The last question im going to be asking for a while.
Im trying to find a function which in the form of a spiral crosses the x-axis at 45 degrees. Now i can only think of one function that fufills this, that would be the tan function since at Pi/4 it would give me 1 fulfulling my question. But making a function which fufills it not so easy, i know i have to use the polar differentiation but im having trouble inputting it into maple
Any help?
Why isn't DEplot working when my syntax is correct? The equation will plot in one worksheet but not in another?
I tried to install a trial version of Maple on a notebook. After the selft extraction of the installer the rest of the proces is stopped without error messages. The notebook is a modern multi-proc.64-bit  Win 7 correspondent to the software version I tried to install. The question is what to do to solve the problem.
I would like someone to help me with this issue I have.
First after some operation I found the following equation:
> m := (x(q))^2 + x(q)
and then I'm creation a function like this:
> eq := q -> m
but then maple is not substituting the equation m inside the function I created, how can I do that, I must work with functions this way and I'll be working with bigger equations but I don't want to copy/paste or type them into the function.
How do you find the intersection of 2 subspaces of R4
v1= [x(1,2,3,4)+y(0,2,3,2)]
v2= [x(3,2,1,1)+y(3,1,1,3)+z(6,4,2,2)
I need to:
a) Find the equation of the sphere passing through the 4 points [- 8, 3, 11], [5, - 7, 1], [- 15, 4, - 6], [10, 2, 9].  Give the coordinates of its center and its radius.
b) Plot together the sphere of part a along with the 4 points of the dataset.
I can't seem to get maple to do this!  I am very frustrated as the sphere command doesn't even seem to work.  I am a total maple n00b...
Download 321.mw
There is a problem which I feeling very puzzling, it is not the codes, but about when running the codes. It seems that if I running the codes immediately (or use "run all the worksheet" ), an error returned unexpectedly, but if I wait a few seconds before rerunning the code which just causes the error, a correct result returned. I feel very...
When I am trying to write the data of the following program in a datafile
with(plots)
eq := (diff(G(eta), `$`(eta, 2)))/Pr-2*n*b*eta*G(eta)+(a+(1/2)*b*eta*eta)*(diff(G(eta), eta))
> A := {x=0, y=0}:
> B := {x=0, -y=0};
> {A} union {B};
{{x=0, y=0},{x=0, -y=0}}
How to get Maple to realise that A and B are actually the same so that "{A} union {B}" would return "{{x=0, y=0}}" instead of above?
How to join expressions in the set, for example to convert the set {y=0, x>-1, x<1} to {y=0, -1< x <1}?
Thank you in advance.
when drawing a geometry.line object by using geometry.draw, the default for each axis is -10..10, so that I cannot see in the plot, for example, the line y=11;
How can I extend this range?
Best regards
Ouba
I want to plot a bunch of straight lines with positive slope in one colour, and I want to plot a single line of negative slope in another colour.
I hope my code is self-explanatory:
restart; with (plots):
myEqns:=NULL:
for i from 1 to 5 do;
 myEqns:=myEqns,y-x=i;
myEqns:=[myEqns];
 [y - x = 1, y - x = 2, y - x = 3, y - x = 4, y - x = 5]
implicitplot([op(myEqns), y+x=0], x=-10..10, y=-10..10, colour=[red,blue]);
I am a beginner at Maple. A friend of me has told that Maple can solve analytical solutions.
In other words, I want to combine three equations ( a linear system)  in order to conclude to the final solution.
Has Maple the ability to solve analytically a linear system of 2 or more equations?
Thank you very much in advance.
Kind Regards
Thanos
I'm trying to have Maple work through ideas involving the Fundamental Theorem of Calculus, and am encountering a problem with the programming of Maple.
I begin by defining a function like:
F(x) := int(x^2,x)  (or equivalently, F:= x -> int(x^2,x)  )
Then I ask Maple to evaluate F(2).  I expect to get 8/3 but instead I get this error message:
Error, (in int) integration range or variable must be specified in the second argument, got 2
First 1907 1908 1909 1910 1911 1912 1913 Last Page 1909 of 2460
