I'm really struggling with plotting non linear equations onto maple.
I can plot Linear ones with DEtools quite easily, but struggle with Non Linear equations. I've tried PDEtools but not sure if thats relevant.
Trying to plot/display Basin of Attraction;
D(x)(t) = y
D(y)(t) = -ksinx      (can take k = -1)
Any ideas ?
i am supposed to solve this differential equation: y(prime) = 2(1+t)*y^3 where y(o) = 2^(-1/2) this is what ive done so far: > with(PDEtools, declare): with(DEtools): > declare(y(t)=t, prime=t): > diff(y(t),t)= 2(1+t)*(y^(3)); y(0)=2^(-1/2); the problem is that the (1+t) part always drops. what am i doing wrong?
I'm attempting to solve a big set of diff eqs.  I've heard maple has trouble with complex differential equations so I've broken them up into the real and imaginary parts.
The equations are as follows:
 eq1 := diff(RBx(x, t), t) = -x*IBx(x, t)-IUx(x, t)
eq2 := diff(IBx(x, t), t) = x*RBx(x, t)+RUx(x, t)
eq3 := diff(RBy(x, t), t) = -x*IBy(x, t)-IUy(x, t)-3*RBx(x, t)/(2*omega)
eq4 := diff(IBy(x, t), t) = x*RBy(x, t)+RUy(x, t)-3*IBx(x, t)/(2*omega)
A:=[X22(t) = 0, X26(t) = 0, X30(t) = 0, X34(t) = 0, X38(t) = 0, X42(t) = 0, X2(t) = X19(t), X5(t) = X23(t), X8(t) = X27(t), X11(t) = X31(t), X14(t) = X35(t), X17(t) = X39(t), X19(t) = X21(t), X23(t) = X25(t), X27(t) = X29(t), X31(t) = X33(t), X35(t) = X37(t), X39(t) = X41(t), X1(t) = Diff(X3(t), t), X4(t) = Diff(X6(t), t), X7(t) = Diff(X9(t), t),
I've got what turns out to be just a lot of algebraic manipulation - something Maple should rock at. But I can't seem to get things to turn out just right. I have a system of equations in the variable 's'. These are the equations of 3 op-amps, and I'm looking for the transfer function Vo/Vin. V1 and V2 are intermediate voltages at specific nodes, with R1-6 and C1-2, being parameters. V1 = -R2/R1*Vin, V2 = -Vo/(C1*R4*s)-V1/(C1*R3*s), Vo = R6*V2/(R6+R5)+R6*Vin/(1/(C2*s)+R6)
The aim is simple. For some defined procedures, I would like to load them with one single line, and show the 'welcome' message, then be able to use the procedures.
Download 7845_test.zip
View file details
In 'hello' file,
How can I ExportMatrix/ImportMatrix without specific column(s)?
say I want to ExportMatrix(M,filename) without the last column?
casper
I found on the internet a basic definition of mean reversion ( http://mathworld.wolfram.com/ReversiontotheMean.html )
I would assume such definition would also work as an definition of stationarity:
" Reversion to the mean, also called regression to the mean, is the statistical phenomenon stating that the greater the deviation of a random variate from its mean, the greater the probability that the next measured variate will deviate less far. In other words, an extreme event is likely to be followed by a less extreme event."
errors such as
"Error, (in ImportMatrix) file or directory does not exist"
"Error, Matrix index out of range"
can I redefine the error message in a procedure?
say if "Error, (in ImportMatrix) file or directory does not exist" happens,
I want it to printf("You have not got the message yet.")
Generally, what shall I be looking for in the help in Maple?
casper
for what value or interval of p (-infinity < p < infinity) the following is valid
(1+x)^(m+1) > (1+x^m)* 2^m
here x > 1
myproc:=proc(name)
local i;
i:=10;
save i,"i_name";
myproc(bob);
basically, I want to save the value i in the file that has name i_bob in this case.
how should I do that?
and dose it work the same way with Matrix? say I would like to Export a Matrix with name Matrix_bob, (or whatever I input in the myproc proceudre? )
I have a system of five big big big differential equations with a lot of Sin and cos. The system is not complex itself but we have complex  initial condtition?
How can I solve my system with maple with dsolve or something else?
Have attached a worksheet with some questions about getting easy to read answers when solving a trigonometric equation and some other things using the context menu.
Pleas answer in an attached document since my Webb browser of some reason cannot read maple math in the forum.
Yours
Gustav
P.S. I use mapel 12
Edit: removed duplicate content (moderator)
First 2110 2111 2112 2113 2114 2115 2116 Last Page 2112 of 2459
