Does anybody know how to configure the model to obtain the position constraint equations of a slider-crank mechanism as:
l1·cos(theta)+l2·sin(beta)-s = 0
l1·sin(theta)-l2·cos(beta) = 0
instead as obtained in the help-example on:
http://www.maplesoft.com/support/help/MapleSim/view.aspx?path=MapleSim/Multibody/Kinematic_Exports
Hello everyone
I'm a new maple user, so I'm really sorry if this question is dumb, I've tried to find people with a similar problem but didn't find anyone.
So this is my problem: when I try to multiply a vector with a variable it gives me this:
> Restart; With(LinearAlgebra);
> B1 := [1, 2, 0, -1];
[1, 2, 0, -1]
> B2 := [0, 1, -1, 0];
[0, 1, -1, 0]
> A1 := a*B1+b*B2;
Hello everbody! Please, I need your help again.
B(ν)=2hν3/(c2 *(exp(hν/kT)-1);
h=6.63*10-34;
c=3*108;
k=1.38*10-23;
ν=0,001..10 if T=3000;
ν=10..10000 if T=3000;
plot(B(ν),ν);
How can I get this expression, ln(1+y2/(x-1)2)+2ln(x-1) , to simplify to ln((x-1)2+y2) ?  I would think Maple should be able to do that.  Thanks, Ratch
I have a system of three non-linear coupled ODEs. I am trying to obtain the zeroth order, first order and second order equations and their boundary conditions using the perturbation technique. I then need to solve them. I wrote the following MAPLE lines for the purpose.
restart; N := 2
Eq[1] := diff(f(eta), `$`(eta, 3))+(m+4)*f(eta)*(diff(f(eta), `$`(eta, 2)))-(2*(m+1))*(diff(f(eta), eta))^2-(2*(m+1))*h(eta)-(.5*(m-2))*eta*(diff(h(eta), eta))
Eq[2] := g(eta)-(diff(h(eta), eta))
I would like to perform some operations on all the entries of an array (or an all entries in some given rows/columns).
Can this be achieved without writing an ad hoc loop?
(for instance this task is extremely easy in octave/matlab)
Should I use some specific package?
What's the best (or even A way) to numerically solve a system of first order ODE's and output the result to a functional form that could be used later. My first impression was to try to do a curvefit of some sort.
Does any body know how one could calculate such an integration:
Int(expression, 1/x)
Thank You!
powermetal114
try_IG.mw
The following codes is a part of my program for computing ING at several points of r between -1 and 1 (by a step of for example 0.1 or even smaller for a better pointplot of ING(r) ):
H:=(r, teta) -> h(r, zn, teta) # h is a complicated function of (r, z, teta) (referred to the attached maple file) and   zn is a given number
F:= r -> int(H(r, teta), teta= 0…alpha)
Im asked on one of my problem sheets to write a procedure to inverse a square matrix using LU factorization and using partial pivoting. I can do all of these using simple pen and paper but am struggling towrite the procedure, especially to involve the partial pivoting and to then solve the linear system. Any ideas how I can do this question?
I have data which I want to give a simpler and a smaller interpolation function. Not necessary with Cubicspline as in the code attached (polynomial, exponential, etc..).
interpolation.mw
have a list of lists, and I would like to write each of these lists on a separate file, *on a single line*.
For instance consider the following trivial example:
P := [[-.3819660120, .6180339880, -10000, -2], [.6180339880, 1.618033988, -10000, -1], [1.618033988, 10000, -10000, -.5], [2.618033988, 10000, -.5, -0.1e-3], [2.618033988, 10000, 0.1e-3, .5]]
I would like to create
 + a file named  P1.dat containing the line
I have two equations. I need the value of beta2. Can any body help me? I am getting error message like "Warning, solutions may have been lost". Any co-operations will be appreciable.
Nurul ISLAM
nislamce@yahoo.com
Hi everyone.
I have a problem with Maple 15. I have an equation, but when i write in into Maple, it says: "Warning, solutions may have been found". I don't know what to do. I've tried to solve it on paper, but without any luck. Could someone please help me?
Equation: ((x+1)2/3) - ((x+2)(x-2)/2) = ((x+3)/2) - ((x-2)2)/6)
or when i copy paste from Maple...
(1/3)*(x+1)^2-(1/2)*(x+2)(x-2) = (x+3)*(1/2)-(1/6)*(x-2)^2
I've got a small problem:
how can i calculate with units AND show variables and its untits on both axles of a plot in the same worksheet?
and is there a way to give the range for each axle at the same time too?
This one only works for one axle:
with(Units);
d := 40*Unit(m);
a := .25*Unit(m/s^2);
x := d+(1/2)*a*(t*Unit('s'))^2;
plot(x, t = -10*Unit(s) ..10*Unit(s),useunits);
has anyone any ideas how to show "x[m...
First 1822 1823 1824 1825 1826 1827 1828 Last Page 1824 of 2471
