given this equation: f(x,y) = (xysin(x-y)) / (1+(x^2)+(y^2)) , for (1,1,0) i need to compute the partial derivatives and graph the surface and the tangent plane at the given point. this is as far as i got before getting stuck > f := xysin(x-y)/(1+x^2+y^2); xysin(x - y) ------------ 2 2 1 + x + y > plot3d(f, x = -3 .. 3, y = -3 .. 3, grid = [2, 2]);
restart; with(DEtools) x1 := diff(x(t), t) = (4-x-4*y)*x; y1 := diff(y(t), t) = (4-4*x-y)*y; phaseportrait([diff(x(t), t) = (4-x-4*y)*x, diff(y(t), t) = (4-4*x-y)*y], [x(t), y(t)], x = -20 .. 20, y = -20 .. 20, t = -2 .. 2, [[x(0) = 0, y(0) = 1]], stepsize = 0.5e-1, scene = [y(t), x(t)], linecolour = sin((1/2)*t*Pi), method = classical[foreuler]) I'm trying to specify the domain for x and y but I receive the following error Error, (in DEtools/phaseportrait) initial conditions must be specified in inits The above works when I get rid of x = -20 .. 20, y = -20 .. 20,
 How do I get both branches (i.e. positive and negative values) for f(x) on the same plot of f(x) = x^(1/2)?
Thanks very much,
Greg
I have a frustrating error that comes from using Code generation with diff
It works fine when processing a single equation but doesn't like matricies:
> Xx := ((cos(q1)*cos(q2)+0.8e-3*sin(q1)*sin(q2))*sin(q3)+(0.8e-3*(-cos(q1)*sin(q2)+0.8e-3*sin(q1)*cos(q2)))*cos(q3)+sin(q1)*cos(q3))*L3+(0.8e-3*(cos(q1)*sin(q2)-0.8e-3*sin(q1)*cos(q2)+0.8e-3*sin(q1)))*L3+sin(q1)*(L21+L22);
I would like to calculate engineering stress using array; but the following piece of codes do not seem to work. *EngineeringStress = force / area *Define force is an array of measurements of force. crossArea:= 3.2 * 19.1 (not the "*" is really a "." in Maple editor; it is multiplication) force := array ([0., 1380.0, 2780.0, 5630.0]) engineeringStress := force/crossArea; engineeringStress[1] ({0., 1380.0, 2780.0, 5630.0}/crossArea)[1] it suppose to be 0!!!
When i input something like sqrt(30) I just get back 30 with a square root symbol over it. How can I make maple evaluate it?
How do I generate a gaussian random matrix (2x2).
Is this the default setting already in maple or is there code I need to use?
I'm to generate a random matrix ie > with(LinearAlgebra); > RandomMatrix(2, 2, generator = -1 .. 1); and find the eigenvalues of each matrix ten times. How do I put random Matrix in the for loop with Maple?
I have two vector here
X:= vector([-1,0,1])
Y:=vector([1+I*2,3+I,4+3*I], datatype=complex)
I want to fit them in the form a*exp(-I*10*t)+b*exp(I*10*t), a and b may be complex.
How should I do?
I have two vector here, and I want to fit them with the form a*exp(-I*4375*t)+b*exp(I*4375*t), a and b should be complex. How should I do?
X := Vector([-0.000163, 0, 0.000163], datatype = complex);
Y := Vector([-8.84352*10^(-13)+(I*1.71511)*10^(-12), 1.49867*10^(-13)+(I*1.45355)*10^(-12), 1.15763*10^(-12)+(I*9.08261)*10^(-13)], datatype = complex[8]);
I am trying to built in 3d function of recurrence relation
V(i)=a*V(i-1)-V(i-2); a=const; initial conditions: V(i-1)=-1; V(i-2)=-2.
An axes of a three-dimensional surface have to be: V(i); V(i-1); i.
I created these two procedures, I want to introduce within a mla.
 But I have the following two problems that I need you guys help me
solve:
Hi, I want to build recursively defined, piecewise functions.
I first defined my zero-order functions
N40(xi)=piecewise(0<xi and xi<=1);
N50(xi)=piecewise(1<xi and xi<=2);
and I can plot them with desired result
but, how do I combine them, to make first order functions?
 for instance, I want to have a function matematichally defined by:
N41 = (xi-1)*N40 + (2-xi)*N51
I've searched all over, and I can't figure this out: I'm hoping to have a result expressed in symbolic notation.  For example, if my result is x_1+x_2+...+x_n, how can I have maple express this answer as summation of x_i i=1 to n.
I actually have a matrix, each element of which is a ratio of summations.  In order to more easily comprehend it, I'm hoping to view it in summation notation.
Paul Burkander
So far I have a circle with a cornu spiral joining where their curvatures are equal as below.
S1:=unapply(u*FresnelS(u)+((1/Pi)*cos((1/2)*Pi*u^2))-(1/Pi),u);
C1:=unapply(u*FresnelC(u)-((1/Pi)*sin((1/2)*Pi*u^2)),u);
R1:=1;
u1:=evalf(sqrt(0.4));
E1:=evalf(Pi*R1*S1(u1)+R1);
D1:=evalf(Pi*R1*C1(u1));
with(plottools);
c1 := circle([D1, E1], R1);
display(c1);
a:=evalf(Pi*R1*u1);
First 2080 2081 2082 2083 2084 2085 2086 Last Page 2082 of 2470
