Hello.i want animate the circle of radius 2 on the parabola y=x^2-30*x in the interval [-1,2].I wrote like that =animate(plot,[[-30*t+2cos(Phi),t^2+2sin(Phi)],Phi=0..2*Pi],t=-2..1) .But it doesn't work.What is wrong?
How do I slection input and output in a Maple procedure?
first off, I don't think this is a normal "how do you rescale a graph" question - I'm aware that there are plenty of those around, but none seems to answer my question.
I essentially want to change the x-axis of a graph by a factor, rather than just changing the plotting range or tick-marks. For example, I have a function, f(x), and it's derivative (with respect to x) f'(x). I can plot f'(x) for x=1....60 easily for example, but I also want to plot f'(x...
This is something simple but I cannot find the answer
Typing in
a:=5;
gives the maple output
                                      a:=5
I have changed a setting somewhere so that Maple doesn't show the assignment
When I type
a:=5;
Maple returns just
Hi there,
I am plotting flow diagrams of a 2-dimensional system of autonomous 1st order ODEs x'=f(x). I have some free parameters in there, and am analyzing how the flow changes qualitatively when varying these.
To visualise my results I want to do some animations. The Explore command doesn't seem to like the DEplot command, or I am doing something wrong. So I use the animate command, which works fine, although I can only vary a single parameter with it.
Dear Maple-experts,
is there a function which returns the linear parts of an ODE?
So for example for the ODE:
ODE:= diff(x(t),t) + 3*x(t) + diff(x(t),t)*x(t)
which gives
diff(x(t),t) + 3*x(t).
My ODE is so large, that this cannot be done by hand.
Thank you very much,
Peter
I want to calculate  an eigenvector of a jacobian matrix J with fixed parameters from the solution of some equations, but the following code does not work. When I use the command in the last 3rd line, it works well.
But I want Maple to calculate J automatically, what shall I do?
with(linalg);
F[1] := A-(B+1)*X[1]+X[1]^2*X[2];
F[2] := B*X[1]-X[1]^2*X[2];
J := jacobian([F[1], F[2]], [X[1], X[2]]);
sol := solve({F[1] = 0, F[2...
Hi, I am currently trying to draw a standard airfoil NACA 4412 (http://en.wikipedia.org/wiki/NACA_airfoil). I've put all the equations and defined the parameters.
I don't know what is the problem, probably many Float undefined errors... According to me, it should be simple, but somehow I can't get it right. Any suggestions?
Here is the file :
Substituting Periodic Fourier series expansion equation with standing wave equation
Maple formatting cuts off some of the information/question
I've included a link to an image of the full question
http://dl.dropbox.com/u/6576402/questions/sub_per_fou_series_expansion.jpg
and as text file
I would like to know how to program this equation in MAPLE to iterate and derive my results (values of "h") in the form of plots....
I would like someone to take a look at my equation and tell me if its solvable...coz am not able to graduate!!!! :(
Hi there,
Often an expression has more than one output, for example, when simply more solutions exist: sol1, sol2, ...
Then I would get the second solution by %[2]. So far so good.
Anyway sometimes the output is splited in cases, with the { notation. How do I read out a specific case of such a solution?
thx :)
Error, (in LinearAlgebra:-LA_Main:-MatrixInverse) singular matrix
what does this mean?
I have 2 equations that are made up of various powers of 2 different variables. Is there any command to retain only terms of the first order? E.g. no "x^2", "x^{3/2}", etc, just "x"s.
He guys!
I had Maple 11 installed on my Mac, and yesterday upgraded to Maple 15, which was installed in a separate folder. My question is if I now can uninstall Maple 11 from my computer, or will Maple 15 need the files, since it was an upgrade, and no full version?
If I can uninstall it: How do I do it properly? I'm on a Mac with OS X 10.6. Maple 11 is installed in a separate folder in the applications folder. There is no uninstall file however. Is just dragging...
I have just upgraded from Maple 12 to Maple 14.  I opened an old file (Maple 12 format) and when I tried to use display to replot the data - there were capital letters where the fit line should be and the axes were also strange.  Is anyone else having this problem and what should I do about it.  Below is a copy of my info:
[animate, animate3d, animatecurve, arrow, changecoords,
complexplot, complexplot3d, conformal, conformal3d,
First 1898 1899 1900 1901 1902 1903 1904 Last Page 1900 of 2460
