Hi everyone,
I was trying to write a Maple sheet to calculate some perturbation theory expension as close to the "book notation" as possible. Lets for example consider a linearly perturbed harmonic oscillator with H = hω(n+1/2) and V = λ(a†+a), this is one of the classical examples as it can be solved analytically by completing the square. In the Kato formulation (as used in the appended Maple worksheet), as well as in Rayleigh-Schrödinger perturbation theory one uses the projector onto the complement of the unperturbed state. I would like to do this by defining a projector in Maple. I've read the examples concerning projectors in Maple but it seems I have to use a rather ugly workaround by treating the states "below" the unperturbed state and the ones "above" separately. While this is a little annoying in one dimension it becomes a major nuisance in higher dimensions.
My question would be: How do I define the projector onto the complement of some state?
Cheers, Sören
restart; with(Physics); Setup(mathematicalnotation = true)
a := Annihilation(N, 1):
assume(`and`(`in`(m, nonnegint), m > 0)):
Physics:-Ket(N, m)
H := Physics:-`*`(Physics:-`*`(h, omega), n+1/2):
`ΔE__2` := simplify(value(Typesetting:-delayDotProduct(Typesetting:-delayDotProduct(Typesetting:-delayDotProduct(Typesetting:-delayDotProduct(Dagger(psi), V), 1/(E(m)-H)), V), psi)))
-lambda^2/(h*omega)
`ΔE__4,111` := simplify(value(Dagger(psi).V.(1/(E(m)-H)).V.(1/(E(m)-H)).V.(1/(E(m)-H)).V.psi))
Error, (in Physics:-Dagger) numeric exception: division by zero
`ΔE__4,201` := -simplify(value(Typesetting:-delayDotProduct(Typesetting:-delayDotProduct(Typesetting:-delayDotProduct(Typesetting:-delayDotProduct(Physics:-`*`(Typesetting:-delayDotProduct(Typesetting:-delayDotProduct(Typesetting:-delayDotProduct(Typesetting:-delayDotProduct(Dagger(psi), V), 1/(E(m)-H)^2), V), psi), Dagger(psi)), V), 1/(E(m)-H)), V), psi)))
lambda^4*(2*m+1)/(h^3*omega^3)
`ΔE__4` := `ΔE__4,111`+`ΔE__4,201`
`ΔE__4,111`+lambda^4*(2*m+1)/(h^3*omega^3)
Download kato_perturbation_theory.mw
i googled nullspace from ReducedRowEchelonForm
but when calculate it, ReducedRowEchelonForm do not contain the eigenvector in nullspace
how to calculate nullspace by hand?
i find that in maple 12 and maple 15 null space are different , however the common thing is that they are different from eigenvector by one of column multiply -1
is multiplication to one of column is due to rank=2 < 3, 3-2 = 1, so that random choose a column to multiply -1?
then i use elementary transformation, still can not get a rref which is like eigenvector, where is wrong?
sys1:=NewInput3-Matrix([[FirstEigenValue, 0, 0], [0, FirstEigenValue, 0], [0, 0, FirstEigenValue]]); sys1 := Matrix([[sys1[1,1], sys1[1,2], sys1[1,3]], [sys1[2,1]-sys1[2,1]/sys1[1,1]*sys1[1,1], sys1[2,2]-sys1[2,1]/sys1[1,1]*sys1[1,2], sys1[2,3]-sys1[2,1]/sys1[1,1]*sys1[1,3]], [sys1[3,1], sys1[3,2], sys1[3,3]]]);
sys1 := Matrix([[sys1[1,1], sys1[1,2], sys1[1,3]], [sys1[2,1], sys1[2,2], sys1[2,3]], [sys1[3,1]-sys1[3,1]/sys1[1,1]*sys1[1,1], sys1[3,2]-sys1[3,1]/sys1[1,1]*sys1[1,2], sys1[3,3]-sys1[3,1]/sys1[1,1]*sys1[1,3]]]);
sys1 := Matrix([[sys1[1,1]/sys1[1,1], sys1[1,2]/sys1[1,1], sys1[1,3]/sys1[1,1]], [sys1[2,1], sys1[2,2], sys1[2,3]], [sys1[3,1], sys1[3,2], sys1[3,3]]]);
sys1 := Matrix([[sys1[1,1], sys1[1,2], sys1[1,3]], [sys1[2,1], sys1[2,2], sys1[2,3]], [sys1[3,1]-sys1[3,2]/sys1[2,2]*sys1[2,1], sys1[3,2]-sys1[3,2]/sys1[2,2]*sys1[2,2], sys1[3,3]-sys1[3,2]/sys1[2,2]*sys1[2,3]]]);
sys1 := Matrix([[sys1[1,1], sys1[1,2], sys1[1,3]], [sys1[2,1]/sys1[2,2], sys1[2,2]/sys1[2,2], sys1[2,3]/sys1[2,2]], [sys1[3,1], sys1[3,2], sys1[3,3]]]);
http://rosettacode.org/wiki/Reduced_row_echelon_form#C.23
change c# code from integer to double, it return only an identity matrix. same as maple, how eigenvector come from rref?
when compare maple with sympy in python27,
sympy even do not have solution in nullspace!!!
from sympy import *
InputMatrix3 = Matrix([[31.25,30.8,30.5],[30.8,30.5,0],[30.5,0,0]])
NewInput3 := InputMatrix3.T*InputMatrix3
NewInput3.nullspace()
InputMatrix3 := Matrix([[31.25,30.8,30.5],[30.8,30.5,0],[30.5,0,0]]);
NewInput3 := MatrixMatrixMultiply(Transpose(InputMatrix3), InputMatrix3);
Old_Asso_eigenvector := Eigenvectors(NewInput3);
FirstEigenValue := solve(Determinant(NewInput3-Matrix([[lambda1, 0, 0], [0, lambda1, 0], [0, 0, lambda1]])), lambda1)[3]; # find back eigenvalue from eigenvector
SecondEigenValue := solve(Determinant(NewInput3-Matrix([[lambda1, 0, 0], [0, lambda1, 0], [0, 0, lambda1]])), lambda1)[2]; # find back eigenvalue from eigenvector
ThirdEigenValue := solve(Determinant(NewInput3-Matrix([[lambda1, 0, 0], [0, lambda1, 0], [0, 0, lambda1]])), lambda1)[1]; # find back eigenvalue from eigenvector
sys2:=NewInput3-Matrix([[SecondEigenValue, 0, 0], [0, SecondEigenValue, 0], [0, 0, SecondEigenValue]]);
sys3:=NewInput3-Matrix([[ThirdEigenValue, 0, 0], [0, ThirdEigenValue, 0], [0, 0, ThirdEigenValue]]);
sys1b:=MatrixMatrixMultiply(NewInput3-Matrix([[FirstEigenValue, 0, 0], [0, FirstEigenValue, 0], [0, 0, FirstEigenValue]]),Matrix([[x],[y],[z]]));
sys2b:=MatrixMatrixMultiply(NewInput3-Matrix([[SecondEigenValue, 0, 0], [0, SecondEigenValue, 0], [0, 0, SecondEigenValue]]),Matrix([[x],[y],[z]]));
sys3b:=MatrixMatrixMultiply(NewInput3-Matrix([[ThirdEigenValue, 0, 0], [0, ThirdEigenValue, 0], [0, 0, ThirdEigenValue]]),Matrix([[x],[y],[z]]));
ReducedRowEchelonForm(sys1);
NullSpace(sys1);
NullSpace(sys2);
NullSpace(sys3);
The following code will not produce a plot. My previous attempts with different equations have worked fine. What am I missing? Thanks for any help.
with(DEtools);
sys := diff(x(t), t) = 10*x(t)-3*x(t)^2-x(t)*y(t), diff(y(t), t) = 14*y(t)-3*y(t)^2-x(t)*y(t);
fcns := {x(t), y(t)}; p := dsolve({sys, x(0) = 10, y(0) = 15}, fcns, type = numeric, method = classical);
odeplot(p, [[t, x(t)], [t, y(t)]], 0 .. 14);
Hi everyone,
I wanted to plot the fourier series up to a given order of a step function using the code I attached, to change the order I used a sum with upper boundary M. When setting M to a particular value and plotting the function the result is obtained within a second, when on the otherhand using plot(subs(M=11,...),...) it takes close to a minute to produce a picture.
This might be a misuse of subs, in any case, I wanted to share my experience and maybe get an explanation about why this takes that much longer.
Cheers,
Sören
f := proc (t) options operator, arrow; sum(-4*sin((2*n+1)*t)/(Pi*(2*n+1)), n = 0 .. M) end proc
plot(subs(M = 11, f(t)), t = 0 .. 2*Pi)
M := 11; plot(f(t), t = 0 .. 2*Pi)
Download fourier_subs.mw
I have the a code with some parameters including
Nr= 0, 50, 100
Ha=0, 5, 10
EPSILONE= 0, 0.5, 1
Phiavg= 0.02, 0.06, 0.1
0.1<NBT<10
I can give the solution for higher values of 5<NBT<10 and there is no problem. However, As I reduce the values of NBT, the convergence of the problem is hard. for some values of parameters I cannot find the solution. for example:
Nr=Ha=0
EPSILONE=1
Phiavg=0.06
NBT=0.3
I would be most grateful if you can tel me how change the algorithm to find the solution in the range of all parameters.
Many thanks for your attentions in advance
The code has been attached
code_7-8-2014_(1).mw
Amir
Now that I got my units converted I have a new problem:
I have g/mol and g/cm^3, and the result is supposed to be per cm^3 too. So I would like to keep my grams as well as my  cm^3. However, Maple converts it all to kg and m^3!
That means I have to divide the final result by 10e6. No big deal, only that it looks strange on my worksheet (when I divide the units stay the same, so if I show that to someone they'll be amazed at the gigantic m^3 result number I got instead of just a few cm^3).
By the way, turing off the automatic unit cancellation (see link, my question a few days ago) does not change anything, the g->kg and cm^3->m^3 conversion take place as soon as I enter the values:
results in
gives
Hi guys,
im trying to solve the linear equation system:
mysol := solve({J*a = m*l*(-c*ct^2*sf-c*sf*st^2+cf*d*st^2+d*sf*st^2)+m*g*l*st, cx*ux = cMx*xd+M*c+m*l*(-cp*pd^2*st-cp*st*td^2-2*ct*pd*sp*td+a*cp*ct-b*sp*st), cy*uy = cMy*yd+M*d+m*l*(2*cp*ct*pd*td-pd^2*sp*st-sp*st*td^2+a*ct*sp+b*cp*st), (-l^2*m*st^2+J)*b = -ml(c*cf*ct+ct*d*sf)}, {a, b, c, d}) :
Then, assigning the solutions:
assign(mysol):
Then, eliminating the RootOf's for variable a:
a_explicit := allvalues(a):
Unfortunately, a_explicit still contains RootOf's. How can I avoid this?
Martin
Hi all.
I want to know how do I declare symbol in maple. Say y=2x+b, I want maple to treat this y as a function of x with b as a constant (or symbol). How should I do that?
More specificaly, I am trying to ask maple to do some calculation for me. and it returns me "Fail". So I am suspecting that maple didn't take other letters as symbol. Here is my code:
with(Statistics); h := RandomVariable(Exponential(H)); simplify(PDF(h, t))
with(Statistics); g := RandomVariable(Exponential(G)); simplify(PDF(g, t))
constants := constants, Ps Pr
PDF(Ps*g*h/(Pr*g+2), t)
but maple return:
          Fail
The TensorSubstittuition is not finding all of the eta[~mu,~mu]*l[nu](X)=l[~mu](X) substitutions.
with(Physics):
Setup(mathematicalnotation = true, coordinatesystems = X, usephysicsevaluator = false)
[coordinatesystems = {X}, mathematicalnotation = true, usephysicsevaluator = false]
Define(l[mu]);
{Physics:-Dgamma[mu], Physics:-Psigma[mu], Physics:-d_[mu], eta[mu, nu], Physics:-g_[mu, nu], l[mu], Physics:-KroneckerDelta[mu, nu], Physics:-LeviCivita[alpha, beta, mu, nu], Physics:-SpaceTimeVector[mu](X)}
Define(G[mu, nu] = eta[mu, nu]+Physics:-`*`(l[mu](X), l[nu](X)))
{Physics:-Dgamma[mu], G[mu, nu], Physics:-Psigma[mu], Physics:-d_[mu], eta[mu, nu], Physics:-g_[mu, nu], l[mu], Physics:-KroneckerDelta[mu, nu], Physics:-LeviCivita[alpha, beta, mu, nu], Physics:-SpaceTimeVector[mu](X)}
declare(l(X))
l(x1, x2, x3, x4)*`will now be displayed as`*l
Setup(metric = rhs(G[]))
[metric = {(1, 1) = 1+l[1](X)^2, (1, 2) = l[1](X)*l[2](X), (1, 3) = l[1](X)*l[3](X), (1, 4) = l[1](X)*l[4](X), (2, 2) = 1+l[2](X)^2, (2, 3) = l[2](X)*l[3](X), (2, 4) = l[2](X)*l[4](X), (3, 3) = 1+l[3](X)^2, (3, 4) = l[3](X)*l[4](X), (4, 4) = -1+l[4](X)^2}]
g_[];
g[mu, nu] = (Matrix(4, 4, {(1, 1) = 1+l[1](X)^2, (1, 2) = l[1](X)*l[2](X), (1, 3) = l[1](X)*l[3](X), (1, 4) = l[1](X)*l[4](X), (2, 1) = l[1](X)*l[2](X), (2, 2) = 1+l[2](X)^2, (2, 3) = l[2](X)*l[3](X), (2, 4) = l[2](X)*l[4](X), (3, 1) = l[1](X)*l[3](X), (3, 2) = l[2](X)*l[3](X), (3, 3) = 1+l[3](X)^2, (3, 4) = l[3](X)*l[4](X), (4, 1) = l[1](X)*l[4](X), (4, 2) = l[2](X)*l[4](X), (4, 3) = l[3](X)*l[4](X), (4, 4) = -1+l[4](X)^2}))
Christoffel[`~alpha`, mu, nu] = convert(Christoffel[`~alpha`, mu, nu], g_)
Physics:-Christoffel[`~alpha`, mu, nu] = (1/2)*Physics:-g_[`~alpha`, `~beta`]*(Physics:-d_[nu](Physics:-g_[beta, mu], [X])+Physics:-d_[mu](Physics:-g_[beta, nu], [X])-Physics:-d_[beta](Physics:-g_[mu, nu], [X]))
Christoffel[beta, mu, nu] = convert(Christoffel[beta, mu, nu], g_)
Physics:-Christoffel[beta, mu, nu] = (1/2)*Physics:-d_[nu](Physics:-g_[beta, mu], [X])+(1/2)*Physics:-d_[mu](Physics:-g_[beta, nu], [X])-(1/2)*Physics:-d_[beta](Physics:-g_[mu, nu], [X])
SubstituteTensor(g_[mu, nu] = eta[mu, nu]+Physics:-`*`(l[mu](X), l[nu](X)), Physics:-Christoffel[beta, mu, nu] = (1/2)*Physics:-d_[nu](Physics:-g_[beta, mu], [X])+(1/2)*Physics:-d_[mu](Physics:-g_[beta, nu], [X])-(1/2)*Physics:-d_[beta](Physics:-g_[mu, nu], [X]), evaluateexpression)
Physics:-Christoffel[beta, mu, nu] = (1/2)*Physics:-d_[nu](l[beta](X), [X])*l[mu](X)+(1/2)*l[beta](X)*Physics:-d_[nu](l[mu](X), [X])+(1/2)*Physics:-d_[mu](l[beta](X), [X])*l[nu](X)+(1/2)*l[beta](X)*Physics:-d_[mu](l[nu](X), [X])-(1/2)*Physics:-d_[beta](l[mu](X), [X])*l[nu](X)-(1/2)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])
Christoffel[`~alpha`, mu, nu] = Simplify(Physics:-`*`(eta[`~alpha`, `~beta`]-Physics:-`*`(l[`~alpha`](X), l[`~beta`](X)), rhs(Physics:-Christoffel[beta, mu, nu] = (1/2)*Physics:-d_[nu](l[beta](X), [X])*l[mu](X)+(1/2)*l[beta](X)*Physics:-d_[nu](l[mu](X), [X])+(1/2)*Physics:-d_[mu](l[beta](X), [X])*l[nu](X)+(1/2)*l[beta](X)*Physics:-d_[mu](l[nu](X), [X])-(1/2)*Physics:-d_[beta](l[mu](X), [X])*l[nu](X)-(1/2)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X]))))
Physics:-Christoffel[`~alpha`, mu, nu] = -(1/2)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[nu](l[beta](X), [X])*l[mu](X)+(1/2)*Physics:-d_[nu](l[beta](X), [X])*l[mu](X)*eta[`~alpha`, `~beta`]-(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[beta](X)*Physics:-d_[nu](l[mu](X), [X])+(1/2)*l[beta](X)*Physics:-d_[nu](l[mu](X), [X])*eta[`~alpha`, `~beta`]-(1/2)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[mu](l[beta](X), [X])*l[nu](X)+(1/2)*Physics:-d_[mu](l[beta](X), [X])*l[nu](X)*eta[`~alpha`, `~beta`]-(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[beta](X)*Physics:-d_[mu](l[nu](X), [X])+(1/2)*l[beta](X)*Physics:-d_[mu](l[nu](X), [X])*eta[`~alpha`, `~beta`]+(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[nu](X)*Physics:-d_[beta](l[mu](X), [X])-(1/2)*l[nu](X)*Physics:-d_[beta](l[mu](X), [X])*eta[`~alpha`, `~beta`]+(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])-(1/2)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])*eta[`~alpha`, `~beta`]
SubstituteTensor({Physics:-`*`(eta[`~mu`, `~nu`], d_[gamma](l[nu](X))) = d_[gamma](l[`~mu`](X)), Physics:-`*`(l[nu](X), eta[`~mu`, `~nu`]) = l[`~mu`](X), Physics:-`*`(l[`~mu`](X), l[mu](X)) = 0}, Physics:-Christoffel[`~alpha`, mu, nu] = -(1/2)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[nu](l[beta](X), [X])*l[mu](X)+(1/2)*Physics:-d_[nu](l[beta](X), [X])*l[mu](X)*eta[`~alpha`, `~beta`]-(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[beta](X)*Physics:-d_[nu](l[mu](X), [X])+(1/2)*l[beta](X)*Physics:-d_[nu](l[mu](X), [X])*eta[`~alpha`, `~beta`]-(1/2)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[mu](l[beta](X), [X])*l[nu](X)+(1/2)*Physics:-d_[mu](l[beta](X), [X])*l[nu](X)*eta[`~alpha`, `~beta`]-(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[beta](X)*Physics:-d_[mu](l[nu](X), [X])+(1/2)*l[beta](X)*Physics:-d_[mu](l[nu](X), [X])*eta[`~alpha`, `~beta`]+(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[nu](X)*Physics:-d_[beta](l[mu](X), [X])-(1/2)*l[nu](X)*Physics:-d_[beta](l[mu](X), [X])*eta[`~alpha`, `~beta`]+(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])-(1/2)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])*eta[`~alpha`, `~beta`])
Physics:-Christoffel[`~alpha`, mu, nu] = -(1/2)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[nu](l[beta](X), [X])*l[mu](X)+(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[mu](X)+(1/2)*l[beta](X)*Physics:-d_[nu](l[mu](X), [X])*eta[`~alpha`, `~beta`]-(1/2)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[mu](l[beta](X), [X])*l[nu](X)+(1/2)*Physics:-d_[mu](l[`~alpha`](X), [X])*l[nu](X)+(1/2)*l[beta](X)*Physics:-d_[mu](l[nu](X), [X])*eta[`~alpha`, `~beta`]+(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[nu](X)*Physics:-d_[beta](l[mu](X), [X])-(1/2)*l[nu](X)*Physics:-d_[beta](l[mu](X), [X])*eta[`~alpha`, `~beta`]+(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])-(1/2)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])*eta[`~alpha`, `~beta`]
Ricci[mu, nu] = convert(Ricci[mu, nu], Christoffel)
Physics:-Ricci[mu, nu] = Physics:-d_[alpha](Physics:-Christoffel[`~alpha`, mu, nu], [X])-Physics:-d_[nu](Physics:-Christoffel[`~alpha`, alpha, mu], [X])+Physics:-Christoffel[`~beta`, mu, nu]*Physics:-Christoffel[`~alpha`, alpha, beta]-Physics:-Christoffel[`~beta`, alpha, mu]*Physics:-Christoffel[`~alpha`, beta, nu]
term1 := SubstituteTensor(Physics:-Christoffel[`~alpha`, mu, nu] = -(1/2)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[nu](l[beta](X), [X])*l[mu](X)+(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[mu](X)+(1/2)*l[beta](X)*Physics:-d_[nu](l[mu](X), [X])*eta[`~alpha`, `~beta`]-(1/2)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[mu](l[beta](X), [X])*l[nu](X)+(1/2)*Physics:-d_[mu](l[`~alpha`](X), [X])*l[nu](X)+(1/2)*l[beta](X)*Physics:-d_[mu](l[nu](X), [X])*eta[`~alpha`, `~beta`]+(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[nu](X)*Physics:-d_[beta](l[mu](X), [X])-(1/2)*l[nu](X)*Physics:-d_[beta](l[mu](X), [X])*eta[`~alpha`, `~beta`]+(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])-(1/2)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])*eta[`~alpha`, `~beta`], Physics:-`*`(Physics:-`*`(d_[alpha](Christoffel[`~alpha`, mu, nu]), l[`~mu`](X)), l[`~nu`](X)))
Physics:-d_[alpha](-(1/2)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[nu](l[beta](X), [X])*l[mu](X)+(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[mu](X)+(1/2)*l[beta](X)*Physics:-d_[nu](l[mu](X), [X])*eta[`~alpha`, `~beta`]-(1/2)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[mu](l[beta](X), [X])*l[nu](X)+(1/2)*Physics:-d_[mu](l[`~alpha`](X), [X])*l[nu](X)+(1/2)*l[beta](X)*Physics:-d_[mu](l[nu](X), [X])*eta[`~alpha`, `~beta`]+(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[nu](X)*Physics:-d_[beta](l[mu](X), [X])-(1/2)*l[nu](X)*Physics:-d_[beta](l[mu](X), [X])*eta[`~alpha`, `~beta`]+(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])-(1/2)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])*eta[`~alpha`, `~beta`], [X])*l[`~mu`](X)*l[`~nu`](X)
expand(Physics:-d_[alpha](-(1/2)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[nu](l[beta](X), [X])*l[mu](X)+(1/2)*Physics:-d_[nu](l[`~alpha`](X), [X])*l[mu](X)+(1/2)*l[beta](X)*Physics:-d_[nu](l[mu](X), [X])*eta[`~alpha`, `~beta`]-(1/2)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[mu](l[beta](X), [X])*l[nu](X)+(1/2)*Physics:-d_[mu](l[`~alpha`](X), [X])*l[nu](X)+(1/2)*l[beta](X)*Physics:-d_[mu](l[nu](X), [X])*eta[`~alpha`, `~beta`]+(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[nu](X)*Physics:-d_[beta](l[mu](X), [X])-(1/2)*l[nu](X)*Physics:-d_[beta](l[mu](X), [X])*eta[`~alpha`, `~beta`]+(1/2)*l[`~alpha`](X)*l[`~beta`](X)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])-(1/2)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])*eta[`~alpha`, `~beta`], [X])*l[`~mu`](X)*l[`~nu`](X))
(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~beta`]*Physics:-d_[alpha](l[beta](X), [X])*Physics:-d_[nu](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~beta`]*l[beta](X)*Physics:-d_[alpha](Physics:-d_[nu](l[mu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~beta`]*Physics:-d_[alpha](l[beta](X), [X])*Physics:-d_[mu](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~beta`]*l[beta](X)*Physics:-d_[alpha](Physics:-d_[mu](l[nu](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~beta`]*Physics:-d_[alpha](Physics:-d_[beta](l[mu](X), [X]), [X])*l[nu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~beta`]*Physics:-d_[beta](l[mu](X), [X])*Physics:-d_[alpha](l[nu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~beta`]*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[beta](l[nu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~beta`]*l[mu](X)*Physics:-d_[alpha](Physics:-d_[beta](l[nu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](Physics:-d_[mu](l[`~alpha`](X), [X]), [X])*l[nu](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~alpha`](X), [X])*Physics:-d_[alpha](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](Physics:-d_[nu](l[`~alpha`](X), [X]), [X])*l[mu](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*Physics:-d_[alpha](l[mu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[alpha](Physics:-d_[nu](l[beta](X), [X]), [X])*l[mu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[nu](l[beta](X), [X])*Physics:-d_[alpha](l[mu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~beta`](X)*Physics:-d_[nu](l[beta](X), [X])*l[mu](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~beta`](X)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[beta](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~beta`](X)*l[mu](X)*Physics:-d_[alpha](Physics:-d_[beta](l[nu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~beta`](X)*l[nu](X)*Physics:-d_[beta](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[nu](X)*Physics:-d_[beta](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[nu](X), [X])*Physics:-d_[beta](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~beta`](X)*l[nu](X)*Physics:-d_[alpha](Physics:-d_[beta](l[mu](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~beta`](X)*Physics:-d_[mu](l[beta](X), [X])*l[nu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*Physics:-d_[mu](l[beta](X), [X])*l[nu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[alpha](Physics:-d_[mu](l[beta](X), [X]), [X])*l[nu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[mu](l[beta](X), [X])*Physics:-d_[alpha](l[nu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*Physics:-d_[nu](l[beta](X), [X])*l[mu](X)
(14)
SubstituteTensor({Physics:-`*`(eta[`~mu`, `~nu`], d_[gamma](l[nu](X))) = d_[gamma](l[`~mu`](X)), Physics:-`*`(eta[`~mu`, `~nu`], l[nu](X)) = l[`~mu`](X), Physics:-`*`(l[`~mu`](X), l[mu](X)) = 0}, (1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~beta`]*Physics:-d_[alpha](l[beta](X), [X])*Physics:-d_[nu](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~beta`]*l[beta](X)*Physics:-d_[alpha](Physics:-d_[nu](l[mu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~beta`]*Physics:-d_[alpha](l[beta](X), [X])*Physics:-d_[mu](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~beta`]*l[beta](X)*Physics:-d_[alpha](Physics:-d_[mu](l[nu](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~beta`]*Physics:-d_[alpha](Physics:-d_[beta](l[mu](X), [X]), [X])*l[nu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~beta`]*Physics:-d_[beta](l[mu](X), [X])*Physics:-d_[alpha](l[nu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~beta`]*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[beta](l[nu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~beta`]*l[mu](X)*Physics:-d_[alpha](Physics:-d_[beta](l[nu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](Physics:-d_[mu](l[`~alpha`](X), [X]), [X])*l[nu](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~alpha`](X), [X])*Physics:-d_[alpha](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](Physics:-d_[nu](l[`~alpha`](X), [X]), [X])*l[mu](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*Physics:-d_[alpha](l[mu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[alpha](Physics:-d_[nu](l[beta](X), [X]), [X])*l[mu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[nu](l[beta](X), [X])*Physics:-d_[alpha](l[mu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~beta`](X)*Physics:-d_[nu](l[beta](X), [X])*l[mu](X)+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~beta`](X)*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[mu](X)*Physics:-d_[beta](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[beta](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~beta`](X)*l[mu](X)*Physics:-d_[alpha](Physics:-d_[beta](l[nu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~beta`](X)*l[nu](X)*Physics:-d_[beta](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*l[nu](X)*Physics:-d_[beta](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[nu](X), [X])*Physics:-d_[beta](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~beta`](X)*l[nu](X)*Physics:-d_[alpha](Physics:-d_[beta](l[mu](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~beta`](X)*Physics:-d_[mu](l[beta](X), [X])*l[nu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*Physics:-d_[mu](l[beta](X), [X])*l[nu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[alpha](Physics:-d_[mu](l[beta](X), [X]), [X])*l[nu](X)-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[mu](l[beta](X), [X])*Physics:-d_[alpha](l[nu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*Physics:-d_[alpha](l[`~beta`](X), [X])*Physics:-d_[nu](l[beta](X), [X])*l[mu](X))
(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~beta`]*l[beta](X)*Physics:-d_[alpha](Physics:-d_[nu](l[mu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~beta`]*l[beta](X)*Physics:-d_[alpha](Physics:-d_[mu](l[nu](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~beta`]*Physics:-d_[beta](l[mu](X), [X])*Physics:-d_[alpha](l[nu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~beta`]*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[beta](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[beta](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[nu](X), [X])*Physics:-d_[beta](l[mu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[mu](l[beta](X), [X])*Physics:-d_[alpha](l[nu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[nu](l[beta](X), [X])*Physics:-d_[alpha](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~alpha`](X), [X])*Physics:-d_[alpha](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*Physics:-d_[alpha](l[mu](X), [X])+(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[nu](X), [X])+(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[mu](X), [X])
(15)
Simplify((1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~beta`]*l[beta](X)*Physics:-d_[alpha](Physics:-d_[nu](l[mu](X), [X]), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~beta`]*l[beta](X)*Physics:-d_[alpha](Physics:-d_[mu](l[nu](X), [X]), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~beta`]*Physics:-d_[beta](l[mu](X), [X])*Physics:-d_[alpha](l[nu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*eta[`~alpha`, `~beta`]*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[beta](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[mu](X), [X])*Physics:-d_[beta](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[alpha](l[nu](X), [X])*Physics:-d_[beta](l[mu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[mu](l[beta](X), [X])*Physics:-d_[alpha](l[nu](X), [X])-(1/2)*l[`~mu`](X)*l[`~nu`](X)*l[`~alpha`](X)*l[`~beta`](X)*Physics:-d_[nu](l[beta](X), [X])*Physics:-d_[alpha](l[mu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[`~alpha`](X), [X])*Physics:-d_[alpha](l[nu](X), [X])+(1/2)*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[`~alpha`](X), [X])*Physics:-d_[alpha](l[mu](X), [X])+(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[mu](l[nu](X), [X])+(1/2)*Physics:-d_[alpha](l[`~alpha`](X), [X])*l[`~mu`](X)*l[`~nu`](X)*Physics:-d_[nu](l[mu](X), [X]))
l[`~lambda`](X)*Physics:-d_[beta](Physics:-d_[lambda](l[mu](X), [X]), [X])*l[alpha](X)*l[`~mu`](X)*eta[`~alpha`, `~beta`]-eta[`~beta`, `~kappa`]*Physics:-d_[beta](l[lambda](X), [X])*Physics:-d_[kappa](l[nu](X), [X])*l[`~lambda`](X)*l[`~nu`](X)+Physics:-d_[alpha](l[`~alpha`](X), [X])*Physics:-d_[kappa](l[nu](X), [X])*l[`~kappa`](X)*l[`~nu`](X)+Physics:-d_[kappa](l[nu](X), [X])*Physics:-d_[mu](l[`~kappa`](X), [X])*l[`~mu`](X)*l[`~nu`](X)
(16)
"SubstituteTensor({l[~mu](X)*l[mu](X)=0,eta[~mu,~nu]*l[nu](X)=l[~mu](X),eta[~mu,~nu]*d_[gamma](l[nu](X))=d_[gamma](l[~mu](X))},l[~lambda](X)*Physics:-d_[beta](Physics:-d_[lambda](l[mu](X),[X]),[X])*l[alpha](X)*l[~mu](X)*eta[~alpha,~beta]-eta[~beta,~kappa]*Physics:-d_[beta](l[lambda](X),[X])*Physics:-d_[kappa](l[nu](X),[X])*l[~lambda](X)*l[~nu](X)+Physics:-d_[alpha](l[~alpha](X),[X])*Physics:-d_[kappa](l[nu](X),[X])*l[~kappa](X)*l[~nu](X)+Physics:-d_[kappa](l[nu](X),[X])*Physics:-d_[mu](l[~kappa](X),[X])*l[~mu](X)*l[~nu](X))"
(17)
The first term should change eta[~alpha,~beta]*l[alpha] -> l[~beta]. I made eta symmetric so the order should not matter. I notice that the command seems to work when the substitution is at the beginning of the term.  Do I need to use the new RepositionRepeatedIndicesAsIn command?
Download Maple_Question_7.7.14.mw
Hi everyone,
I have a question regarding the simplification of an equation. Suppose I have and equation in maple such as (4*y^2 + 8*y + 8*sin(y))/(y^2 +1)=0. Is there a sequence of commands in Maple to simpliy this equation to (1/2)y^2 + y + sin(y)=0?
I know mulitplying the entire original equation by (1/8)*(y^2+1) would achieve the objective, but the equations I am generating are much longer and more complicated. The example above was chosen just to illustrate the goal.
Best,
Justin
Hello Maple-Primers!
I am trying to evaluate a system at many different points.  I would like to include an interpolation function in this system, but have thusfar been unsuccessful.
Usually, I solve a system symbolically by using eliminate and unapply:
eq[1] := A = M^3;
eq[2] := C = A*2;
eq[3] := D = N+3;
eq[4] := B = piecewise(A = 0, 0,C);
eq[5] := E = B*D;
elimsol:=eliminate(convert(eq,list),[A,B,C,D,E])[1];
unappsol:=unapply(elimsol,[N,M]);
unappsol(1,2);
{A = 8, B = 16, C = 16, D = 4, E = 64} <--- great!
Now, I want to include an interpolation function in the system of equations.  They look like this (see worksheet for actual interpolation function):
B_interp := (W,T) -> CurveFitting:-ArrayInterpolation([FC_Map_W,FC_Map_T],FC_Map,Array(1 .. 1, 1 .. 1, 1 .. 2, [[[W, T]]]),method=linear);
eq[5] := E = B_interp(N,M);
Error, (in CurveFitting:-ArrayInterpolation) invalid input: coordinates of xvalues must be of type numeric <-- bad!
Anyone have any ideas?  I've tried to use polynomials, but I can't seem to get a fit close enough for my purposes.
Maple_2D_Interpolate_FC.mw
A (probably) stupid question that is driving me crazy: how can I expand in Taylor series the following potential function
f(r_):=Int(Int(Int(G(r_-r0_)-(x_-r0_)*rho(r_))))?
essentially the Green representation formula for a harmonic function f in the whole 3d space.
Thanks in advance!
solve([x + 3*y + 5*z = 0,
7*x + 9*y + 11*z = 0,
13*x + 15*y + 17*z = 0],[x,y]);
Hi guys,
I'm trying to find the solutions to a nonlinear equation system:
mysol := solve({J*a = m*g*l*st-m*l*(c*cp*st+d*sp*st), cx*ux = cMx*xd+(Mx+m)*c+m*l*(-cp*pd^2*st-cp*st*td^2-2*ct*pd*sp*td+a*cp*ct-b*sp*st), cy*uy = cMy*yd+(My+m)*d+m*l*(2*cp*ct*pd*td-pd^2*sp*st-sp*st*td^2+a*ct*sp+b*cp*st), (-M*l^2*st^2+J)*b = m*l*sqrt(d^2-2*d*ct+ct^2+c^2*ct^2+(c^2*sp^2-2*c*cp*d*sp+cp^2*d^2)*st^2)}, {a, b, c, d})
The solution contains various implicit solutions with RootOf's. When trying to evaluate them by typing
allvalues(mysol);,
the returned set of solutions is about 800.000 characters long, but unfortunately contains various "+ [...15295 terms...] +" elements, and thus not displaying the full solution. The limits on the precision tab in the maple options are all disabled.
Does anybody know how to display the full expression, although it gets very long?
Thank you in advance,
Martin
Hi everyone,
I'm running Maple 18 and MapleSim 6.4 on my macbook pro 13 " with retina display and the GUI is blurred like there is no smoothing or the antialiasing is not working properly. I tried to find something helpfull in the setting but with no luck.
Is there something I can do to fix this?
Carlo
First 1447 1448 1449 1450 1451 1452 1453 Last Page 1449 of 2471
