I downloaded the Modelica_Fluid 1.0 Library from the Modelica website. When I try to import this library into MapleSim5 I get the following error:
Duplicate class definition found for Modelica_Fluid.Pipes.BaseClasses.WallFriction.Detailed.msim/UNKNOWN
I then click "ok" and the importing stops working with the last message being:
Querying Modelica classes...
Can anybody offer help with this?
Christian
Consider a "toy system" of floating-point arithmetic where each floating-point numberis of the form
x = (-1)s × (1 + m) × 2e-σ:
The mantissa is a binary number such that
m = 0:m1m2m3 (base 2) belongs to [0; 1)
and the exponent e is a binary integer such that
1 ≤ e = e3e2e1e0 (base 2) ≤ 14:
Each m
I have a solution containing many exponentail terms, some of which are in the denominators of rational terms. I would like to be able to have the solution given to me in a manner where there are no exponentials in denominators but only in the numerators. The simplify command in maple does it, however for the shear number of terms (just shy of 400,000 terms and maple saying it's million plus) i am looking at, that particular command is just taking too long (15 hours!). Is there...
Is there any  function  in maple to compute the SVD of a matrix  using jacobi method? Or anybody has maple code to do so?
b) Define a procedure f(x, y) which returns 1 if x < y and 1 if
Hi friends,
I am running an application which consumes big memory and the result was given smoothly
but after 5 hours I running the program again but in the middle of calculation the maple give message show  I got this error:
Execution stopped: Memory allocation failed! Please see
I am currently writing a Python program which takes a Maple Worksheet and evaluate the commands in the terminal version of Maple. However, I have trouble figuring out how the input is formatted. As an example I have following XML code in a .mw file:
<Input><Text-field prompt="&gt; " style="Maple Input" layout="Normal">
<Equation executable="true" style="2D Input" input-equation="A := 4;"
display="LUklbXJvd0c2Iy9JK21vZHVsZW5hbWVHNiJJLFR5cGVzZXR0aW5n\
Dear guys!
I want to solve this system:
> c := 1: RC := 0.03: h := 1: m := 0.3:
> a := H(z)^2/(1+z)-h^2*(m*(1+z)^2+2*RC/(1+z));
> ode1 := diff(H(z),z) = (H(z)^4/((1+z)^2)+m*(1+z)*h^2*H(z)^2-2*m^2*h^4*(1+z)^4)/(2*H(z)*a) - (2*H(z)*h^2*RC)/(a*(1+z)^2) + (2*RC*h^2*(1+z)/(c*H(z)^2*a))*(H(z)^2/(1+z)^2-(H(z)^2/(1+z)-m*h^2*(1+z)^2)^2/(4*RC*h^2))^(3/2):
> ode2 := diff(M(z),z)=3*M(z)/(1+z)-2*M(z)*diff(H(z),z)/H(z):
> sys := {ode1, ode2}:
Dear all! I have 2 different lists:
ch1 := [[0.1e-1, -.56], [0.25e-1, -.57], [0.35e-1, -.555], [.115, -.43], [.16, -.3], [.195, -.24], [.28, -.155], [.315, -0.25e-1], [.32, -0.85e-1], [.41, .19], [.425, .11], [.425, .425], [.425, .43], [.425, .44], [.43, .12], [.43, .265], [.43, .405], [.43, .445], [.435, .295], [.435, .38], [.465, .44], [.5, .29], [.505, .31], [.505, .395], [.51, .37]];
ch2 := [[0.3e-1, -.5], [0.5e-1, .575], [.11, .495], [.15, -.295], [.19, -.33...
I want to plot the data with some error bars. I have tried the errorbar( ) function but it doesn't work. May I know what is the problem ?
I have a quick question. I'm using OpenMaple under C and I am calling the "latex" function. I cannot get its output :( When checking the textCallback function, I get the command back as output (latex(%)). How could I solve this issue?
Remus.
hello
I need help, I have two arrays a{1,6,0,-9,13,15} and b{6,-3,10,16,6,1}. How create program, which would bring the two sorted arrays of elements of the rising and descending?
I don't know why maple can't solve this PDE
> restart;
> PDE := 4.2000*10^6*(diff(u[1](x, t), t))-.445*(diff(u[1](x, t), x, x))+4200.*u[1](x, t)+464.82-20836.*x-15.832*t+4.0442*10^5*x^2+2953.7*x*t+0.14631e-1*t^2+9.6788*10^6*x^3-2.7139*10^5*x^2*t-.99786*x*t^2+0.15902e-4*t^3-1.0085*10^9*x^4-6.3082*10^6*x^3*t-1069.3*x^2*t^2-0.15006e-1*x*t^3-3.9073*10^(-8)*t^4+2.3478*10^10*x^5+2.5874*10^8*x^4*t+1.2265*10^5*x^3*t^2+2.9028*x^2*t^3+0.17521e-4*x*t^4+1.9407*10^(-11...
I've been trying to find a way to plot error bars in a polar coordinate system. Using ErrorPlot i can display my data with error bars in cartesian coordinates but the usual option 'coords=polar' doesn't seem to be followed. Perversely, the option 'axiscoordinates=polar' does work in ErrorPlot, so i just get a cartesian plot of my data sitting on top of a polar axis. Is there a way to plot my data with errors in a polar basis?
I have had this problem on all of my computers ever since Maple 11, I believe. No matter the number of points in a spacecurve or DEplot3d command, the graph comes out with gaps. For example, this is the output from Maple 14:
First 1837 1838 1839 1840 1841 1842 1843 Last Page 1839 of 2464
