bob`;
teksbiasa:=Hello! Bob
nilaiASCII:=[72, 101, 108, 108, 111, 33, 32, 66, 111, 98]
and my E will be >> E:=[72+6, 101+6, 108+6, 108+6, 111+6, 33+6, 32, 66+3, 111+3, 98+3] which is >>
E:= [78, 107, 114, 114, 117, 39, 32, 69, 114, 101]
Thanks for help~=]]
Have a nice day~=]]
I am trying to find the interpolation of a 3D function.
I have the vector x, the vector y and a matrix M at my disposition.
I know how to do the pointplot3d , but I can not find the function: f(x,y)
any suggestion?
Thank you for help
I tried to rearrange below set of equations to have the equations in term of P[0], P[1], P[2], P[3], P[4], P[5] and P[6]. I used the symbol := for function definition for all Ps except one of them. Thus maple will rearrange that excepted one. However, I got error massage stating "Error, (in P[3]) too many levels of recursion" when I tried to rearranged equations for P[0].
Can I get help to rearranged them.
P[0](s) = (P[1](s)*mu[1]+P[2](s)*mu[2]+1)/(s+3*lambda+3*sigma)
P[1](s) = (3*P[0](s)*lambda+3*P[3](s)*mu[1]+P[4](s)*mu[2])/(s+mu[1]+2*lambda+2*sigma)
P[2](s) = (3*P[0](s)*sigma+P[4](s)*mu[2]+P[3](s)*mu[1])/(s+mu[2]+2*lambda+2*sigma)
P[3](s) = 2*lambda(P[1](s)+P[2](s))/(s+2*mu[1]+lambda)
P[4](s) = 2*sigma(P[1](s)+P[2](s))/(s+2*mu[2]+sigma)
P[5](s) = lambda(P[3](s)+P[4](s))/s
P[6](s) = sigma(P[3](s)+P[4](s))/s
Thank you for your help
Is it possible to create a sumif function, like the one in excel?
I know that the following expression (a:=6*s*sqrt(9*s^2+32)+18*s^2+32)
can be rewritten as
However, none of the following maple functions is abble to give the factored result:
factor(a)
simplify(a)
combine(a)
Someone could help me to understand what is going on, please?
Let us consider the maximum value of the polynomial
x^4+c*x^2+x^3+d*x-c-1
on the interval x=-1..1 as a function g of the parameters c and d. General considerations suggest its continuity. However, a plot3d of g does not  confirm it.  Also the question arises "Is the function g(c,d) bounded from below?". Here is my try with the DirectSearch and NLPSolve:
g(10, -10)
9.
plot(x^4+x^3+10*x^2-10*x-10-1, x = -1 .. 1)
plot3d(g, -5 .. 5, -5 .. 5, grid = [100, 100], style = surface, color = "DarkOliveGreen")
DirectSearch:-GlobalOptima(proc (a, b) options operator, arrow; g(a, b) end proc, {a = -1000 .. 1000, b = -1000 .. 1000}, variables = [a, b])
[-167.208333252089, Vector(2, {(1) = 999.9999999975528, (2) = 166.20833325208952}, datatype = float[8]), 815]
DirectSearch:-GlobalOptima( (a, b) -> g(a, b), variables = [a, b])
DirectSearch:-GlobalOptima(proc (a, b) options operator, arrow; g(a, b) end proc, variables = [a, b])
Error, (in Optimization:-NLPSolve) invalid input: PolynomialTools:-CoefficientVector expects its 1st argument, poly, to be of type polynom(anything, x), but received HFloat(HFloat(undefined))*x^4+HFloat(HFloat(undefined))*x^3+HFloat(HFloat(undefined))*x^2+HFloat(HFloat(undefined))*x+HFloat(HFloat(undefined))
Download bound.mw
I am trying to slve the second order differential equation with initial conditions  t0=0.dy/dt=0,y0=10000
-(diff(y, t, t))-9.81+0.563e-3*(0.1832e-2*abs(diff(y, t))+0.51702e-1*abs(diff(y, t))^(3/2)+.4*(diff(y, t))^2) = 0
using 4th order runge kutta.do i need to declare a step parameter like (D(y))(t) = u or is a command that can be applied automatically?
 rk4.mw
>nombor1:=[4,6,2];
nombor1:=[4,6,2]
Hi, anyone know hot i need to continue my command to get 462 from [4,6,2]?
Thank you~=]]
I have an equation for r(t) that involves 3 (slidable) constants; an equation for phi(t) that involves the same three constants and is written in terms of arctan; theta is a slidable constant. How do I plot this on an x,y,z plot? I want an animation in terms of t.
First 1185 1186 1187 1188 1189 1190 1191 Last Page 1187 of 2470
