Hello Everyone;
I need help to solve the following system using rk-4 method
NULL;
NULL;
C := 1.0;
gK := 36.0;
gNa := 120.0;
gL := 0.3;
VK := -77.0;
VNa := 50.0;
VL := -54.0;
III := 20;
alpha_n := 0.01*(v(t) + 55.0)/(1 - exp(-1.0/10.0*v(t) - 11.0/2.0));
beta_n := 0.125*exp((-v(t))/80.0 + (-1)*13.0/16.0);
alpha_m := 0.1*(v(t) + 40.0)/(1 - exp(-1.0/10.0*v(t) - 4.0));
beta_m := 4.0*exp(-1.0/18.0*v(t) - 65.0/18.0);
alpha_h := 0.07*exp((-1)*(v(t) + 65.0)/20.0);
beta_h := 1/(1.0 + exp((-v(t) + 35.0)/10.0));
dsys1 := {diff(h(t), t) = alpha_h*(1 - h(t)) - beta_h*h(t), diff(m(t), t) = alpha_m*(1 - m(t)) - beta_m*m(t), diff(n(t), t) = alpha_n*(1 - n(t)) - beta_n(t), diff(v(t), t) = III - gK*n(t)^4*(v(t) - VK) - gNa*m(t)^3*h(t)*(v(t) - VNa) - gL*(v(t) - VL), h(0) = 0.9996937394, m(0) = 0.02890553447, n(0) = 0.2445865495, v(0) = -70};
HPM.mw
  • Please help me
  • How do I write Homotopy Perturbation method for a partial differential equation for this question in Maple?
Download HPM.mw
modifed_practice.mw
Impact of Shape-Dependent Hybrid Nanofluid on Transient Efficiency of a Fully W
et Porous Longitudinal Fin
dear sir please help me to solve the graph i given reference pdf also. i have implimented the code but getting error in ploting
Using the SingularValues command with any output type specified causes this error
Error, (in sanity) invalid input: LinearAlgebra:-SingularValues expects value for keyword parameter output to be of type {list(identical(U,S,Vt,list)), identical(U,S,Vt,list)}, but received [U, S, Vt]
Below is a minimal example to trigger the error. Is there something wrong about how I am calling the function?
sanity := proc()
  local A,U,S,Vt;
  A :=RandomMatrix(3,10);
  U,S,Vt := SingularValues(A, output=['U','S','Vt']);
sanity();
Dear Maple experts,
I have a system of several nonlinear equaitons. My code can solve it for a given parameter. But when I want to plot it, it takes too much time with no results. So, I decided to plot it for several given points. I get the answer for the points individually, but I don't know how to apply this to 'plot' command. Would you please help?
restartNULL
with(plots); with(RealDomain)
c := 1; cr := 0.3e-1*c; u := 5; sExp := 0.6e-1*c; s := .65*c; v := 3*c
FirmModelPartial1 := proc (alpha, beta, delta) local L1s, qs, ps, prs, hs, `&kappa;s`, `&lambda;__1s`, `&lambda;__2s`, `&lambda;__3s`, q, p, pr, h, kappa, `&lambda;__1`, `&lambda;__2`, `&lambda;__3`, FirmpfSiS, RecpfSiS, UnsoldSiS, EnvironSiS, p0, OldSoldPrim, xi, prof1, prof2, L1, L2, E1, E2, E3, E4, E5, E6, E7, E8, E9, E10, E11, E12; prof1 := (ps-c)*qs+((1/2)*beta^2*`&kappa;s`^2/(u*(1-alpha))-(1/2)*(qs+beta*`&kappa;s`)^2/u)*(ps-s)+hs*prs*(beta*`&kappa;s`-(1/2)*beta^2*`&kappa;s`^2/(u*(1-alpha))); L1s := prof1+`&lambda;__1s`*(1-sExp/prs-hs)+`&lambda;__2s`*(qs-`&kappa;s`)+`&lambda;__3s`*(qs-alpha*beta*`&kappa;s`/(1-alpha)); E1 := qs*(diff(L1s, qs)) = 0; E2 := hs*(diff(L1s, hs)) = 0; E3 := `&lambda;__1s`*(1-sExp/prs-hs) = 0; E4 := `&lambda;__2s`*(qs-`&kappa;s`) = 0; E5 := `&lambda;__3s`*(qs-alpha*beta*`&kappa;s`/(1-alpha)) = 0; E6 := qs = alpha*u*(v-ps)/(v-s); E7 := prs = ps-delta*v; E8 := `&kappa;s` = (beta*prs*(1-hs)+sExp*(1-beta))/(beta^2*(prs*(1-hs)-sExp)/(u*(1-alpha))+2*cr); p, q, pr, h, kappa, `&lambda;__1`, `&lambda;__2`, `&lambda;__3` := (eval([ps, qs, prs, hs, `&kappa;s`, `&lambda;__1s`, `&lambda;__2s`, `&lambda;__3s`], solve({0 <= qs-alpha*beta*`&kappa;s`/(1-alpha), 0 <= qs-`&kappa;s`, 0 <= 1-sExp/prs-hs, 0 <= `&lambda;__1s`, 0 <= `&lambda;__2s`, 0 <= `&lambda;__3s`, diff(L1s, qs) <= 0, diff(L1s, hs) <= 0, c < ps, (1/2)*beta*`&kappa;s`/(u*(1-alpha)) < 1, sExp+delta*v < ps, E1, E2, E3, E4, E5, E6, E7, E8}, [ps, qs, prs, hs, `&kappa;s`, `&lambda;__1s`, `&lambda;__2s`, `&lambda;__3s`])[1]))[]; xi := kappa/q; FirmpfSiS := max(0, eval(prof1, [ps = p, qs = q, prs = p-delta*v, hs = h, `&kappa;s` = kappa])); RecpfSiS := ((1-h)*pr-sExp)*(beta*kappa-(1/2)*beta^2*kappa^2/(u*(1-alpha)))+(sExp-cr)*kappa; UnsoldSiS := (1/2)*(q+beta*kappa)^2/u-(1/2)*beta^2*kappa^2/(u*(1-alpha)); EnvironSiS := q+UnsoldSiS; return p, q, FirmpfSiS, RecpfSiS, EnvironSiS, h, UnsoldSiS, h, xi end proc
FirmModelPartial1(.1, .2, .1)[3]
Error, (in FirmModelPartial1) invalid subscript selector
FirmModelPartial1(.2, .2, .1)[3]
FirmModelPartial1(.3, .2, .1)[3]
.2200894743
FirmModelPartial1(.4, .2, .1)[3]
.2892440018
FirmModelPartial1(.5, .2, .1)[3]
.3801240291
FirmModelPartial1(.6, .2, .1)[3]
.4921660779
FirmModelPartial1(.7, .2, .1)[3]
.6227094789
FirmModelPartial1(.8, .2, .1)[3]
.7668402612
FirmModelPartial1(.9, .2, .1)[3]
.9161921261
plot('FirmModelPartial1(alpha, .2, .2)[3]', alpha = .1 .. .90, adaptive = false, sample = [.1, .2, .3, .4, .5, .6, .7, .8, .9])
Download Reza_Tchno_(v3).mw
Besdies, it seems for some points there is no feasible solution. So, there is no need to have plot for them.
I attach the code. Thank you so much!
dS/dt=qnv-alpha_1*S*H-mu_sh*S
dH/dt=lamda_h-alpha_1*S*H-mu_h*H
dI/dt=alpha_1*S*H-beta_1*I-mu_i*I
dS/dt=beta_1*I-delta_1*S-mu_s*S
DATA:
q=0.75; n=15;v=20; alpha_You1=0.001; S=2000; H=3000; mu_sh=0.000000000012; lambda=3000;mu_h=0.94; beta_1=0.125; I=0; mi_i=0.95; delta_1=0.0975; S=0; mu_s=0.029
Good day all,
please I am new Maple user, i used the same code to solve boundary layer flow. Itried to use the same code in solving nanofluid but the solution is not coverging at some point. But the author i want to compared my results with had solution at those points.
Is there any way i can get solution of this model at this with these values?. Please i need your help. Thank you in advance
secod_code.mw
with*plots; ode1 := (1+1/bet)*(diff(f(eta), eta, eta, eta))-(diff(f(eta), eta))^2+f(eta)*(diff(f(eta), eta, eta))+Gr*(theta(eta)+lambda1*theta(eta)^2)+Gc*(phi(eta)+lambda2*phi(eta)^2)-M*(diff(f(eta), eta)) = 0
(1+1/bet)*(diff(diff(diff(f(eta), eta), eta), eta))-(diff(f(eta), eta))^2+f(eta)*(diff(diff(f(eta), eta), eta))+Gr*(theta(eta)+lambda1*theta(eta)^2)+Gc*(phi(eta)+lambda2*phi(eta)^2)-M*(diff(f(eta), eta)) = 0
ode2 := (diff(theta(eta), eta, eta))*(1+(4*R*(1/3))*(theta(eta)+CT)^3)/Pr+4*R*(theta(eta)+CT)^2*(diff(theta(eta), eta))^2+f(eta)*(diff(theta(eta), eta))+Nb*(diff(phi(eta), eta))*(diff(theta(eta), eta))+Nt*(diff(theta(eta), eta))^2-de*(f(eta)*(diff(f(eta), eta))*(diff(theta(eta), eta))+f(eta)^2*(diff(theta(eta), eta, eta))) = 0
(diff(diff(theta(eta), eta), eta))*(1+(4/3)*R*(theta(eta)+CT)^3)/Pr+4*R*(theta(eta)+CT)^2*(diff(theta(eta), eta))^2+f(eta)*(diff(theta(eta), eta))+Nb*(diff(phi(eta), eta))*(diff(theta(eta), eta))+Nt*(diff(theta(eta), eta))^2-de*(f(eta)*(diff(f(eta), eta))*(diff(theta(eta), eta))+f(eta)^2*(diff(diff(theta(eta), eta), eta))) = 0
ode3 := diff(phi(eta), eta, eta)+Pr*Le*(diff(phi(eta), eta))*f(eta)+Nt*(diff(theta(eta), eta, eta))/Nb-Pr*Le*dc*(f(eta)*(diff(f(eta), eta))*(diff(phi(eta), eta))+f(eta)^2*(diff(phi(eta), eta, eta))) = 0
diff(diff(phi(eta), eta), eta)+Pr*Le*(diff(phi(eta), eta))*f(eta)+Nt*(diff(diff(theta(eta), eta), eta))/Nb-Pr*Le*dc*(f(eta)*(diff(f(eta), eta))*(diff(phi(eta), eta))+f(eta)^2*(diff(diff(phi(eta), eta), eta))) = 0
bcs1 := f(0) = 0, (D(f))(0) = 1+xi*((D^2)(f))(0), (D(f))(6) = 0, theta(6) = 0, phi(0) = 1+`&varsigma;`*(D(phi))(0), theta(0) = 1+Zeta*(D(theta))(0), phi(6) = 0
f(0) = 0, (D(f))(0) = 1+xi*(D(f))(0)^2, (D(f))(6) = 0, theta(6) = 0, phi(0) = 1+varsigma*(D(phi))(0), theta(0) = 1+Zeta*(D(theta))(0), phi(6) = 0
L := [0., .1, .4, 1]
[0., .1, .4, 1]
  for k to 10 do
      sol_All := dsolve
                 ( eval
                   ( {bcs1, ode1, ode2,ode3},
                     [xi= L[k],R=1, CT=0.2, Gr=0.5, Gc=0.5, lambda1=0.2, lambda2=0.2, Pr=0.72, Nb=0.5,  Le=1, dc=0.2, de=0.2, Nt=0.5, Zeta=0.5, varsigma=0.5, M=1.5, bet=1.5]
                   [f(eta), theta(eta),phi(eta)],
                   numeric,
                   output = listprocedure
      Y_sol || k := rhs(sol_All[5]);
      YP_sol || k := -rhs(sol_All[6]);
feta || k := rhs(sol_All[4]);
      fpeta || k := rhs(sol_All[3]);
phieta || k := rhs(sol_All[8]);
      phipeta || k := rhs(sol_All[7])
for k to 10 do L[k], [(Y_sol || k)(0), (YP_sol || k)(0)] end do
0., [Y_sol1(0), YP_sol1(0)]
.1, [Y_sol2(0), YP_sol2(0)]
.4, [Y_sol3(0), YP_sol3(0)]
1, [Y_sol4(0), YP_sol4(0)]
for k to 10 do L[k], [(feta || k)(0)] end do
0., [feta1(0)]
.1, [feta2(0)]
.4, [feta3(0)]
1, [feta4(0)]
Error, mismatched or missing bracket/operator
"for k  from 1 to  10 do L[k], ([phieta ||k(0),phipeta||k(0)]); od; "
  plot( [ seq((Y_sol||j)(eta), j = 1..6)],
         eta = 0 .. 6,
         labels = [eta, theta(eta)],
         axes = boxed
plot( [ seq((YP_sol||j)(eta), j = 1..6)],
         eta = 0 .. 8,
         labels = [eta, thetaprime(eta)],
         axes = boxed
 plot( [ seq((feta||j)(eta), j = 1..6)],
         eta = 0 .. 8,
         labels = [eta, f(eta)],
         axes = boxed
  plot( [ seq((fpeta||j)(eta), j = 1..6)],
         eta = 0 .. 5,
         labels = [eta, fprime(eta)],
         axes = boxed
plot( [ seq((phipeta||j)(eta), j = 1..6)],
         eta = 0 .. 5,
         labels = [eta, phiprime(eta)],
         axes = boxed
plot( [ seq((phieta||j)(eta), j = 1..6)],
         eta = 0 .. 5,
         labels = [eta, phi(eta)],
         axes = boxed
Warning, expecting only range variable eta in expression Y_sol1(eta) to be plotted but found name Y_sol1
Warning, expecting only range variable eta in expression YP_sol1(eta) to be plotted but found name YP_sol1
Warning, expecting only range variable eta in expression feta1(eta) to be plotted but found name feta1
Warning, expecting only range variable eta in expression fpeta1(eta) to be plotted but found name fpeta1
Warning, expecting only range variable eta in expression phipeta1(eta) to be plotted but found name phipeta1
Warning, expecting only range variable eta in expression phieta1(eta) to be plotted but found name phieta1
Sometimes the canvas in the 2d-workspace of a subsystem (or component) is grayed out and the parameters in the parameter pane cannot be changed.
Example from the Model Gallery where the mass cannot be changed
Another example of a CAD geometry where I would like to change color and transparency:  seeshell.msim
How to unprotect the parameters?
I have observed that copy and pasting (Edit2: in a new document) and deleting the original component and copy/paste back into the original document and reconnection of the pasted  component works. Are there shorter ways to unprotect?
And: How to do the reverse action (i.e. protecting a component)?
(I could not find a "when" and "why" for the protection in the documentation. Maybe I overlooked something)
Edit:
Other reasons why to unprotect are suppressions of components and highlight of multibody ports and axes.
Adding or reformating automatically generated ports (Edit3).
Hello Everyone;
Can anybody help me to solve the analytical solution of the following ODE?
AAS := C*diff(y(t), t) + (-B0*y(t)^3 - B1*y(t)^2 - B2*y(t) - B3);y[0] := 1
C,B0,B1,B2 are constants.
How did Maple arrive at the following, implicit solution,
MSimplicitesolution := (-9*y(x)*(-y(x)*x^2)^(1/3)*6^(2/3)*x^2 + 16*_C1*x^(8/3) - 24*x^2 + 6)/(16*x^(8/3)) = 0,
to the following 'ode',
ODE:= (2/3)*(int[(y'(x)*(x^2)/((x^2) -1)]) =int(-sqrt [2*y(x)])?
'odeadvisor' suggested y=G(x,y'(x), but I could not see how this could be implimented with this equation.
(Unfortunately, I am unable to download the Maple worksheet onto this sheet at this time.  Any assitance
would be appreciated.
I want to write the expresstion x^3 + (-m - 1)*x^2 + (-4*m - 3)*x in the form x^3 - (m-1) x^2 - (4m + 3). I tried
collect(expand(x^3 + (-m - 1)*x^2 + (-4*m - 3)*x), x)
I get x^3 + (-m - 1)*x^2 + (-4*m - 3)*x
Why is Maple not calculating 'sqrt' and continuously showing 'Evaluating'?
with(LinearAlgebra); with(PDEtools); with(DifferentialGeometry)
with(plots)
with(Physics)
q := (31.00000000*exp(-4.976*t+2.*x)*exp((-2.488+.8336000001*I)*t+(1.+.2*I)*x)-3.000000000*exp(-4.976*t+2.*x)*exp((2.488+.8336000001*I)*t+(-1.+.2*I)*x)+(94.0*I)*exp(I*(.8336*t+.2000*x))*exp(-4.976*t+2.*x))/((11.50000000*I)*exp(-2.488*t+x)+132.44*exp(-4.976*t+2.*x)-(104.5000000*I)*exp(-7.464*t+3.*x)-5.25*exp(-9.952*t+4.*x)+.25)
assume(x::real); assume(t::real)
q1 := simplify(subs({I = -I}, q))
(-(94.*I)*exp(-I*(.8336*t+.2000*x))+31.*exp((-2.488-.8336000001*I)*t+(1.-.2*I)*x)-3.*exp((2.488-.8336000001*I)*t+(-1.-.2*I)*x))*exp(-4.976*t+2.*x)/(-(11.50000000*I)*exp(-2.488*t+x)+132.44*exp(-4.976*t+2.*x)+(104.5000000*I)*exp(-7.464*t+3.*x)-5.25*exp(-9.952*t+4.*x)+.25)
q2 := simplify(sqrt(q*q1))
Download q_sqrt.mw
Help me please?
ElzakiTransform := proc(f, t) int(f*exp(-t/v)*v, t = 0 .. infinity); end proc;
f := e^(n*t);
result := ElzakiTransform(f, t);
result;
Is this true?
For_MaplePrimes_question.mw
In the above Maple document, I present a puzzling problem:  When I use plot3d, the options
font = [Times, bold, 16], labels = ['u', 'v', 'z'], labelfont = [Times, bold, 40] in the command
plot3d([u*sin(2*v), u^2, u*cos(2*v)], transparency = 0.60, shading = none, font = [Times, bold, 16], labels = ['u', 'v', 'z'], labelfont = [Times, bold, 40], grid = [60, 60]);
produces nice big labels on the axes, which are visible as opposed to the almost invisible default size, especially on printouts but when I use these options as in below command:
fieldplot3d([0, 0, -y], x = -2 .. 2, y = -2 .. 2, z = -2 .. 2, arrows = `3-D`, fieldstrength = maximal(0.5), font = [Times, bold, 16], labels = ['x', 'y', 'z'], labelfont = [Times, bold, 40], grid = [4, 4, 4])
the lables x, y and z on the fieldplot are small, the default.  I used the same option and get different results.
I have been researching this for almost 2 hours and I can't find a way to increase the font size in the fieldplot command.
Is this a bug or does the fieldplot command not use these options the way it is used in the plot3d command?
Thank You for reading my question. (I am relatively inexperienced with Maple.)
Tom K.
First 203 204 205 206 207 208 209 Last Page 205 of 2458
