I'm using the following function for my project,:
printlevel:=2:for Prc from 2 by 1 to 100 do for B from 2 by 0.5 to 100 do (mf(Prc,B)):=(f(Prc))*(m(Prc,B)) end do end do
Is there any way to be able to sort the answers in ascending order? I tried to use sort, but when I put sort(mf(Prc,B)) it gives me a wrong answer and jumps into Prc=101 and B=20.5.
Also is there any way to put a condition for show only real numbers, without complex numbers?
upload2.mw Dear guys!
Pleaes visit the attached file and tell me what should I do. Thanks a lot.
Hi there,
I'm doing a lot of computations with Maple right now (currently the ancient 10 and 12 versions but maybe soon 14).
I would like to do Unit-Tests of my Software as known for instance in JUnit with Java. Is it possible or do I have to use the ASSERT(...) - statements?
Dear Friends:
My original equation is
solve({(1-3*q2)*(1+lamda) = 0, r1*q1-2*r2*XA*(1+lamda) = 0, (1-2*q2)*q2-r2*XA^2 = 0, 1-3*q1+r1*XA = 0}, {XA, q1, q2, lamda})
The answer is
{XA = -1/r1, q1 = 0, q2 = RootOf(r2-r1*_Z+2*_Z^2)/r1, lamda = -1}, {XA = RootOf(-1+9*r2*_Z^2), q1 = 1/3+(1/3)*r1*RootOf(-1+9*r2*_Z^2), q2 = 1/3, lamda = (1/6)*(9*r2*r1*RootOf(-1+9*r2*_Z^2)+r1^2-6*r2)/r2}
Two questions:
1. Actually I want...
let x , y in R , say for example
x=0.1243134710481
y=0.1243234710571
Then we can compare the digits where x and y agree and where they differ.
In the example , x and y agree on the first 4 digits , differ on the next digit, agree of the next 5 digits , differ on the next two digits, and agree on the last digit.
Q: Write a procedure compdigits in maple that given two decimal numbers returns a list stating the number of digits they are...
bestfit1-loop.mw, sn_union2.txt
I've written a program, but it shows an error related to maxfun limit when I run it. Can anyone tell me what the problem is? and how can I solve it? The program and the data file are attached.
Thanks a lot.
Hello all,
This is my first time posting here; I usually find answers to all my questions by searching patiently but I was unsuccessful with this particular issue.
I attend an introduction Maple class and i'm building an animated bike as project. I was already rather comfortable with Maple so i'm trying to show off a little by adding lots of cheesy details to the scene, even if unnecessary. However, some objects such as the sky, which i would like to...
I have this function:
I2:=g->(200*g)/sqrt(0.04+g^2);
plot(I2(g),g=0..1);
plot(I2(g),g=1..0);
Those two plots give the same result.
Is it possible to invert the x axes to start from 1 ?
I also tried this below, but the result is as above.
x:=seq([g,I2(g)],g=1..0,-0.02);
pointplot([x],style=line);
                     gama2 q2 - 2 gama1 XA=0
                    [-1] q1 + [1 - 2 q1] - C=0
              [-1] q2 + [1 - 2 q2] - C + gama2 XA=0
Hello everybody,
I have this equation J:
> J := Matrix(2, 6, [[j41, j42, j43, j44, j45, j46], [j51, j52, j53, j54, j55, j56]]);
it's a 2 times 6 matrix made with the results of other equation, each one of those small j's are long analytical terms.
Later I want to generate a Matlab code of J using this:
> Matlab(J, resultname = "j4", output = "file.m", optimize);
I use the optimize code at the end because then I avoid getting...
Is there any way to use the final answer obtained on a previous section/subsection and use it on a different section/subsection on the same file?
Thanks, Jose
Hey all,
 I have created a nested while loop to investigate the Riemann zeta function:
for q to 10 do
 m := 10^(-q);
  for s from 2 to 10 do
   n := 1;
   b := 1;
    while b >= m do
     b := evalf(abs(Zeta(s)-euclid(s, n)));
     n := n+1
  print(m, s, n-1)
 end do
end do
it...
Is there any easy way to browse 3D matrices within maple, other than storing matrices in an array?
How to find the shortest distance between  two points on a cube with Maple? The related twodimensional problem was considered in MaplePrimes, but the thread  seems to be lost. Here are the results of the "shortest distance" search in MP. The results of "shortest distance between two points on a cube" googling do not encourage too.
There was a recent exchange I was a part of on Maple classic versus standard, etc. It disappeared from the list of "recent discussions" so I tried to track it by other means. A keyword search did not immediately return a helpful link, so I thought I would click on my profile and look for my recent comments from the lists there. But I could only find a list of "questions," "answers" and "posts". My contribution there was merely a "comment" and I can't seem to find any list about those...
First 1905 1906 1907 1908 1909 1910 1911 Last Page 1907 of 2460
