I was trying to assign a Vector to a Vector inside a procedure. However, when the Vector has a size of 5, I was able to do that. But not when the Vector has a size of 7.
I have the following example. I can't assign the Vector over when the Vector has a size of 7 as shown in oneStep_egcd2.  But I can do that when the size is 5 in oneStep_egcd. Copying the contents over using a for loop works as expected.
a:= 17; b:= 5;
17
5
# <s, a, t, b, g>
prev := <1, a, 0, b, a>;
Vector(5, {(1) = 1, (2) = 17, (3) = 0, (4) = 5, (5) = 17})
curr := <0, a, 1, b, b>;
Vector(5, {(1) = 0, (2) = 17, (3) = 1, (4) = 5, (5) = 5})
oneStep_egcd := proc(prev::Vector, curr::Vector)
    local q, t1, t2, t3;
    if (curr[5] <> 0) then
        q := iquo(prev[5], curr[5]);
        t1, t2, t3 := prev[1] - curr[1] * q, prev[3] - curr[3] * q, prev[5] - curr[5] * q;
        prev = curr;
        curr[1], curr[3], curr[5] := t1, t2, t3;
    end if:
oneStep_egcd(prev, curr)
1, -3, 2
# <s, expr_s, a, t, expr_t, b, g>
prev := <1, 1, a, 0, 0, b, a>;
Vector(7, {(1) = 1, (2) = 1, (3) = 17, (4) = 0, (5) = 0, (6) = 5, (7) = 17})
curr := <0, 0, a, 1, 1, b, b>;
Vector(7, {(1) = 0, (2) = 0, (3) = 17, (4) = 1, (5) = 1, (6) = 5, (7) = 5})
oneStep_egcd2 := proc(prev::Vector, curr::Vector)
    local q, sb_q, t1, t2, t4, t5, t7;
    if (curr[7] <> 0) then
        q := iquo(prev[7], curr[7]);
        sb_q := (q);
        t1 := prev[1] - curr[1] * q;
        t2 := prev[2] - curr[2] * q;
        t4 := prev[4] - curr[4] * q;
        t5 := prev[5] - curr[5] * q;
        t7 := prev[7] - curr[7] * q;
        prev := curr;
        curr[1], curr[2], curr[4], curr[5], curr[7] := t1, t2, t4, t5, t7;
    end if:
oneStep_egcd2(prev, curr)
Error, (in oneStep_egcd2) invalid left hand side in assignment
oneStep_egcd3 := proc(prev::Vector, curr::Vector)
    local q, sb_q, t1, t2, t4, t5, t7, i;
        sb_q := (q);
        for i to 7 do
            prev[i] := curr[i];
    end if:
oneStep_egcd3(prev, curr)
1, 1, -3, -3, 2
Download ErrorExample.mw
I want to write a program to get unknown coefficients of multiple polynomials. I have a problem with this program. The code sometimes doesn't work. Can anyone help me? It's very important to me.
with(student)
EQ[0] := tanh(d)*b[1]*(b[1]+1)
EQ[1] := -(-1+(a[1]-b[1]-1)*tanh(d)^2+(a[0]+1)*tanh(d))*b[1]
EQ[2] := tanh(d)*((a[1]-b[1])*(a[0]+1)*tanh(d)-b[1]^2-a[1])
EQ[3] := (-a[1]^2+(2*b[1]-1)*a[1]-b[1]^2-b[1])*tanh(d)^2+(a[1]+b[1])*(a[0]+1)*tanh(d)-a[1]-b[1]
EQ[4] := -tanh(d)*((a[1]-b[1])*(a[0]+1)*tanh(d)+a[1]^2+b[1])
EQ[5] := -a[1]*(-1+(-a[1]+b[1]-1)*tanh(d)^2+(a[0]+1)*tanh(d))
EQ[6] := (a[1]+1)*a[1]*tanh(d)
Eqs := {seq(EQ[i], i = 0 .. 6)}
Sol := solve(Eqs, {a[0], a[1], b[1]})NULL
{a[0] = a[0], a[1] = 0, b[1] = 0}, {a[0] = (tanh(d)^2-tanh(d)+1)/tanh(d), a[1] = -1, b[1] = -1}, {a[0] = -(tanh(d)-1)/tanh(d), a[1] = -1, b[1] = 0}, {a[0] = -(tanh(d)-1)/tanh(d), a[1] = 0, b[1] = -1}
for i from 2 to 4 do Case[i] := allvalues(Sol[i]) end do
T1.mw
T2.mw
My Maple-Program is creating svg-files (or PNG) in a squared format.
There are a lot of these files in a local folder.
I would like to add a white surrounding frame (10% of the Imagesize) to it and afterwards store it as a TIFF file.
Studying ImageTools I have not found a way to solve this with ImageTools.
Until now I am using a graphic software to add a frame and store as TIFF in a desired resolution.
Now I plan to do this process automatically with maple.
Thanks for support :)
I found this option mentioned in help(MapleSim,Multibody,Dynamic_Exports).
For the example of the help page I tried
SliderCrank:-GetDynEQs(AugType = Reaction);
SliderCrank:-GetDynEQs(AugType = Lagrange);
but the output is the same (which I would expect since GetDynEQs is not defined with parameters).
In the help system I only find deprecated commands that use this option
How can this option be set in newer versions of MapleSim without using deprecated commands?
For the following Equation:
Equation := int(diff(u(x), x)*v(x), x) = int(u(x)^(1/2)*v(x), x)^(-2/3);
Maplesoft finds the following solution:
Solution1:=3/4*u(x)^(4/3) + 2/3*u(x)^(5/6)*Intat(1/(sqrt(u(x))*Int(v(_b), _b))^(5/3), _b = x) + _C1 = 0
or , which I believe as an alternative, can be written as
Solution2:=3/4*u(x)^(4/3) + 2/3*u(x)^(5/6)*Int(1/(sqrt(u(x))*Int(v(x),x))^(5/3) +_C1=0
My question is how did Maple arrive at 'Solution1' from 'Equation'? In other words, can someone fill
in the steps between 'Equation'  and 'Solution1'? Or even, prove that Solution 1 is a valid solution to Equation.
Plugging the Solution1 into Equation, did not clearly demonstate the validity of the solution (to me at least)
Unfortunately, I am still unable to post the corresponding Maplesoft worksheet onto this post.
Invoked by the OEIS superseeker, Maple "gfun" package "listtoalgeq" identified possible lgdegf for https://oeis.org/A035001
1, 2, 4, 5, 8, 12, 14, 16, 28, 32, 37, 64, 94, 106, 128, 144, 232, 256, 289, 320, 512, 560, 704, 760, 838, 1024, 1328, 1536, 1944, 2048, 2329, 3104, 3328, 4096, 4864, 6266, 6802, 7168, 8192, 11952, 15360, 16384, 16428, 19149, 28928, 32768, 37120, 42168
as follows:
1024-5120*a(n)+11520*a(n)^2-15360*a(n)^3+13440*a(n)^4-8064*a(n)^5+3360*a(n)^6-960*a(n)^7+180*a(n)^8-20*a(n)^9+a(n)^{10}
The coefficients of above polynomial are:
{1, -20, 180, -960, 3360, -8064,13440, -15360, 11520, -5120, 1024,...}
It is interesting that the absolute values of above polynomial coefficients satisfy a(n) of
https://oeis.org/A013609
for n=55...65,
which is the 11th row in the triangle presentation of A013609, so in other words the absolute values of above polynomial coefficients are T={11, k} for k=1...11
Dear Users!
I hope you are doing well. I have the following discretized form
for n>=1 and j=0..M. We obtained the following matrix equation for any "n" and j=0..M as:
I want matrix proc of any useful way to define A^n, u^n, and b^n. I am waiting for your positive response. Thanks in advancs
I would like to do some point and line calculations, and the geom3d package seems a good one.
But how do I define a generic point such that I can use it in a function to generate genric points and lines?
eg
    P:=(a,b,c)->point(P, a,b,c)
or equivalent?
I would then want to define generic lines between generic points.
Consider the following.
We have a matrix A with five parameters in it.
If we tell Maple to solve Ax=0, it gives us the trivial solution.
Then, if I make a matrix B where I choose specific values for those five parameters and I tell Maple to solve Bx=0 I get a non-trivial solution.
Why doesn't Maple give me a more informative result in the Ax=0 case?
A := Matrix(5, 5, {(1, 1) = 1, (1, 2) = 0, (1, 3) = 0, (1, 4) = 0, (1, 5) = a__1, (2, 1) = 0, (2, 2) = 1, (2, 3) = 0, (2, 4) = 0, (2, 5) = b__1, (3, 1) = -216, (3, 2) = -18, (3, 3) = 0, (3, 4) = 0, (3, 5) = c__1, (4, 1) = 0, (4, 2) = 0, (4, 3) = 1, (4, 4) = 0, (4, 5) = d__1, (5, 1) = 0, (5, 2) = 0, (5, 3) = 0, (5, 4) = 1, (5, 5) = e__1}) = Matrix(%id = 36893488151959194068)NULL
with(LinearAlgebra)
GaussianElimination(A)
Matrix(%id = 36893488151959184316)
LinearSolve(A, `<,>`(0, 0, 0, 0, 0))
Vector[column](%id = 36893488151959183100)
B := Matrix(5, 5, {(1, 1) = 1, (1, 2) = 0, (1, 3) = 0, (1, 4) = 0, (1, 5) = 0, (2, 1) = 0, (2, 2) = 1, (2, 3) = 0, (2, 4) = 0, (2, 5) = 0, (3, 1) = -216, (3, 2) = -18, (3, 3) = 0, (3, 4) = 0, (3, 5) = 0, (4, 1) = 0, (4, 2) = 0, (4, 3) = 1, (4, 4) = 0, (4, 5) = 1, (5, 1) = 0, (5, 2) = 0, (5, 3) = 0, (5, 4) = 1, (5, 5) = 4}) = Matrix([[1, 0, 0, 0, 0], [0, 1, 0, 0, 0], [-216, -18, 0, 0, 0], [0, 0, 1, 0, 1], [0, 0, 0, 1, 4]])NULL
GaussianElimination(B) = Matrix(%id = 36893488151959174788)NULL
LinearSolve(B, `<,>`(0, 0, 0, 0, 0))
Vector[column](%id = 36893488151959164916)
An even easier way to show a non-trivial solution is to just make the entire last column zero.
Download polyn_matrix.mw
I have a function defined on many sub-intervals, how can I simplify this the funciton obtained at each iteration. I hope obatin B_{i,1}, B_{i,2}, and B_{i,3}
B_Spline.mw
Dear Users!
I hope everyone is fine here. I have three vectors say V[1], V[2] and V[3] as:
restart; with(LinearAlgebra); with(linalg);
V[1] := Vector([3, 2, -4]);
V[2] := Vector([1, 2/3, 7]);
V[3] := Vector([-9, 0, 1/2]);
I can define a Vector V have V[1], V[2] and V[3] using blockmatrix command as:
C := blockmatrix(3, 1, [V[1], V[2], V[3]]);
My question is that how I can extract vectors V[1], V[2] and V[3] from C? Thanks in advance
Is there a simple 4-vector package available for Maple? Yes, I know about using Tensors, but don't want to fool with metrics and raising and lowering operators.
I have written my  own, but it seems buggy. I generate some vectors in in CM that should add up to a massless neutrino, but some times when I boost them to the 'lab' and do the addition there the neutrion acquires a substantial mass. It's not a merely numerical issue. It's weird because most of the time the neutrion mass is 0 or close to it.
My homemade boost proc 'boostTo' is attached.
Привет. У меня проблема с пестремой, помогите пожалуйста:
y:=sqrt((x^2*(x^2-4))/(x^2-1));
readlib(extrema): readlib(maximize): readlib(minimize):
extrema(y,{},x,'s');s;
ymax:=maximize(y,{x});
Error, (in maximization) unexpected parameters: {x}
ymin:=minimize(y,{x});
Error, (in minimization) unexpected parameters: {x}
  I am unable to draw both 3d plots sowing error please help me to solve
restart:NULLNULL
p1 := 0.1e-1; p2 := 0.2e-1; p3 := 0.1e-1; Px := p1+p2+p3
rf := 1050; kf := .52; cpf := 3617; sigmaf := .8
sigma1 := 25000; rs1 := 5200; ks1 := 6; cps1 := 670
sigma2 := 59.7*10^6; rs2 := 8933; ks2 := 400; cps2 := 385
sigma3 := 2380000; rs3 := 4250; ks3 := 8.9538; cps3 := 686.2
B1 := 1+2.5*Px+6.2*Px^2; B2 := 1+13.5*Px+904.4*Px^2; B3 := 1+37.1*Px+612.6*Px^2; B4 := (ks1+2*kf-2*Px*(kf-ks1))/(ks1+2*kf+Px*(kf-ks1)); B5 := (ks2+3.9*kf-3.9*Px*(kf-ks2))/(ks2+3.9*kf+Px*(kf-ks2)); B6 := (ks3+4.7*kf-4.7*Px*(kf-ks3))/(ks3+4.7*kf+Px*(kf-ks3))
a2 := B1*p1+B2*p2+B3*p3
a1 := 1-p1-p2-p3+p1*rs1/rf+p2*rs2/rf+p3*rs3/rf
a3 := 1-p1-p2-p3+p1*rs1*cps1/(rf*cpf)+p2*rs2*cps2/(rf*cpf)+p3*rs3*cps3/(rf*cpf)
a4 := B4*p1+B5*p2+B6*p3
a5 := 1+3*((p1*sigma1+p2*sigma2+p3*sigma3)/sigmaf-p1-p2-p3)/(2+(p1*sigma1+p2*sigma2+p3*sigma3)/((p1+p2+p3)*sigmaf)-((p1*sigma1+p2*sigma2+p3*sigma3)/sigmaf-p1-p2-p3))
ODE:=[(a2+K)*(diff(U0(eta), eta, eta))/a1-Ra*(diff(U0(eta), eta))+lambda0/a1-a5*M1^2*U0(eta)/a1+K*(diff(N0(eta), eta))/a1+la*Ra*Theta0(eta)*(1+Qc*Theta0(eta)), (a2+K)*(diff(U1(eta), eta, eta))/a1-H^2*l1*U1(eta)-Ra*(diff(U1(eta), eta))+lambda1/a1-a5*M1^2*U1(eta)/a1+K*(diff(N1(eta), eta))/a1+la*Ra*(Theta1(eta))(1+2*Qc*Theta0(eta)), diff(N0(eta), eta, eta)-Ra*a1*Pj*(diff(N0(eta), eta))-2*n1*N0(eta)-n1*(diff(U0(eta), eta)), diff(N1(eta), eta, eta)-Ra*a1*Pj*(diff(N1(eta), eta))-2*n1*N1(eta)-n1*(diff(U1(eta), eta))-H^2*a1*Pj*l1*N1(eta), (a4/(a3*Pr)-delta*Ra^2/H^2+4*Rd*(1+(Tp-1)^3*Theta0(eta)^3+3*(Tp-1)^2*Theta0(eta)^2+(3*(Tp-1))*Theta0(eta))/(3*a3*Pr))*(diff(Theta0(eta), eta, eta))-Ra*(diff(Theta0(eta), eta))+a5*Ec*M1^2*U0(eta)^2/a3+(a2+K)*Ec*(diff(U0(eta), eta))^2/a1+Q*Theta0(eta)/a3+4*(diff(Theta0(eta), eta))^2*Rd*(3*(Tp-1)+6*(Tp-1)^2*Theta0(eta)+3*(Tp-1)^3*Theta0(eta)^2)/(3*a3*Pr), (a4/(a3*Pr)-delta*Ra^2/H^2+4*Rd*(1+(Tp-1)^3*Theta0(eta)^3+3*(Tp-1)^2*Theta0(eta)^2+(3*(Tp-1))*Theta0(eta))/(3*a3*Pr))*(diff(Theta1(eta), eta, eta))-(H^2*l1+2*Ra*delta*l1+Ra)*(diff(Theta1(eta), eta))+(Q/a3-delta*H^2*l1^2)*Theta1(eta)+2*(a2+K)*Ec*(diff(U0(eta), eta))*(diff(U1(eta), eta))/a1+2*a5*Ec*M^2*U0(eta)*U1(eta)/a3+4*(diff(Theta0(eta), eta, eta))*Theta1(eta)*Rd*(3*(Tp-1)+6*(Tp-1)^2*Theta0(eta)+3*(Tp-1)^3*Theta0(eta)^2)/(3*a3*Pr)+4*Rd*(diff(Theta0(eta), eta))^2*(6*(Tp-1)^2*Theta1(eta)+6*(Tp-1)^3*Theta0(eta)*Theta1(eta))/(3*a3*Pr)+4*Rd*(diff(Theta1(eta), eta))*(diff(Theta0(eta), eta))*(6*(Tp-1)+6*(Tp-1)^3*Theta0(eta)^2+12*(Tp-1)^2*Theta0(eta))/(3*a3*Pr)]:
(LB,UB):= (0,1):
BCs:= [
  U0(0) = 0, U1(0) = 0, N0(0) = 0, N1(0) = 0, Theta0(0) = 0, Theta1(0) = 0, U0(1) = 0, U1(1) = 0, N0(1) = 0, N1(1) = 0, Theta0(1) = 1, Theta1(1) = 0
Params:= Record(
   M1=  1.2, Rd=0.8,la=0.8,n1=1.2,Q=0.2,Pj=0.001,Ra=0.8,Ec=1,    Pr= 21,   delta= 0.2,    t1= (1/4)*Pi, lambda0=2,lambda1=3,   Qc= 0.1,    l1= 1,K=0.4,H=3 ,deltat=0.05  ):
NBVs:= [
a1**D(U0)(0) = `C*__f` , # Skin friction coefficient
 (a4+(4*Rd*(1/3))*(1+(Tp-1)*(Theta0(0)+0.1e-2*exp(l1*t1)*Theta1(0)))^3)*((D(Theta0))(0)+0.1e-2*exp(l1*t1)*(D(Theta1))(0)) = `Nu*`    # Nusselt number
Nu:= `Nu*`:
Cf:= `C*__f`:
Solve:= module()
local
   nbvs_rhs:= rhs~(:-NBVs), #just the names
   Sol, #numeric dsolve BVP solution of any 'output' form
   ModuleApply:= subs(
      _Sys= {:-ODEs[], :-BCs[], :-NBVs[]},
      proc({
          M1::realcons:=  Params:-M1,
         Pr::realcons:= Params:-Pr,
         Rd::realcons:= Params:-Rd,
         la::realcons:= Params:-la,
         Tp::realcons:= Params:-Tp,
         n1::realcons:= Params:-n1,
         Q::realcons:= Params:-Q,
         Pj::realcons:= Params:-Pj,
         Ra::realcons:= Params:-Ra,
         Ec::realcons:= Params:-Ec,
         t1::realcons:=  Params:-t1,
         delta::realcons:= Params:-delta,
         lambda0::realcons:= Params:-lambda0,
         lambda1::realcons:= Params:-lambda1,
         Qc::realcons:= Params:-Qc,
         K::realcons:= Params:-K,
         l1::realcons:= Params:-l1,
         H::realcons:= Params:-H
         Sol:= dsolve(_Sys, _rest, numeric);
         AccumData(Sol, {_options});
         Sol
      end proc
   AccumData:= proc(
      Sol::{Matrix, procedure, list({name, function}= procedure)},
      params::set(name= realcons)
   local n, nbvs;
      if Sol::Matrix then
         nbvs:= seq(n = Sol[2,1][1,Pos(n)], n= nbvs_rhs)
         nbvs:= (nbvs_rhs =~ eval(nbvs_rhs, Sol(:-LB)))[]
      fi;
      SavedData[params]:= Record[packed](params[], nbvs)
   end proc,
   ModuleLoad:= eval(Init);
export
   SavedData, #table of Records
   Pos, #Matrix column indices of nbvs
   Init:= proc()
      Pos:= proc(n::name) option remember; local p; member(n, Sol[1,1], 'p'); p end proc;
      SavedData:= table();
      return
   end proc ;
   ModuleLoad()
end module:
#procedure that generates 3-D plots (dropped-shadow contour + surface) of an expression
ParamPlot3d:= proc(
   Z::{procedure, `module`}, #procedure that extracts z-value from Solve's dsolve solution
   X::name= range(realcons), #x-axis-parameter range
   Y::name= range(realcons), #y-axis-parameter range
   FP::list(name= realcons), #fixed values of other parameters
      #fraction of empty space above and below plot (larger "below"
      #value improves view of dropped-shadow contourplot):
      zmargin::[realcons,realcons]:= [.05,0.15],
      eta::realcons:= :-LB, #independent variable value
      dsolveopts::list({name, name= anything}):= [],
      contouropts::list({name, name= anything}):= [],
      surfaceopts::list({name, name= anything}):=[]
local
   LX:= lhs(X), RX:= rhs(X), LY:= lhs(Y), RY:= rhs(Y),
   Zremember:= proc(x,y)
   option remember; #Used because 'grid' should be the same for both plots.
      Z(
         Solve(
            LX= x, LY= y, FP[],
            #Default dsolve options can be changed by setting 'dsolveopts':
            'abserr'= 0.5e-7, 'interpolant'= false, 'output'= Array([eta]),
            dsolveopts[]
   end proc,
   plotspec:= (Zremember, RX, RY),
   C:= plots:-contourplot(
      plotspec,
      #These default plot options can be changed by setting 'contouropts':
      'grid'= [25,25], 'contours'= 5, 'filled',
      'coloring'= ['yellow', 'orange'], 'color'= 'green',
      contouropts[]
   P:= plot3d(
      plotspec,
      #These default plot options can be changed by setting 'surfaceopts':
      'grid'= [25,25], 'style'= 'surfacecontour', 'contours'= 6,
      surfaceopts[]
   U, L #z-axis endpoints after margin adjustment
   #Stretch z-axis to include margins:
   (U,L):= ((Um,Lm,M,m)-> (M*(Lm-1)+m*Um, M*Lm+m*(Um-1)) /~ (Um+Lm-1))(
      zmargin[],
      (max,min)(op(3, indets(P, 'specfunc'('GRID'))[])) #actual z-axis range
   plots:-display(
         plots:-spacecurve(
               [[lhs(RX),rhs(RY),U],[rhs(RX),rhs(RY),U],[rhs(RX),rhs(RY),L]], #yz backwall
               [[rhs(RX),rhs(RY),U],[rhs(RX),lhs(RY),U],[rhs(RX),lhs(RY),L]]  #xz backwall
            'color'= 'grey', 'thickness'= 0
         plottools:-transform((x,y)-> [x,y,L])(C), #dropped-shadow contours
         P
      #These default plot options can be changed simply by putting the option in the
      #ParamPlot3d call:
      'view'= ['DEFAULT', 'DEFAULT', L..U], 'orientation'= [-135, 75], 'axes'= 'frame',
      'labels'= [lhs(X), lhs(Y), Z], 'labelfont'= ['TIMES', 'BOLDOBLIQUE', 16],
      'caption'= nprintf(cat("%a = %4.2f, "$nops(FP)-1, "%a = %4.2f"), (lhs,rhs)~(FP)[]),
      'captionfont'= ['TIMES', 14],
      'projection'= 2/3,
      _rest
GetNu := proc (Sol::Matrix) options operator, arrow; Sol[2, 1][1, Solve:-Pos(:-Nu)] end proc
ParamPlot3d(
   GetNu,Q= 0..5, Rd= 0..5, [
   Pr= 21   ],
   labels= [Q, gamma, Nu]
Error, (in plot/iplot2d/levelcurve) could not evaluate expression
Download P6_3D_plots.mw
Anyone knows how to plot a surface btw 2 spacecurves in 3d? For example a flat curve x^2+y^2=1 which maybe a upper half of above circle for y=0 to 1 and a spacecurve which is a function for example 2+x^2*y. So second curve should be above the first and limit a surface From the top.
Can't find a solution in help and parametric curves does not solve a problem.
In fact it would be enough to have a vertical surface starting on a xy plane and limited by Givenchy function. As it is in line integral calculations.
Marcin
First 194 195 196 197 198 199 200 Last Page 196 of 2457
