How do I graph x=(cos(t)) , y = (sin(t)) , z = (2sin(t)cos(t)) ?
I want to exporte a file maple into LaTeX but i need to have the file maple2e.sty in maple version. Thanks for fast help
Hi, all, After some computation, I got a huge polynomial: a00*x^123+a45*x^233+a02*x^123+a67*x^156+a47*x^67+.......(with more than 30,000 monomials). This generated polynomial has some features: 1: the degree of each monomial is not more than 256. 2:each monomial only has ONE coefficient. 3:There are two or more monomials have the same degree, so they can be combined together. Such as a00*x^123+a02*x^123=(a00+a02)*x^123. 4:for any coefficient a[ij], i is from 0 though 15, j is also from 0 through 15.
with(plots); m1 := implicitplot3d(
9*x^2+4*y^2-36*z^2
, x = -2 .. 2, y = -3 .. 3, z = -1 .. 1, grid = [20, 20, 20]); n := animate3d([x, y, t], x = -2 .. 2, y = -3 .. 3, t = -1 .. 1); display({n, m1})
Everytime i execte the above goes in loop, used up memory increases and status bar says
evaluating and computer slows down. I had to stop the process. what am i doing wrong?
i have trouble starting classic worksheet maple 12.  it used to work fine, but now it freezes at the maple 12 title page.  when closing the program, classic worksheet asks: "You are in the middle of a computation.  Are you sure you want to interrupt it?", even though i have not entered any commands and am unable to enter any commands.  The program also does not close correctly in the task manager.  i have to end the process manually or end the process tree manually.  any help on how to fix this problem?  i have tried uninstalling and re
I tried the following:
E.g. I have five solutions from former computations i.e. k1..k5, some of which are common expressions, some are multiple solutions and some are just nothing, because Maple was not able to compute it.
Now I try the following:
for i from 1 to 5 do
subs(x = a, k||i):
That won´t work, because Maple realizes, that some of the k||i expressions are no expressions.
Now I think of inserting a boolean-check such as:
for i from 1 to 5
while type(k||i, t) do
I have some code for evaluating a velocity given different variables: > h := 50; e := 5/6; > d := .218*100; Omega := 6*Pi*(1/100); > a := -h/e; b := h/(1-e); > Q := piecewise(x <><><><><><><><><><><><><><><><><><><> k := piecewise(0 <><><><> F := 0; > tau[1] := 1/(30*d); tau[2] := (1/4)*tau[1];
How do I get Maple to go into 1-d input?
Choosing Maple Input only changes the font color to red, 3^b as it should be displayed is displayed as 3.
This is in Maple 12.01.
Is there a way to ask Maple to write an expression in terms of other expressions? Eg.
f[1] := v[1]+v[2];
 f[2] := v[1]*a[1]+v[2]*a[2];
 f[3] := v[1]*a[3]*a[4]+v[2]*a[5]*a[6];
 f[4] := v[1]*a[1]*a[4]+v[2]*a[2]*a[6];
 f[5] := v[1]*a[3]*a[7]*a[8]+v[2]*a[5]*a[9]*a[10];
 f[6] := v[1]*a[3]*a[4]*a[8]+v[2]*a[5]*a[6]*a[10];
 f[7] := v[1]*a[1]*a[7]*a[8]+v[2]*a[2]*a[9]*a[10];
 f[8] := v[1]*a[1]*a[4]*a[8]+v[2]*a[2]*a[6]*a[10];
Is there a way to make Maple turn expressions of the form a(b+c)^d  into (a^(1/d)b + a^(1/d)c)^d? A specific example of what annoys me is results like these:
10.17594299*(-.2450501048*x+.2692858295)^2.824978580
This expression would look simpler if 10.17594299 is moved into the parentheses, like this:
(-0.5570846541*u + 0.6121809387)^2.824978580
Can Maple do this for me? I have blindly tried simplify, expand, etc, but none of them do what I want.
Photobucket
Help me, thank a lot
> R := 1000*Dirac(x-10):
int(R, x = 0 .. 10);
500
we have result to be 500
I define a function of time t and variable x
> p := piecewise(0 <= t and x < 10, R, 10 <= t and t < 20, 0):
int(p, x = 0 .. 10);
I am trying to animate two different space curves such that the second curve starts a specified time after the 1st curve. At first glance, it looked like this would work, but it does not. > with(plots); with(Student[VectorCalculus]); > > a := animate(spacecurve, [[cos(t), sin(t), t], t = 0 .. A], A = 0 .. 2 Pi, color = red, axes = boxed, labels = [x, y, z]); > b := animate(spacecurve, [[sin(t), cos(t), t], t = Pi .. B], B = Pi .. 2 Pi), color = blue); > display(a, b);
I'm using the LinearAlgebra package and the Matrix() command to build matrices in Maple 9.5. I need to be able to find the number of rows and the number of columns of a certain matrix A. I ran into problems running nops(A[1,1..-1]) and discovered that if I find the operands of a 3x2 matrix "wem" I am returned this: 3, 2, {(1, 1) = 0.7, (1, 2) = 0.1, (2, 1) = 0.2, (2, 2) = 0.3, (3, 1) = 0.1, (3, 2) = 0.6}, datatype = anything, storage = rectangular, order = Fortran_order, shape = []
First 2048 2049 2050 2051 2052 2053 2054 Last Page 2050 of 2470
