Dear Kamel Boughrara
I am grateful for your attention to my problem.
I have not the special boundary condition for phi[2](r,theta) and phi[4](r,theta) at this stage of process of solution. In fact, these functions are auxiliary functions to decouple high-coupled another PDEs.
 You tried to explain the stages of solution.  I ask for you to perform (write all requisite commands...
by trying to solve the following system of equations:
sys := {V[0]*(diff(P[0](t), t))/(k[B]*T0) = -z*C*A[1]*P[0](t)*(P[1](t)/P[0](t))^(1/gamma)*sqrt(2*gamma*(1-(P[1](t)/P[0](t))^((gamma-1)/gamma))/((gamma-1)*k[B]*T0*m0)), V[1]*(diff(P[1](t), t))/(k[B]*mu[T][1](t)) = z*C*A[1]*P[0](t)*(P[1](t)/P[0](t))^(1/gamma)*sqrt(2*gamma*(1-(P[1](t)/P[0](t))^((gamma-1)/gamma))/((gamma-1)*k[B]*T0*m0))-C*A[2]*P[1](t)*(P[2](t)/P[1](t))^(1/gamma)*sqrt(2*gamma*(1-(P[2](t)/P[1](t))^((gamma-1)/gamma))/((gamma-1)*k[B...
I am trying to calculate something but my computer(dual-core with 4GB memory) is too slow/old for it.
just copy and paste these into a new blank Worksheet Mode document and Edit->Execute->Worksheet and then post your result here. Thanks in advance!!!
G := [a[1]*(y[0]^2)-y[1]^2*a[1]-a[1]*(y[3]^2)+2*a[2]*y[0]*y[3]-2*a[3]*y[0]*y[2]-a[1]*(y[2]^2)+b[1]*y[0]+3*y[1]*(y[0]^2)+y[1]*b[0]-y[1]^3-y[1]*(y[2]^2)-y[1]*(y[3]^2)+c[1]+b[2]*y[3]-b[3]*y[2], -2*a[1...
Hey, I've been trying to calculate the mean from a set of measurements I took in an experiment. The measurements are (76.0,75.9,76.1,75.9,76.0,76.1,76.1,76.0,75.9,76.0,76.0,75.9,75.9,75.9,76.0,75.8,76.0,76.0,75.9,75.9,75.9,75.9,75.9,75.9,75.9,76.0,75.9,76.0,76.0,76.0), and I always do
y1:=(all of the measurements I just listed);
then I try to do the mean of y1
Mean(y1);
but everytime I try this an error comes up.
Error, (in Statistics:-Mean...
Dear my friends
I have a linear partial differential equation to solve.
> equ1:=F5*(diff(phi[2](r, theta), r, r)+(diff(phi[2](r, theta), r))/r+(diff(phi[2](r, theta), theta, theta))/r^2)+F3*phi[4](r,theta) = 0;
where F5 and F3 is constant and phi[2](r,theta) is unknown function.
I tried to solve this equation by the following Maple's command:
> pdsolve(equ1,phi[2](r,theta));
When I type
cos(x), sin(x)
and start the Plot Builder (using the contextual menu) the first option it gives me is for a 2-D plot.  However, when I type
cos(x), x
and start the Plot Builder the first option is a 2-D polar plot and the "standard" 2-D plot is nowhere on the list.  Is this a known bug?  (I'm using Maple 15.01 on Windows 7.)
We have the following sequence of natural numbers 1, 4, 9, 13, 11, 27, 25, 37,.. . What is the next term?
Is it possible to find it with Maple? The approach
> with(gfun):
>l:=[1, 4, 9, 13, 11, 27]:
>rec:=listtorec(l,u(n));
fails because it produces a noninteger value of u(n) for some natural values of n.
Hello all,
I'm familiar with using _ and ^ to enter subscripts and superscripts in document mode. However, the only way I know of moving out of those modes is to use the arrow keys. I was wondering if there was an alternative shortcut that wouldn't require me to move my hands from the home row?
Amr
EDIT: I have figured it out (somewhat), so nevermind!
I wrote this in my AddSystem:
However for output that should be unitless, I still get units (which can be cancelled), like this:
hi
i want to export figures in maple to word. in other software like Tecplot when we use WMF format, the figures saves like a vector and when magnifiyng picture , quality remains good. but in maple when i export figure as WindowsMetaFile the quality of figure decrase and decrases with magnifing. i want to know how i export figures in maple to keep quality high. thancks
In my Maple program results are exported to a file. But the problem is that I should write a path every time manually that complicates a work. Moreover, I often forget to change a path and correspondingly new results would often rewrite previous results stored in other directory. The reason is that the path of stored results folder have to be the same as the path of Maple code run.
How can to do it automatically? How to make that Maple knows a path from where Maple...
Hello. I'm studying engenieering mathematics at DTU and I just started working with Maple. When I tried to open my work in progress I got the following message: "
There were problems during the loading process. Your worksheet may be incomplete".
Some of my colleges are experiencing the same problem...
opgave_1a.mw
I am trying to solve a differential equations with the periodic coefficients, which have the following form:
where
In the attached workbook I define a function that contains an if. This seems to confuse the plot function when I try to plot my function. How do I plot this function?
PlotFunctionWithI.mw
Is it possible to a plot,  shown in worksheet, insert vertical lines using the Builder plot ?
GRACIAS
First 1858 1859 1860 1861 1862 1863 1864 Last Page 1860 of 2464
