I want to find a tagent lines to the below contourlines for a function  U := Q[a]^alpha*Q[b]^(1-alpha); given any
value of Q[a] and Q[b]. I know the slope of such a tagent lines but I dont know the intercept. How can I derive such an equation ?
I would like to customize arrows of motion in a phase diagram. The system is the following, with critical point (1,1):
xdot := diff(x(t),t) = x(t)-y(t):
ydot := diff(y(t),t) = y(t)*(1-x(t)):
with phase diagram (the black line is the stable manifold of the system):
What keyboard configuration must have the Win XP to use the keyboard shortcut "Shortcut Keys" and not the key combination "International" to introduce 2-D math expressions. I refer to the help "2-D Math Shortcut Keys and Hints".
The configuration I have enabled is:
Input Device Language: Spanish.
Keyboard layout / IME: United States International.
Gracias
HerClau
when the expression is short, the 'collect' can works,but the expression is longer,it is different.for example: gg1 := collect(expression, z)
Hello:)
Im trying now to make a program that does the same thing as BackwardSubstitutes in maple
I tried 2 things
I tried combining the matrix and the vector in the procedure but its not working
substitutioninverse := proc (matrice, vecteur)
local n, m, j, i, resultat, V, matrice2, a;
matrice2 := [matrice, vecteur];
m, n := Dimension(matrice2);
 V := Vector(m);
for i to m do
 resultat := 0;
for j from n to 1 do
Hello, In Mathematica, one can plot a region where an inequality is true by using the RegionPlot[] function. E.g. if the region (x^2 + y^2
Hi, I am wandering whether are some functions to compute all irreducible polynomial and prmitive polynomial over Galois field. For example, I want to all the irreducible and prmitive polynomials of GF(2^5). are there such commands to perform that? thanks
Hi there I'm in desperate need for your help! I need to solve the rocket motion equation numerically in Maple or some other program. I'm having trouble writing the ODs in the program and setting up all their parameters. I have derived the rocket motion equation in a single dimension: [tex] \frac {d\vec v_r(t)}{dt} = - \, \frac {\dot m_e(t)} {m_r(t)} \, \vec v_e(t) [/tex] I assume that the change of mass is constant and the exhaust velocity is constant. Let's say that the rocket has an initial mass of 1 kg, an empty mass of 0.1 kg and the exhaust velocity 5 m/s.
Im trying to make a program that does the same thing as RowOperation in maple but i dont know what to write to make it return the new matrix matrix
thats what i tried
rowoperation := proc (matrice, i, j, r)
 local m, n, k;
 m, n := Dimension(matrice);
I have only been using maple for the last 3/4 months. Its part of my course in college. We have only covered, what seem to be basic topics but they aren't entirely. We have covered 'for loops, if statements, boolean functions, matrices and procedures'. I am finding some of it difficult as the lecture isn't necessarily capable of teaching it. Here is an example of the kind of revision questions she gave us:
I have a depressed quartic equation with the quadratic term also removed. It has at least one positive real root which is the solution that I am looking for. There are three cases to consider. Two of the cases have trivial solutions. Maple gives its usual RootOf solution for the general case. My worksheet is below.
when input "()" in 2D-Math mode,sometimes I can't edit the context,I can't delete the parentheses,and add something between them.It seems to be locked,
I have strings like "2009-08-01" as tick marks in a plot. I want them to be displayed vertical... how ?
I have a series of experimental data points (current vs voltage in A and B columns respectively) in excel and would like to open these with Maple 13. I would then want to plot the current vs. voltage relationship plot and find out its trendline and function that best describes this curve.
a separate task is that, i have a set of pre-defined functions, and i would like to see which part (section) of the curve obtained from above procedures can give the best fit to the pre-defined function. I appreciate help from members of the forum.
First 2087 2088 2089 2090 2091 2092 2093 Last Page 2089 of 2459
